RT-Thread开发GD32F450添加adc外设
冬至子 来源:YZRD 作者:YZRD 2023-10-08 15:04 次阅读
开发板使用的是gd32f450zk,env工具使用的版本是1.3.5,rtthread版本是5.0.0
添加adc外设的步骤如下:
步骤1: 查看开发板的电路原理图,确定adc的使用引脚,使用的是引脚PF6,即adc012_IN4,如下图:
步骤2: 使用env工具开启adc外设,并选择配置相应的adc外设,如下如
步骤3:打开drv_adc.c文件,修改代码
修改后代码如下,也可以全部修改为GET_PIN(F, 6)
#ifdef BSP_USING_ADC2
ADC2,
RCU_ADC2,
GET_PIN(A, 0), GET_PIN(A, 1), GET_PIN(A, 2), GET_PIN(A, 3),
GET_PIN(F, 6), GET_PIN(A, 5), GET_PIN(A, 6), GET_PIN(A, 7),
GET_PIN(B, 0), GET_PIN(B, 1), GET_PIN(C, 0), GET_PIN(C, 1),
GET_PIN(C, 2), GET_PIN(C, 3), GET_PIN(C, 4), GET_PIN(C, 5),
&adc2,
"adc2",
#endif
还需要修改的函数有:
static rt_err_t gd32_adc_enabled(struct rt_adc_device *device, rt_uint32_t channel, rt_bool_t enabled);
static rt_err_t gd32_adc_convert(struct rt_adc_device *device, rt_uint32_t channel, rt_uint32_t *value);
提示ADC_REGULAR_CHANNEL 未定义。改为ADC_ROUTINE_CHANNEL,同时将其余报错进行修改,修改后的代码如下:
@brief ADC enable
This function enable adc.
@param device, channel, enabled
@retval None
static rt_err_t gd32_adc_enabled(struct rt_adc_device device, rt_uint32_t channel, rt_bool_t enabled)
uint32_t adc_periph;
struct gd32_adc * adc = (struct gd32_adc )device->parent.user_data;
if (channel >= MAX_EXTERN_ADC_CHANNEL)
LOG_E("invalid channel");
return -RT_EINVAL;
adc_periph = (uint32_t )(adc->adc_periph);
if (enabled == ENABLE)
gd32_adc_gpio_init(adc->adc_clk, adc->adc_pins[channel]);
adc_channel_length_config(adc_periph, ADC_ROUTINE_CHANNEL, 1);
adc_data_alignment_config(adc_periph, ADC_DATAALIGN_RIGHT);
#if defined SOC_SERIES_GD32F4xx
adc_external_trigger_source_config(adc_periph, ADC_ROUTINE_CHANNEL, ADC_EXTTRIG_ROUTINE_EXTI_11);
#else
adc_external_trigger_source_config(adc_periph, ADC_REGULAR_CHANNEL, ADC0_1_2_EXTTRIG_REGULAR_NONE);
#endif
adc_external_trigger_config(adc_periph, ADC_ROUTINE_CHANNEL, ENABLE);
adc_routine_channel_config(adc_periph, 0, channel, ADC_SAMPLETIME_480);
#else
adc_regular_channel_config(adc_periph, 0, channel, ADC_SAMPLETIME_13POINT5);
#endif
adc_enable(adc_periph);
ADC calibration and reset calibration /
adc_calibration_enable(adc_periph);
else
adc_disable(adc_periph);
return 0;
@brief convert adc.
This function get adc value.
