Helm部署MinIO集群
马哥Linux运维 来源:马哥Linux运维 2023-12-03 09:44 次阅读
添加Helm仓库
[root@node1 ~]
[root@node1 ~]
[root@node1 minio]
"minio" has been added to your repositories
[root@node1 minio]
搜索并下载MinIO Chart
[root@node1 minio]
NAME            CHART VERSION   APP VERSION     DESCRIPTION
bitnami/minio   12.8.6          2023.9.16       MinIO(R) is an object storage server, compatibl...
minio/minio     8.0.10          master          High Performance, Kubernetes Native Object Storage
stable/minio    0.5.5                           Distributed object storage server built for clo...
[root@node1 minio]
[root@node1 minio]
minio-8.0.10.tgz
[root@node1 minio]
[root@node1 minio]
minio  minio-8.0.10.tgz
[root@node1 minio]
查看目录结构
[root@node1 minio]
[root@node1 minio]
Chart.yaml  ci  README.md  templates  values.yaml
创建名称空间
后面将MinIO集群部署到该名称空间下
[root@node1 ~]
namespace/minio created
创建一个Secret
[root@node1 cert]
secret/tls-ssl-minio created
[root@node1 cert]
NAME            TYPE     DATA   AGE
tls-ssl-minio   Opaque   2      10s
修改value.yaml中的一些变量值
nameOverride: ""
fullnameOverride: ""
clusterDomain: cluster.local
image:
  repository: minio/minio
  tag: RELEASE.2021-02-14T04-01-33Z
  pullPolicy: IfNotPresent
mcImage:
  repository: minio/mc
  tag: RELEASE.2021-02-14T04-28-06Z
helmKubectlJqImage:
  repository: bskim45/helm-kubectl-jq
  tag: 3.1.0
mode: distributed
additionalLabels: []
additionalAnnotations: []
extraArgs: []
DeploymentUpdate:
  type: RollingUpdate
  maxUnavailable: 0
  maxSurge: 100%
StatefulSetUpdate:
  updateStrategy: RollingUpdate
priorityClassName: ""
accessKey: "admin"
secretKey: "minio123456"
certsPath: "/etc/minio/certs/"
configPathmc: "/etc/minio/mc/"
mountPath: "/export"
existingSecret: ""
bucketRoot: ""
drivesPerNode: 1
replicas: 4
zones: 1
tls:
  enabled: false
  certSecret: ""
  publicCrt: public.crt
  privateKey: private.key
trustedCertsSecret: ""
persistence:
  enabled: true
  existingClaim: ""
  storageClass: "rook-ceph-block"
  VolumeName: ""
  accessMode: ReadWriteOnce
  subPath: ""
service:
  type: NodePort
  clusterIP: ~
  port: 9000
  nodePort: 32100
  externalIPs: []
  annotations: {}
imagePullSecrets: []
ingress:
  enabled: false
  labels: {}
  annotations: {}
  path: /
  hosts:
    - chart-example.local
  tls: []
nodeSelector: {}
tolerations: []
affinity: {}
securityContext:
  enabled: true
  runAsUser: 1000
  runAsGroup: 1000
  fsGroup: 1000
podAnnotations: {}
podLabels: {}
resources:
  requests:
    memory: 4Gi
defaultBucket:
  enabled: false
  policy: none
  purge: false
buckets: []
makeBucketJob:
  podAnnotations:
  annotations:
  securityContext:
    enabled: false
    runAsUser: 1000
    runAsGroup: 1000
    fsGroup: 1000
  resources:
    requests:
      memory: 128Mi
updatePrometheusJob:
  podAnnotations:
  annotations:
  securityContext:
    enabled: false
    runAsUser: 1000
    runAsGroup: 1000
    fsGroup: 1000
s3gateway:
  enabled: false
  replicas: 4
  serviceEndpoint: ""
  accessKey: ""
  secretKey: ""
azuregateway:
  enabled: false
  replicas: 4
gcsgateway:
  enabled: false
  replicas: 4
  gcsKeyJson: ""
  projectId: ""
nasgateway:
  enabled: false
  replicas: 4
  pv: ~
environment: {}
networkPolicy:
  enabled: false
  allowExternal: true
podDisruptionBudget:
  enabled: false
  maxUnavailable: 1
serviceAccount:
  create: true
  name:
metrics:
  serviceMonitor:
    enabled: false
    additionalLabels: {}
    relabelConfigs: {}
etcd:
  endpoints: []
  pathPrefix: ""
  corednsPathPrefix: ""
  clientCert: ""
  clientCertKey: ""
使用Helm安装
[root@node1 minio]
[root@node1 minio]
LAST DEPLOYED: Fri Sep 22 13:03:56 2023
NAMESPACE: minio
STATUS: deployed
REVISION: 1
TEST SUITE: None
NOTES:
