芯片特性
- XuanTie 64 bit RISC V C 906 CPU , up to 480 MHz
- HiFi5 Audio DSP up to 400 MHz
- Arm M33 Star MCU , up to 192 MHz
- Memories
- 1MB SRAM
- SiP 8 MB/16 MB Flash
- 8 MB H S PSRAM in R128 S 1
- 8 MB LS PSRAM & 8 MB HS PSRAM in R128 S2
- 32 MB HS PSRAM in R128 S3
- 2048 bit efuse
- Image and Graphics
- Supports Graphic 2D accelerator with rotate, mixer, and 4 layers
- Supports RGB output interface, up to 1024 x 768 @60 fps
- Supports display engine
- Video Input
- 8 bit parallel CSI interface
- Supports both online and offline mode for JPEG encoder
- Supports JPEG encoder, 1920 x 108 8
- Analog Audio Codec
- 2 DAC channels 24 bit audio codec for R128 S1 and R128 S2
- 1 DAC channel 24 bit for R128 S3
- 3 ADC channels
- Supports USB audio playback
- Up to 119 dB SNR during DAC playback path (signal through DAC and lineout with A weighted filter)
- Up to 98 dB SNR during ADC record path (signal through PGA and ADC with A weighted filter)
- One I2S/TDM/PCM external inte rface (I2S0
- Security Engine
- Symmetrical algorithm: AES, DES, 3DES
- Hash algorithm: MD5, SHA1, SHA224, SHA256, SHA384, SHA512, HMAC
- Asymmetrical algorithm: RSA512/1024/2048bit
- S upports TRNG
- External Peripherals
- One USB 2.0 DRD
- Up to 3 UART controllers (UART 0, UART1, UART2)
- Up to 2 SPI controllers (SPI0, SPI1)
- Up to 2 TWIs
- One CIR RX and one CIR TX
- Up to 8 PWM channels (PWM[ 7 0
- Up to 7 GPADC input channels (R128 S1 & R128 S2)/8 channels (R128 S3)
- One LEDC used to control the external intelligent control LED lamp
- Package
- QFN80, 0.35 mm pitch, 8 mm x 8 mm body
GPIO 复用
Pin Name | GPIO Group | IO Type | Function 2 | Function 3 | Function 4 | Function 5 | Function6 | Function7 | Function8 | Function 14 |
PA0 | GPIOA | I/O | IR-RX | PWM7 | TWI0-SCL | TWI1-SCL | LCD-VSYNC | LCD-D2 | PA-EINT0 | |
PA1/FEL0 | GPIOA | I/O | IR-TX | FEM-CTRL1 | IR-RX | TWI0-SDA | TWI1-SDA | LCD-D3 | PA-EINT1 | |
PA2/FEL1 | GPIOA | I/O | SPI1-CS | DMIC-DATA0 | JTAG-RV-TMS | SDC-DATA1 | I2S-LRCLK | JTAG-DSP-TMS | LCD-D4 | PA-EINT2 |
PA3 | GPIOA | I/O | SPI1-CLK | DMIC-DATA1 | JTAG-RV-TDI | SDC-DATA0 | I2S-BCLK | JTAG-DSP-TDI | LCD-D5 | PA-EINT3 |
PA4 | GPIOA | I/O | SPI1-MOSI | DMIC-DATA2 | UART0-TX | SDC-CLK | I2S-DIN | PWM1 | LCD-D6 | PA-EINT4 |
PA5 | GPIOA | I/O | SPI1-MISO | DMIC-DATA3 | JTAG-RV-TDO | SDC-CMD | I2S-DOUT | JTAG-DSP-TDO | LCD-D7 | PA-EINT5 |
PA6 | GPIOA | I/O | SPI1-HOLD | DMIC-CLK | UART0-RX | SDC-DATA3 | I2S-MCLK | LCD-CLK | LCD-D14 | PA-EINT6 |
PA7 | GPIOA | I/O | SPI1-WP | OWA-IN | JTAG-RV-TCK | SDC-DATA2 | JTAG-DSP-TCK | LCD-HSYNC | LCD-D13 | PA-EINT7 |
PA8 | GPIOA | I/O | UART0-RX | OWA-OUT | PWM0 | OWA-IN | TWI1-SCL | FEM-CTRL2 | LCD-D12 | PA-EINT8 |
