DshanMCU-R128s2芯片简介
weidongshan 来源:weidongshan 作者:weidongshan 2023-12-22 09:55 次阅读
芯片简介
R128是一颗专为“音视频解码”而打造的全新高集成度 SoC,主要应用于智能物联和专用语音交互处理解决方案。
单片集成 MCU+RISCV+DSP+CODEC+WIFI/BT+PMU,提供生态配套成熟、完善的用于系统、应用和网络连接开发的高效算力;
集成 8MB/16MB/32MB PSRAM,为音视频解码、大容量存储、扫码以及网络连接提供充裕的高容量、高带宽的内存支持;
拥有丰富的音频接口 IIS/PCM、OWA、DMIC、LINEOUT、MICIN 以及通用通讯接口 IIC、UARTSDIO、 SPI、ISO7816卡接口;同时支持 U 盘、SD卡、IR-TX/RX;
内置 LDO、GPADCLEDC,简化系统方案设计,降低 BOM成本。
芯片应用场景
芯片实物图
芯片框图
芯片特性简介
- XuanTie 64 bit RISC V C 906 CPU , up to 480 MHz
- HiFi5 Audio DSP up to 400 MHz
- Arm M33 Star MCU , up to 192 MHz
- Memories
  - 1MB SRAM
  - SiP 8 MB/16 MB Flash
  - 8 MB H S PSRAM in R128 S 1
  - 8 MB LS PSRAM & 8 MB HS PSRAM in R128 S2
  - 32 MB HS PSRAM in R128 S3
  - 2048 bit efuse
- Image and Graphics
  - Supports Graphic 2D accelerator with rotate, mixer, and 4 layers
  - Supports RGB output interface, up to 1024 x 768 @60 fps
  - Supports display engine
- Video Input
  - 8 bit parallel CSI interface
  - Supports both online and offline mode for JPEG encoder
  - Supports JPEG encoder, 1920 x 108 8
- Analog Audio Codec
  - 2 DAC channels 24 bit audio codec for R128 S1 and R128 S2
  - 1 DAC channel 24 bit for R128 S3
  - 3 ADC channels
  - Supports USB audio playback
  - Up to 119 dB SNR during DAC playback path (signal through DAC and lineout with A weighted filter)
  - Up to 98 dB SNR during ADC record path (signal through PGA and ADC with A weighted filter)
- One I2S/TDM/PCM external inte rface (I2S0
- Security Engine
  - Symmetrical algorithm: AES, DES, 3DES
  - Hash algorithm: MD5, SHA1, SHA224, SHA256, SHA384, SHA512, HMAC
  - Asymmetrical algorithm: RSA512/1024/2048bit
  - S upports TRNG
- External Peripherals
  - One USB 2.0 DRD
  - Up to 3 UART controllers (UART 0, UART1, UART2)
  - Up to 2 SPI controllers (SPI0, SPI1)
  - Up to 2 TWIs
  - One CIR RX and one CIR TX
  - Up to 8 PWM channels (PWM[ 7 0
  - Up to 7 GPADC input channels (R128 S1 & R128 S2)/8 channels (R128 S3)
  - One LEDC used to control the external intelligent control LED lamp
- Package
  - QFN80, 0.35 mm pitch, 8 mm x 8 mm body
不同版本芯片的区别
R128 共有R128-S1、R128-S2 和R128-S3 三个型号,各型号具体配置差异如下表:
Contents R128-S1 R128-S2 R128-S3
CPU M33 + C906 M33 + C906 M33 + C906
DSP HiFi5 HiFi5 HiFi5
PSRAM 8MB HS-PSRAM 8MB HS-PSRAM + 8MB LS-PSRAM 32MB HS-PSRAM
FLASH 8MB 16MB /
DAC 2 Audio DAC
LINEOUTLP/N
LINEOUTRP/N
2 Audio DAC
LINEOUTLP/N
LINEOUTRP/N
1 Audio DAC
LINEOUTLP/N
GPADC Channels 7 7 8
Package QFN80 8*8mm 0.35pitch QFN80 8*8mm 0.35pitch QFN80 8*8mm 0.35pitch
请注意,R128-S1、R128-S2引脚封装是相同的,而 R128-S3 与R128-S1、R128-S2是不同的。具体请参照芯片参数章节
审核编辑:汤梓红
  • 芯片
  • mcu
    mcu
  • soc
    soc
  • 硬件开发
    DshanMCU-R128s2-DEVKIT应用开发案例
    本文章为DshanMCU-R128s2-DEVKIT应用开发案例,本文案例(点亮一颗 LED 灯)代码可以到全志在线-在线文档或者复制链接前往下载。