Minio can be accessed via port 9000 on the following DNS name from within your cluster:
minio.minio.svc.cluster.local
To access Minio from localhost, run the below commands:
  1. export POD_NAME=$(kubectl get pods --namespace minio -l "release=minio" -o jsonpath="{.items[0].metadata.name}")
  2. kubectl port-forward $POD_NAME 9000 --namespace minio
Read more about port forwarding here: http://kubernetes.io/docs/user-guide/kubectl/kubectl_port-forward/
You can now access Minio server on http://localhost:9000. Follow the below steps to connect to Minio server with mc client:
  1. Download the Minio mc client - https://docs.minio.io/docs/minio-client-quickstart-guide
  2. Get the ACCESS_KEY=$(kubectl get secret minio -o jsonpath="{.data.accesskey}" | base64 --decode) and the SECRET_KEY=$(kubectl get secret minio -o jsonpath="{.data.secretkey}" | base64 --decode)
  3. mc alias set minio-local http://localhost:9000 "$ACCESS_KEY" "$SECRET_KEY" --api s3v4
  4. mc ls minio-local
Alternately, you can use your browser or the Minio SDK to access the server - https://docs.minio.io/categories/17
查看pod运行情况
[root@node1 ~]
NAME      READY   STATUS    RESTARTS   AGE
minio-0   1/1     Running   0          3m50s
minio-1   1/1     Running   0          3m50s
minio-2   1/1     Running   0          3m50s
minio-3   1/1     Running   0          3m49s
[root@node1 minio]
NAME             STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS      AGE
export-minio-0   Bound    pvc-a70a5caa-2bad-40ab-bf19-dbbfccd3d151   10Gi       RWO            rook-ceph-block   28s
export-minio-1   Bound    pvc-c3c1a8c5-d429-47e4-acf6-a57da3bacd5a   10Gi       RWO            rook-ceph-block   28s
export-minio-2   Bound    pvc-15ed67b3-7ea0-4f06-ba46-93137480066c   10Gi       RWO            rook-ceph-block   28s
export-minio-3   Bound    pvc-a58ceb7f-dac0-4ee7-9a34-473c8f336d28   10Gi       RWO            rook-ceph-block   2
8s
查看Service地址
[root@node1 ~]
NAME        TYPE        CLUSTER-IP   EXTERNAL-IP   PORT(S)          AGE
minio       NodePort    10.98.63.2           9000:32100/TCP   8m25s
minio-svc   ClusterIP   None                 9000/TCP         8m25s
登陆网页端上传文件验证
命令行方式访问测试
curl https://dl.min.io/client/mc/release/linux-amd64/mc
  --create-dirs
  -o $HOME/minio-binaries/mc
chmod +x $HOME/minio-binaries/mc
export PATH=$PATH:$HOME/minio-binaries/
[root@node1 minio]
NAME:
  mc - MinIO Client for object storage and filesystems.
USAGE:
  mc [FLAGS] COMMAND [COMMAND FLAGS | -h] [ARGUMENTS...]
COMMANDS:
  alias      manage server credentials in configuration file
  ls         list buckets and objects
  mb         make a bucket
  rb         remove a bucket
  cp         copy objects
  mv         move objects
  rm         remove object(s)
  mirror     synchronize object(s) to a remote site
  cat        display object contents
  head       display first 'n' lines of an object
  pipe       stream STDIN to an object
  find       search for objects
  sql        run sql queries on objects
  stat       show object metadata
  tree       list buckets and objects in a tree format
  du         summarize disk usage recursively
  retention  set retention for object(s)
  legalhold  manage legal hold for object(s)
  support    support related commands
  license    license related commands
  share      generate URL for temporary access to an object
  version    manage bucket versioning
  ilm        manage bucket lifecycle
  quota      manage bucket quota
  encrypt    manage bucket encryption config
  event      manage object notifications
访问MinIO中存储的文件
[root@node1 minio]
[root@node1 minio]
admin
[root@node1 minio]
[root@node1 minio]
minio123456
[root@node1 minio]
Added `my-minio` successfully.
