【XR806开发板试用】使用编码器进行调光
冬至配饺子 来源:阿珣 作者:阿珣 2023-10-08 11:08 次阅读
之前做过一个LED调光的项目,这次想拿XR806来实现,后续打算加入远程控制的功能。这个项目使用旋转编码器来调节LED的亮度,基本原理是MCU识别编码器的旋转方向和步数,调节PWM输出占空比,从而实现亮度调节。
识别其旋转方向和步数,要考虑消除抖动,否则会出现识别错误,导致系统不稳定,这和按键是类似的。
Github上有对应的Arduino库,注意它的开源协议是GNU GPL V3!本人曾经移植到STM32,现已移植到XR806,效果良好。旋转编码器相关代码如下:
头文件re.h源码:
 * Rotary encoder library for Arduino.
 * Port to XR806 by Zixun Chen.
#ifndef _ROTARY_ENCODER_H_
#define _ROTARY_ENCODER_H_
#ifdef __cplusplus
extern "C" {
#endif
#include "main.h"
// 根据编码器的输出类型来选择是否定义RE_HALF_STEP
#define RE_HALF_STEP
// 旋转编码器通常外接上拉电阻,对应空闲电平是00B。如果外接电阻是下拉的,需要定义RE_PINS_PULL_DOWN
// #define RE_PINS_PULL_DOWN
#define DIR_NONE 0    // 尚无完整有效的步进
#define DIR_CW   0x10 // 顺时针步进
#define DIR_CCW  0x20 // 逆时针步进
typedef struct {
    // 定义编码器A端所连的GPIO引脚
    GPIO_Port GPIO_A;
    GPIO_Pin PIN_A;
    // 定义编码器B端所连的GPIO引脚
    GPIO_Port GPIO_B;
    GPIO_Pin PIN_B;
    uint8_t RetVal; // 保存返回值
    uint8_t State; // 内部变量,保存状态机状态
} REHandle_t;
void RotaryEncoderInit(REHandle_t *REVal); // 初始化
void RotaryEncoderProcess(REHandle_t *REVal); // 读取步进
#ifdef __cplusplus
#endif
#endif // _ROTARY_ENCODER_H_
源文件re.c:
/* Rotary encoder handler for arduino.
 * Copyright 2011 Ben Buxton. Licenced under the GNU GPL Version 3.
 * Contact: bb@cactii.net
#include "re.h"
 * The below state table has, for each state (row), the new state
 * to set based on the next encoder output. From left to right in,
 * the table, the encoder outputs are 00, 01, 10, 11, and the value
 * in that position is the new state to set.
#define R_START 0x0
#ifdef RE_HALF_STEP
// Use the half-step state table (emits a code at 00 and 11)
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
    // R_START (00)
    {R_START_M,           R_CW_BEGIN,    R_CCW_BEGIN,  R_START},
    // R_CCW_BEGIN
    {R_START_M | DIR_CCW, R_START,       R_CCW_BEGIN,  R_START},
    // R_CW_BEGIN
    {R_START_M | DIR_CW,  R_CW_BEGIN,    R_START,      R_START},
    // R_START_M (11)
    {R_START_M,           R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
    // R_CW_BEGIN_M
    {R_START_M,           R_START_M,     R_CW_BEGIN_M, R_START | DIR_CW},
    // R_CCW_BEGIN_M
    {R_START_M,           R_CCW_BEGIN_M, R_START_M,    R_START | DIR_CCW},
#else
// Use the full-step state table (emits a code at 00 only)
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
static uint8_t ReadPinLevel(GPIO_Port GPIOx, GPIO_Pin PINy); // 内部函数,读取引脚电平
void RotaryEncoderInit(REHandle_t *REVal) {
    GPIO_InitParam GPIO_InitVal={0};
    // 初始化GPIO引脚
    GPIO_InitVal.driving=GPIO_DRIVING_LEVEL_1;
    GPIO_InitVal.mode=GPIOx_Pn_F0_INPUT;
    GPIO_InitVal.pull=GPIO_PULL_NONE;
    HAL_GPIO_Init(REVal- >GPIO_A, REVal- >PIN_A, &GPIO_InitVal);
    HAL_GPIO_Init(REVal- >GPIO_B, REVal- >PIN_B, &GPIO_InitVal);
    // 初始化状态机
    REVal- >State=R_START;
void RotaryEncoderProcess(REHandle_t *REVal) {
    uint8_t pinstate;
    // 读取AB端电平
    pinstate=(ReadPinLevel(REVal- >GPIO_B, REVal- >PIN_B)< < 1) |
              ReadPinLevel(REVal- >GPIO_A, REVal- >PIN_A);
    // 状态机操作
    REVal- >State=ttable[REVal- >State & 0xf][pinstate];
    // 返回编码器步进信息
