u-boot在汇编启动阶段的相关操作介绍
麦辣鸡腿堡 来源:CSDN博客 作者:内核新视界 2023-12-07 11:22 次阅读
u-boot在汇编启动阶段对系统的一些初始化
cpu交由u-boot接管进入u-boot后, 首先会到_start符号处开始执行初始化, 并在此期间完成一些必要的系统寄存器相关的初始化,包括保存boot参数进行地址无关fixed,系统寄存器复位,底层平台相关初始化等 ,启动代码位于arch/arm/cpu/armv8/start.S,入口地址为_start。
启动前为后续流程做的一些平台相关操作
从_start开始,u-boot会根据board定义做一些平台化相关的初始化工作或者是保存一些重要寄存器信息,代码如下:
 * Startup Code (reset vector)
.globl _start
_start: ------------------------------------------------------------------------ (1)
#if defined(CONFIG_LINUX_KERNEL_IMAGE_HEADER) ---------------------------------- (2)
#include < asm/boot0-linux-kernel-header.h >
#elif defined(CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK) -------------------------------- (3)
 * Various SoCs need something special and SoC-specific up front in
 * order to boot, allow them to set that in their boot0.h file and then
 * use it here.
#include < asm/arch/boot0.h >
#else
    b reset ----------------------------------------------------------------- (4)
#endif
    .align 3
.globl _TEXT_BASE ------------------------------------------------------------ (5)
_TEXT_BASE:
    .quad CONFIG_SYS_TEXT_BASE
 * These are defined in the linker script.
.globl _end_ofs -------------------------------------------------------------- (5)
_end_ofs:
    .quad _end - _start
.globl _bss_start_ofs
_bss_start_ofs:
    .quad __bss_start - _start
.globl _bss_end_ofs
_bss_end_ofs:
    .quad __bss_end - _start
reset:
    /* Allow the board to save important registers */
    b save_boot_params ----------------------------------------------------- (6)
.globl save_boot_params_ret
save_boot_params_ret:
... /* 此处省略无关代码,待分析到时再展开代码 */
WEAK(save_boot_params)
    b save_boot_params_ret /* back to my caller */
ENDPROC(save_boot_params)
#endif
  • • (1)_start段标记为全局可见并在链接脚本中被声明为入口地址,表示u-boot的入口地址为_start;
  • • (2)首先进入入口后有两种可配置情况,一种就是定义了LINUX_KERNEL_IMAGE_HEADER,boot0-linux-kernel-header.h展开部分后如下:
.macro le64sym, sym
    .long sym()_lo32
    .long sym()_hi32
    .endm
.globl _start
_start:
     * DO NOT MODIFY. Image header expected by Linux boot-loaders.
    b reset    /* branch to kernel start, magic */
    .long 0    /* reserved */
    le64sym _kernel_offset_le  /* Image load offset from start of RAM, little-endian */
    le64sym _kernel_size_le   /* Effective size of kernel image, little-endian */
    le64sym _kernel_flags_le  /* Informative flags, little-endian */
    .quad 0    /* reserved */
    .ascii "ARMx64"   /* Magic number */
此处将与在链接脚本中定义的LINUX_KERNEL_IMAGE_HEADER对应起来,为u-boot头部添加一个类似与Linux arm64 的Image头部,首先是起始8字节, 如果没有定义efi相关的功能则是一个跳转指令,跳转到reset段继续执行启动流程 ,其他如链接脚本中解释一致;
  • • (3)第二种可能的配置,就是定义了ENABLE_ARM_SOC_BOOT0_HOOK配置,此处的头文件根据不同board会引用到不同头文件,如瑞芯微的最终会引用到如下部分代码头文件:
#ifdef CONFIG_SPL_BUILD
     * We need to add 4 bytes of space for the 'RK33' at the
     * beginning of the executable.  However, as we want to keep
     * this generic and make it applicable to builds that are like
     * the RK3368 (TPL needs this, SPL doesn't) or the RK3399 (no
     * TPL, but extra space needed in the SPL), we simply insert
     * a branch-to-next-instruction-word with the expectation that
     * the first one may be overwritten, if this is the first stage
     * contained in the final image created with mkimage)...
    b 1f  /* if overwritten, entry-address is at the next word */
1:
#endif
#if CONFIG_IS_ENABLED(ROCKCHIP_EARLYRETURN_TO_BROM)
    adr     r3, entry_counter
    ldr r0, [r3]
    cmp r0, #1           /* check if entry_counter == 1 */
    beq reset            /* regular bootup */
    add     r0, #1
    str r0, [r3]         /* increment the entry_counter in memory */
    mov     r0, #0           /* return 0 to the BROM to signal 'OK' */
    bx lr               /* return control to the BROM */
entry_counter:
    .word   0
#endif
#if (defined(CONFIG_SPL_BUILD) || defined(CONFIG_ARM64))
    /* U-Boot proper of armv7 do not need this */
    b reset
#endif
#if !defined(CONFIG_ARM64)
     * For armv7, the addr '_start' will used as vector start address
     * and write to VBAR register, which needs to aligned to 0x20.
