XMLRPC服务器如何启动
麦辣鸡腿堡 来源:古月居 作者:古月居 2023-09-14 17:56 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
roscore调用了roslaunch.main,我们继续追踪,进到ros_comm-noetic-develtoolsroslaunchsrcroslaunch文件夹中,发现有个__init__.py文件,说明这个文件夹是一个python包,打开__init__.py文件找到def main(argv=sys.argv),这就是roscore调用的函数roslaunch.main的实现,如下(这里只保留主要的代码,不太重要的删掉了)。
def main(argv=sys.argv):
    options = None
    logger = None
    try:
        from . import rlutil
        parser = _get_optparse()
        (options, args) = parser.parse_args(argv[1:])
        args = rlutil.resolve_launch_arguments(args)
        write_pid_file(options.pid_fn, options.core, options.port)
        uuid = rlutil.get_or_generate_uuid(options.run_id, options.wait_for_master)
        configure_logging(uuid)
        # #3088: don't check disk usage on remote machines
        if not options.child_name and not options.skip_log_check:
            rlutil.check_log_disk_usage()
        logger = logging.getLogger('roslaunch')
        logger.info("roslaunch starting with args %s"%str(argv))
        logger.info("roslaunch env is %s"%os.environ)
        if options.child_name:
           # 这里没执行到,就不列出来了
        else:
            logger.info('starting in server mode')
            # #1491 change terminal name
            if not options.disable_title:
                rlutil.change_terminal_name(args, options.core)
            # Read roslaunch string from stdin when - is passed as launch filename.
            roslaunch_strs = []
            # This is a roslaunch parent, spin up parent server and launch processes.
            # args are the roslaunch files to load
            from . import parent as roslaunch_parent
            # force a port binding spec if we are running a core
            if options.core:
                options.port = options.port or DEFAULT_MASTER_PORT
            p = roslaunch_parent.ROSLaunchParent(uuid, args, roslaunch_strs=roslaunch_strs, is_core=options.core, port=options.port, local_only=options.local_only, verbose=options.verbose,  force_screen=options.force_screen, force_log=options.force_log, num_workers=options.num_workers, timeout=options.timeout, master_logger_level=options.master_logger_level, show_summary=not options.no_summary, force_required=options.force_required, sigint_timeout=options.sigint_timeout, sigterm_timeout=options.sigterm_timeout)
            p.start()
            p.spin()
roslaunch.main开启了日志,日志记录的信息可以帮我们了解main函数执行的顺序。
我们去Ubuntu的.ros/log/路径下,打开roslaunch-ubuntu-52246.log日志文件,内容如下。
通过阅读日志我们发现,main函数首先检查日志文件夹磁盘占用情况,如果有剩余空间就继续往下运行。
然后把运行roscore的终端的标题给改了。
再调用ROSLaunchParent类中的函数,这大概就是main函数中最重要的地方了。
ROSLaunchParent类的定义是在同一路径下的parent.py文件中。为什么叫LaunchParent笔者也不清楚。
先不管它,我们再看日志,发现运行到了下面这个函数,它打算启动XMLRPC服务器端。
所以调用的顺序是:roslaunch_ init _.py文件中的main()函数调用parent.pystart()函数,start()函数调用自己类中的_start_infrastructure()函数,_start_infrastructure()函数调用自己类中的_start_server()函数,_start_server()函数再调用server.py中的start函数。
def _start_server(self):
        self.logger.info("starting parent XML-RPC server")