    REVal- >RetVal=REVal- >State & 0x30;
    GPIO_PinState RDPin;
    RDPin=HAL_GPIO_ReadPin(GPIOx, PINy);
    #ifdef RE_PINS_PULL_DOWN
    // 如果定义RE_PINS_PULL_DOWN,需要反转引脚电平
    if(GPIO_PIN_HIGH==RDPin) {
        return 0;
    } else {
        return 1;
    #else // RE_PINS_PULL_DOWN
        return 1;
    } else {
        return 0;
    #endif // RE_PINS_PULL_DOWN
编码器A端和B端分别连接PA12和PA13,使用板载LED即可,引脚是PA21,对应PWM_CH2。开发环境基于FreeRTOS,XR806 SDK在 ~/tools/目录下。在 ~/tools/xr806_sdk/project/demo/ 目录下新建 tryre 文件夹,并在其中添加源代码,makefile等文件,然后按照教程编译链接下载即可。主要代码如下:
头文件main.h:
#ifndef __MAIN_H
#define __MAIN_H
#ifdef __cplusplus
extern "C" {
#endif
// 需要包含的头文件
#include < stdio.h >
#include "driver/chip/hal_gpio.h"
#include "driver/chip/hal_pwm.h"
#include "re.h"
#include "FreeRTOS.h"
#include "task.h"
#ifdef __cplusplus
#endif
#endif /* __MAIN_H */
main.c:
#include "main.h"
// 定义编码器占用的GPIO引脚
static REHandle_t REVal={
    .GPIO_A=GPIO_PORT_A,
    .PIN_A=GPIO_PIN_12,
    .GPIO_B=GPIO_PORT_A,
    .PIN_B=GPIO_PIN_13
static const uint8_t STEPMAX=10, STEPMIN=0;
static uint8_t step=0; // 控制LED亮度等级
static void RotaryScan(void); // 编码器识别与处理
// PWM输出初始化
#define PWM_CHANNEL   PWM_GROUP1_CH2
#define PWM_MODE      PWM_CYCLE_MODE
#define PWM_GPIO_PORT GPIO_PORT_A
#define PWM_GPIO_PIN  GPIO_PIN_21
#define PWM_GPIO_MODE GPIOA_P21_F4_PWM2_ECT2
static int max_duty_ratio; // PWM计数上限
static void PWMCycleModeSet(void); // PWM重复输出模式初始化
static HAL_Status PWMDutyRatioSet(int val); // 设置PWM输出占空比
// FreeRTOS配置
#define TASK_RE_PRIO     1
#define TASK_RE_STK_SIZE 200
static TaskHandle_t TaskRE_Handler=NULL;
static void TaskCreation(void); // 创建任务
static void TaskRE(void *pvParameters); // 编码器识别任务
int main(void)
    printf("Rotary encoder & PWM demo.rn"); // 串口输出相关信息
    RotaryEncoderInit(&REVal); // 初始化编码器
    PWMCycleModeSet(); // 初始化PWM
    PWMDutyRatioSet(max_duty_ratio*step/STEPMAX); // 设置PWM输出占空比
    TaskCreation(); // 创建任务
    // 任务调度不需要用户指定
    return 0;
    BaseType_t xRet = NULL;
    taskENTER_CRITICAL();
    xRet = xTaskCreate((TaskFunction_t )TaskRE, (const char *)"TaskRE", (uint16_t)TASK_RE_STK_SIZE,
                       (void *)NULL, (UBaseType_t)TASK_RE_PRIO, (TaskHandle_t *)&TaskRE_Handler);
    if(pdPASS == xRet) {
        printf("TaskRE created!rn"); // 任务创建成功
    taskEXIT_CRITICAL();
    while (1) {
        RotaryScan(); // 识别编码器步进
        vTaskDelay(10); // 延迟10(ms)
    RotaryEncoderProcess(&REVal); // 识别编码器步进
    if(DIR_CW == REVal.RetVal) { // 顺时针步进
        if(step< STEPMAX) {
            step++; // 增大亮度,上限是STEPMAX
            printf("%d  ", step);
    } else if(DIR_CCW == REVal.RetVal) {
        if(step >STEPMIN) {
            step--; // 减小亮度,下限是STEPMIN
    // 初始化硬件所需变量声明
    GPIO_InitParam io_param = {0};
    HAL_Status status = HAL_ERROR;
    PWM_ClkParam clk_param = {0};
    PWM_ChInitParam ch_param = {0};
    // 配置GPIO复用,官方例程里面缺了这一部分
    io_param.driving = GPIO_DRIVING_LEVEL_1;
    io_param.mode = PWM_GPIO_MODE;
    io_param.pull = GPIO_PULL_NONE;
    HAL_GPIO_Init(PWM_GPIO_PORT, PWM_GPIO_PIN, &io_param);
    // 配置PWM时钟
    clk_param.clk = PWM_CLK_HOSC;
    clk_param.div = PWM_SRC_CLK_DIV_1;
