RZ/G2L Linux系统如何添加新的内核模块
瑞萨MCU小百科 来源:瑞萨MCU小百科 2024-01-04 12:19 1997次阅读
RZ/G2L Linux系统的镜像基于yocto构建,本篇介绍如何添加新的内核模块。
方式1:内核源码外添加
方式2:内核源码中添加
需要提前已按照文档构建好开发环境和安装SDK,本篇依据G2L VLP3.0.3
方式1示例
A. bitbake编译模块方式
目录和内容参考:
左右滑动查看完整内容
rzg2l_vlp_v3.0.3$ tree meta-renesas/meta-rz-common/recipes-kernel/kernel-module-helloworld/
├── files
│  ├── helloworld.c
│  └── Makefile
└── kernel-module-helloworld.bb
helloworld.c
左右滑动查看完整内容
#include
static int hello_world_init(void)
  printk("Hello world
  return 0;
static void hello_world_exit(void)
  printk("Bye world
module_init(hello_world_init);
module_exit(hello_world_exit);
MODULE_LICENSE("GPL v2");
Makefile
左右滑动查看完整内容
obj-m := helloworld.o
SRC := $(shell pwd)
all:
    make -C $(KERNELSRC) M=$(SRC) modules
install:
    make -C $(KERNELSRC) M=$(SRC) modules_install
clean:
    rm -f *.o *~ core .depend .*.cmd *.ko *.mod.c
    rm -f Module.markers Module.symvers modules.order
    rm -rf .tmp_versions Modules.symvers
左右滑动查看完整内容
SRC_URI = "
  file://helloworld.c
  file://Makefile
S = "${WORKDIR}"
EXTRA_OEMAKE = "KERNELDIR=${STAGING_KERNEL_BUILDDIR}"
EXTRA_OEMAKE += "CROSS_COMPILE=${CROSS_COMPILE}"
KERNEL_MODULE_PACKAGE_SUFFIX = ""
do_install() {
  # Create destination directory
  install -d ${D}/lib/modules/${KERNEL_VERSION}/extra/
  # Install kernel module
  install -m 644 ${S}/helloworld.ko ${D}/lib/modules/${KERNEL_VERSION}/extra/
  # Install module symbol file
  install -m 644 ${S}/Module.symvers ${STAGING_KERNEL_BUILDDIR}/helloworld.symvers
PACKAGES = "
  ${PN}
FILES_${PN} = "
  /lib/modules/${KERNEL_VERSION}/extra/helloworld.ko
编译模块:
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3$ source poky/oe-init-build-env
### Shell environment set up for builds. ###
You can now run 'bitbake '
Targets are:
  core-image-minimal
  core-image-bsp
  core-image-weston
  core-image-qt
hank@rz:~/rzg2l_vlp_v3.0.3/build$ MACHINE=smarc-rzg2l bitbake -s | grep hello
go-helloworld                     :0.1-r0
kernel-module-helloworld               :1.0-r0
lib32-go-helloworld                  :0.1-r0
hank@rz:~/rzg2l_vlp_v3.0.3/build$ MACHINE=smarc-rzg2l bitbake kernel-module-helloworld
WARNING: Layer qt5-layer should set LAYERSERIES_COMPAT_qt5-layer in its conf/layer.conf file to list the core layer names it is compatible with.
Loading cache: 100%
NOTE: Tasks Summary: Attempted 650 tasks of which 635 didn't need to be rerun and all succeeded.
