利用VF2部署一个网络摄像头
发烧电子爱好者 来源:发烧电子爱好者 作者:发烧电子爱好者 2023-09-11 09:01 次阅读
本来今天想下载编译openWRT,后来发现tf卡空间分配问题,明天再调整吧,看了看桌上的USB摄像头,今天晚上就你出场了。
一开始我是犹豫的,因为RISC-V的生态,不一定能部署的上相关软件,但是JH7110,加上Imagination的GPU,再加上Debian OS,想不出会有什么不兼容的场景,最大风险可能来自CPU,有的话应该都能解决掉,那就上吧。
一、软件环境
(一)操作系统
官方的Debian镜像(starfive-jh7110-202306-SD-minimal-desktop.img),也没用去update了,反正也挺新的。
root@starfive:# uname -a
Linux starfive 5.15.0-starfive #1 SMP Sun Jun 11 07:48:39 UTC 2023 riscv64 GNU/Linux
就是因为文件名上带minimal,可能需要安装的东西会比较多,反正我心里有个数。
(二)安装libjpeg62-turbo-dev
root@starfive:# apt install libjpeg62-turbo-dev
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  libc-dev-bin libc-devtools libc6-dev libcrypt-dev libnsl-dev libtirpc-dev
  linux-libc-dev manpages manpages-dev rpcsvc-proto
Suggested packages:
  glibc-doc
The following NEW packages will be installed:
  libc-dev-bin libc-devtools libc6-dev libcrypt-dev libjpeg62-turbo-dev
  libnsl-dev libtirpc-dev linux-libc-dev manpages manpages-dev rpcsvc-proto
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 8933 kB of archives.
After this operation, 44.8 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(三)安装imagemagick
root@starfive:#  apt install imagemagick
  imagemagick-6.q16 libnetpbm11 netpbm
Suggested packages:
  imagemagick-doc autotrace cups-bsd | lpr | lprng curl enscript ffmpeg gimp
  gnuplot grads graphviz hp2xx html2ps libwmf-bin mplayer povray radiance
  texlive-base-bin transfig ufraw-batch xdg-utils
  imagemagick imagemagick-6.q16 libnetpbm11 netpbm
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
After this operation, 7693 kB of additional disk space will be used.
(四)安装libv4l-dev
root@starfive:# apt install libv4l-dev
  libv4l2rds0
Suggested packages:
  pkg-config
  libv4l-dev libv4l2rds0
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 291 kB of archives.
After this operation, 1948 kB of additional disk space will be used.
Get:1 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 libv4l2rds0 riscv64 1.22.1-5+b1 [80.4 kB]
Get:2 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 libv4l-dev riscv64 1.22.1-5+b1 [211 kB]
Fetched 291 kB in 5s (61.7 kB/s)
(五)安装编译工具
发现gcc、git、cmake啥都没用,果然够minimal,逐一apt install。
root@starfive: # apt install gcc
  gcc-12 libasan8 libcc1-0 libgcc-12-dev
Suggested packages:
  gcc-multilib make autoconf automake libtool flex bison gdb gcc-doc
  gcc-12-doc gcc-12-locales
  gcc gcc-12 libasan8 libcc1-0 libgcc-12-dev
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.6 MB of archives.
After this operation, 70.0 MB of additional disk space will be used.
Get:1 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 libcc1-0 riscv64 12.2.0-10 [38.4 kB]
Get:2 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 libasan8 riscv64 12.2.0-10 [2067 kB]
Get:3 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 libgcc-12-dev riscv64 12.2.0-10 [1951 kB]
Get:4 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 gcc-12 riscv64 12.2.0-10 [14.6 MB]
Get:5 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 gcc riscv64 4:12.2.0-1 [5200 B]
Fetched 18.6 MB in 3min 55s (79.5 kB/s)
安装完成后检查下:
root@starfive:# gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/riscv64-linux-gnu/12/lto-wrapper
Target: riscv64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 12.2.0-10' --with-bugurl=file:///usr/share/doc/gcc-12/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-12 --program-prefix=riscv64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --disable-multilib --with-arch=rv64gc --with-abi=lp64d --enable-checking=release --build=riscv64-linux-gnu --host=riscv64-linux-gnu --target=riscv64-linux-gnu
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 12.2.0 (Debian 12.2.0-10)
二、源码下载、编译和安装
(一)源码下载
JH7110处理能力毋庸置疑,直接板子上编译和安装,源代码直接从github上拉取。
git clone https://github.com/jacksonliam/mjpg-streamer.git
Cloning into 'mjpg-streamer'...
remote: Enumerating objects: 2964, done.
remote: Total 2964 (delta 0), reused 0 (delta 0), pack-reused 2964
Receiving objects: 100% (2964/2964), 3.48 MiB | 4.33 MiB/s, done.
