代码main.py,通过网页把它传入ESP8266 micropython固件中即可。如何传输自行查找资料吧。本人也忘记如何传输了。本文只是为了记录一下曾经写过的代码案例。方便以后查找。
import usocket #导入socket包
import machine
import network
import time
LED=machine.Pin(2, machine.Pin.OUT)
LED.value(1)
WIFI_flag=1;
is_flag=0
ssid="CMCC-lin-----"
pwd="linjia@15120613059"
ap_ip=""
st_ip=""
while True:
if WIFI_flag == 1:
ap = network.WLAN(network.AP_IF)
ap.active(True)
ap.config(essid='ESP8266_WIFI')
ap.config(authmode=0)
print("ESP8266_IP:",ap.ifconfig()[0]+",Port:23")#获取IP信息
s=usocket.socket()
s.bind(('',23)) #监听本地端口23
s.listen(5)
if WIFI_flag == 0:
#连接热点WIFI
sta_if=network.WLAN(network.STA_IF)
sta_if.active(True)
#sta_if.scan()# 扫描当前可连接的WiFi名称
sta_if.connect(ssid,pwd) # 设置要连接WiFi的名称和连接密码
print("SSID:",ssid+"nPassword:",pwd)
print("Linking WIFI...")
while True:
if sta_if.isconnected()==True:
break
else :
time.sleep(10)
print("Linking WIFI error.Please reset device and input right SSID or PAWD again!n")
print("ESP8266 link WIFI status:",sta_if.isconnected())#检查是否连接成功
print("ESP8266_IP:",sta_if.ifconfig()[0]+",Port:80")#获取IP信息
s=usocket.socket()
s.bind(('',80)) #监听本地端口23
s.listen(5)
print("waiting...")
c,a=s.accept()
print("one device link!")
c.send("Hi,Welcome micropython of ESP8266n")
while True:
client_data=c.recv(1024)#接收到的是字节
print("client_data:",client_data)
if client_data==b"":
#s.listen(5)
print("waiting...")
c,a=s.accept()
print("client:",client_data) #输出收到的消息
if client_data==b"ON":#判断字节
LED.value(0)#开灯
print("+++ LED OPEN +++")
c.send("+++ LED OPEN +++n")
if client_data==b"OFF":#判断字节,字符串前面加b为强制类型转换为字节
LED.value(1)#关灯
print("--- LED CLOSE ---")
c.send("Hi,Welcome ESP8266 micropythonn")
c.send("--- LED CLOSE ---n")
if client_data[0:5]==b"SSID:": #判断 要连接的WIFI 名
ssid=client_data[5:]
ssid=bytes.decode(ssid)#字节转换成字符串
print("ssid:",ssid)
if client_data[0:5]==b"PAWD:": #判断WIFI密码
pwd=client_data[5:]
pwd=bytes.decode(pwd)#字节转换成字符串
print("password:",pwd)
if client_data==b"CXIP":
app = network.WLAN(network.AP_IF)
sta = network.WLAN(network.STA_IF)
print("STA_IP:",app.ifconfig()[0]+",Port:23n")
print("AP_IP:",sta.ifconfig()[0]+",Port:23n")
c.send("nPort:23,STA_IP:")
c.send(sta.ifconfig()[0])
c.send("nPort:23,AP_IP:")
c.send(app.ifconfig()[0])
if client_data==b"WIFI_AP":
WIFI_flag=1
print("--- WIFI_AP ---")
for i in range(1):
LED.value(0)#开灯
time.sleep(0.5)
LED.value(1)#关灯
time.sleep(0.5)
ap.active(True)
print("waiting...")