@param device, channel, value
@retval None
struct gd32_adc * adc = (struct gd32_adc *)(device->parent.user_data);
if (!value)
LOG_E("invalid param");
return -RT_EINVAL;
adc_software_trigger_enable(adc_periph, ADC_ROUTINE_CHANNEL);
while(!adc_flag_get(adc_periph, ADC_FLAG_EOC)){};
// clear flag
adc_flag_clear(adc_periph, ADC_FLAG_EOC);
*value = adc_routine_data_read(adc_periph);
return 0;
步骤4:编译正常,下载到开发板,进行测试,测试指令如下:
msh />adc
Usage:
adc probe - probe adc by name
adc read - read adc value on the channel
adc disable - disable adc channel
adc enable - enable adc channel
步骤5:测试发现输入并无变化的情况下,读取的值一直在变,并且变化太大,读取到的值快速减小。
说明配置的有问题,查找原因,发现再使能adc外设的时候,没有对引脚的时钟进行使能,再static void gd32_adc_gpio_init(rcu_periph_enum adc_clk, rt_base_t pin)函数中增加使能引脚时钟,修改如下:
rcu_periph_clock_enable(RCU_GPIOF);
修改之后测试,测试结果
读取的值不会变化很大,而是再一定的范围内变化。
  • GPIO
  • CLK
    CLK
  • ADC
    ADC
  • GD32F450
  • RTThread
    梁山派GD32F450/470-RT-Thread Nano移植(二)
    在上一篇文章中,我实现了在keil中给梁山派移植RT-Thread Nano,但在官方的移植教程中,除了系统的移植,还有在 RT-Thread Nano 上添加UART控制台与 FinSH的教程,所以我在本文中将实现在梁山派的N
    的头像 发表于 09-25 15:40 2196次阅读
    梁山派<b class='flag-5'>GD32F450</b>/470-<b class='flag-5'>RT-Thread</b> Nano移植(二)
    梁山派GD32F450/470-RT-Thread Nano移植(三)
    RT-Thread FinSH 是 RT-Thread 的命令行组件(shell),提供一套供用户在命令行调用的操作接口,主要用于调试或查看系统信息。
    的头像 发表于 09-26 14:50 1908次阅读
    梁山派<b class='flag-5'>GD32F450</b>/470-<b class='flag-5'>RT-Thread</b> Nano移植(三)
    rt-thread studio新建gd32f450工程
    rt-thread studio 软件版本是:2.2.6;开发板的软件包是:GD32450Z-GD-EVAL版本是V1.0.1;开发板使用兆易的官方
    的头像 发表于 09-28 14:17 1899次阅读
    <b class='flag-5'>rt-thread</b> studio新建<b class='flag-5'>gd32f450</b>工程
    RT-Thread开发GD32F450添加串口外设的方法
    开发板使用的是gd32f450zk,env工具使用的版本是1.3.5,rtthread版本是5.0.0。
    的头像 发表于 09-28 17:01 3169次阅读
    <b class='flag-5'>RT-Thread</b><b class='flag-5'>开发</b><b class='flag-5'>GD32F450</b><b class='flag-5'>添加</b>串口<b class='flag-5'>外设</b>的方法
    星空派(GD开发板介绍
    本帖最后由 jf_39160458 于 2021-9-11 17:41 编辑 `星空派(GD开发板板载GD32F450ZG芯片和广和通L610 4G模组,搭载RT-Thread
    发表于 06-26 18:08
    移植RT-Thread操作系统到GD32星空派开发
    。它把面向对象的设计方法应用到实时系统设计中,使得代码风格优雅、架构清晰、系统模块化并且可裁剪性非常好。本次移植所使用开发板为GD32星空派: 2 代码下载目前RT-Thread提供很多下载方式,有百度网
    发表于 10-13 15:56
    发表于 10-13 16:06
    基于RT-Thread Studio的ADC外设使用方案介绍
    1、基于RT-Thread Stduio使用ART-Pi的ADC外设1. 打开 RT-Thread Stduio,左上角新建 RT-Thread
    发表于 03-28 16:57
    GD32F4系列芯片移植RTOS Demo工程 GD32F407移植FreeRTOS GD32F407移植RT-Thread
    GD32F4系列移植FreeRTOS和RT-Thread工程例程GD32F407/GD32F450
    发表于 06-07 22:10
    基于GD32F310开发板在rt-thread添加finsh及其shell功能
    1、GD32F310开发板试用+finsh/shell添加与进程STACK优化  上一次只是移植了rt-thread nano的内核,但rt-thr
    发表于 11-08 16:05
    GD32F450开发板工程RT系统启动错误如何解决呢?
    我自己设计的GD32F405的板子,在RT-Thread Studio里用的GD32F450开发板工程,改了一下RAM大小,从128改成了192然后把SDRAM、eth删除,在主函数
    发表于 02-21 11:33
    RT-Thread移植到GD32F150系列MCU
    发表于 12-07 19:36 7次下载
    <b class='flag-5'>RT-Thread</b>移植到<b class='flag-5'>GD32F</b>150系列MCU
    RT-Thread文档_ADC 设备
    RT-Thread文档_ADC 设备
    发表于 02-22 18:33 1次下载
    <b class='flag-5'>RT-Thread</b>文档_<b class='flag-5'>ADC</b> 设备
    RT-Thread开发GD32F450添加spiflash外设的步骤
    gd32f450工程上使用env工具增加spi falsh。
    的头像 发表于 08-07 14:58 2285次阅读
    <b class='flag-5'>RT-Thread</b><b class='flag-5'>开发</b><b class='flag-5'>GD32F450</b><b class='flag-5'>添加</b>spiflash<b class='flag-5'>外设</b>的步骤
    RT-Thread开发GD32F450使用scons添加新的文件夹
    开发板使用的是gd32f450zk,想在工程中新建文件夹,通过scons管理
    的头像 发表于 10-08 16:44 983次阅读
    <b class='flag-5'>RT-Thread</b><b class='flag-5'>开发</b><b class='flag-5'>GD32F450</b>使用scons<b class='flag-5'>添加</b>新的文件夹