查看结果:
左右滑动查看完整内容
build/tmp/work/smarc_rzg2l-poky-linux/kernel-module-helloworld/1.0-r0/helloworld.ko
如果想编译到rootfs,请修改conf/local.conf追加内容并重新编译rootfs
左右滑动查看完整内容
MACHINE_EXTRA_RRECOMMENDS = " kernel-module-helloworld"
库文件包已含在rootfs内
左右滑动查看完整内容
build$ find ./tmp/work/smarc_rzg2l-poky-linux/ -name helloworld.ko
./tmp/work/smarc_rzg2l-poky-linux/core-image-qt/1.0-r0/rootfs/lib/modules/5.10.158-cip22-yocto-standard/extra/helloworld.ko
./tmp/work/smarc_rzg2l-poky-linux/kernel-module-helloworld/1.0-r0/helloworld.ko
B.在源码目录直接编译方式
左右滑动查看完整内容
cd /opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build
source /opt/poky_vlp3.0.3/environment-setup-aarch64-poky-linux
sudo chown -R $USER .
make scripts
make prepare
mkdir hello //并拷贝上边的源码文件
/opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello$ ls
helloworld.c  Makefile
/opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello$ make
make -C /opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/usr/src/kernel M=/opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello modules
make[1]: Entering directory '/opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build'
 CC [M] /opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello/helloworld.o
 MODPOST /opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello/Module.symvers
 CC [M] /opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello/helloworld.mod.o
 LD [M] /opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello/helloworld.ko
make[1]: Leaving directory '/opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build'
hank@rz:/opt/poky_vlp3.0.3/sysroots/aarch64-poky-linux/lib/modules/5.10.158-cip22-yocto-standard/build/hello$ ls
helloworld.c helloworld.ko helloworld.mod helloworld.mod.c helloworld.mod.o helloworld.o Makefile modules.order Module.symvers
方式2示例
首先提取内核源码:
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build$ MACHINE=smarc-rzg2l devtool modify linux-renesas
NOTE: Starting bitbake server...
INFO: Adding local source files to srctree...
INFO: Copying kernel config to srctree
INFO: Source tree extracted to /home/xxx/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas
WARNING: SRC_URI is conditionally overridden in this recipe, thus several devtool-override-* branches have been created, one for each override that makes changes to SRC_URI. It is recommended that you make changes to the devtool branch first, then checkout and rebase each devtool-override-* branch and update any unique patches there (duplicates on those branches will be ignored by devtool finish/update-recipe)
INFO: Recipe linux-renesas now set up to build from /home/xxx/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas
上面最后一行就是Linux内核源码提取后所在目录,即/home/xxx/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas, 然后去这个目录修改代码即可。
进入Linux源码目录下找个目录增加模块代码,这里使用build/workspace/sources/ linux-renesas /drivers/char目录,在该目录下执行mkdir hello创建目录,然后在hello目录下创建以下文件。
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas/drivers/char$ tree hello/
hello/
├── hello.c
├── Kconfig
└── Makefile
hello.c
左右滑动查看完整内容
#include
  printk("Hello world
  return 0;
  printk("Bye world
Kconfig
左右滑动查看完整内容
config HELLO
    tristate 'Create a hello module'
    default n
    help
        This is a module to print Hello World!
Makefile
obj-$(CONFIG_HELLO) += hello.o
修改build/workspace/sources/ linux-renesas /drivers/char目录的Kconfig和Makefile:
左右滑动查看完整内容
diff --git a/drivers/char/Kconfig b/drivers/char/Kconfig
index b4e65d1ed..2b96630ab 100644
--- a/drivers/char/Kconfig
+++ b/drivers/char/Kconfig
@@ -508,4 +508,6 @@ config RANDOM_TRUST_BOOTLOADER
     believe its RNG facilities may be faulty. This may also be configured
     at boot time with "random.trust_bootloader=on/off".
