SSD1306 OLED 屏幕模块配备 0.9 英寸迷你单色屏,128×32 分辨率,白光像素点。拥有极高的对比度,显示清晰极易辨识。OLED 仅使用树莓派的 I2C 和电源引脚,无需独立供电,即插即用。
接线
屏幕模块的 VCC 接树莓派 Pico 的 3V3 引脚
屏幕模块的 GND 接树莓派 Pico 的 GND 引脚
屏幕模块的 SDA 引脚接树莓派 Pico 的 GP14 引脚
屏幕模块的 SCL 引脚接树莓派 Pico 的 SCL 引脚
代码
这里使用开源的MicroPython ssd1306 库。将下面的代码保存在 Pico 上,命名为 ssd1306.py。
# MicroPython SSD1306 OLED driver, I2C and SPI interfaces from micropython import const import framebuf # register definitions SET_CONTRAST = const(0x81) SET_ENTIRE_ON = const(0xA4) SET_NORM_INV = const(0xA6) SET_DISP = const(0xAE) SET_MEM_ADDR = const(0x20) SET_COL_ADDR = const(0x21) SET_PAGE_ADDR = const(0x22) SET_DISP_START_LINE = const(0x40) SET_SEG_REMAP = const(0xA0) SET_MUX_RATIO = const(0xA8) SET_IREF_SELECT = const(0xAD) SET_COM_OUT_DIR = const(0xC0) SET_DISP_OFFSET = const(0xD3) SET_COM_PIN_CFG = const(0xDA) SET_DISP_CLK_DIV = const(0xD5) SET_PRECHARGE = const(0xD9) SET_VCOM_DESEL = const(0xDB) SET_CHARGE_PUMP = const(0x8D) # Subclassing FrameBuffer provides support for graphics primitives # http://docs.micropython.org/en/latest/pyboard/library/framebuf.html class SSD1306(framebuf.FrameBuffer): def __init__(self, width, height, external_vcc): self.width = width self.height = height self.external_vcc = external_vcc self.pages = self.height // 8 self.buffer = bytearray(self.pages * self.width) super().__init__(self.buffer, self.width, self.height, framebuf.MONO_VLSB) self.init_display() def init_display(self): for cmd in ( SET_DISP, # display off # address setting SET_MEM_ADDR, 0x00, # horizontal # resolution and layout SET_DISP_START_LINE, # start at line 0 SET_SEG_REMAP | 0x01, # column addr 127 mapped to SEG0 SET_MUX_RATIO, self.height - 1, SET_COM_OUT_DIR | 0x08, # scan from COM[N] to COM0 SET_DISP_OFFSET, 0x00, SET_COM_PIN_CFG, 0x02 if self.width > 2 * self.height else 0x12, # timing and driving scheme SET_DISP_CLK_DIV, 0x80, SET_PRECHARGE, 0x22 if self.external_vcc else 0xF1, SET_VCOM_DESEL, 0x30, # 0.83*Vcc # display SET_CONTRAST, 0xFF, # maximum SET_ENTIRE_ON, # output follows RAM contents SET_NORM_INV, # not inverted SET_IREF_SELECT, 0x30, # enable internal IREF during display on # charge pump SET_CHARGE_PUMP, 0x10 if self.external_vcc else 0x14, SET_DISP | 0x01, # display on ): # on self.write_cmd(cmd) self.fill(0) self.show() def poweroff(self): self.write_cmd(SET_DISP) def poweron(self): self.write_cmd(SET_DISP | 0x01) def contrast(self, contrast): self.write_cmd(SET_CONTRAST) self.write_cmd(contrast) def invert(self, invert): self.write_cmd(SET_NORM_INV | (invert & 1)) def rotate(self, rotate): self.write_cmd(SET_COM_OUT_DIR | ((rotate & 1) << 3)) self.write_cmd(SET_SEG_REMAP | (rotate & 1)) def show(self): x0 = 0 x1 = self.width - 1 if self.width != 128: # narrow displays use centred columns col_offset = (128 - self.width) // 2 x0 += col_offset x1 += col_offset self.write_cmd(SET_COL_ADDR) self.write_cmd(x0) self.write_cmd(x1) self.write_cmd(SET_PAGE_ADDR) self.write_cmd(0) self.write_cmd(self.pages - 1) self.write_data(self.buffer) class SSD1306_I2C(SSD1306): def __init__(self, width, height, i2c, addr=0x3C, external_vcc=False): self.i2c = i2c self.addr = addr self.temp = bytearray(2) self.write_list = [b"x40", None] # Co=0, D/C#=1 super().