大联大友尚集团推出基于晶像光电 JX-F32传感器 + 伟诠WT8932 ISP 的1080P 两路行车纪录器方案
大大通 2022-10-26 08:00 次阅读
晶像光电 SOI JX-F32 影像传感器与伟诠WT8932 图像处理器结合,具精简及低能耗特性.可以在相机模块中提供最佳的图像质量性能。支持多重曝光的高动态影像合成.产生高清晰度的影像品质,提升系统端的AI边缘运算能力,因很容易集成到镜头模块或系统板中,故在行车纪录器多路应用上可在原先的架构中扩增摄像头.减少客户开发时间利于系统整合。有助于缩短最终产品的上市时间。
_SOI JX-F32 : 1/2.7" Full HD影像传感器
【 Key Specifications】
_Weltrend WT8932图像处理器
【 Features 】
Embedded 32-bit RISC CPU core
- DSP instruction set
- Up to 180 MHz operation frequency
Memory
- Embedded serial flash 2MB
- Internal 8KB I-cache
- Internal 48KB DLM
Video inputs 视频输入
- MIPI CSI-2 (support virtual channel up to 3) 4 lanes, data rate up to 1Gbps/lane
- HiSPi SLVS/HiVcm 4 lanes(support formats Packetized-SP and Streaming-SP mode), data rate up to 700Mbps/lane
- Max. resolution: 640x480@360fps, 2M@60fps, 2M@30fps(w/ IPU HDR, 2:1 Exp), 3M@30fps, 4M@30fps, 5M@25fps, 8M@15fps(w/ sensor HDR)
- Data formats : 8/10/12/14/16-bit Bayer RAW, YUV 4:2:2 8-bit
- RGB-IR
Video outputs视频输出
- MIPI CSI-2 4 lanes
- Max. resolution: 8M@15fps
- Bayer output follow input format, YUV 4:2:2 8-bit
Image Processing Unit (IPU)
- Automatic Exposure Control(AEC)_自动曝光控制
- Automatic Gain Control(AGC) 自动增益控制
- Auto White Balance(AWB)_自动白平衡控制
- Black Level Compensation_黑电平补偿
- Lens Shading Correction_镜头阴影校正
- Spatial Domain Denoise
- HDR Stitch_支援2 EXP HDR
- WDR Local Tone Mapping
- Edge Enhancement
- Bayer Patten Interpolation (Color Interpolation)
- Color Correction Matrix_颜色校正矩阵
- Gamma
- YUV Processing (for brightness, contrast, saturation, and hue processing)
Communication interfaces 通讯接口
- ISP and ICE interface
- 2 master/slave mode I2C interfaces up to 400 kHz
- 1 full-duplex UART up to 1.5 MHz
- 1 master/slave SPI up to 12 MHz
Timer with 16-bit prescaler
GPIOs with configurable input/output direction and pull-up/pull-down resistor
Window Watchdog Timer (WWDT)
CPU clock source
- External crystal oscillator 24 MHz (built-in PLL)
Power consumption
- Operating: < 0.40W (2M@30fps)
- Standby current: <1mA
- Power supply 3.0V ~ 3.6V
- Core power supply 1.08V ~ 1.32V
- Host I/O power supply 3.0V ~ 3.6V
- Sensor I/O power supply 1.6V ~ 3.6V