+source "drivers/char/hello/Kconfig"
 endmenu
diff --git a/drivers/char/Makefile b/drivers/char/Makefile
index ffce287ef..3056303ff 100644
--- a/drivers/char/Makefile
+++ b/drivers/char/Makefile
@@ -47,3 +47,5 @@ obj-$(CONFIG_PS3_FLASH)        += ps3flash.o
 obj-$(CONFIG_XILLYBUS)     += xillybus/
 obj-$(CONFIG_POWERNV_OP_PANEL) += powernv-op-panel.o
 obj-$(CONFIG_ADI)       += adi.o
+obj-$(CONFIG_HELLO) += hello/
返回yocto顶层目录,选择内核配置
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build$ source poky/oe-init-build-env
~/rzg2l_vlp_v3.0.3/build$ MACHINE=smarc-rzg2l bitbake virtual/kernel -c menuconfig
编译内核
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build$ MACHINE=smarc-rzg2l devtool build linux-renesas
NOTE: Tasks Summary: Attempted 607 tasks of which 594 didn't need to be rerun and all succeeded.
生成结果
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build$ ls tmp/work/smarc_rzg2l-poky-linux/linux-renesas/5.10.158-cip22+git999-r1/linux-renesas-5.10.158-cip22+git999/drivers/char/hello/
built-in.a hello.o modules.order
最后制作补丁,创建自己的layer保存补丁。
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build$ bitbake-layers create-layer ../meta-mylayer
~/rzg2l_vlp_v3.0.3/build$ bitbake-layers add-layer ../meta-mylayer
hank@rz:~/rzg2l_vlp_v3.0.3/build$ tree ../meta-mylayer/
../meta-mylayer/
├── conf
│  └── layer.conf
├── COPYING.MIT
├── README
└── recipes-example
  └── example
    └── example_0.1.bb
3 directories, 4 files
再次进入源码目录,提交修改,生成补丁
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas$ git status .
Refresh index: 100% (70807/70807), done.
On branch devtool
Changes not staged for commit:
 (use "git add ..." to update what will be committed)
 (use "git restore ..." to discard changes in working directory)
    modified:  drivers/char/Kconfig
    modified:  drivers/char/Makefile
Untracked files:
 (use "git add ..." to include in what will be committed)
    drivers/char/hello/
no changes added to commit (use "git add" and/or "git commit -a")
~/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas$ git add ./*
The following paths are ignored by one of your .gitignore files:
oe-logs
oe-workdir
Use -f if you really want to add them.
~/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas$ git commit -m "add the hello module"
[devtool 6dc52bd44] add the hello module
 5 files changed, 25 insertions(+)
 create mode 100644 drivers/char/hello/Kconfig
 create mode 100644 drivers/char/hello/Makefile
 create mode 100644 drivers/char/hello/hello.c
切到build目录执行
左右滑动查看完整内容
~/rzg2l_vlp_v3.0.3/build$ MACHINE=smarc-rzg2l devtool finish linux-renesas ../meta-mylayer/
Parsing of 2151 .bb files complete (0 cached, 2151 parsed). 5440 targets, 887 skipped, 3 masked, 0 errors.
INFO: Leaving source tree /home/xxx/rzg2l_vlp_v3.0.3/build/workspace/sources/linux-renesas as-is; if you no longer need it then please delete it manually