__init__(width, height, external_vcc) def write_cmd(self, cmd): self.temp[0] = 0x80 # Co=1, D/C#=0 self.temp[1] = cmd self.i2c.writeto(self.addr, self.temp) def write_data(self, buf): self.write_list[1] = buf self.i2c.writevto(self.addr, self.write_list) class SSD1306_SPI(SSD1306): def __init__(self, width, height, spi, dc, res, cs, external_vcc=False): self.rate = 10 * 1024 * 1024 dc.init(dc.OUT, value=0) res.init(res.OUT, value=0) cs.init(cs.OUT, value=1) self.spi = spi self.dc = dc self.res = res self.cs = cs import time self.res(1) time.sleep_ms(1) self.res(0) time.sleep_ms(10) self.res(1) super().__init__(width, height, external_vcc) def write_cmd(self, cmd): self.spi.init(baudrate=self.rate, polarity=0, phase=0) self.cs(1) self.dc(0) self.cs(0) self.spi.write(bytearray([cmd])) self.cs(1) def write_data(self, buf): self.spi.init(baudrate=self.rate, polarity=0, phase=0) self.cs(1) self.dc(1) self.cs(0) self.spi.write(buf) self.cs(1)
该库使用了 MicroPython 的framebuf 库。关于 framebuf 库的用法可以参考文档,也可以通过这篇文章快速了解一下「MicroPython 帧缓冲区库 framebuf 的使用方法」。
下面是示例代码,在屏幕上输出指定的信息,将代码保存在 Pico 上,命名为 main.py。
import machine
import ssd1306
i2c = machine.I2C(1, sda=machine.Pin(14), scl=machine.Pin(15), freq=400_000)
print("I2C device: " + str(i2c.scan()[0]))
oled = ssd1306.SSD1306_I2C(128, 64, i2c)
oled.text("PICO LAB", 0, 0)
oled.hline(0, 10, 128, 1)
oled.text("Hello World!", 0, 26)
oled.hline(0, 48, 128, 1)
oled.text("PICO.NXEZ.COM", 0, 52)
oled.show()
显示效果如图。
下面的示例代码来画一个树莓派 Logo 并显示在屏幕上。将代码保存在 Pico 上,命名为 main.py。
import ssd1306
import framebuf
data = [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x3E,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x07,0x00,0x00,0x00,0x7F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x80,0x03,0x80,0x00,0x01,0xF7,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0xFF,0x80,0x01,0xF8,0x00,0x0F,0x90,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xE0,0x01,0xFF,0x00,0x0E,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x01,0xF8,0x01,0xFF,0xC0,0x3C,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0xFF,0xFF,0xE1,0xE0,0x70,0x00,0x60,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x38,0x00,0xFF,0xFF,0xE0,0x70,0x70,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xFF,0xFF,0xF0,0x39,0xC0,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0xFF,0xDF,0xF0,0x1D,0xC0,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x01,0xFE,0x01,0xF8,0x0F,0x80,0x00,0x30,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xC0,0x01,0xF8,0x00,0x7C,0x0F,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x03,0xF8,0x00,0x3E,0x0F,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x07,0xF0,0x00,0x1F,0x06,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xC0,0x0F,0xE0,0x00,0x1F,0x86,0x00,0x20,0x30,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xC0,0x3F,0xE0,0x00,0x0F,0x86,0x00,0x20,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xC0,0x7F,0xE0,0x00,0x0F,0xC6,0x00,0x40,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x0F,0xF7,0x00,0xC0,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xE0,0x00,0x0F,0xFF,0x00,0x80,0x60,0x00,0x00,0x00,