PA9 | GPIOA | I/O | UART0-TX | PWM1 | LEDC | TWI1-SDA | LCD-DE | LCD-D15 | PA-EINT9 | |
PA10 | GPIOA | I/O | UART2-RTS | IR-RX | PWM2 | TWI1-SCL | LCD-D11 | PA-EINT10 | ||
PA11/WUPIO0 | GPIOA | I/O | UART2-CTS | IR-TX | PWM3 | TWI1-SDA | 32KOSCO | FEM-CTRL1 | LCD-D10 | PA-EINT11 |
PA12/WUPIO1/ LXTAL-IN | GPIOA | I/O | UART2-TX | TWI0-SCL | UART2-RTS | IR-RX | SPI1-CS/DBI-CSX | LCD-VSYNC | LCD-D18 | PA-EINT12 |
PA13/WUPIO2/ LXTAL-OUT | GPIOA | I/O | UART2-RX | TWI0-SDA | UART2-CTS | IR-TX | SPI1-CLK/DBI-SCLK | LEDC | LCD-D19 | PA-EINT13 |
PA14/WUPIO3 | GPIOA | I/O | PWM0 | SPI1-MOSI | UART2-RX | SIM-DATA | UART1-RTS | TWI1-SCL | LCD-D20 | PA-EINT14 |
PA15 | GPIOA | I/O | PWM1 | SPI1-HOLD | UART2-TX | SIM-CLK | UART1-CTS | TWI1-SDA | LCD-D21 | PA-EINT15 |
PA16 | GPIOA | I/O | TWI0-SCL | OWA-IN | TWI1-SCL | UART0-TX | IR-RX | UART2-TX | SWD-TMS | PA-EINT16 |
PA17 | GPIOA | I/O | TWI0-SDA | OWA-OUT | TWI1-SDA | UART0-RX | IR-TX | UART2-RX | SWD-TCK | PA-EINT17 |
PA18/WUPIO4 | GPIOA | I/O | I2S-MCLK | IR-RX | IR-TX | SPI1-MOSI | NCSI-HSYNC | LCD-VSYNC | PA-EINT18 | |
PA19/WUPIO5 | GPIOA | I/O | I2S-LRCLK | UART1-RTS | PWM4 | DMIC-DATA0 | SPI1-HOLD | NCSI-VSYNC | LCD-HSYNC | PA-EINT19 |
PA20/WUPIO6 | GPIOA | I/O | I2S-BCLK | UART1-CTS | PWM5 | DMIC-DATA1 | SPI1-WP | NCSI-PCLK | LCD-CLK | PA-EINT20 |
PA21/WUPIO7 | GPIOA | I/O | I2S-DIN | UART1-RX | PWM6 | DMIC-DATA2 | SPI1-MISO | NCSI-MCLK | LCD-DE | PA-EINT21 |
PA22/WUPIO8 | GPIOA | I/O | I2S-DOUT | UART1-TX | PWM7 | DMIC-DATA3 | LEDC | NCSI-D0 | PA-EINT22 | |
PA23/WUPIO9 | GPIOA | I/O | I2S-MCLK | DCXO-PUP-OUT | SWD-SWO | DMIC-CLK | TWI0-SCL | PWM0 | NCSI-D1 | PA-EINT23 |
PA24 | GPIOA | I/O | SDC-DATA3 | SPI0-MISO | PWM4 | UART2-RX | TWI0-SDA | SIM-DATA | NCSI-D6 | PA-EINT24 |
PA25 | GPIOA | I/O | SDC-CMD | SPI0-WP | PWM5 | JTAG-M33-TDO | JTAG-RV-TDO | SIM-CLK | NCSI-D5 | PA-EINT25 |
PA26 | GPIOA | I/O | SDC-DATA0 | SPI0-CLK | PWM6 | JTAG-M33-TDI | JTAG-RV-TDI | LEDC | NCSI-D3 | PA-EINT26 |
PA27 | GPIOA | I/O | SDC-DATA1 | SPI0-HOLD | PWM7 | JTAG-M33-TMS | JTAG-RV-TMS | SIM-DET | NCSI-D2 | PA-EINT27 |
PA28 | GPIOA | I/O | SDC-DATA2 | SPI0-CS | FEM-CTRL1 | JTAG-M33-TCK | JTAG-RV-TCK | SIM-RST | NCSI-D7 | PA-EINT28 |
PA29 | GPIOA | I/O | SDC-CLK | SPI0-MOSI | FEM-CTRL2 | UART2-TX | PWM1 | LEDC | NCSI-D4 | PA-EINT29 |
For R128-S1/S2
PB0/ADC0 | GPIOB | I/O | UART0-TX | TWI1-SCL | IR-RX | UART2-RTS | PWM2 | NCSI-HSYNC | PB-EINT0 | |
PB1/ADC1 | GPIOB | I/O | UART0-RX | TWI1-SDA | IR-TX | UART2-CTS | PWM3 | NCSI-VSYNC | PB-EINT1 | |
PB2/ADC2 | GPIOB | I/O | PWM2 | SPI1-MISO | TWI1-SCL | SIM-RST | UART1-RX | UART2-RTS | LCD-D23 | PB-EINT2 |