[root@node1 minio]
[2023-09-22 1956 CST]     0B books/
[root@node1 minio]
遇到的问题
问题一
[root@node1 minio]
Error: INSTALLATION FAILED: create: failed to create: Secret "sh.helm.release.v1.minio.v1" is invalid: data: Too long: must have at most 1048576 bytes
由于我在minio chart的解压目录新创建了一个cert文件夹,并生成了一些证书文件,导致了该错误的产生
解决办法:删除除了minio Chart 包中以外的文件包括文件夹,重新执行安装。
审核编辑:汤梓红
  • 存储
  • 集群
  • 文件
原文标题:Helm部署MinIO集群
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
    MinIO的基础概念和环境部署
    MinIO Client (mc) 为 UNIX 命令(如 ls、cat、cp、mirror、diff、find 等)提供了现代替代方案。它支持文件系统和兼容 Amazon S3 的云存储服务(AWS Signature v2 和 v4)。
    的头像 发表于 08-29 10:07 3788次阅读
    使用Helm 在容器服务k8s集群一键部署wordpress
    摘要: Helm 是啥? 微服务和容器化给复杂应用部署与管理带来了极大的挑战。Helm是目前Kubernetes服务编排领域的唯一开源子项目,做为Kubernetes应用的一个包管理工具,可理解
    发表于 03-29 13:38
    Hadoop的集群环境部署说明
    或者是相同,指令多、步骤繁琐。有的时候觉得不免觉得很奇怪,这些发行商为什么不对hadoop的集群环境部署做一下优化呢?幸运的是总算是让我找到了一个hadoop发行版集群环境搭建简单易用。这里使用的是一款
    发表于 10-12 15:51
    Flink集群部署方法
    Flink集群部署详细步骤
    发表于 04-23 11:45
    如何在集群部署时实现分布式session?
    集群部署时的分布式 session 如何实现?
    发表于 07-17 06:57
    redis集群的如何部署
    redis集群部署(伪分布式)
    发表于 05-29 17:13
    Docker部署Redis服务器集群的方法
    Docker部署Redis服务器集群
    发表于 06-13 09:12
    请问鸿蒙系统上可以部署kubernetes集群吗?
    发表于 06-08 11:16
    如何部署基于Mesos的Kubernetes集群
    的内核。把Kubernetes运行在Mesos集群之上,可以和其他的框架共享集群资源,提高集群资源的利用率。 本文是Kubernetes和Mesos集成指南系列文章第一篇:实战部署
    发表于 10-09 18:04 0次下载
    如何<b class='flag-5'>部署</b>基于Mesos的Kubernetes<b class='flag-5'>集群</b>
    Helm Kubernetes包管理器
    helm.zip
    发表于 04-27 14:25 2次下载
    <b class='flag-5'>Helm</b> Kubernetes包管理器
    高性能对象存储MinIO的基本概念和环境部署
    MinIO 是在 GNU Affero 通用公共许可证 v3.0 下发布的高性能对象存储。它与 Amazon S3 云存储服务 API 兼容。使用 MinIO 为机器学习、分析和应用程序数据工作负载构建高性能基础架构。
    发表于 08-29 10:54 3280次阅读
    Kubernetes的集群部署
    Kubeadm是一种Kubernetes集群部署工具,通过kubeadm init命令创建master节点,通过 kubeadm join命令把node节点加入到集群
    的头像 发表于 02-15 10:35 1816次阅读
    如何开发一个helm chart
    使用helmfile时,我们首先得了解helm的使用,以及如何开发一个helm chart。
    的头像 发表于 05-16 09:28 724次阅读
    Helm的一些概念及用法
    应用,使用 Helm (https://helm.sh)是一个很不错的选择,它具备如下的能力: 简化部署 :Helm允许使用单个命令轻松部署
    的头像 发表于 05-30 09:51 1278次阅读
    <b class='flag-5'>Helm</b>的一些概念及用法
    请问如何使用Helm在K8s上集成Prometheus呢?
    ArtifactHub 为 Helm Chart 提供了公共和私有资源库。我们将使用这些 Helm Chart 来设置 Kubernetes 集群中的 pod 和服务。
    的头像 发表于 01-10 17:24 756次阅读
    请问如何使用<b class='flag-5'>Helm</b>在K8s上集成Prometheus呢?
