线程间通信的几种方式
科技绿洲 来源:Java技术指北 作者:Java技术指北 2023-10-10 16:23 次阅读
1 使用synchronized,wait,notify,notifyAll
使用synchronized 等方法来控制共享变量,完成交替打印。
思路:
  1. 在同步方法中先判断信号量,如果不是当前需要的信号使用wait()阻塞线程。
  2. 完成打印之后切换信号变量。再唤醒所有线程。
public class ThreadSignaling2 {
    public static void main(String[] args) {
        NorthPrint print = new NorthPrint(new NorthSignal());
        ThreadA threadA = new ThreadA(print);
        ThreadB threadB = new ThreadB(print);
        threadA.start();
        threadB.start();
public static class ThreadA extends Thread {
    private NorthPrint print;
    public ThreadA(NorthPrint print) {
        this.print = print;
    @Override
    public void run() {
        print.printNumber();
public static class ThreadB extends Thread {
    public ThreadB(NorthPrint print) {
        this.print = print;
    @Override
    public void run() {
        print.printChar();
public class NorthSignal {
    protected boolean hasDataToProcess = false;
    public synchronized boolean hasDataToProcess(){
        return this.hasDataToProcess;
    public synchronized void setHasDataToProcess(boolean hasData){
        this.hasDataToProcess = hasData;
public class NorthPrint {
    private NorthSignal signal;
    public NorthPrint(NorthSignal signal) {
        this.signal = signal;
    public synchronized void printNumber() {
        try {
            for (int i = 1; i <= 26; ) {
                if (signal.hasDataToProcess()) {
                    wait();
                }else {
                    System.out.print(i * 2 - 1);
                    System.out.print(i * 2);
                    signal.setHasDataToProcess(true);
                    i++;
                    notifyAll();
        } catch (InterruptedException e) {
            e.printStackTrace();
    public synchronized void printChar() {
        try {
            for (int i = 'A'; i <= 'Z'; ) {
                if (!signal.hasDataToProcess()) {
                    wait();
                }else {
                    System.out.print((char)i);
                    signal.setHasDataToProcess(false);
                    i++;
                    notifyAll();
2 Lock,Condition
通过使用Lock,Condition的signal() 和 await()来进行换新阻塞交替打印。
public class ThreadSignalingReentrant {
        Lock lock = new ReentrantLock();
        Condition condition1 = lock.newCondition();
        Condition condition2 = lock.newCondition();
        new Thread(() - > {
            try{
                lock.lock();
                int i = 1;
                while (i <= 26) {
                    i++;
                    condition2.signal();
                    condition1.await();
            } finally {
                lock.unlock();
        }).start();
        new Thread(() - > {
            try{
                lock.lock();
                char i = 'A';
                while (i <= 'Z') {
                    System.out.print(i);
                    i++;
                    condition1.signal();
                    condition2.await();
            } finally {
                lock.unlock();
        }).start();
3 LockSupport
LockSupport 用来创建锁和其他同步类的基本线程阻塞。当调用LockSupport.park时,表示当前线程将会等待,直至获得许可,当调用LockSupport.unpark时,必须把等待获得许可的线程作为参数进行传递,好让此线程继续运行。
其中:
  • park函数,阻塞线程,并且该线程在下列情况发生之前都会被阻塞: ① 调用unpark函数,释放该线程的许可。② 该线程被中断。③ 设置的时间到了。并且,当time为绝对时间时,isAbsolute为true,否则,isAbsolute为false。当time为0时,表示无限等待,直到unpark发生。
  • unpark函数,释放线程的许可,即激活调用park后阻塞的线程。这个函数不是安全的,调用这个函数时要确保线程依旧存活。
public class ThreadSignalingLockSupport {
    private static Thread threadA = null;
    private static Thread threadB = null;
        threadA = new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                i++;
                LockSupport.unpark(threadB);
                LockSupport.park();
        threadB = new Thread(() - > {
            char i = 'A';
            while (i <= 'Z') {
                LockSupport.park();
                i++;
                LockSupport.unpark(threadA);
        threadA.start();
        threadB.start();
4 volatile