PB3/ADC3 | GPIOB | I/O | PWM3 | SPI1-WP | TWI1-SDA | SIM-DET | UART1-TX | UART2-CTS | LCD-D22 | PB-EINT3 |
PB4/ADC4 | GPIOB | I/O | PWM4 | LCD-DE | PB-EINT4 | |||||
PB14/ADC6 | GPIOB | I/O | UART1-TX | NCSI-PCLK | PB-EINT14 | |||||
PB15/ADC7 | GPIOB | I/O | UART1-RX | PWM0 | NCSI-MCLK | PB-EINT15 |
For R128-S3
PB4/ADC4 | GPIOB | I/O | UART1-RTS | SDC-CLK | SPI0-CS | PWM4 | LCD-DE | PB-EINT4 | ||
PB5/ADC5 | GPIOB | I/O | UART1-CTS | SDC-DATA1 | SPI0-MOSI | PWM5 | PB-EINT5 | |||
PB6 | GPIOB | I/O | UART1-TX | SDC-DATA0 | SPI0-CLK | PWM6 | PB-EINT6 | |||
PB7 | GPIOB | I/O | UART1-RX | SDC-DATA3 | SPI0-HOLD | PWM7 | PB-EINT7 | |||
PB14/ADC6 | GPIOB | I/O | UART1-TX | SDC-DATA2 | SPI0-WP | NCSI-PCLK | PB-EINT14 | |||
PB15/ADC7 | GPIOB | I/O | UART1-RX | SDC-CMD | SPI0-MISO | PWM0 | NCSI-MCLK | PB-EINT15 |
信号描述
Signal Name | Description | Type |
HS-PSRAM PHY IO | ||
VDD12-PSM | Power Supply of PSRAM | P |
RF0 | ||
ANT0 | Antenna of RF0 | A |
HXTAL-IN | Digital Compensated Crystal Oscillator Input | AI |
HXTAL-OUT | Digital Compensated Crystal Oscillator Output | AO |
VCC33-RFPA0 | Power Supply of RF0 Input | P |
VCC18-TX0 | Power Supply of RF0 Input | P |
VCC18-ANA0 | Power Supply of RF0 Analog/RF Input | P |
Note: HXTAL is the system clock of the whole chip, which includes the clocks required by the RF module and other modules. | ||
RF1 | ||
ANT1 | Antenna of RF1 | A |
VCC33-RFPA1 | Power Supply of RF1 Input | P |
VDD18-TX1 | Power Supply of RF1 Input | P |
VCC18-ANA1 | Power Supply of RF1 Analog/RF Input | P |
PMU | ||
VIN-VBAT | VBAT System Power Input | P |
VDD-RTC | RTC Power | P |
VDD-AON | VDD-AON Power Supply of AON Domain | P |
VDD-DSP | VDD-DSP Power Supply of DSP | P |
LX | Power Supply of DCDC Output | P |
EXT-LDO33 | VDD-3V3 Power Output of 3.3V | P |
VDD-SENSE | Power Supply of Internal LDO Input | P |
VDD-SYS | Power Supply for System | P |
RESET | ||
CHIP-PWD | System Power on Reset | I |
RSTN | System Reset | I |
USB | ||
VC33-USB | Power Supply of USB | P |
USB-DM | USB Data Signal DM | A I/O |
USB-DP | USB Data Signal DP | A I/O |
Audio Codec | ||
MBIAS | Master Analog Microphone Bias Voltage Output | AO |
MICIN1P | Microphone Positive Input 1 | AI |
MICIN1N | Microphone Negative Input 1 | AI |
MICIN2P | Microphone Positive Input 2 | AI |
MICIN2N | Microphone Negative Input 2 | AI |
MICIN3P | Microphone Positive Input 3 | AI |
MICIN3N | Microphone Negative Input 3 | AI |
VRA1 | Reference Voltage | AO |
VRA2 | Reference Voltage | AO |
AGND | Analog Ground | G |
AVCC | Power Supply for Analog Part | P |
LOUTRN | Stereo Lineout Output Right Negative Channel | AO |
LOUTRP | Stereo Lineout Output Right Positive Channel | AO |
