MCU(STM32F767IGTX)上电启动后执行的代码分析
冬至子 来源:聊点嵌入式 作者:聊点嵌入式 2023-11-06 15:04 次阅读
这一节,我们来看一下MCUSTM32F767IGTX)上电启动后执行的代码,也就是常说的启动代码。上一节里我们已经讲过了CubeIDE工程的启动代码在Core/Startup文件夹下,是一个汇编源文件。
不是所有的启动代码都是汇编写的,NXP就是用C写的启动代码。可见C语言真是上得了厅堂(能编写大型软件,比如操作系统、编译器),下得了厨房(直接跟硬件打交道也不在话下),在嵌入式领域那可是统治地位。
1. 编译参数与全局变量
先把代码放到下边再分析。
.syntax unified
  .cpu cortex-m7
  .fpu softvfp
  .thumb
.global  g_pfnVectors
.global  Default_Handler
/* start address for the initialization values of the .data section.
defined in linker script */
.word  _sidata
/* start address for the .data section. defined in linker script */
.word  _sdata
/* end address for the .data section. defined in linker script */
.word  _edata
/* start address for the .bss section. defined in linker script */
.word  _sbss
/* end address for the .bss section. defined in linker script */
.word  _ebss
/* stack used for SystemInit_ExtMemCtl; always internal RAM used */
前4行是编译参数,告诉编译器编译对象、参数,编译器才好工作。
第6和第7行定义了两个全局变量,下面的代码里会用到。
接下来申明了5个外部变量,在链接文件中定义的,每个变量占有1个字,存储的是一个地址,具体的含义代码里已经有说明了,作用是在启动时把data段从FLASH拷贝到RAM中,bss段清零。
2. 系统入口Reset_Handler
 * @brief  This is the code that gets called when the processor first
 *          starts execution following a reset event. Only the absolutely
 *          necessary set is performed, after which the application
 *          supplied main() routine is called.
 * @param  None
 * @retval : None
    .section  .text.Reset_Handler
  .weak  Reset_Handler
  .type  Reset_Handler, %function
Reset_Handler:
  ldr   sp, =_estack      /* set stack pointer */
/* Copy the data segment initializers from flash to SRAM */
  ldr r0, =_sdata
  ldr r1, =_edata
  ldr r2, =_sidata
  movs r3, #0
  b LoopCopyDataInit
CopyDataInit:
  ldr r4, [r2, r3]
  str r4, [r0, r3]
  adds r3, r3, #4
LoopCopyDataInit:
  adds r4, r0, r3
  cmp r4, r1
  bcc CopyDataInit
/* Zero fill the bss segment. */
  ldr r2, =_sbss
  ldr r4, =_ebss
  movs r3, #0
  b LoopFillZerobss
FillZerobss:
  str  r3, [r2]
  adds r2, r2, #4
LoopFillZerobss:
  cmp r2, r4
  bcc FillZerobss
/* Call the clock system initialization function.*/
  bl  SystemInit
/* Call static constructors */
    bl __libc_init_array
/* Call the application's entry point.*/
  bl  main
  bx  lr
.size  Reset_Handler, .-Reset_Handler
系统上电后,默认会从FLASH的起始地址取指令执行,这个地方存放的是栈顶地址和中断向量表,第一个中断向量就是Reset_Handler,也即上电后会首先执行Reset_Handler这个函数,Reset_Handler是系统的入口(Entry Point)。
这段代码的第10,11,12行指明了Reset_Handler这个函数在代码段,且是弱函数,用户可以改写。
第13行是Reset_Handler函数的起始,14行Reset_Handler函数的第一条指令就是取栈顶地址送到SP中。
第17到31行是把data段从FLASH拷贝到RAM中,其中_sidata是data段在FLASH中的起始地址,_sdata是data段在RAM中的起始地址,_edata是data段在RAM中的结束地址。具体是如何复制的大家自己去看这段汇编代码,汇编指令不清楚的可以去找F7的编程手册(Programming Manual)。
第39行到45行是把bss段清零。代码也靠大家自己去解读。
第48行调用SystemInit函数,这个函数在system_stm32f7xx.c中,主要作用是设置FPU,根据需要设置中断向量表的起始地址。
第50行调用__libc_init_array函数,这个函数是GCC提供的,其作用是初始化C库。
第52行调用main函数,终于到了我们熟悉的地方了,用户代码的入口。
后边的指令是执行不到的,因为main函数中有个无限循环。
分析到这里,大家就明白了,系统启动后不是直接执行main函数的,执行main函数之前还有一些工作要做。所以,认为main函数是系统入口的观点是不对的。
3. 意料外中断的处理函数Default_Handler
 * @brief  This is the code that gets called when the processor receives an
 *         unexpected interrupt.  This simply enters an infinite loop, preserving
 *         the system state for examination by a debugger.