根据volatile修饰的对象在JVM内存中的可见性,完成交替打印
public class ThreadSignalingVolatile {
    enum ThreadRunFlag{PRINT_NUM, PRINT_CHAR}
    private volatile static ThreadRunFlag threadRunFlag = ThreadRunFlag.PRINT_NUM;
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                while(threadRunFlag == ThreadRunFlag.PRINT_CHAR){}
                i++;
                threadRunFlag = ThreadRunFlag.PRINT_CHAR;
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                while (threadRunFlag == ThreadRunFlag.PRINT_NUM){}
                i++;
        }).start();
5 AtomicInteger
同样利用了AtomicInteger的并发特性,来完成交替打印。
public class AtomicIntegerSignal {
    private static AtomicInteger threadSignal = new AtomicInteger(1);
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                while(threadSignal.get() == 2){}
                i++;
                threadSignal.set(2);
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                while (threadSignal.get() == 1){}
                i++;
                threadSignal.set(1);
        }).start();
6 利用 Piped Stream
使用Stream中的Piped Stream分别控制输出,但是其运行速度极慢。
public class ThreadSignalPipedStream {
    private final PipedInputStream inputStream1;
    private final PipedOutputStream outputStream1;
    private final PipedInputStream inputStream2;
    private final PipedOutputStream outputStream2;
    private final byte[] MSG;
    public ThreadSignalPipedStream() {
        inputStream1 = new PipedInputStream();
        outputStream1 = new PipedOutputStream();
        inputStream2 = new PipedInputStream();
        outputStream2 = new PipedOutputStream();
        MSG = "Go".getBytes();
        try {
            inputStream1.connect(outputStream2);
            inputStream2.connect(outputStream1);
        } catch (IOException e) {
        ThreadSignalPipedStream signal = new ThreadSignalPipedStream();
        signal.threadA().start();
        signal.threadB().start();
    public Thread threadA (){
        final String[] inputArr = new String[2];
        return new Thread() {
            String[] arr = inputArr;
            PipedInputStream in1 = inputStream1;
            PipedOutputStream out1 = outputStream1;
            @Override
            public void run() {
                int i = 1;
                while (i <= 26) {
                    try {
                        out1.write(MSG);
                        byte[] inArr = new byte[2];
                        in1.read(inArr);
                        while(!"Go".equals(new String(inArr))){ }
                        i++;
    public Thread threadB (){
            private String[] arr = inputArr;
            private PipedInputStream in2 = inputStream2;
            private PipedOutputStream out2 = outputStream2;
            @Override
            public void run() {
                char i = 'A';
                while (i <= 'Z'){
                    try {
                        in2.read(inArr);
                        i++;
                        out2.write(MSG);
7 利用BlockingQueue
BlockingQueue 通常用于一个线程生产对象,另外一个线程消费这些对象的场景。
一个线程负责往里面放,另一个线程从里面取一个BlockingQueue。
线程可以持续将新对象插入到队列之中,直到队列达到可容纳的临界点。当队列到达临界点之后,线程生产者会在插入对象是进入阻塞状态,直到有另外一个线程从队列中拿走一个对象。消费线程会不停的从队列中拿出对象。如果消费线程从一个空的队列中获取对象的话,那么消费线程会处阻塞状态,直到一个生产线程把对象丢进队列。
BlockingQueue常用方法如下:
image-20210906230302480
那么我们使用一个LinkedBlockingQueue来完成开始出现的题目
方法中我们使用offer,peek,poll这几个方法来完成。
public class ThreadSignalBlockingQueue {
    private static LinkedBlockingQueue< String > queue = new LinkedBlockingQueue<  >();
    public static void main(String[] args) throws InterruptedException {
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                i++;
                queue.offer("printChar");
                while(!"printNumber".equals(queue.peek())){}
                queue.poll();
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                while(!"printChar".equals(queue.peek())){}
                queue.poll();
                i++;
                queue.offer("printNumber");