    的头像 发表于 09-28 16:26 858次阅读
    <b class='flag-5'>DshanMCU-R128s2</b>-DEVKIT应用开发案例
    基于DShanMCU-R128s2-DevKit开发智能手表
    本项目基于DShanMCU-R128s2-DevKit开发,用意是提供一个综合的示例进行学习参考。
    的头像 发表于 11-01 15:32 784次阅读
    基于<b class='flag-5'>DShanMCU-R128s2</b>-DevKit开发智能手表
    DshanMCU-R128s2全志R128视频教程
    基于DShanMCU-R128S2_DevKit的入门教程
    的头像 发表于 12-26 14:05 594次阅读
    DshanMCU-R128s2芯片参数
    MB LS PSRAM R128 S2)/8 channels (R128 S3) - One LEDC used to control the external intellige
    的头像 发表于 12-26 10:57 1073次阅读
    DshanMCU-R128s2芯片手册与资料
    : Xplorer Software (SDK) Download Xtensa Xplorer 授权申请: Cadence Tensilica Offerings Xtensa Xplorer 试用申请: request an evaluation license 其余手册将在R128
    的头像 发表于 12-26 11:02 763次阅读
    DshanMCU-R128s2 R128 模组
    R128-S2-N16R16 R128-S2 Arm Cortex-M33 C906 RISC-V HIFI5 DSP 1MByte 8Mbyte 8Mbyte 16M NOR Flash 2 Audio
    的头像 发表于 12-26 11:11 1038次阅读
    <b class='flag-5'>DshanMCU-R128s2</b> <b class='flag-5'>R128</b> 模组
    DshanMCU-R128s2 R128 DevKit 开发板
    针对 R128 模组,百问科技推出了 R128 DevKit 开发板作为快速开发评估工具。 特性: 板载 R128-S2-N16R16 模组 板载 2.4G RF 陶瓷天线 板载 USB Type
    的头像 发表于 12-22 12:02 618次阅读
    <b class='flag-5'>DshanMCU-R128s2</b> <b class='flag-5'>R128</b> DevKit 开发板
    DshanMCU-R128s2 R128 EVT 开发套件
    针对 R128 模组,百问科技推出了 R128 EVT 开发套件作为快速开发评估工具。
    的头像 发表于 12-22 15:16 776次阅读
    <b class='flag-5'>DshanMCU-R128s2</b> <b class='flag-5'>R128</b> EVT 开发套件
    DshanMCU-R128s2 SDK 架构与目录结构
    R128 S2 是全志提供的一款 M33(ARM)+C906(RISCV-64)+HIFI5(Xtensa) 三核异构 SoC,同时芯片内部 SIP 有 1M SRAM、8M LSPSRAM、8M
    的头像 发表于 12-22 15:57 738次阅读
    <b class='flag-5'>DshanMCU-R128s2</b> SDK 架构与目录结构
    DshanMCU-R128s2 Hello World!
    载入方案选择 r128s2_module_c906 $ source envsetup.sh $ lunch_rtos 1 编辑程序 打开你喜欢的编辑器,修改文件: lichee/rtos
    的头像 发表于 12-22 17:24 601次阅读
    <b class='flag-5'>DshanMCU-R128s2</b> Hello World!
    DshanMCU-R128s2 配置引脚复用
    解析 sys_config.fex 的驱动配置位于 licheertos-componentsawsys_config_script 中。 对于配置引脚复用,只需要修改 boardr128s2{PROJECT}configsys_config.fex 文件即可。 GPIO描述
    的头像 发表于 12-22 17:36 660次阅读
    DshanMCU-R128s2启动与资源划分
    下面简单介绍一下 R128 方案的资源划分与启动流程。 资源划分 CPU 资源划分 这只是默认配置方案,CPU 资源划分可以按照需求任意修改 CPU 功能说明 M33 控制核。运行 WI-FI/BT
    的头像 发表于 12-22 17:46 656次阅读
    <b class='flag-5'>DshanMCU-R128s2</b>启动与资源划分
    DshanMCU-R128s2硬件设计指南
    原理图设计 硬件系统框图 R128是一颗专为“音视频解码”而打造的全新高集成度 SoC,主要应用于智能物联和专用语音交互处理解决方案。 单片集成 MCU+RISCV+DSP+CODEC+WIFI
    的头像 发表于 12-25 09:41 840次阅读
    <b class='flag-5'>DshanMCU-R128s2</b>硬件设计指南
    DshanMCU-R128s2硬件设计参考
    R128 DevKit 开发板 硬件工程开源地址:https://oshwhub.com/gloomyghost/r128-module 电路图
    的头像 发表于 12-26 09:46 978次阅读
    DshanMCU-R128s2术语表
    M33+C906+HIFI5 处理器的 SoC 平台 AudioCodec 芯片内置音频接口 I2S/PCM 外置数字音频接口,常用于外接codec 模块。 AHUB 音频集线器,内部集成I2S 接口及DAM 混音器,可实现多
    的头像 发表于 12-25 10:07 617次阅读