for i in range(2):
LED.value(0)#开灯
time.sleep(0.5)
LED.value(1)#关灯
time.sleep(0.5)
c,a=s.accept()
for i in range(3):
LED.value(0)#开灯
time.sleep(0.5)
LED.value(1)#关灯
time.sleep(0.5)
if client_data==b"WIFI_ST":
WIFI_flag=0
print("--- WIFI_ST ---")
for i in range(1):
LED.value(0)#开灯
time.sleep(0.5)
LED.value(1)#关灯
time.sleep(0.5)
#连接热点WIFI
sta_if.active(True)
while True:
is_flag=1
break
else :
time.sleep(10)
print("ESP8266_IP:",sta_if.ifconfig()[0]+",Port:23")#获取IP信息
print("waiting...")
for i in range(2):
LED.value(0)#开灯
time.sleep(0.5)
LED.value(1)#关灯
time.sleep(0.5)
c,a=s.accept()
for i in range(3):
LED.value(0)#开灯
time.sleep(0.5)
LED.value(1)#关灯
time.sleep(0.5)
举报投诉
led
244文章
24731浏览量
692646 -
TCPIP
1文章
56浏览量
23564 -
ESP8266
51文章
972浏览量
49853 -
Micropython
1文章
69浏览量
5899
热点推荐
CC2530采用ESP8266与手机APP通信
项目概述: 项目实现通过CC2530控制ESP8266将其配置成AP+TCP服务器模式,并通过手机APP连接到TCP服务器并完成数据传输。
esp8266,tcp通信实例详解
ESP8266工作在station模式下,需确认ESP8266已经连接AP(路由器)并分配到IP地址,启用client连接,ESP8266工作在soft-AP模式下,需确认连接ESP8266
发表于 11-04 10:14
•4.4w次阅读
如何使用ESP8266和Android控制继电器
ESP8266 WiFi模块系列的下一个项目是通过在MIT App Inventor的帮助下开发的App(应用程序)使用ESP8266和Android控制继电器。通过在Android手
怎样使用ESP8266 Flasher和Programmer烧写ESP8266 AT固件
选择要连接的COM端口ESP8266 Flasher和Programmer + ESP8266 Wifi串行收发器模块。将BAUDRATE设置为115200。
普中WIFI ESP8266模块的详细资料合集免费下载
规格书)PZ-WIFI-ESP8266模块程序(PZ-WIFI-ESP8266模块--STM32F1程序,PZ-WIFI-ESP8266模块--STM32F4程序),调试工具(TCP&
发表于 03-03 08:00
•114次下载
STM32-ESP8266wifi模块实现
1.ESP8266WiFi模块介绍1.1ESP8266wifi 模块低功耗串口WiFi模块ESP8266内置一个Tensilica(泰思立达) Xtensa架构的32位处理器L106,
发表于 11-19 13:06
•80次下载
ESP8266之硬件机理
上的wifi4.4找到你要接入的wifi,添加账号和密码4.5获取此时esp8266的IP地址4.6开启多通道模式4.7开启服务器,设置服务
发表于 12-09 12:21
•34次下载
使用ESP8266-01制作WIFI遥控小车(一)
互联网实现对设备的远程控制。AP 模式:ESP8266 模块作为热点,手机或电脑直接与模块连接,实现局域网无线控制。STA+AP 模式:两种
发表于 01-12 19:47
•49次下载
使用ESP8266 Wifi模块和iPhone/Android控制LED
电子发烧友网站提供《使用ESP8266 Wifi模块和iPhone/Android控制LED.zip》资料免费下载
发表于 11-09 14:15
•10次下载
ESP8266芯片WIFI模块接入云平台的方法教程
ESP8266 的模块芯片是基于无线通信协议的 UART-WiFi透传模块芯片,支持 802.11b/g/n 的无线标准,并带有三种可选择的工作模式。ESP8266 模块的控制是通过
esp8266wifi模块怎么连接手机
和密码)。 配置成功后,ESP8266将能够通过路由器连接到互联网。 手机连接同一WiFi网络 : 在手机上打开WiFi设置,
ESP8266实现TCP控制LED和设置WIFI密码