0x00,0x00,0x00,0x3F,0xFF,0xFF,0xF0,0x00,0x0F,0xFF,0x01,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x39,0xFF,0x80,0xF0,0x00,0x0F,0x9F,0x83,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0xFE,0x00,0x78,0x00,0x0F,0x0F,0xC6,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xFE,0x00,0x3C,0x00,0x0E,0x07,0xFC,0x00,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0xE0,0x7C,0x00,0x1E,0x00,0x1E,0x03,0xFC,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x78,0x00,0x1F,0x00,0x3C,0x03,0xFC,0x03,0x80,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x78,0x00,0x0F,0xE0,0xFC,0x03,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x78,0x00,0x0F,0xFF,0xFC,0x01,0xFF,0xFC,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0xC0,0x78,0x00,0x0F,0xFF,0xFC,0x01,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x78,0x00,0x0F,0xFF,0xFC,0x03,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x78,0x00,0x0F,0xFF,0xFC,0x03,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x78,0x00,0x0F,0xE0,0xFC,0x03,0xFE,0x07,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0x78,0x00,0x0F,0x00,0x3C,0x03,0xFC,0x03,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x7C,0x00,0x1E,0x00,0x1E,0x07,0xF8,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x7E,0x00,0x3C,0x00,0x0E,0x07,0xFC,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0xFE,0x00,0x38,0x00,0x0F,0x0F,0xC6,0x00,0xE0,0x00,0x00,0x00,
0x00,0x00,0x00,0x38,0xFF,0x80,0xF8,0x00,0x07,0x9F,0x83,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xE3,0xF0,0x00,0x07,0xFF,0x01,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xF0,0x00,0x07,0xF7,0x00,0x80,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xE0,0xFF,0xF0,0x00,0x07,0xE7,0x00,0xC0,0x30,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xC0,0x3F,0xF0,0x00,0x0F,0x86,0x00,0x40,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xC0,0x0F,0xF0,0x00,0x0F,0x86,0x00,0x20,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x07,0xF0,0x00,0x1F,0x0E,0x00,0x20,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x03,0xF0,0x00,0x3E,0x0E,0x00,0x10,0x30,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xC0,0x01,0xF8,0x00,0x7C,0x4F,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0xFC,0x00,0xF8,0x1F,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0xFF,0x03,0xF8,0x1D,0x80,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x7F,0xFF,0xF0,0x39,0xC0,0x00,0x30,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x70,0x00,0x7F,0xFF,0xE0,0xF1,0xC0,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x7F,0xFF,0xE1,0xE0,0x70,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,0x7F,0x00,0xFF,0xC0,0x70,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x01,0xF0,0x00,0xFF,0x00,0x3C,0x00,0x60,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0xFF,0xC0,0x01,0xF8,0x00,0x0E,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0x80,0x03,0xC0,0x00,0x07,0x90,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xE0,0x07,0x80,0x00,0x01,0xF7,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x1F,0x00,0x00,0x00,0x7F,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00]
buf = framebuf.FrameBuffer(bytearray(data), 128, 64, framebuf.MONO_HLSB)
oled.blit(buf, 0, 0)
oled.show()
运行效果如图。
审核编辑:汤梓红
OLED
121文章
6370浏览量
234261 -
屏幕
7文章
1243浏览量
57221 -
引脚
16文章
2119浏览量
56009 -
树莓派
122文章
2082浏览量
110753
原文标题:树莓派 Pico 上使用 SSD1306 OLED 屏幕
文章出处:【微信号:趣无尽,微信公众号:趣无尽】欢迎添加关注!文章转载请注明出处。
SSD1306如何显示字符测试结果
SSD1306芯片介绍
OLED的SSD1306软件包上电瞬间出现花屏如何解决
【BPI-Pico-RP2040 开发板】SSD1306 OLED显示
基于SSD1306的OLED开发模块
SSD1306(OLED驱动芯片介绍)
基于树莓派的SSD1306 OLED视频播放器
SSD1306 OLED显示屏上的Arduino Flash文本
Arduino在SSD1306 OLED显示屏上随机移动文本
树莓派Pico上使用SSD1306 OLED屏幕
