流程分析
kobject/kset
的相关代码比较简单,毕竟它只是作为一个结构体嵌入其他high-level的结构中,充当纽带的作用。不过,我还是简单的上一张图吧:
- 完成的工作基本就是分配结构体,初始化各个结构体字段,构建拓扑关系(主要是添加到kset的list中,parent的指向等)等,看懂了结构体的组织,这部分的代码理解起来就很轻松了;
示例
先上一个原理图:
代码
#include < linux/kernel.h >
#include < linux/module.h >
#include < linux/slab.h >
#include < linux/kobject.h >
//自定义一个结构,包含了struct kobject子结构
struct test_kobj {
int value;
struct kobject kobj;
//自定义个属性结构体,包含了struct attribute结构
struct test_kobj_attribute {
struct attribute attr;
ssize_t (*show)(struct test_kobj *obj, struct test_kobj_attribute *attr, char *buf);
ssize_t (*store)(struct test_kobj *obj, struct test_kobj_attribute *attr, const char *buf, size_t count);
//声明一个全局结构用于测试
struct test_kobj *obj;
//用于初始化sysfs_ops中的函数指针
static ssize_t test_kobj_attr_show(struct kobject *kobj, struct attribute *attr, char *buf)
struct test_kobj_attribute *test_kobj_attr;
ssize_t ret = -EIO;
test_kobj_attr = container_of(attr, struct test_kobj_attribute, attr);
//回调到具体的实现函数
if (test_kobj_attr- >show)
ret = test_kobj_attr- >show(container_of(kobj, struct test_kobj, kobj), test_kobj_attr, buf);
return ret;
static ssize_t test_kobj_attr_store(struct kobject *kobj, struct attribute *attr, const char *buf, size_t count)
ssize_t ret = -EIO;
//回调到具体的实现函数
if (test_kobj_attr- >store)
ret = test_kobj_attr- >store(container_of(kobj, struct test_kobj, kobj), test_kobj_attr, buf, count);
return ret;
//用于初始化kobj_ktype
const struct sysfs_ops test_kobj_sysfs_ops = {
.show = test_kobj_attr_show,
.store = test_kobj_attr_store,
//用于初始化kobj_ktype,最终用于释放kobject
void obj_release(struct kobject *kobj)
struct test_kobj *obj = container_of(kobj, struct test_kobj, kobj);
printk(KERN_INFO "test kobject release %sn", kobject_name(&obj- >kobj));
kfree(obj);
//定义kobj_ktype,用于指定kobject的类型,初始化的时候使用
static struct kobj_type test_kobj_ktype = {
.release = obj_release,
.sysfs_ops = &test_kobj_sysfs_ops,
//show函数的具体实现
ssize_t name_show(struct test_kobj *obj, struct test_kobj_attribute *attr, char *buffer)
return sprintf(buffer, "%sn", kobject_name(&obj- >kobj));
//show函数的具体实现
ssize_t value_show(struct test_kobj *obj, struct test_kobj_attribute *attr, char *buffer)
return sprintf(buffer, "%dn", obj- >value);
//store函数的具体实现
ssize_t value_store(struct test_kobj *obj, struct test_kobj_attribute *attr, const char *buffer, size_t size)
sscanf(buffer, "%d", &obj- >value);
return size;
//定义属性,最终注册进sysfs系统
struct test_kobj_attribute name_attribute = __ATTR(name, 0664, name_show, NULL);
struct test_kobj_attribute value_attribute = __ATTR(value, 0664, value_show, value_store);
struct attribute *test_kobj_attrs[] = {
&name_attribute.attr,
&value_attribute.attr,
NULL,
//定义组
struct attribute_group test_kobj_group = {
.name = "test_kobj_group",
.attrs = test_kobj_attrs,
//模块初始化函数
static int __init test_kobj_init(void)
int retval;
printk(KERN_INFO "test_kobj_initn");
obj = kmalloc(sizeof(struct test_kobj), GFP_KERNEL);
if (!obj) {
return -ENOMEM;
obj- >value = 1;
memset(&obj- >kobj, 0, sizeof(struct kobject));
//添加进sysfs系统
kobject_init_and_add(&obj- >kobj, &test_kobj_ktype, NULL, "test_kobj");
//在sys文件夹下创建文件
retval = sysfs_create_files(&obj- >kobj, (const struct attribute **)test_kobj_attrs);
if (retval) {
kobject_put(&obj- >kobj);
return retval;
//在sys文件夹下创建group
retval = sysfs_create_group(&obj- >kobj, &test_kobj_group);
if (retval) {
return retval;
return 0;
//模块清理函数
static void __exit test_kobj_exit(void)
printk(KERN_INFO "test_kobj_exitn");
kobject_del(&obj- >kobj);
return;
module_init(test_kobj_init);
module_exit(test_kobj_exit);
MODULE_AUTHOR("LoyenWang");
MODULE_LICENSE("GPL");
Makefile
ifneq ($(KERNELRELEASE),)
obj-m:=test_kobject.o
else
KERDIR := /lib/modules/$(shell uname -r)/build
PWD:=$(shell pwd)
all:
make -C $(KERDIR) M=$(PWD) modules
clean:
rm -f *.ko *.o *.symvers *.cmd *.cmd.o modules.* *.mod.c
endif
Makefile
没有太多好说的,注意Tab
的使用,否则容易出错;
测试结果
- 在/sys目录下创建了test_kobj文件夹,在该文件夹下除了
name
和value
外,还有一个test_kobj_group
的子文件夹; - 可以通过
cat/echo
的操作,来操作name
和value
,分别会调用到底层的xxx_show
和xxx_store
函数; - 对着代码看这个图,一目了然;
举报投诉
嵌入式
5082文章
19126浏览量
305201 -
Linux
87文章
11304浏览量
209502 -
设备
2文章
4509浏览量
70638 -
模型
1文章
3243浏览量
48840 -
结构体
1文章
130浏览量
10842
详解linux设备驱动模型架构
LDD3中说:“Linux内核需要一个对系统结构的一般性描述。”这个描述就是linux设备驱动模型(下面简称为LDDM)。LDDM不是独立存在,其体系如下图所示:
发表于 07-25 07:25
Linux设备模型之一:Kobject
Kobject是Linux设备模型的基础,也是设备模型中最难理解的一部分(可参考Documentation/kobject.txt的表述)。
发表于 05-06 15:51
•3361次阅读
Linux设备模型学习笔记(1)
Linux设备模型学习笔记1KobjectKobject, Kset和KtypeUeventsysfs文件系统wowo这里写的很好了:http://www.wowotech.net
发表于 12-22 18:52
•0次下载