Operating temperature range: -40℃ ~ +85℃
Package type: QFN-88L (10x10)
►场景应用图
►产品实体图
►展示板照片
►方案方块图
►核心技术优势
SOI 晶像光电 JX-F32 车用影像传感器,其有三个工作温度版本. JX-F32-C1 : -30 ~ 85℃ JX-F32-A1 : -40 ~ 85℃ JX-F32-A2 : -40 ~ 105℃ 是一适用于车后市场应用且性价比很高的1080P解决方案. 现今车辆设计已朝向更高智能化及大量运用现今电子科技技术的导向。 人类及机器视觉的搭配完成更高行车安全的环境也是车用市场开发的方向。 晶相光电除了提供行车记录仪,环景监视,现在也提供更多技术应用于DMS或是视觉数位化的车用领域应用。 伟诠电子的图像处理器WT8932可以在相机模块中提供最佳的图像质量性能。 优势: _ 用于相机模块集成的组件更少 _ 低功耗、低成本 _ 快速启动时间和高速帧率 _ 丰富的IPU功能和高质量的图像(低噪声和真彩色) _ 嵌入式串行闪存,用于简单的生产校准和相机 ID 信息。 _ 支持系统内编程(ISP)进行系统升级
►方案规格
JX-F32 是一款高性能 2.0MP CMOS 图像传感器,采用 SOI 的 3.0um 像素技术设计和制造。 它可以在全高清模式下以 60fps 的速度提供图像。 JX-F32拥有1936 x 1088 有效像素传感器且带有on-chip 10-bit ADC _可编程增益控制(PGA), _相关双采样correlated double sampling (CDS) 帮助降低fixed pattern noise (FPN)。 此传感器也有许多标准的可编程和自动功能。 同时具有符合行业标准的 DVP 并行端口和 MIPI CSI2 双数据通道串行接口。 WT8932 是一款高性能图像处理器,集成了 32 位 RISC CPU 和 DSP 指令集,运行频率高达 180 MHz,并针对具有 HiSPi/MIPI 接口的图像传感器进行了优化。 此外,WT8932 嵌入了硬件图像处理器单元 (IPU),支持高达 8 兆像素的输入分辨率,为相机应用提供实时和卓越的可视性技术。
  • 影像传感器
  • ISP
    ISP
  • 图像处理器
    联大控股推出基于炬芯ATS2853的蓝牙音箱方案
    近日,国际领先的半导体元器件分销商大联大控股宣布,其旗下子公司推出了基于炬芯科技ATS2853 SoC的蓝牙音箱方案。该
    的头像 发表于 12-18 11:31 810次阅读
    光电传感器与激光传感器的对比
    在现代工业自动化和精密测量领域,传感器技术扮演着至关重要的角色。光电传感器和激光传感器作为种常用的检测技术,它们各自有着独特的优势和应用场景。 工作原理
    的头像 发表于 12-17 17:03 507次阅读
    给DM8168两路视频数据1080P和640x480逐行,在正常运行一段时间后640x480就没数据了,是什么原因导致的?
    在给DM8168两路视频数据1080P和640x480逐行,在正常运行一段时间后640x480就没数据了,1080P还是正常的。 用示波器看了一下640x480的解码芯片TVP5158没有时钟信号输出但是TVP5158的寄存
    发表于 12-16 07:39
    联大集团推出基于onsemi和NXP产品的机器视觉方案
    联大控股宣布,其旗下推出基于安森美(onsemi)AR1335图像传感器和恩智浦(NXP)i.MX 8M Plus处理
    的头像 发表于 11-25 09:46 338次阅读
    大<b class='flag-5'>联大</b><b class='flag-5'>友</b><b class='flag-5'>尚</b><b class='flag-5'>集团</b><b class='flag-5'>推出</b>基于onsemi和NXP产品的机器视觉<b class='flag-5'>方案</b>
    强大视觉方案:i.MX8MP与AR0144的完美结合
    联大集团推出基于NXPi.MX8MP处理和onsemiAR0144图像
    的头像 发表于 10-29 08:04 323次阅读
    强大视觉<b class='flag-5'>方案</b>:i.MX8MP与AR0144的完美结合
    联大集团推出AOV摄像头方案
    联大控股近期宣布,其子公司集团成功推出了一款创新的AOV摄像头方案。该方案融合了联咏科技(
    的头像 发表于 10-28 17:37 760次阅读
    联大基于NuVolta产品的车载无线快充方案
    让车载无线充电更快更安全,大联大集团基于NuVolta NU8060Q无线充电之车载快充应用方案,高集成度、高效率、高精度,单颗芯片支持