Resolving deltas: 100% (1885/1885), done.
(二)源码编译和安装
进入/mjpg-streamer/mjpg-streamer-experimental 文件夹,执行 make all。
检查下生成的文件,
再安装。
三、服务启动
(一)前期工作
首先确保网络正常连接。
之后插入USB camera,OS提示已经识别:
root@starfive: # [ 3976.150090] usb 1-1.3: new high-speed USB device number 3 using xhci_hcd
[ 3976.295340] usb 1-1.3: Found UVC 1.00 device HIK 720P Camera (2bdf:0280)
[ 3976.306997] input: HIK 720P Camera: HIK 720P Camer as /devices/platform/soc/2b000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1        .3/1-1.3:1.0/input/input0
通过对比video大法判断设备名,找出是/dev/video4:
root@starfive: # ls -l /dev/video*
crw-rw----+ 1 root video 81, 0 Dec 22  2022 /dev/video0
crw-rw----+ 1 root video 81, 1 Dec 22  2022 /dev/video1
crw-rw----+ 1 root video 81, 2 Dec 22  2022 /dev/video2
crw-rw----+ 1 root video 81, 3 Dec 22  2022 /dev/video3
crw-rw----+ 1 root video 81, 6 Aug 21 14:42 /dev/video4
crw-rw----+ 1 root video 81, 7 Aug 21 14:42 /dev/video5
crw-rw----+ 1 root video 81, 4 Dec 22  2022 /dev/video6
crw-rw----+ 1 root video 81, 5 Dec 22  2022 /dev/video7
(二)启动USB摄像头
直接输入 mjpg_streamer 即可启动服务,默认的是video0,VF2开发板的USB摄像头是video4。在启动服务命令中通过“-d /dev/video4” 选项来指定。
y是表示YUV格式。如果没有-y,默认启动是mjpeg格式
-d指定设备
-f 制订帧数,默认30帧
-r指定视频大小,如320×240
-q指定画质,默认80对于输出参数
-p 指定端口,一般是8080
-w 指定网页目录,设置的是/www目录
-c设置通过密码访问
./mjpg_streamer -i "./input_uvc.so -d /dev/video4 -f 30 -q 90 -n" -o "./output_http.so -w ./www"
启动后的日志如下:
四、网络摄像头测试
(一)在线视频查看
打开浏览器,访问URL为:[VF2开发板 IP]:8080 ,得到的内容如下:
(二)取一张图
取一张图的URL为`IP:8080?action=snapshot,直接给自己照相:
五、一些体会
全程下来无错误,整个软件安装非常顺利,本以为会出现的各种小问题一个都没。
JH7110 CPU功能强大,之前在H616上也编译过mjpg-streamer,耗时跟VF2完全不同,在VF2上简直飞一般编译安装。
GPU(Imagination BXE-4-32 GPU)还没有测试,按理来说Imagination的应该兼容性和性能不会有什么大问题,下次有时间可以测试下。
审核编辑:汤梓红
  • gpu
    gpu
  • 操作系统
  • OpenWrt
  • 网络摄像头
  • RISC-V
    基于RK3588的AI摄像头应用解决方案
    记录到主动预警的转变。目前有三种算力部署方式:AI分析部署在云端、AI分析部署在边缘、AI分析部署摄像头,也就是我们常说的云,边,端。但越
    的头像 发表于 01-16 17:19 117次阅读
    基于RK3588的AI<b class='flag-5'>摄像头</b>应用解决方案
