作者:Frederic Descamps,MySQL 社区经理
翻译:爱可生开源社区
如您所知,MySQL 8.2 发布了最令人期待的功能之一:读写分离。
在这篇文章中,我们将了解如何将它与 MySQL-Connector/Python 一起使用。
架构
为了使用我们的 Python 程序,我们将使用 InnoDB Cluster。
以下是在 MySQL Shell 中查询 Cluster 的状态:
JS > cluster.status() { "clusterName": "fred", "defaultReplicaSet": { "name": "default", "primary": "127.0.0.1:3310", "ssl": "REQUIRED", "status": "OK", "statusText": "Cluster is ONLINE and can tolerate up to ONE failure.", "topology": { "127.0.0.1:3310": { "address": "127.0.0.1:3310", "memberRole": "PRIMARY", "mode": "R/W", "readReplicas": {}, "replicationLag": "applier_queue_applied", "role": "HA", "status": "ONLINE", "version": "8.2.0" }, "127.0.0.1:3320": { "address": "127.0.0.1:3320", "memberRole": "SECONDARY", "mode": "R/O", "readReplicas": {}, "replicationLag": "applier_queue_applied", "role": "HA", "status": "ONLINE", "version": "8.2.0" }, "127.0.0.1:3330": { "address": "127.0.0.1:3330", "memberRole": "SECONDARY", "mode": "R/O", "readReplicas": {}, "replicationLag": "applier_queue_applied", "role": "HA", "status": "ONLINE", "version": "8.2.0" } }, "topologyMode": "Single-Primary" }, "groupInformationSourceMember": "127.0.0.1:3310" } JS > cluster.listRouters() { "clusterName": "fred", "routers": { "dynabook::system": { "hostname": "dynabook", "lastCheckIn": "2023-11-09 1759", "roPort": "6447", "roXPort": "6449", "rwPort": "6446", "rwSplitPort": "6450", "rwXPort": "6448", "version": "8.2.0" } } }
MySQL Connector/Python
Python 程序使用 MySQL-Connector/Python 8.2.0。
初始化测试脚本代码:
import mysql.connector cnx = mysql.connector.connect(user='python', passowrd='Passw0rd!Python', host='127.0.0.1', port='6450') cursor = cnx.cursor() query = ("""select member_role, @@port port from performance_schema.replication_group_members where member_id=@@server_uuid""") for (role, port) in cursor: print("{} - {}".format(role, port)) cursor.close() cnx.close()
我们可以测试一下:
$ python test_router.py PRIMARY - 3310
很好,我们可以使用读 / 写分离端口(6540)连接到集群并执行查询……。哦 ?!但为什么我们会直达主实例呢?
我们不应该是去访问只读实例(副本实例)之一吗?
autocommit
Connector/Python 默认禁用自动提交(请参阅 MySQLConnection.autocommit 属性)。并且读写分离功能必须启用自动提交才能正常工作。
在第 8 行上方添加以下代码:
cnx.autocommit = True
然后我们可以再次运行该程序:
$ python test_router.py SECONDARY - 3320 $ python test_router.py SECONDARY - 3330
太棒了,达到预期效果工作!