        self.server = roslaunch.server.ROSLaunchParentNode(self.config, self.pm)
        self.server.start()
我们再进到server.py文件中,找到ROSLaunchNode类,里面的start函数又调用了父类XmlRpcNode中的start函数。
class ROSLaunchNode(xmlrpc.XmlRpcNode):
    Base XML-RPC server for roslaunch parent/child processes
    def start(self):
        logger.info("starting roslaunch XML-RPC server")
        super(ROSLaunchNode, self).start()
我们来到ros_comm-noetic-develtoolsrosgraphsrcrosgraph路径,找到xmlrpc.py文件。找到class XmlRpcNode(object)类,再进入start(self)函数,发现它调用了自己类的run函数,run函数又调用了自己类中的_run函数,_run函数又调用了自己类中的_run_init()函数,在这里才调用了真正起作用的ThreadingXMLRPCServer类。
因为master节点是用python实现的,所以,需要有python版的XMLRPC库。
幸运的是,python有现成的XMLRPC库,叫SimpleXMLRPCServer。SimpleXMLRPCServer已经内置到python中了,无需安装。
所以,ThreadingXMLRPCServer类直接继承了SimpleXMLRPCServer,如下。
class ThreadingXMLRPCServer(socketserver.ThreadingMixIn, SimpleXMLRPCServer)
  • 函数
  • MASTER
  • ROS
    ROS
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    什么是服务器虚拟化?私人云服务器
    什么是 服务器虚拟化 ? 服务器虚拟化是一种将物理服务器转化为虚拟服务器的过程,使得多个虚拟服务器可以在同一台物理
    的头像 发表于 08-08 10:44 2442次阅读
    labview Web服务器如何启动
    labview利用web服务器发布网页时,想在浏览中预览时无法启动web服务器
    发表于 04-12 07:59
    许可证服务器无法启动
    :flexnetls-nvidia.service-LSB:启动和停止FlexNet许可证服务器 已加载:已加载(/etc/init.d/flexnetls-nvidia;错误;供应商预设:已启用) 活动:失败(结果:退出
    发表于 09-18 16:15
    Linux下的形式启动和关闭服务器思路介绍
    最近用maven工程的形式打jar包写一个小型服务器,于是希望提供脚本的形式启动和关闭服务器
    发表于 07-12 06:09
    启动时的Web服务器问题
    背景:MPLAB X IDE v3.65,XC32 v1.44,PIC32MZ2048EFH100,Harmony v2.03b,LAN8720一切都与HTTP服务器配合得很好,但是在它工作之前,我
    发表于 03-09 09:01
    Tomcat服务器简介
    简介简介Tomcat服务器是一个开放源码的轻量级Web应用服务器,非常适合搭建微服务应用。Embedded Tomcat嵌入式Tomcat服务器则无需部署外置tomcat,开发者只需引
    发表于 12-16 08:24
    如何解决“无法启动GDB服务器”的问题?
    我正在尝试使用 CUBEIDE 对 STM32F103C8T6 进行编程。在解决了这么多错误之后,我现在遇到了这个错误“无法启动 GDB 服务器”,尝试了不同的端口号,并将调试概率从“OPEN OCD”更改为“GDB SERVER”,但无济于事。
    发表于 12-02 06:25
    用AT+CIPSERVER=1,80启动服务器时,可以启动UDP服务器吗?
    大家好, 我刚收到新的 esp 板,我发现有了新固件,我无法使用 AT 命令 AT+GMR 启动 UDP 服务器,给我的是: 代码:全选AT version:0.21.0.0 SDK version
    发表于 05-15 07:27
    存储服务器怎么配置_存储服务器的作用
    安装目录默认为:IVM S-4200 NiVM S-4200 Storage ) , 打开存储服务器。在电脑右下角任务栏中显示,表示服务器启动成功。
    发表于 05-06 15:18 6310次阅读
    如何重新启动Linux服务器
    使用个人电脑工作的时候,可能会因为各种原因而关闭机器。对于 Linux 初学者来说,与电源相关(关机、重启等)的任务总是最后才想到如何去实现的,所以有可能对于如何重新启动远程服务器不太了解。今天我们介绍一些可以用来通过终端来重新启动
    的头像 发表于 05-14 16:03 3316次阅读
    ROS是如何实现XMLRPC
    XMLRPC的C++代码在下载后的ros_comm-noetic-develutilitiesxmlrpcpp路径下。 还好,整个工程不算太大。XMLRPC分成客户端和服务器端两大部分。 咱们先看
    的头像 发表于 09-14 17:45 1495次阅读
    节点是如何调用XMLRPC
    。 而节点与master对话使用的就是XMLRPC。 从这一点来看,master叫节点管理确实名副其实,它是一个大管家,给刚出生的节点提供服务。 下面我们以两个节点:talker和listener为例,介绍其通过
    的头像 发表于 09-14 17:52 1549次阅读
    节点是如何调用<b class='flag-5'>XMLRPC</b>的
    服务器数据恢复—非正常关机导致服务器文件丢失的数据恢复案例
    ;分析: 服务器在运行过程中自动关机且无法启动服务器管理员对服务器进行修复后成功启动服务器
    的头像 发表于 01-19 13:42 1451次阅读
    服务器数据恢复—意外断电!Linux服务器数据恢复大揭秘
    某品牌服务器+存储,安装的linux操作系统。 机房意外断电导致服务器操作系统无法正常启动服务器管理员故障服务器进行修复操作后进入系统查
    的头像 发表于 11-18 11:20 804次阅读
    服务器数据恢复—供电不稳引发服务器EXT4分区挂载失败的数据恢复案例
    服务器在运行过程中突然关机且无法启动服务器管理员对故障服务器进行修复后,虽然服务器可以正常启动
    的头像 发表于 01-04 17:10 482次阅读
