RT-Thread中Lan8720和lwip协议栈的使用
冬至配饺子 来源:YZRD 作者:YZRD 2023-10-13 10:19 次阅读
开发环境:野火的stm32f407,rt-thread studio版本是版本: 2.2.6,stm32f4的资源包为0.2.2,Agile Modbus软件包版本为v1.1.2。新建选择芯片工程。
修改工程使用外部晶振,可参考第一篇文章 rt-thread studio新建stm32f407工程 。
查看野火工程的资料,可知道芯片的使用引脚为:
PG11 : RMII_TX_EN;
PG13 : RMII_TXD0;
PG14 : RMII_TXD1;
PC5 : RMII_RXD1;
PC4 : RMII_RXD0;
PA7 : RMII_CRSDV;
PA1 : RMII_REF_CLK;
PC1 : RMII_MDC
PA2 : RMII_MDIO;
复位脚 :NRST脚。
接线方式: 笔记本连接路由器,野火开发板也连接路由器。
根据文档需要做的步骤如下:
/*if you want to use eth you can use the following instructions.
  • STEP 1, define macro related to the eth
  • such as    BSP_USING_ETH
  • STEP 2, copy your eth init function from stm32xxxx_hal_msp.c generated by stm32cubemx to the end if board.c file
  • such as     void HAL_ETH_MspInit(ETH_HandleTypeDef* heth)
  • STEP 3, modify your stm32xxxx_hal_config.h file to support eth peripherals. define macro related to the peripherals
  • such as     #define HAL_ETH_MODULE_ENABLED
  • STEP 4, config your phy type
  • such as     #define PHY_USING_LAN8720A
  • #define PHY_USING_DM9161CEP
  • #define PHY_USING_DP83848C
  • STEP 5, implement your phy reset function in the end of board.c file
  • void phy_reset(void)
STEP 6, config your lwip or other network stack
按照要求修改即可,主要讲STEP2和STEP6的修改。STEP2 中的代码使用cubmx生成,生成的代码如下:
void HAL_ETH_MspInit(ETH_HandleTypeDef* ethHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(ethHandle->Instance==ETH)
/* USER CODE BEGIN ETH_MspInit 0 /
USER CODE END ETH_MspInit 0 /
ETH clock enable */
__HAL_RCC_ETH_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
/**ETH GPIO Configuration
PC1 ------> ETH_MDC
PA1 ------> ETH_REF_CLK
PA2 ------> ETH_MDIO
PA7 ------> ETH_CRS_DV
PC4 ------> ETH_RXD0
PC5 ------> ETH_RXD1
PG11 ------> ETH_TX_EN
PG13 ------> ETH_TXD0
PG14 ------> ETH_TXD1
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_13|GPIO_PIN_14;
HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
USER CODE BEGIN ETH_MspInit 1 /
USER CODE END ETH_MspInit 1 */
STEP6 中是能lwip的协议栈,双击工程下的RT—Thread Settings,选择组件,选择lwIP。右键lwIP选择配置项进行配置,选择版本等参数。选择的是v2.0.2。保存配置,等待下载即可。
对程序进行编译,编译正常下载,查看打印信息
在中断,可看到打印信息 lwIP-2.0.2 initialized! 。使用ping指令ping 笔记本ip,可正常ping通。
  • 路由器
  • LwIP协议栈
  • LAN8720
  • STM32F407
  • RT-Thread
    Cube+lwip配置的只有LAN8742,如何改成LAN8720
    Cube+lwip配置的只有LAN8742,如何改成LAN8720,现在项目需要,用Cube配置的有点晕了!
    发表于 04-15 07:53
    如何使用RT-Thread Studio添加以太网驱动和lwIP协议
    lwIP 协议 在前面的配置我们已经配置好了 ETH 相关的硬件部分驱动,接下来就需要配置 lwIP
    发表于 03-29 06:29
    Lan8720以太网芯片操作系统
    硬件资源:正点原子stm32f407 探索者开发板,板载Lan8720以太网芯片操作系统:rt-thread 4.0.1实验目的:1.实现ping功能,能够ping通外网2.实现Telnet功能
    发表于 08-05 07:04
    网络协议-lwip2.1.2移植
    本篇目标:上一篇freertos的优化(stm32f4_os_app),RTOS的移植已经告一段落了,接下来就是移植重要的网络协议-lwip2.1.2!硬件配置:STM32_ETH
    发表于 08-16 08:08
    怎样去设计一种基于stm32f407和Lan8720rt-thread操作系统
    rt-thread操作系统有哪些功能?怎样去设计一种基于stm32f407和Lan8720rt-thread操作系统?
    发表于 10-26 06:03
    如何在RT-Thread Studio移植LAN8720A驱动的基础上打开lwIP和SA呢
    如何在RT-Thread Studio移植LAN8720A驱动的基础上打开lwIP和SA呢?有哪些操作流程呢?
    发表于 03-01 06:13
    SC0085 AT32在RT-Thread上运行LwIP协议
    示例目的演示在RT-Thread上运行LwIP协议,并搭建一个UDP echo server支持型号列表:支持型号AT32F407xxAT32F437xx主要使用外设列表:主要使用外
    发表于 08-23 20:40
    RT-ThreadLan8720lwip协议的使用
    */  }  }  step6lwiprt - thread设置,选择选择组件,选择
    发表于 02-13 14:55
    RT-Thread的mymqtt软件包添加步骤与使用方法
    文章 RT-ThreadLan8720lwip协议的使用的工程基础上添加mymqtt软件包
    发表于 02-13 14:58
    RT-ThreadLan8720a和lwip基础上移植ntp的步骤
    开发环境:野火的stm32f407,rt-thread studio版本是版本: 2.2.6,stm32f4的资源包为0.2.2。以RT-ThreadLan8720
    发表于 02-15 11:21
    RT-Thread移植使用webserver的流程
    ,stm32f4的资源包为0.2.2,rt-thread版本为4.0.3。以RT-ThreadLan8720lwip
    发表于 02-22 15:10
    RT-Thread使用webserver的步骤
    sTM32F407,rt-thead studio版本版本:2.2.6 .3。以RT-ThreadLan8720lwip
    发表于 02-24 14:47
    CubeMX创建裸机工程:STM32F407+ LAN8720A + RMII + lwIP
    MCU和PHY芯片接口:RMII操作系统:无TCP/IP网络协议lwIP配置工具:CubeMX编译工具:Keil5烧录器:J-Link烧录模式:SWD原理图部分STM32F407与PHY芯片
    发表于 12-05 12:06 110次下载
    CubeMX创建裸机工程:STM32F407+ <b class='flag-5'>LAN8720</b>A + RMII + <b class='flag-5'>lwIP</b>
    RT-ThreadLan8720a和 lwip基础上移植ntp流程
    的头像 发表于 10-12 16:59 2040次阅读
    <b class='flag-5'>RT-Thread</b>在<b class='flag-5'>Lan8720</b>a和 <b class='flag-5'>lwip</b>基础上移植ntp流程
    RT-Threadmymqtt软件包的使用方法
    在上一篇文章 RT-ThreadLan8720lwip协议的使用的工程基础上添加mymqt
    的头像 发表于 10-13 10:44 1058次阅读
    <b class='flag-5'>RT-Thread</b><b class='flag-5'>中</b>mymqtt软件包的使用方法