    .align(5), 0x0
_start:
    ARM_VECTORS
#endif
#if !defined(CONFIG_TPL_BUILD) && defined(CONFIG_SPL_BUILD) &&
    (CONFIG_ROCKCHIP_SPL_RESERVE_IRAM > 0)
    .space CONFIG_ROCKCHIP_SPL_RESERVE_IRAM /* space for the ATF data */
#endif
因为有些设备boot到u-boot之前已经有安全固件了,
所以此时控制权交给u-boot时,其实是可能有一些传递参数信息的要求,比如这里瑞芯微芯片通过bootrom boot到tpl后,
后续在完成tpl初始化后会将控制权再交还给bootrom固件,由bootrom固件继续加载spl,
所以这里在进行u-boot流程之前保存了bootrom的返回地址,以便后续瑞芯微板级软件使用。
定义有可能也是arm32的模式,所以还可能在入口地址处保存异常向量表;
  • • (4)如果对应board没有上述两种需求,那么_start段则是一条最简单的跳转指令b reset跳转到reset处继续启动流程初始化;
  • • (5)在_start到reset之间,有一个.align 3用于8字节对齐,因为可能在读取常量地址之前各自平台做了自己代码逻辑导致当前地址并不是8字节对齐的, 这里不管是否对齐都强制对齐了一下,之后还保存了一些常量信息,其中包括_TEXT_BASE保存了链接地址,用于在启动地址无关功能时进行对运行时地址的偏移计算,其他几个偏移值目前未使用;
  • • (6)save_boot_params用于保存一些board相关的重要寄存器,此处定义为了一个弱函数,为直接跳转回save_boot_params_ret继续往下执行,如果某些board需要保存寄存器参数则可以在自己的lowlevel.S文件中实现此函数。 一般由atf,bl2或者rom跳转到spl或u-boot时厂商可能需要在两个固件之间传递参数,比如由bl2在寄存器x0,x1,x2中分别存入了一些固件的地址信息,那么u-boot则可以在早期通过此函数保存这些信息,并在后续某个时机中使用。
  • ARM
    ARM
  • 汇编
  • Uboot
    U-Boot介绍
    移植 Linux之前我们需要先移植一个 bootloader 代码,这个 bootloader 代码用于启动 Linux 内核, bootloader有很多,常用的就是 U-Boot
    的头像 发表于 10-08 10:50 3935次阅读
    U-Boot代码执行流程详解
    U-Boot通常是从架构相关汇编文件(尾缀为大写S的汇编文件意为可链接)中获取第一条执行的指令,
    发表于 10-19 15:22 1009次阅读
    <b class='flag-5'>U-Boot</b>代码执行流程详解
    U-boot的基本介绍
    从本文开始,将陆续推送“手把手教你移植U-boot”系列文章,目标是由浅入深地讲解U-boot的工作流程、原理、配置方法和移植方法,手把手教你完成U-boot的移植工作,默认硬件开发平台为ARM,
    发表于 07-14 16:52 2759次阅读
    <b class='flag-5'>U-boot</b>的基本<b class='flag-5'>介绍</b>
    U-BOOT启动流程分享
    Bootloader移植(下)U-BOOT 启动流程u-boot启动三个2启动步骤(重点)U-boot
    发表于 01-18 10:17
    U-Boot启动及移植分析
    bootloader 开发是嵌入式系统必不可少而且十分重要的部分,U-Boot 为功能强大的bootloader 开发软件。本文详细分析了U-Boot启动流程,并结合其源码,阐述了U-Bo
    发表于 09-01 16:34 27次下载
    嵌入式U-BOOT启动流程及移植
    摘要:嵌入式系统一般没有通用的bootloader,u-boot是功能强大的bootloader开发软件,但相对也比较复杂。文中对u-boot启动流程作了介绍,详细给出了
    发表于 02-25 16:00 59次下载
    基于ARM9的U-Boot自动识别启动实现
    嵌入式ARM9系列处理器支持U-Boot从Nor FLASH或者Nand FLASH启动,也支持U-Boot直接下载到内存中调试运行,根据U-Boot
    发表于 03-04 16:23 91次下载
    基于ARM9的<b class='flag-5'>U-Boot</b>自动识别<b class='flag-5'>启动</b>实现
    u-boot简介
    U-Boot是BootLoader的一种,是操作系统内核运行之前运行。可以初始化硬件设备、建立内存空间映射图,从而将系统的软硬件环境带到一个
    发表于 10-14 11:17 3538次阅读
    fireflyFace-RK3399主板U-Boot模式启动
    RK U-Boot 基于开源的 U-Boot 进行开发,工作模式有启动加载模式和下载模式。
    的头像 发表于 12-04 08:52 4480次阅读
    fireflyFace-RK3399主板<b class='flag-5'>U-Boot</b>模式<b class='flag-5'>启动</b>
    fireflyAIO-3399C主板U-Boot介绍
    的头像 发表于 12-04 10:31 1411次阅读
    fireflyAIO-3288C主板U-Boot介绍
    的头像 发表于 12-16 13:52 1129次阅读
    fireflyAIO-3288C主板<b class='flag-5'>U-Boot</b><b class='flag-5'>介绍</b>
    fireflyAIO-3288J主板U-Boot使用简介
    的头像 发表于 12-20 10:06 1533次阅读
    fireflyAIO-3288J主板<b class='flag-5'>U-Boot</b>使用简介
    fireflyAIO-3399J主板U-Boot使用介绍
    的头像 发表于 12-24 10:00 1610次阅读
    fireflyAIO-3399J主板<b class='flag-5'>U-Boot</b>使用<b class='flag-5'>介绍</b>
    U-Boot启动内核的工作过程详细说明
    U-Boot 启动内核的过程可以分为两个阶段,两个阶段的功能如下:(1)第一阶段的功能 硬件设备初始化 加载
    发表于 12-28 08:00 3次下载
    <b class='flag-5'>U-Boot</b><b class='flag-5'>启动</b>内核的工作过程详细说明
    u-boot中使用ethernet的方法
    KV260 petalinux BSPu-boot device tree中disable了GEM3,也就是说ethernetu-boot中不建议使用ethernet。
    的头像 发表于 07-21 10:25 3841次阅读