 * @param  None
 * @retval None
    .section  .text.Default_Handler,"ax",%progbits
Default_Handler:
Infinite_Loop:
  b  Infinite_Loop
  .size  Default_Handler, .-Default_Handler
接下来又定义了一个函数——Default_Handler,这个函数里只有一个无限循环。主要作用是当遇到意料外的中断时,都会调用Default_Handler来处理。什么是意料外的中断呢?当用户程序里没有定义某一个中断的中断服务程序,但是某种情况下这个中断又产生了,这个时候就要靠Default_Handler来处理了。这在调试的时候有用,进入Default_Handler后,产生中断的原因,进入Default_Handler前运行的代码等情况都被保存下来,可以提取查看,解决BUG。
4. 其余代码
接下来的代码就不放上来了。其实也不是代码,是中断向量和中断服务函数的定义。这里的中断向量的名称和顺序与F767的系统异常/中断一一对应。
  • RAM
    RAM
  • GCC
    GCC
  • 中断处理
  • MCU控制
  • STM32F7
    STM32F407ZGT6偶尔启动失败的原因是什么?
    硬件为stm32f407zgt6,运行FREERTOS系统。STM32F407ZGT6偶尔启动
    发表于 08-04 08:00
    FPU如何从MCU STM32F746ZG移植到MCU STM32F767ZGT6
    我想了解从 MCU STM32F746ZG 移植到 MCU STM32F767ZGT6 需要付出多少努力...我应该做多少改变?非常感谢您提供这些信息,但如您所知,现在微型产品的供应情
    发表于 12-21 06:08
    请问STM32F767代码可以在STM32F777运行吗?
    你好!从 STM32F767ZIT MCU 代码创建的二进制文件能否在 STM32F777ZIT MCU 中运行?它们是否 100% 引脚兼
    发表于 01-06 06:19
    stm32f103zet6启动文件详解
    启动文件这部分和arm11的还是很类似的,是开发板执行的第一段代码,唯一不同的感觉的就是比
    发表于 11-07 14:17 1.2w次阅读
    MCU启动应用程序的准备
    MCU整体工作流程可总结如下:——》主时钟起振——》启动代码——》用户程序(main函数)。对于我们应用开发来说,大部分工作重点是在应用
    发表于 07-27 10:22 2830次阅读
    stm32f429/f767核心板电路方案
    stm32f429/767 核心板,邮票孔,SDRAM等长布线,兼容正点原子底板。 在正点原子阿波罗F4核心板基础又添加邮票空引脚设计。走线优化。
    的头像 发表于 12-07 10:56 7181次阅读
    STM32启动过程
    STM32启动过程
    发表于 11-15 18:21 16次下载
    <b class='flag-5'>STM32</b><b class='flag-5'>上</b><b class='flag-5'>电</b><b class='flag-5'>后</b><b class='flag-5'>启动</b>过程
    STM32CubeMX Nucleo F767ZI 教程(2)
    STM32CubeMX Nucleo F767ZI 教程(2)前言一、原理图1.MB1137 顶层文件2.Connectors.SchDoc3.MCU_144.SchDoc4.USB.SchDoc5.ST_LINK_V2-1.
    发表于 12-06 10:06 21次下载
    <b class='flag-5'>STM32</b>CubeMX Nucleo <b class='flag-5'>F767</b>ZI 教程(2)
    MCU启动应用程序前的工作
    MCU(复位)时,从固定的地址启动,一般是地址0x00000000,如ARM7;个别特殊的如STM32默认
    发表于 02-09 11:17 7次下载
    <b class='flag-5'>MCU</b><b class='flag-5'>上</b><b class='flag-5'>电</b>到<b class='flag-5'>启动</b>应用程序前的工作
    Apollo STM32F767 CORE图
    Apollo STM32F767 CORE图免费下载。
    发表于 09-28 14:33 8次下载
    STM32F767 LWIP开发手册 V1.0
    /IP协议栈的支持。ALIENTEK STM32F767开发板板载一颗PHY层芯片。本章主要介绍基本的以太网知识以及LWIP在ALIENTEK STM32F767开发板的移植。
    发表于 09-28 15:06 7次下载
    APM32F103VBT6_电源,芯片不启动
    发表于 11-09 21:03 4次下载
    APM32<b class='flag-5'>F</b>103VBT6_电源<b class='flag-5'>上</b><b class='flag-5'>电</b><b class='flag-5'>后</b>,芯片不<b class='flag-5'>启动</b>
    DS11532_STM32F765xx和STM32F767xx和STM32F768Ax和STM32F769xx单片机数据手册
    发表于 11-23 20:28 0次下载
    DS11532_<b class='flag-5'>STM32F</b>765xx和<b class='flag-5'>STM32F767</b>xx和<b class='flag-5'>STM32F</b>768Ax和<b class='flag-5'>STM32F</b>769xx单片机数据手册
    STM32F0系列MCU硬件电路boot设计
    Boot配置的作用是用于选择芯片从何处读取可执行代码运行,STM32F0系列
    的头像 发表于 09-27 14:21 3333次阅读
    <b class='flag-5'>STM32F</b>0系列<b class='flag-5'>MCU</b>硬件电路boot设计
    MCU启动的可能原因分析
    在GD32 MCU,BOOT引脚决定了MCU启动方式,通常BOOT0引脚下拉时是flash启动,如果BOOT电平不对就不会
    发表于 01-12 17:08 2239次阅读
    <b class='flag-5'>MCU</b><b class='flag-5'>上</b><b class='flag-5'>电</b>不<b class='flag-5'>启动</b>的可能原因<b class='flag-5'>分析</b>