../meta-mylayer/
├── conf
│  └── layer.conf
├── COPYING.MIT
├── README
├── recipes-example
│  └── example
│    └── example_0.1.bb
└── recipes-kernel
  └── linux
    ├── linux-renesas
    │  ├── 0001-add-the-hello-module.patch
    │  └── devtool-fragment.cfg
    └── linux-renesas_%.bbappend
6 directories, 7 files
上边patch文件就是修改的内容了。
审核编辑:汤梓红
  • 内核
  • Linux
  • Linux系统
  • 源码
  • SDK
    SDK
原文标题:RZ/G2L添加新的内核模块
文章出处:【微信号:瑞萨MCU小百科,微信公众号:瑞萨MCU小百科】欢迎添加关注!文章转载请注明出处。
    瑞萨RZ/G2L串口SCI的使用(上)
    瑞萨RZ/G2L的串口简称SCI,全称Serial Communication Interface。
    的头像 发表于 01-17 12:19 1778次阅读
    瑞萨<b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b>串口SCI的使用(上)
    RZ/G2L高速虚拟串口方案 基于瑞萨RZ/G2L SMARC开发板的虚拟(Virtual UART)实现方案
    UART)实现方案,以实现高速Linux UART通信,供客户参考。 虚拟(Virtual UART)方案介绍 很多工业客户,都有Linux下高速UART需求(1Mbps以上波特率),但是RZ/
    发表于 11-20 14:41 823次阅读
    <b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b>高速虚拟串口方案 基于瑞萨<b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b> SMARC开发板的虚拟(Virtual UART)实现方案
    G2L系列 核心板 -RZ/G2L 处理器简介|框架图|功耗|原理图及硬件设计指南
    用户便捷开发,轻松选型。 三、RZ/G2L系列 Linux系统整机功耗表很多小伙伴对FET-G2LD-C核心板和OK-
    发表于 06-21 14:45
    【飞凌RZ/G2L开发板试用体验】+01.开箱(zmj)
    ,主要应用于各种具有视频输出的工控行业。2.硬件讲解硬件讲解:从外观结构上看,飞凌RZ/G2L开发板使用模块和扩展板的方式组成,重点是飞凌扩展板原理图/PCB图免费提供,扩展板可以更换
    发表于 08-28 19:13
    【米尔瑞萨RZ/G2L开发板-试用体验】米尔瑞萨RZ/G2L开发板使用SSH登录
    收到的米尔瑞萨RZ/G2L开发板上电测试一下SSH登录方式和其它测试! SSH登录 在使用之前,需要事先连接网络,笔者这里使用的是以太网,事先需要使用串口的登录,然后输入以下命令查看IP地址
    发表于 06-11 21:47
    嵌入式LINUX系统内核内核模块调试
    嵌入式LINUX系统内核内核模块调试(嵌入式开发和硬件开发)-嵌入式LINUX系统
    发表于 07-30 13:55 10次下载
    嵌入式<b class='flag-5'>LINUX</b><b class='flag-5'>系统</b><b class='flag-5'>内核</b>和<b class='flag-5'>内核模块</b>调试
    瑞萨G2L系列核心板-RZ/G2L处理器简介
    RZ/G2L是瑞萨在智能工控领域的一款高性能、超高效处理器。RZ/G2L采用Arm Cortex-A55内核,运行频率高达1.2GHz,内部
    发表于 06-09 11:54 1030次阅读
    RZ/G2LRZ/V2L SMARC 模块板用户手册:硬件
    发表于 01-09 19:00 4次下载
    <b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b>、<b class='flag-5'>RZ</b>/V<b class='flag-5'>2L</b> SMARC <b class='flag-5'>模块</b>板用户手册:硬件
    RZ/G2LRZ/G2LC 用户手册概述
    发表于 01-10 19:04 6次下载
    <b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b>、<b class='flag-5'>RZ</b>/<b class='flag-5'>G2</b>LC 用户手册概述
    发表于 06-30 18:38 1次下载
    发表于 06-30 19:47 6次下载
    RZ/G2L开发板使用指南(上)
    如果需要评估RZ/G2L产品的各项功能,RZ/G2L评估板是最合适的平台。
    的头像 发表于 11-03 12:19 1347次阅读
    <b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b>开发板使用指南(上)
    RZ/G2L Demo调试经验流程分享(1)
    r01us0553ej0107-rz-g(Release Note).pdf,r01us0556ej0102-rz-g(Board_StartUp_Guide_smarcEVK).pdf,对SMARC EVK of RZ/
    的头像 发表于 05-06 14:25 877次阅读
    <b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b> Demo调试经验流程分享(1)
    RZ/G2L串口SCI的使用(上)
    RZ/G2L串口SCI的使用
    的头像 发表于 07-25 08:06 649次阅读
    RZ/G2L串口SCI的使用(下)
    RZ/G2L串口SCI的使用
    的头像 发表于 08-03 08:06 652次阅读
    <b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b>串口SCI的使用(下)