LOUTLP | Stereo Lineout Output Left Positive Channel | AO |
LOUTLN | Stereo Lineout Output Left Negative Channel | AO |
Power | ||
VCC-IO1 | Power Supply of IO1 Domain | P |
VCC-IO2 | Power Supply of IO2 Domain | P |
CIR Receiver | ||
IR-RX | Consumer Infrared Receiver | I/O |
CIR Transmitter | ||
IR-TX | Consumer Infrared Transmitter | I/O |
SPI | ||
SPI0-CS | SPI0 Chip Select Signal, Low Active | I/O |
SPI0-CLK | SPI0 Clock Signal | I/O |
SPI0-MOSI | SPI0 Master Data Out, Slave Data In | I/O |
SPI0-MISO | SPI0 Master Data In, Slave Data Out | I/O |
SPI0-WP | SPI0 Write Protect, Low Active | I/O |
SPI0-HOLD | SPI0 Hold Signal | I/O |
SPI1-CS | SPI1 Chip Select Signal, Low Active/Chip Select Signal, Low Active | I/O |
SPI1-CLK | SPI1 Clock Signal/Serial Clock Signal | I/O |
SPI1-MOSI | SPI1 Master Data Out, Slave Data In/Data Output Signal | I/O |
SPI1-MISO | SPI1 Master Data In, Slave Data Out/Data Input Signal/Tearing Effect Input/DCX pin is the select output signal of data and command | I/O |
SPI1-HOLD | SPI1 Hold Signal/ DCX pin is the select output signal of data and command/When DBI operates in dual data lane format, the RGB666 format 2 can use WRX to transfer data | I/O |
SPI1-WP | SPI1 Write Protect, Low Active/ Tearing Effect Input | I/O |
UART | ||
UART0-RX | UART0 Data Receive | I/O |
UART0-TX | UART0 Data Transmit | I/O |
UART1-RTS | UART1 Data Request to Send | I/O |
UART1-CTS | UART1 Data Clear to Send | I/O |
UART1-RX | UART1 Data Receive | I/O |
UART1-TX | UART1 Data Transmit | I/O |
UART2-RTS | UART2 Data Request to Send | I/O |
UART2-CTS | UART2 Data Clear to Send | I/O |
UART2-RX | UART2 Data Receive | I/O |
UART2-TX | UART2 Data Transmit | I/O |
PWM | ||
PWM[7:0] | Pulse Width Modulation Output Channel0 | I/O |
TWI | ||
TWI0-SCL | TWI0 Serial CLOCK Signal | I/O |
TWI0-SDA | TWI0 Serial Data Signal | I/O |
TWI1-SCL | TWI1 Serial CLOCK Signal | I/O |
TWI1-SDA | TWI1 Serial Data Signal | I/O |
I2S | ||
I2S-LRCLK | I2S sample rate clock | I/O |
I2S-BCLK | I2S Bit Rate Clock | I/O |
I2S-DIN | I2S Serial Data Input | I/O |
I2S-DOUT | I2S Serial Data Input | I/O |
I2S-MCLK | I2S Master Clock | I/O |
SDIO | ||
SDC-CMD | SDIO Command Signal | I/O |
SDC-DATA[3:0] | SDIO data Signal | I/O |
SDC-CLK | SDIO clock Signal | I/O |
DMIC | ||
DMIC-DATA[3:0] | Digital MIC Data input signal | I/O |
DMIC-CLK | Digital Microphone Clock Output | I/O |
OWA | ||
OWA-IN | One Wire Audio Input | I/O |
OWA-OUT | One Wire Audio Output | I/O |
JTAG | ||
JTAG-RV-TMS | RISC-V JTAG TMS signal | I/O |
JTAG-DSP-TMS | DSP JTAG TMS signal | I/O |
JTAG-RV-TDI | RISC-V JTAG TDI signal | I/O |
JTAG-DSP-TDI | DSP JTAG TDI signal | I/O |
JTAG-RV-TDO | RISC-V JTAG TDO signal | I/O |
