一、Gradle/Maven配置国内镜像源
配置方式有仅对单个项目生效和对所有项目生效两种方式 对单个项目生效
1.打开Android Studio工程文件,找到build.gradle
2.使用文本编辑器打开,默认格式如下:
buildscript { repositories { google() jcenter() } dependencies { classpath 'com.android.tools.build3.5.1' } } allprojects { repositories { google() jcenter() } } task clean(type: Delete) { delete rootProject.buildDir }3.修改为以下内容:
buildscript { repositories { maven { url 'https://maven.aliyun.com/repository/google' } maven { url 'https://maven.aliyun.com/repository/public' } maven { url 'https://maven.aliyun.com/repository/jcenter' } } dependencies { classpath 'com.android.tools.build3.5.1' } } allprojects { repositories { maven { url 'https://maven.aliyun.com/repository/google' } maven { url 'https://maven.aliyun.com/repository/public' } maven { url 'https://maven.aliyun.com/repository/jcenter' } } } task clean(type: Delete) { delete rootProject.buildDir }对所有项目生效
1.打开系统用户的Gradle配置目录
C:Usersxxx.gradle2.新建文件init.gradle(注意文件后缀名为gradle)
allprojects{ repositories { def ALIYUN_REPOSITORY_URL = 'https://maven.aliyun.com/repository/public' def ALIYUN_JCENTER_URL = 'https://maven.aliyun.com/repository/jcenter' all { ArtifactRepository repo -> if (repo instanceof MavenArtifactRepository){ def url = repo.url.toString() if (url.startsWith('https://repo1.maven.org/maven2')) { project.logger.lifecycle "Repository ${repo.url} replaced by $ALIYUN_REPOSITORY_URL." remove repo } if (url.startsWith('https://jcenter.bintray.com/')) { project.logger.lifecycle "Repository ${repo.url} replaced by $ALIYUN_JCENTER_URL." remove repo } } } maven { url ALIYUN_REPOSITORY_URL url ALIYUN_JCENTER_URL } } }
二、两种配置国内镜像的方法
第一种:直接配置国内镜像源
国内镜像源地址:
1.东软信息学院
mirrors.neusoft.edu.cn 端口:802.北京化工大学
ubuntu.buct.edu.cn/ubuntu.buct.cn 端口:803.中国科学院开源协会
mirrors.opencas.cn (mirrors.opencas.org/mirrors.opencas.ac.cn) 端口:804.上海GDG镜像服务器
sdk.gdgshanghai.com 端口:80005.电子科技大学
mirrors.dormforce.net 端口:80配置步骤:
1.打开File -> setting -> Appearance & Behavior-> System Settings -> HTTP Proxy
2.点击Manual proxy configuration,选中HTTP,在Host name中输入地址,并在Port number中输入端口号
第二种:利用host配置国内镜像源
1.在C盘的C:WindowsSystem32driversetc路径下找到hosts文件,并用记事本打开(或者用notepad++)
2.打开多个地点Ping服务器,网站测速(http://ping.chinaz.com/) - 站长工具该网站对dl.google.com进行ping检测,得到可以用的IP地址,并将其添加到hosts文件末尾
3.配置Android Studio 找到Android Studio安装目录,进入bin文件夹找到studio64.exe.vmoptions,并用记事本打开(或者用notepad++)
4.在studio64.exe.vmoptions末尾添加以下配置:
-Djava.net.preferIPv4Stack=true-Didea.updates.url=http://dl.google.com/android/studio/patches/updates.xml -Didea.patches.url=http://dl.google.com/android/studio/patches/
5.在Android studio中打开File -> setting -> Appearance & Behavior-> System Settings -> HTTP Proxy,选中No proxy即可
审核编辑:汤梓红
举报投诉
Android
12文章
3943浏览量
127841 -
Studio
2文章
190浏览量
28806 -
编辑器
1文章
806浏览量
31279 -
镜像
170浏览量
10791
原文标题:Android Studio配置国内镜像源
文章出处:【微信号:哆啦安全,微信公众号:哆啦安全】欢迎添加关注!文章转载请注明出处。
Android Studio由于下载的SDK Tools版本造成无法更新SDK问题
/mirrors.opencas.ac.cn) 端口:80 4、上海GDG镜像服务器 sdk.gdgshanghai.com 端口:8000 5、电子科技大学 mirrors.dormforce.net 端口:80 其中,强烈推荐电子科技大学的镜像
发表于 09-26 18:12
Linux下配置Android Studio与Eclipse
一. 配置Android Studio 2.01.下载Linux版本的android studio 由于被墙的原因,可以在
发表于 09-27 16:52
教大家如何烧写单独的Android镜像
图所示:在烧写之前需要先导入镜像的配置文件,将烧写工具下面的 android11.cfg 文件导入进去,如下图所示。如果是烧写 Android12
发表于 08-25 17:39
镜像电流源原理及其应用电路
镜像电流源原理及其应用电路:摘要:本文简要介绍了由运算放大器构成的镜像电流源的基本原理,并演化出多种应用电路,可为使用者提供选择和参考。关键词:镜像
发表于 09-25 16:54
•285次下载
模拟电路之精确镜像电流源的设计
由基本镜像电流源可知,三极管的直流增益βF对镜像电流源的输出误差会产生影响,为了减少这一误差,可以借助β增强电路对基本镜像电流
发表于 12-26 15:15
•1.1w次阅读
国内Docker CE 镜像源的配置
阿里云官方镜像站: https://developer.aliyun.com/mirror/?utm_content=g_1000303593 Docker CE 是免费的 Docker 产品
教程分享:Pip安装如何使用国内镜像源
阿里云官方镜像站: https://developer.aliyun.com/mirror/?utm_content=g_1000303593 直接使用国内镜像源 默认情况下 pi
发表于 11-10 14:38
•3627次阅读
怎样使用配置文件修改镜像源
/use-condarc.html#show-channel-urls-show-channel-urls 使用配置文件修改镜像源 使用 conda info 命令查看 .condarc
发表于 12-13 16:01
•1112次阅读
Android Studio引入AI编程助手Studio Bot
谷歌在昨晚的 Google I/O 2023 大会上发布了用于 Android Studio 的 AI 编程助手 Studio Bot—— 支持生成代码和修复错误。Studio Bot
如何在Windows系统上设置Docker镜像源
在使用 Docker 进行镜像下载和构建时,由于众所周知的原因,国内用户可能会遇到下载速度慢或者无法连接的问题。为了解决这个问题,我们可以使用国内的镜像