    status = HAL_PWM_GroupClkCfg(PWM_CHANNEL / 2, &clk_param);
    if (status != HAL_OK) {
        printf("%s(): %d, PWM group clk config errorn", __func__, __LINE__);
    // 配置PWM模式,频率和极性
    ch_param.hz = 1000;
    ch_param.mode = PWM_MODE;
    ch_param.polarity = PWM_HIGHLEVE;
    max_duty_ratio = HAL_PWM_ChInit(PWM_CHANNEL, &ch_param);
    if (max_duty_ratio == -1) {
        printf("%s(): %d, PWM ch init errorn", __func__, __LINE__);
    // 设置占空比
    status = HAL_PWM_ChSetDutyRatio(PWM_CHANNEL, max_duty_ratio / 2);
        printf("%s(): %d, PWM set duty ratio errorn", __func__, __LINE__);
    // 使能通道
    status = HAL_PWM_EnableCh(PWM_CHANNEL, PWM_MODE, 1);
        printf("%s(): %d, PWM ch enable errorn", __func__, __LINE__);
    return HAL_PWM_ChSetDutyRatio(PWM_CHANNEL, val);
  • 旋转编码器
  • LED调光
  • GNU
    GNU
  • MCU控制
  • PWM输出
    XR806开发板适用】基于多源信息融合的粮食霉变检测系统设计
    XR806开发板具有强大的数据处理和传输能力,广泛应用于物联网和嵌入式系统开发
    的头像 发表于 10-27 17:06 988次阅读
    【<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>适用】基于多源信息融合的粮食霉变检测系统设计
    基于全志XR806开发板的家用环境监测传感设计
    本文来自全志XR806开发板评测活动文章,作者使用XR806开发板制作一个简单的家用环境监测传感,可以获取当前的温度、湿度、气压、海拔这四
    的头像 发表于 12-03 10:20 715次阅读
    基于全志<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>的家用环境监测传感<b class='flag-5'>器</b>设计
    如何使用XR806开发板来设计一个粮食霉变检测系统?
    的头像 发表于 01-05 17:30 870次阅读
    如何使用<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>来设计一个粮食霉变检测系统?
    OpenHarmony南向嵌入式:【XR806开发板指导文档】
    XR806_OpenHarmony开发板是基于XR806芯片设计开发的参考评估,身集成了XR806
    的头像 发表于 04-14 09:25 805次阅读
    OpenHarmony南向嵌入式:【<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>指导文档】
    XR806芯片、XR806开源鸿蒙开发板简介
    。可广泛满足 智能家居、智慧楼宇、工业互联、儿童玩具、电子竞赛、极客DIY 等领域的无线连接需求。芯片框图芯片参数XR806开源鸿蒙开发板介绍XR806开发板是基于
    发表于 11-15 17:08
    发表于 11-15 18:32
    如何对XR806开发板的环境进行配置呢
    如何对XR806开发板的环境进行配置呢?有哪些配置步骤?
    发表于 12-28 07:51
    请问大佬XR806鸿蒙开发板怎么样?
    请问大佬XR806鸿蒙开发板怎么样?
    发表于 12-29 07:06
    简述星辰处理的全志XR806鸿蒙开发板上手体验
    本文转载于极术社区极术专栏:STAR CPU(星辰处理)作者:PingYang XR806鸿蒙开发板是全志科技新出的一款支持WiFi和BLE的高集成度无线MCU芯片,支持鸿蒙L0系统。CPU采用
    的头像 发表于 11-03 15:00 8636次阅读
    简述星辰处理<b class='flag-5'>器</b>的全志<b class='flag-5'>XR806</b>鸿蒙<b class='flag-5'>开发板</b>上手体验
    简述XR806开发板与STAR-MC1处理
    全志XR806开发板基于XR806芯片设计,搭载了安谋中国的星辰系列STAR-MC1处理。该开发板体积较小,具备WiFi、低功耗蓝牙技术等
    的头像 发表于 04-11 18:08 3255次阅读
    XR806开发板试用】留言功能开发
    XR806开源鸿蒙开发板是一款基于XR806芯片设计,高度集成WiFi/BLE/常用外设,可供开发进行方案评估、DIY或小规模产品研发,可
    的头像 发表于 10-08 10:58 727次阅读
    XR806开发板试用】FreeRTOS创建任务测试
    这篇来学习下,XR806开发板在FreeRTOS系统下创建两个任务测试,由于没有找到学习的文档,试着参考例程来测试。
    的头像 发表于 10-10 11:47 674次阅读
    【<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b><b class='flag-5'>试用</b>】FreeRTOS创建任务测试
    使用XR806芯片驱动一下DHT11温湿度传感
    参与全志在线与极术社区联合举办的开发板试用活动,收到寄来的全志XR806开发板,之前用过很多全志的SOC芯片,但是像这种无线芯片还是第一次用。这次打算使用
    发表于 10-13 17:28 685次阅读
    使用<b class='flag-5'>XR806</b>芯片驱动一下DHT11温湿度传感<b class='flag-5'>器</b>
    XR806串口驱动CM32M对小厨宝的控制实验
    非常感谢基于安谋科技STAR-MC1的全志XR806 Wi-Fi+BLE开源鸿蒙开发板试用活动,并获得开发板试用
    的头像 发表于 10-23 11:39 618次阅读
    <b class='flag-5'>XR806</b>串口驱动CM32M对小厨宝的控制实验
    全志XR806开发板原理图
    全志XR806开发板原理图
    发表于 10-19 15:11 12次下载
