在我们平时的开发过程中,常常会遇到引入各种不同的 jar 包,然后引发的 Maven
依赖冲突,今天我们来学习下如何使用 Maven 命令检测 pom.xml
中的重复依赖项。
为什么要检测重复的依赖关系
在pom.xml
中, 经常引入各种不同的jar 包, 又会依赖其他的jar。特别是一些常用的工具库,比较容易出现版本冲突,例如,让我们看下这个pom.xml
< project >
< dependencies >
< dependency >
< groupId >org.apache.commons< /groupId >
< artifactId >commons-lang3< /artifactId >
< version >3.12.0< /version >
< /dependency >
< dependency >
< version >3.11< /version >
< /dependency >
< /dependencies >
< /project >
从上面的代码中,commons-lang3
被引用了两次,而且版本号也不一样。现在我们就来看看如何使用Maven命令来检测这些重复的依赖关系。
依赖树命令
让我们在终端运行 mvn dependency:tree
的命令,看看输出结果
$ mvn dependency:tree
[INFO] Scanning for projects...
[WARNING]
[WARNING] Some problems were encountered while building the effective model for com.javanorth:maven-duplicate-dependencies:jar:0
.0.1-SNAPSHOT
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.apache.commons:commons-lang3:jar -
> version 3.12.0 vs 3.11 @ line 14, column 15
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO]
[INFO] -------------< com.javanorth:maven-duplicate-dependencies >--------------
[INFO] Building maven-duplicate-dependencies 0.0.1-SNAPSHOT
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-dependency-plugin:2.8:tree (default-cli) @ maven-duplicate-dependencies ---
[WARNING] The artifact xml-apis:xml-apis:jar:2.0.2 has been relocated to xml-apis:xml-apis:jar:1.0.b2
[INFO] com.javanorth:maven-duplicate-dependencies:jar:0.0.1-SNAPSHOT
[INFO] - org.apache.commons:commons-lang3:jar:3.11:compile
[INFO] ------------------------------------------------------------------------
[INFO] BUILD SUCCESS
[INFO] Total time: 1.136 s
我们可以看到,commons-lang3
jar的3.11版和 3.12 版同时被引入进来了,出现这种情况是因为Maven选择了pom.xml
中后来出现的依赖。
依赖关系analyze-duplicate
命令
现在让我们运行 mvn dependency:analyze-duplicate
,看看输出输出结果。
$ mvn dependency:analyze-duplicate
[WARNING]
.0.1-SNAPSHOT
[WARNING]
[WARNING]
[WARNING]
[INFO]
[INFO]
[INFO] --- maven-dependency-plugin:2.8:analyze-duplicate (default-cli) @ maven-duplicate-dependencies ---
[INFO] List of duplicate dependencies defined in < dependencies/ > in your pom.xml:
o org.apache.commons:commons-lang3:jar
[INFO] Total time: 0.835 s
我们注意到,WARNING
和INFO
日志语句都提到了重复依赖的存在。
如果存在重复的依赖,则构建失败
在上面的例子中,我们看到了如何检测重复的依赖关系,但BUILD
仍然是成功的,但这可能导致使用了不正确的 jar 版本。
使用[Maven Enforcer Plugin](https://maven.apache.org/enforcer/maven-enforcer-plugin/index.html),我们可以确保在存在重复依赖的情况下构建不成功。
我们需要在pom.xml
中加入这个Maven插件,并加入banDuplicatePomDependencyVersions
规则。
< project >
< build >
< plugins >
< plugin >
< groupId >org.apache.maven.plugins< /groupId >
< artifactId >maven-enforcer-plugin< /artifactId >
< version >3.0.0< /version >
< executions >
< execution >
< id >no-duplicate-declared-dependencies< /id >
< goals >
< goal >enforce< /goal >
< /goals >
< configuration >
< rules >
< banDuplicatePomDependencyVersions/ >
< /rules >
< /configuration >
< /execution >
< /executions >
< /plugin >
< /plugins >
< /build >
< /project >
现在,该规则约束了我们的Maven构建。
$ mvn verify
[WARNING]
.0.1-SNAPSHOT
> version 3.12.0 vs 3.11 @ line 14, column 14
[WARNING]
[INFO]
[INFO] --- maven-enforcer-plugin:3.0.0:enforce (no-duplicate-declared-dependencies) @ maven-duplicate-dependencies ---
[WARNING] Rule 0: org.apache.maven.plugins.enforcer.BanDuplicatePomDependencyVersions failed with message:
Found 1 duplicate dependency declaration in this project:
- dependencies.dependency[org.apache.commons:commons-lang3:jar] ( 2 times )
[INFO] BUILD FAILURE
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-enforcer-plugin:3.0.0:enforce (no-duplicate-declared-dependencies) on project maven-duplicate-dependencie
s: Some Enforcer rules have failed. Look above for specific messages explaining why the rule failed.
删除重复的依赖关系
只要确定了重复的依赖关系,我们就需要在 pom.xml
中删除它们,只保留那些我们项目使用的唯一依赖关系。
总结
本文中,我们学习了如何使用mvn dependency:tree
和mvn dependency:analyze-duplicate
命令检测Maven中的重复依赖,还学习了如何使用Maven Enforcer插件,通过应用内置规则使包含重复依赖的构建失败。
开发
370浏览量
40902 -
日志
138浏览量
10670 -
maven
30浏览量
3732
