Banana Pi BPI-M4 4核64位开发板,采用RTD1395芯片设计 ,为banana pi 团队最新的Banana Pi BPI-M4具有与Raspberry Pi Model B 一样的尺寸,但搭载更强悍的Realtek RTD1395 SoC,并支援PoE网路线供电与M.2插槽等功能,使用上更具弹性。
关键特性:
1,Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit
2,Mali 470 MP4 GPU OpenGL ES 1.1/2.0 H.264 H.265,2K4K
3,Onboard1 GB DDR4 (option 2 GB)
4,8G eMMC flash (max 64 GB)
5,10/100 Mbit/s Ethernet and RTL8821 module support Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2
6,USB 2.0 TYPE C
7,M.2 Key E slot PCIE 2.0 and USB 2.0
8,PoE 网络供电功能支持
硬件接口:
硬件规格:
Banana pi BPI-M4 硬件规格列表 | |||
主控芯片 | Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit | ||
GPU图形 | Mali 470 MP4 GPU OpenGL ES 1.1/2.0 | ||
内存 | 1 GB DDR4 (option 2 GB) | ||
Storage | MicroSD slot with support for up to 256GB expansion and 8G eMMC flash with support for up to 64GB | ||
网络 | 10/100 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2 | ||
Video Output(s) | HDMI port and multi-channel audio output support 1080P H.264 H.265 2K/4K | ||
Audio Output(s) | 3.5mm jack and HDMI | ||
PCIE | M.2 Key E slot PCIE 2.0 and USB 2.0 | ||
USB ports | USB 2.0 PORT (x4), USB 2.0 TYPE C(x1) | ||
GPIO | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM | ||
Switches | Reset, Power and U-boot | ||
LED | Power Status and Activity status | ||
Power Source | 5 volt @2A via Micro USB (TYPE C) or PoE support | ||
Size & Weight | 92x60mm, 48g | ||
OS | Android and Linux |
Android
12文章
3943浏览量
127877 -
Linux
87文章
11342浏览量
210324 -
嵌入式开发
18文章
1035浏览量
47692 -
工业控制
38文章
1468浏览量
86014 -
banana pi
1文章
114浏览量
3101