JTAG-DSP-TDO | DSP JTAG TDO signal | I/O |
JTAG-RV-TCK | RISC-V JTAG TCK signal | I/O |
JTAG-DSP-TCK | DSP JTAG TDO signal | I/O |
JTAG-M-TDO | ARM M33 JTAG TDO signal | I/O |
JTAG-M-TDI | ARM M33 JTAG TDI signal | I/O |
JTAG-M-TMS | ARM M33 JTAG TMS signal | I/O |
JTAG-M-TCK | ARM M33 JTAG TCK signal | I/O |
SWD | ||
SWD-SWO | Serial Wire Debug data signal | I/O |
SWD-TMS | Serial Wire Debug TMS signal | I/O |
SWD-TCK | Serial Wire Debug clock signal | I/O |
System | ||
FEM-CTRL1 | Front End Module Control, TX-EN | I/O |
FEM-CTRL2 | Front End Module Control, RX-EN | I/O |
SIM-DATA | Smart Card data signal | I/O |
SIM-CLK | Smart Card clock signal | I/O |
SIM-DET | Smart Card detect signal | I/O |
SIM-RST | Smart Card reset signal | I/O |
DCXO | ||
DCXO-PUP-OUT | Power Control of External DCDC | I/O |
LEDC | ||
LEDC | Intelligent control LED signal output | I/O |
CLOCK | ||
32KOSCO | 32.768K clock fanout | I/O |
LCD | ||
LCD-VSYNC | LCD Vertical Sync | I/O |
LCD-D[7:2] | LCD Data Output | I/O |
LCD-D[15:10] | LCD Data Output | I/O |
LCD-D[23:18] | LCD Data Output | I/O |
LCD-CLK | LCD CLOCK | I/O |
LCD-HSYNC | LCD Horizontal Sync | I/O |
LCD-DE | LCD Data Output Enable | I/O |
NCSI | ||
NCSI-HSYNC | DVP-CSI Horizontal Sync signal | I/O |
NCSI-VSYNC | DVP-CSI Vertical Sync signal | I/O |
NCSI-PCLK | DVP-CSI pixel clock signal | I/O |
NCSI-MCLK | DVP-CSI master clock signal | I/O |
NCSI-D[7:0] | DVP-CSI data signal[7:0] | I/O |
Interrupt | ||
PA_EINT[29:0] | GPIO A Interrupt | I/O |
PB_EINT[4:0] | GPIO B Interrupt | I/O |
PB_EINT[15:14] | GPIO B Interrupt | I/O |
R128-S1/R128-S2 与 R128-S3 的引脚区别
Ball Number | R128-S1/R128-S2 Pin | R128-S3 Pin |
19 | RSTN | VIN-VBAT |
20 | VIN-VBAT | LX |
21 | LX | VDD-SENSE |
22 | VDD-SENSE | VCC33-USB |
23 | VCC33-USB | USB-DM |
24 | USB-DM | USB-DP |
25 | USB-DP | VDD-SYS |
26 | VDD-SYS | VDD12-PSM |
27 | VDD12-PSM | PA16 |
28 | PA16 | PA17 |
29 | PA17 | PA15 |
30 | PA15 | PA27 |
31 | PA27 | PA26 |
32 | PA26 | PA29 |
33 | PA29 | PA25 |
34 | PA25 | PA24 |
35 | PA24 | PA28 |
36 | PA28 | PB7 |
39 | PB14/ADC6 | PB6 |
40 | PB15/ADC7 | PB5/ADC5 |
41 | PB1/ADC1 | PB14/ADC6 |
42 | PB0/ADC0 | PB15/ADC7 |
43 | PB4/ADC4 | PB0/ADC0 |
44 | VDD-SYS | PB1/ADC1 |
45 | VCC-IO1 | PB4/ADC4 |
46 | MBIAS | VDD-SYS |
47 | MICIN1P | VCC-IO1 |
48 | MICIN1N | MBIAS |
49 | MICIN2P | MICIN1P |
50 | MICIN2N | MICIN1N |
51 | MICIN3P | MICIN2P |
52 | MICIN3N | MICIN2N |
53 | VRA1 | MICIN3P |
54 | VRA2 | MICIN3N |
55 | AGND | VRA1 |
56 | AVCC | VRA2 |
57 | LOUTLN | AGND |
58 | LOUTLP | AVCC |
59 | LOUTRP | LOUTLN |
60 | LOUTRN | LOUTLP |
举报投诉
R128
41浏览量
148
ADC128S022的驱动架构参考 ti-adc128s052.c,要如何做移位生成12bit结果呢?