查询属性
现在让我们看看如何在主节点上强制执行查询。
MySQL Router 提供了使用查询属性来强制执行读 / 写拆分决策的可能性:router.access_mode。
在执行查询 (cursor.execute (query) ) 之前添加以下行:
cursor.add_attribute("router.access_mode", "read_write")
让我们再执行一次:
$ python test_router.py PRIMARY - 3310router.access_mode可接受的值为:
auto
read_only
read_write
测试 DML 语句
让我们尝试一些不同的东西,我们将向表中插入行。
我们将使用下表:
CREATE TABLE `t1` ( `id` int unsigned NOT NULL AUTO_INCREMENT, `port` int DEFAULT NULL, `role` varchar(15) DEFAULT NULL, `timestamp` timestamp NULL DEFAULT CURRENT_TIMESTAMP, PRIMARY KEY (`id`) ) ENGINE=InnoDB ;
我们将使用以下 Python 脚本:
import mysql.connector cnx = mysql.connector.connect(user='python', password='Passw0rd!Python', host='127.0.0.1', port='6450', database='test') cnx.autocommit = True cursor = cnx.cursor() for i in range(3): query = ("""insert into t1 values(0, @@port, ( select member_role from performance_schema.replication_group_members where member_id=@@server_uuid), now())""") cursor.execute(query) cursor.close() cnx.close() for i in range(3): cnx = mysql.connector.connect(user='python', password='Passw0rd!Python', host='127.0.0.1', port='6450', database='test') cnx.autocommit = True cursor = cnx.cursor() query = ("""select *, @@port port_read from t1""") cursor.execute(query) for (id, port, role, timestamp, port_read) in cursor: print("{} : {}, {}, {} : read from {}".format(id, port, role, timestamp, port_read)) cursor.close() cnx.close()
让我们执行它:
$ python test_router2.py 1 : 3310, PRIMARY, 2023-11-09 1700 : read from 3330 2 : 3310, PRIMARY, 2023-11-09 1700 : read from 3330 3 : 3310, PRIMARY, 2023-11-09 1700 : read from 3330 1 : 3310, PRIMARY, 2023-11-09 1800 : read from 3320 2 : 3310, PRIMARY, 2023-11-09 1800 : read from 3320 3 : 3310, PRIMARY, 2023-11-09 1800 : read from 3320 1 : 3310, PRIMARY, 2023-11-09 1700 : read from 3330 2 : 3310, PRIMARY, 2023-11-09 1700 : read from 3330 3 : 3310, PRIMARY, 2023-11-09 1700 : read from 3330
我们可以看到没有错误,并且我们写入了主节点并从所有辅助节点读取。
请小心,如果在写入之前将router.access_mode的查询属性设置为read_only(第 16 行),您将收到错误,因为副本节点上不允许写入:
_mysql_connector.MySQLInterfaceError: The MySQL server is running with the --super-read-only option so it cannot execute this statement
事务
现在我们要玩一下事务。我们创建一个新脚本来执行多个事务:
自动提交中的读操作
事务中的读操作(默认情况下,这是读 / 写事务)
只读事务中的读操作
具有多次插入和回滚的事务
这是程序的源码:
import mysql.connector cnx = mysql.connector.connect(user='python', password='Passw0rd!Python', host='127.0.0.1', port='6450', database='test') cnx.autocommit = True cursor = cnx.cursor() query = ("""select member_role, @@port port from performance_schema.replication_group_members where member_id=@@server_uuid""") cursor.execute(query) for (role, port) in cursor: print("{} - {}".format(role, port)) cnx.start_transaction() query = ("""select member_role, @@port port from performance_schema.replication_group_members where member_id=@@server_uuid""") cursor.execute(query) for (role, port) in cursor: print("{} - {}".format(role, port)) cnx.commit() cnx.start_transaction(readonly=True) query = ("""select member_role, @@port port from performance_schema.replication_group_members where member_id=@@server_uuid""") cursor.execute(query) for (role, port) in cursor: print("{} - {}".format(role, port)) cnx.commit() cnx.start_transaction() for i in range(3): query = ("""insert into t1 values(0, @@port, ( select member_role from performance_schema.replication_group_members where member_id=@@server_uuid), now())""") cursor.execute(query) cnx.rollback() cursor.close() cnx.close()
让我们执行脚本:
$ python test_router3.py SECONDARY - 3320 PRIMARY - 3310 SECONDARY - 3320
我们可以看到,第一个操作到达了副本实例,第二个操作(即事务)到达了主节点。
只读事务到达副本节点。
对于作为我们回滚事务一部分的多次写入,我们没有收到任何错误。
结论
我们已经看到将 MySQL Connector/Python 与 MySQL 8.2 读写分离一起用于 InnoDB Cluster 是多么容易。
享受通过 MySQL Connector / Python 使用 MySQL 读写分离!
审核编辑:汤梓红
MySQL
1文章
829浏览量
26719 -
C程序
4文章
255浏览量
36103 -
python
56文章
4807浏览量
84993
原文标题:Python如何使用MySQL 8.2读写分离?
文章出处:【微信号:OSC开源社区,微信公众号:OSC开源社区】欢迎添加关注!文章转载请注明出处。
