XR806开发板进行ST7789LCD屏幕测试步骤
全志在线 来源:全志在线 2023-12-22 17:31 次阅读
XR806开发板ST7789LCD屏幕测试
1
屏幕硬件
连接
本文使用的LCD屏幕的原理图如下,可以确定LCD屏幕的控制引脚接线。
XR806与LCD屏幕的控制引脚分布如下
实际的连接效果如图所示
2
驱动编写
ST7789的驱动使用中景园的LCD驱动库,驱动文件包括:
lcd.c
lcd.h
lcd_init.c
lcd_init.h
lcd_font.h
在XR806的示例程序中GPIO工程的基础上进行移植。在gpio示例文件夹中添加lcd的驱动代码。
移植时要实现对LCD引脚的控制,在lcd_init.h中添加以下代码
#include "driver/chip/hal_gpio.h"
#include "kernel/os/os.h"
#define LCD_SCLK_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_7, GPIO_PIN_LOW)
#define LCD_SCLK_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_7, GPIO_PIN_HIGH)
#define LCD_MOSI_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_4, GPIO_PIN_LOW)
#define LCD_MOSI_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_4, GPIO_PIN_HIGH)
#define LCD_RES_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_5, GPIO_PIN_LOW)
#define LCD_RES_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_5, GPIO_PIN_HIGH)
#define LCD_DC_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_3, GPIO_PIN_LOW)
#define LCD_DC_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_3, GPIO_PIN_HIGH)
#define LCD_CS_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_6, GPIO_PIN_LOW)
#define LCD_CS_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_6, GPIO_PIN_HIGH)
//硬件上没有给出控制接口,这里不做定义
#define LCD_BLK_Clr()
#define LCD_BLK_Set()
在lcd_init.c中添加引脚的初始化函数,并替换延时函数为OS_MSleep,相关的代码如下:
#include "lcd_init.h"
void LCD_GPIO_Init(void)
 GPIO_InitParam param;
 param.driving = GPIO_DRIVING_LEVEL_1;
 param.mode = GPIOx_Pn_F1_OUTPUT;
 param.pull = GPIO_PULL_NONE;
 HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_3, ¶m);
 HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_4, ¶m);
 HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_5, ¶m);
 HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_6, ¶m);
 HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_7, ¶m);
void LCD_Init(void)
 LCD_GPIO_Init();
 LCD_RES_Clr();
 OS_MSleep(100);//替换延时函数
 LCD_RES_Set();
 OS_MSleep(100);
  //以下代码忽略
在main.c中添加以下代码
int main(void)
 LCD_Init();
 OS_MSleep(100);
 LCD_Fill(0, 0, LCD_W, LCD_H, RED);
 // LCD_ShowString(4, 0, "XR806 LCD Test", RED, CYAN, 16, 0);
 LCD_DrawRectangle(0, 0, LCD_W - 1, LCD_H - 1, MAGENTA);
 LCD_DrawRectangle(1, 1, LCD_W - 2, LCD_H - 2, MAGENTA);
 while (1)
  OS_MSleep(1000);
  LCD_Fill(0, 0, LCD_W, LCD_H, BLUE);
  OS_MSleep(1000);
  LCD_Fill(0, 0, LCD_W, LCD_H, GREEN);
  OS_MSleep(1000);
  LCD_Fill(0, 0, LCD_W, LCD_H, YELLOW);
  OS_MSleep(1000);
  LCD_Fill(0, 0, LCD_W, LCD_H, LIGHTGREEN);
  printf("XR806 LCD Test
 return 0;
3
屏幕驱动
效果
编译下载后,可以看到屏幕的颜色切换以及串口的数据输出
审核编辑:刘清
  • LCD屏
  • GPIO
  • 串口输出
  • xr806
原文标题:XR806开发板进行ST7789LCD屏幕测试
文章出处:【微信号:gh_79acfa3aa3e3,微信公众号:全志在线】欢迎添加关注!文章转载请注明出处。
    XR806开发板适用】基于多源信息融合的粮食霉变检测系统设计
    XR806开发板具有强大的数据处理和传输能力,广泛应用于物联网和嵌入式系统开发
    的头像 发表于 10-27 17:06 904次阅读
    【<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>适用】基于多源信息融合的粮食霉变检测系统设计
    基于全志XR806开发板的家用环境监测传感器设计
    本文来自全志XR806开发板评测活动文章,作者使用XR806开发板制作一个简单的家用环境监测传感器,可以获取当前的温度、湿度、气压、海拔这四个参数,同时能够通过外部的
    的头像 发表于 12-03 10:20 647次阅读
    基于全志<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>的家用环境监测传感器设计
    如何使用XR806开发板来设计一个粮食霉变检测系统?
    的头像 发表于 01-05 17:30 799次阅读
    如何使用<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>来设计一个粮食霉变检测系统?
    OpenHarmony南向嵌入式:【XR806开发板指导文档】
    XR806_OpenHarmony开发板是基于XR806芯片设计开发的参考评估,身集成了XR806
    的头像 发表于 04-14 09:25 748次阅读
    OpenHarmony南向嵌入式:【<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>指导文档】
    XR806芯片、XR806开源鸿蒙开发板简介
    。可广泛满足 智能家居、智慧楼宇、工业互联、儿童玩具、电子竞赛、极客DIY 等领域的无线连接需求。芯片框图芯片参数XR806开源鸿蒙开发板介绍XR806开发板是基于
    发表于 11-15 17:08
    发表于 11-15 18:32
    请问一下XR806开发板是如何与腾讯云平台进行对接的
    请问一下XR806开发板是如何与腾讯云平台进行对接的?有哪些操作步骤
    发表于 12-28 07:11
    如何利用XR806开发板对TCP通信进行测试
    如何利用XR806开发板对TCP通信进行测试呢?其测试代码该怎样去是实现呢?
    发表于 12-28 07:48
    如何对XR806开发板的环境进行配置呢
    如何对XR806开发板的环境进行配置呢?有哪些配置步骤
    发表于 12-28 07:51
    请问大佬XR806鸿蒙开发板怎么样?
    请问大佬XR806鸿蒙开发板怎么样?
    发表于 12-29 07:06
    在全志XR806上移植st7789屏幕驱动
    \"); st7789_set_orientation(DISPLAY_ORIENTATION); 硬件连接如图所示 屏幕 开发板 BLK B14 CS B06 DC B03 RES VCC
    发表于 11-10 10:21
    全志XR806开发板适配ST7789LCD屏幕测试
    本次使用XR806实现ST7789屏幕的驱动。 硬件连接 本文使用的LCD屏幕的原理图如下,可以确定L
    发表于 12-13 14:03
    XR806开发板试用】留言功能开发
    XR806开源鸿蒙开发板是一款基于XR806芯片设计,高度集成WiFi/BLE/常用外设,可供开发进行方案评估、DIY或小规模产品研发,可
    的头像 发表于 10-08 10:58 640次阅读
    XR806开发板试用】FreeRTOS创建任务测试
    这篇来学习下,XR806开发板在FreeRTOS系统下创建两个任务测试,由于没有找到学习的文档,试着参考例程来测试
    的头像 发表于 10-10 11:47 624次阅读
    【<b class='flag-5'>XR806</b><b class='flag-5'>开发板</b>试用】FreeRTOS创建任务<b class='flag-5'>测试</b>
    全志XR806开发板原理图
    全志XR806开发板原理图
    发表于 10-19 15:11 12次下载