ADC128S022的驱动架构参考 ti-adc128s052.c, 具体如下图所示。
上层读取buf[1], buf[2]请问要如何做移位生成12bit结果呢?
发表于 12-16 06:32
求助,关于ADC128S102的采样速率问题求解
现采用ADC128S102采集温度电压,该芯片的采样速率在500ksps-1Msps。问题(1)一般ADC采样速率从0开始,使用时只要不超过最高采样率都可以使用,不明白该芯片500ksps最低采样
发表于 12-12 07:47
加密核心是基于Rijndael AES-128,具有192位可编程参数的加密芯片
加密芯片 - ALPU-C,该款加密芯片是ALPU系列中的高端IC,其加密核心基于RijntradAES-128,具有192位可编程参数。它是一个从设备,总通过串行总线与单片机一起运行
DAC128S085为什么无输出?
最近做用DAC128S085 的驱动板子,电源3.3V,参考电压2.05V,在板子上测试正常。
芯片电路如图:
用模拟spi和芯片通信
程序第一步设置芯片为WTM模式(0x900
发表于 12-02 06:23
ADC128S052、ADC128S052-Q1模数转换器数据表
电子发烧友网站提供《ADC128S052、ADC128S052-Q1模数转换器数据表.pdf》资料免费下载
发表于 07-22 11:12
•0次下载
东芝 TB67S128FTG:释放精密电机控制的力量
深入了解这款出色的芯片的功能和优点,并探索它如何成为您项目的变革者。 TB67S128FTG 概述 TB67S128FTG 是一款采用东芝 BiCD 工艺(结合双极、CMOS 和 DMOS 技术)设计的高度集成的单片 IC。此集
esp32-s2r2芯片无法下载是什么原因导致的?
求助, 我现在遇到esp32-s2r2芯片无法下载问题,一开始怀疑是我电路设计问题。于是我将乐鑫ESP32-S2-WROVER-I模组内ESP32-S2
发表于 07-01 08:29
ESP32-S2 FN4R2为什么无法烧录?
我用ESP32-S2FN4R2芯片设计出来的板焊上ESP32-S2FN4R2后烧录不了,已经换过2片芯片了还是烧录不了,不知道是什么原因:I
发表于 06-17 08:21
esp32s2FN4R2启用内置的2M PSRAM后,不断重启怎么解决?
heap-caps-malloc(),还是第一个,结果都一样,下载后不停重启
环境是5.1RC
只要不启用外部PSRAM,运行就没有问题
另外,系统例程himem只能使用esp32才能正确编译,设置芯片为esp32s2就会编译出错
是不是说esp32fn4
发表于 06-11 08:56
南京中科微Si24R2E低功耗高性能2.4GHz有源FRID SoC单发射芯片
Si24R2E是针对有源RFID市场设计的低功耗、高性能的2.4GHz标签系统的SoC单芯片,集成嵌入式2.4GHz无线射频发射器模块、128次可编程NVM存储器模块以及自动发射控制器模块等
发表于 05-16 14:02