        }).start();
我们也可以使用两个LinkedBlockinQueue来完成,分别使用带阻塞的put,take来完成。代码如下
public class ThreadSignalBlockingQueue2 {
    private static LinkedBlockingQueue< String > queue1 = new LinkedBlockingQueue<  >();
    private static LinkedBlockingQueue< String > queue2 = new LinkedBlockingQueue<  >();
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                i++;
                try {
                    queue2.put("printChar");
                    queue1.take();
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                try {
                    queue2.take();
                    i++;
                    queue1.put("printNumber");
        }).start();
8 使用CyclicBarrier
CyclicBarrier的字面意思就是可循环使用的屏障,它可以让一组线程到达一个阻塞点(屏障)时被阻塞。直到最后一个线程到达阻塞点后,屏障才会开门,然后所有被拦截的线程就可以继续运行。
CyclicBarrier中有一个barrierCommand,主要就是在所有线程到达阻塞点之后执行的一个线程。可以使用构造方法来 CyclicBarrier(int parties, Runnable barrierAction)进行构建。
关于使用CyclicBarrier进行交替打印,先来说一下思路。
  1. 利用await()方法使得每循环一次都阻塞线程。
  2. 将每次循环输出的值放到一个共享的同步list里面。
  3. 然后再使用barrierAction到达阻塞点之后进行输出。由于list里面的值先后顺序有变化,所有先排序然后再打印。
下面我们看一下实操代码:
public class ThreadSignalCyclicBarrier {
    private static List< String > list =  Collections.synchronizedList(new ArrayList<  >());
    public static void main(String[] args) throws Exception {
        CyclicBarrier barrier = new CyclicBarrier(2,barrierRun());
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                list.add(String.valueOf(i * 2 - 1));
                list.add(String.valueOf(i * 2));
                i++;
                try {
                    barrier.await();
                } catch (Exception e) {
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                try {
                    list.add(String.valueOf(i));
                    i++;
                    barrier.await();
        }).start();
    public static Runnable barrierRun(){
        return new Runnable() {
            @Override
            public void run() {
                Collections.sort(list);
                list.forEach(str- >System.out.print(str));
                list.clear();
  • 通信
  • 函数
  • Lock
  • 线程
    Linux多线程线程同步
    进程所花费的空间,而且,线程彼此切换所需的时间也远远小于进程切换所需要的时间。 线程方便的通信
    发表于 12-08 14:14
    线程的同步方式有哪几种
    线程的同步方式有哪几种
    发表于 05-26 07:13
    IOT-OS之RT-Thread--- 线程同步与线程通信
    rt_thread,下面要介绍线程的同步与通信线程同步对象rt_sem / rt_mutex / rt_event和
    发表于 07-02 06:15
    哪些方式可以实现Linux系统下的进程通信
    哪些方式可以实现Linux系统下的进程通信?进程与线程有哪些不同之处呢?
    发表于 12-24 06:38
    RTT多线程通信机制有哪几种及推荐?
    针对采用RTT OS ,启动了4个线程,两个串口读写线程(数据>10byte以上) 一个触摸按键线程 一个显示线程,针对这几个线程间数据传输
    发表于 04-07 15:52
    QNX消息传递及其在线程通信的应用
    本文介绍了QNX 嵌入式实时多任务操作系统的消息传递和微内核体系结构的特点,创建线程的方法,消息传递的基本原理,以及阻塞式消息传递在线程通信的实现方法,并给出了
    发表于 08-11 08:46 31次下载
    c线程通信
    对于学习嵌入式Linux开发得朋友说,这篇文章帮助你更加了解线程通信
    发表于 08-09 15:12 3次下载
    线程和进程的区别和联系,线程和进程通信方式
    摘要:进程和线程都是计算里的两项执行活动,各有特色和优势。下面就来介绍线程和进程之间的区别联系以及通信方式
    发表于 12-08 14:12 1.2w次阅读
    进程线程通信方式
    进程通信则不同,它的数据空间的独立性决定了它的通信相对比较复杂,需要通过操作系统。以前进程通信只能是单机版的,现在操作系统都继承了基
    的头像 发表于 04-09 15:58 8893次阅读
    进程<b class='flag-5'>间</b>与<b class='flag-5'>线程</b><b class='flag-5'>间</b>的<b class='flag-5'>通信</b><b class='flag-5'>方式</b>
    浅析嵌入式Linux中进程几种通信方式
    线程通信:由于多线程共享地址空间和数据空间,所以多个线程
    的头像 发表于 08-20 09:03 6392次阅读
    了解Linux多线程线程同步
    进程通信IPC,线程可以直接读写进程数据段(如全局变量)来进行通信——需要进程同步和互斥手段的辅助,以保证数据的一致性。
    发表于 04-23 14:23 711次阅读
    了解Linux多<b class='flag-5'>线程</b>及<b class='flag-5'>线程</b><b class='flag-5'>间</b>同步
    使用MQTT作为进程通信方式
    小编对Linux这一块的实际开发经验虽然还不是很足,但也知道进程通信有那么几种方式:管道、消息队列、共享内存、套接字等。
    的头像 发表于 10-22 12:09 6086次阅读
    使用MQTT作为进程<b class='flag-5'>间</b><b class='flag-5'>通信</b>的<b class='flag-5'>方式</b>
    RT-Thread文档_线程通信
    RT-Thread文档_线程通信
    发表于 02-22 18:29 0次下载
    RT-Thread文档_<b class='flag-5'>线程</b><b class='flag-5'>间</b><b class='flag-5'>通信</b>
    线程池的创建方式几种
    的开销。线程池的创建方式有多种,下面将详细介绍几种常用的线程池创建方式。 手动创建线程池 手动创
    的头像 发表于 12-04 16:52 821次阅读
    java实现多线程几种方式
    Java实现多线程几种方式线程是指程序中包含了两个或以上的线程,每个线程都可以并行执行不同
    的头像 发表于 03-14 16:55 571次阅读