    的头像 发表于 10-11 09:55 351次阅读
    大<b class='flag-5'>联大</b><b class='flag-5'>友</b><b class='flag-5'>尚</b>基于NuVolta产品的车载无线快充<b class='flag-5'>方案</b>
    观展邀请 | 大联大邀您共聚 2024慕尼黑华南电子展
    作为全球领先的半导体分销商,大联大将携手世平、品佳、鼎、四大集团,联合 FUDAN MICRO、GreenWaves、Hailo、In
    的头像 发表于 09-30 08:05 443次阅读
    观展邀请 | 大<b class='flag-5'>联大</b>邀您共聚 2024慕尼黑华南电子展
    SENSOR 720P/1080P静电保护方案
    SENSOR 720P/1080P静电保护方案 方案简介 SENSOR 720P/1080P,即
    的头像 发表于 09-27 15:41 383次阅读
    SENSOR 720<b class='flag-5'>P</b>/<b class='flag-5'>1080P</b>静电保护<b class='flag-5'>方案</b>
    联大集团推出基于ST产品的140W USB PD3.1快充方案
    2024年7月18日,致力于亚太地区市场的国际领先半导体元器件分销商---大联大控股宣布,其旗下推出基于意法半导体(ST)ST-ONEHP器件的140W USB PD3.1快充
    的头像 发表于 07-18 22:45 406次阅读
    大<b class='flag-5'>联大</b><b class='flag-5'>友</b><b class='flag-5'>尚</b><b class='flag-5'>集团</b><b class='flag-5'>推出</b>基于ST产品的140W USB PD3.1快充<b class='flag-5'>方案</b>
    联大集团推出基于联咏科技和Hailo产品的后端智能图像分析方案
    处理模块的后端智能图像分析方案。 图示1-大联大鼎基于联咏科技和Hailo产品的后端智能图像分析方案的展示板图 在智能视频分析广泛应用的
    的头像 发表于 07-11 13:53 422次阅读
    大<b class='flag-5'>联大</b><b class='flag-5'>诠</b>鼎<b class='flag-5'>集团</b><b class='flag-5'>推出</b>基于联咏科技和Hailo产品的后端智能图像分析<b class='flag-5'>方案</b>
    联大集团推出基于Innoscience产品的300W电源适配器方案
    2024年6月18日,致力于亚太地区市场的国际领先半导体元器件分销商---大联大控股宣布,其旗下推出基于英诺赛科(Innoscience)InnoGaN INN700D140C
    的头像 发表于 06-18 15:20 421次阅读
    大<b class='flag-5'>联大</b><b class='flag-5'>诠</b>鼎<b class='flag-5'>集团</b><b class='flag-5'>推出</b>基于Innoscience产品的300W电源适配器<b class='flag-5'>方案</b>
    Transphorm携手电子推出款新型系统级封装氮化镓器件
    全球氮化镓功率半导体行业的领军者Transphorm, Inc.和USB PD控制集成电路的佼佼者电子联合宣布,双方已成功推出款新型
    的头像 发表于 05-23 11:20 709次阅读
    Transphorm与电子合作推出新款集成型SiP氮化镓器件
    氮化镓产品系列。 新推出款SiP器件型号分别为WT7162RHUG24B和WT7162RHUG24C,集成了
    的头像 发表于 04-25 10:46 601次阅读
    联大集团推出基于STDES-7KWOBC开发板的7KW车载充电机方案
    2024年4月23日,致力于亚太地区市场的国际领先半导体元器件分销商---大联大控股宣布,其旗下推出基于意法半导体(ST)STDES-7KWOBC开发板的7KW车载充电机
    的头像 发表于 04-25 10:29 736次阅读
    大<b class='flag-5'>联大</b><b class='flag-5'>友</b><b class='flag-5'>尚</b><b class='flag-5'>集团</b><b class='flag-5'>推出</b>基于STDES-7KWOBC开发板的7KW车载充电机<b class='flag-5'>方案</b>