    车载摄像头的EMC问题案例
    前言 如今,车载摄像头已经不再仅仅是辅助设备,而是逐渐成为了智能驾驶系统中不可或缺的一部分。360度全景监控、行车记录仪以及自动驾驶辅
    的头像 发表于 12-18 11:11 686次阅读
    车载<b class='flag-5'>摄像头</b>的EMC问题案例
    车载摄像头的EMC案例分享
    如今,车载摄像头已经不再仅仅是辅助设备,而是逐渐成为了智能驾驶系统中不可或缺的一部分。360度全景监控、行车记录仪以及自动驾驶辅助功能,车载摄像
    的头像 发表于 12-18 11:07 761次阅读
    车载<b class='flag-5'>摄像头</b>的EMC案例分享
    安防监控摄像头气密性测试案例-连拓精密#摄像头气密检测设备
    摄像头
    连拓精密科技
    发布于 :2024年12月11日 15:00:21
    摄像头及红外成像的基本工作原理
    本文介绍了摄像头及红外成像的基本工作原理,摄像头可以将看到的图像真实的呈现出来,所见即所得! 摄像头如何工作? 摄像头可以将看到的图像真实的呈现出来,所见即所得。   比如人眼看到的
    的头像 发表于 11-25 09:28 736次阅读
    <b class='flag-5'>摄像头</b>及红外成像的基本工作原理
    用于环视和CMS摄像头系统的四通道摄像头应用程序
    电子发烧友网站提供《用于环视和CMS摄像头系统的四通道摄像头应用程序.pdf》资料免费下载
    发表于 10-11 10:02 0次下载
    用于环视和CMS<b class='flag-5'>摄像头</b>系统的四通道<b class='flag-5'>摄像头</b>应用程序
    带阻网络电路输入与输出电阻都是600欧姆,VF1与VF2他们的波形为什么是样的?
    如下图所示带阻网络电路输入与输出电阻都是600欧姆,前面加了跟随器,我测了VF1与VF2他们的波形为什么是
    发表于 09-19 06:11
    请问正向输入VF3与反向输入VF2的波形为什么不相同呢?虚短怎么就不成立了呢?
    发表于 08-16 12:07
    摄像头时钟辐射超标问题整改案例
    本次整改的样机是双目摄像头,根据客户的反馈,存在时钟单支辐射超标问题。
    的头像 发表于 07-16 14:43 1120次阅读
    <b class='flag-5'>摄像头</b>时钟辐射超标问题整改案例
    基于FPGA的摄像头心率检测装置设计
    ,该系统便可自动识别被测者并计算出心率者显示在屏幕 上。 (3)使用消费级网络摄像头做到精准的心率捕捉。 (4)用同一个 roi 区域的不同颜色通道来分离心率信号和运动噪声。 4.2 可扩展之处 (1
    发表于 07-01 17:58
    智能摄像头抄表器是什么?
    1.概念理解:智能摄像头抄表器智能摄像头抄表器是种融合了人工智能和物联网技术的创新设备,主要用于自动读取和记录各种计量仪表的数据,如水表、电表、燃气表等。它通过高清摄像头捕捉图像,然
    的头像 发表于 04-24 14:14 714次阅读
    智能<b class='flag-5'>摄像头</b>抄表器是什么?
    Win11 24H2:更强大的人工智能助手,丰富的锁屏小组件和网络摄像头
    手机化身网络摄像头:Win11将支持利用安卓智能手机充当无线网络摄像头。搭配优异质素的拍摄镜头,该功能有可能超越市场上大部分高价
    的头像 发表于 04-17 14:21 903次阅读
    高清网络摄像头多媒体智能屏
    迪文全新推出的28系列智能屏,是面向屏幕实时显示高清网络摄像头视频画面应用的产品。该系列智能屏可通过以太网或WiFi连接摄像头,可接收H.264编码RTSP协议的摄像头视频,支持4路
    的头像 发表于 02-19 13:21 637次阅读
    高清<b class='flag-5'>网络</b><b class='flag-5'>摄像头</b>多媒体智能屏
    摄像头凸透镜成像原理 摄像的原理是小孔成像吗
    原理。摄像头通过透镜将光线聚焦到图像传感器上。这个过程是利用透镜的折射原理完成的。光线从空气中通过透镜进入摄像头内部,透镜会使光线发生折射,使得光线汇聚到
    的头像 发表于 02-01 15:01 2093次阅读
