颜色阈值+图像掩模的方法虽然简单,但是只能应对一些固定颜色车道线的场景。图像像素受光照影响将是一个极其常见的问题。
canny边缘检测+霍夫变换是另外一种简单提取车道线的方法。首先依靠canny提取到原图像的边缘信息,再依靠霍夫变换提取满足要求的直线
import matplotlib.pyplot as plt
import matplotlib.image as mpimg
import numpy as np
import cv2
# Read in and grayscale the image
image = mpimg.imread('test.jpg')
gray = cv2.cvtColor(image,cv2.COLOR_RGB2GRAY)
# Define a kernel size and apply Gaussian smoothing
kernel_size = 5
blur_gray = cv2.GaussianBlur(gray,(kernel_size, kernel_size),0)
# Define our parameters for Canny and apply
low_threshold = 50
high_threshold = 150
edges = cv2.Canny(blur_gray, low_threshold, high_threshold)
# Next we'll create a masked edges image using cv2.fillPoly()
mask = np.zeros_like(edges)
ignore_mask_color = 255
# This time we are defining a four sided polygon to mask
imshape = image.shape
vertices = np.array([[(0,imshape[0]),(0, 0), (imshape[1], 0), (imshape[1],imshape[0])]], dtype=np.int32) # all image
# vertices = np.array([[(0,imshape[0]),(554, 460), (700, 446), (imshape[1],imshape[0])]], dtype=np.int32) # defining a quadrilateral region
cv2.fillPoly(mask, vertices, ignore_mask_color)
masked_edges = cv2.bitwise_and(edges, mask)
# Define the Hough transform parameters
# Make a blank the same size as our image to draw on
rho = 1 # distance resolution in pixels of the Hough grid
theta = np.pi/180 # angular resolution in radians of the Hough grid
threshold = 1 # minimum number of votes (intersections in Hough grid cell)
min_line_length = 5 #minimum number of pixels making up a line
max_line_gap = 1 # maximum gap in pixels between connectable line segments
line_image = np.copy(image)*0 # creating a blank to draw lines on
# Run Hough on edge detected image
# Output "lines" is an array containing endpoints of detected line segments
lines = cv2.HoughLinesP(masked_edges, rho, theta, threshold, np.array([]),
min_line_length, max_line_gap)
# Iterate over the output "lines" and draw lines on a blank image
for line in lines:
for x1,y1,x2,y2 in line:
cv2.line(line_image,(x1,y1),(x2,y2),(255,0,0),10)
# Create a "color" binary image to combine with line image
color_edges = np.dstack((edges, edges, edges))
# Draw the lines on the edge image
lines_edges = cv2.addWeighted(color_edges, 0.8, line_image, 1, 0)
plt.imshow(lines_edges)
plt.show()
canny边缘后,进行霍夫直线检测的结果
在此基础上,增加一个四边形的图像掩模的结果
四边形的设定,写在了代码中,只是进行了注释
总结:
以上两种方法只适合简单的demo,显然并不能识别具备一定曲率的车道线,也无法适应光照不同的情况。
举报投诉
边缘检测
91浏览量
18142 -
Canny
14浏览量
9686 -
python
53文章
4709浏览量
83711
基于Canny边缘检测算子的图像检索算法
【摘要】:针对依赖传统Canny算子的基于边缘的图像检索系统所存在的不足,提出一种基于Canny边缘检测的图像检索算法。使用改进的
发表于 04-24 10:03
【DragonBoard 410c试用体验】之OpenCV中canny算子边缘检测
有显著变化的点凸显出来。在具体编程实现时,可通过计算梯度幅值来确定。 检测:经过增强的图像,往往邻域中有很多点的梯度值比较大,而在特定的应用中,这些点并不是我们要找的边缘点,所以应该采用某种方
发表于 09-11 23:24
关于canny算子边缘检测的问题
grd=edge(Egray,'canny',0.09,'both');大神门 问一下这个后面的0.09和both什么意思是指的是Egray图像的上下大小还是,另外可以的话能大概说说这个canny
发表于 04-04 22:27
Labview图像处理——边缘检测
边缘的灰度值过度较为明显,梯度算子可以得到较好的边缘检测结果。边缘提取其实也是一种滤波,不同的算子有不同的提取效果。比较常用的方法有三种,S
发表于 12-01 12:16
基于Canny 法的红外小目标边缘检测方法
从红外图像的特点出发,基于Canny算法进行了目标边缘检测。首先,对源图像进行小波分解和重构,对图像进行消噪,抑制噪声对目标提取的影响。然后对消噪后的图像用Canny算法进
发表于 05-27 15:02
•12次下载
发表于 02-11 11:22
•28次下载
基于Canny算法的改进Kirsch人脸边缘检测方法
针对Kirsch边缘检测算法的不足,提出了一种基于Canny算法改进的Kirsch人脸边缘检测算法。该算法先对原始图像用高斯滤波器平滑,计算
发表于 02-23 14:31
•10次下载
一套车道线检测系统
车道线检测主要用于驾驶辅助和无人驾驶系统,根据摄像头数量,分为单目和双目两种检测系统。出于实时性和经济性的考虑,一般采用单目检测,在对采集过
发表于 01-31 11:26
•1次下载
![一套<b class='flag-5'>车道</b><b class='flag-5'>线</b><b class='flag-5'>检测</b>系统](https://file.elecfans.com/web1/M00/45/96/pIYBAFpxOAeADqNOAABmrSthqW0630.jpg)
