1CDC常见错误
1.1Reconvergence
1.1.1single_source_reconvergence
结构:同一个信号源头,两个同步处理器。这里提一下,有两个CDC分析工具的参数配置:
1.1.2案列1:divergence_depths为0
// divergence point always @ (posedge tx_clk) ctrl <= ci0 | ci1 ; // two_dff synchronizer always @ (posedge rx_clk) begin: two_dff reg temp; temp <= ctrl; two_dff_sync <= temp; end // shift_reg synchronizer always @ (posedge rx_clk) begin: shift_reg shift_reg_sync <= {shift_reg_sync[0], ctrl}; end // reconvergence point always @ (posedge rx_clk) dout <= two_dff_sync ^ shift_reg_sync[1];
电路如下:divergence_depth为0
CDC报告如下:
1.2Redundant
案例1:
// two_dff synchronizer of tx_sig always @ (posedge rx_clk) begin: two_dff reg s0 , s1; s0 <= tx_sig; // 1st flop s1 <= s0; // 2nd flop end // two_dff synchronizer of tx_sig always @ (posedge rx_clk) begin: shift_reg reg [1:0] sh_reg; sh_reg <= {sh_reg[0], tx_sig}; end
1.3multi_sync_mux_select (DMUX)
MUX的sel端fan-in信号超过一组同步器,不推荐。通常MUX的sel端只能有一组同步器。
案例1:
always @(posedge rx_clk) begin reg s1_sel1, s2_sel1; reg [1:0] s_sel2; s1_sel1 <= tx_sel1; s2_sel1 <= s1_sel1; s_sel2 <= {s_sel2[0], tx_sel2}; if (s_sel2[1] | s2_sel1) rx_data <= tx_data; end
电路如下:
1.4combo_logic
1.4.1错误案列1
always @ (posedge rx_clk) begin s1 <= tx_sig & din; s2 <= s1; end
当然还有如下这种错误,除非additional logic全部是静态变量。
1.5async_reset_no_sync(异步复位、同步撤离)
1.5.1案列1
// Reset triggered by tx_clk always @(posedge tx_clk) tx_sig <= rst; // Unsynchronized reset used in // Rx domain always @(posedge rx_clk,negedge tx_sig) if (!tx_sig) rx_sig <= 1’b0; else rx_sig <= din;
1.5.2错误案列2
// Reset triggered by tx_clk always @(posedge tx_clk) tx_sig <= rst; // Improperly synchronized reset used // in Rx domain always @(posedge rx_clk,negedge tx_sig) if (!tx_sig) rx_reset <= 1’b0; else rx_reset <= 1’b1;
正确的结构如下:
1.6dff_sync_gated_clk
案列1,与门做时钟gating有毛刺,需要clock gating cell。
// gated clock expression assign gclk = rx_clk & clk_en; always @(posedge gclk) sync1 <= tx_sig; // 1st DFF always @(posedge rx_clk) sync2 <= sync1; // 2nd DFF
1.7fanin_different_clks
同步器的输入由两个异步时钟域的组合逻辑构成,如下图所示:(还有combo logic)
值得注意的是,如果sig_a或者sig_b中有一个信号是stable静态变量,那么上图结构的电路就不会被报fanin_different_clks或者combo_logic错误。
假设有sig_a、sig_b、sig_c三个信号及以上的fan_in呢?抛开静态变量后,
若所有信号都是同一个时钟域,CDC错误类型就是combo_logic;
若所有信号来自至少2个时钟域,CDC错误类型就是fanin_different_clks;
举个例子,如下图:
上图电路仍会报fanin_different_clks,但是电路确实是设计者的意图,我们只需要将TEST时钟域的test_sel设置为常数0即可。
1.7.1案列1
always @ (posedge tx1_clk) tx1_sig <= in1; always @ (posedge tx2_clk) tx2_sig <= in2; always @ (posedge rx_clk) begin sync0 <= tx1_sig | tx2_sig; sync1 <= sync0; end
审核编辑:刘清
处理器
68文章
19485浏览量
231510 -
芯片设计
15文章
1032浏览量
55105 -
CDC
57浏览量
17887 -
异步电路
2文章
48浏览量
11161 -
静态变量
13浏览量
6696
原文标题:芯片设计之CDC异步电路(五)
文章出处:【微信号:全栈芯片工程师,微信公众号:全栈芯片工程师】欢迎添加关注!文章转载请注明出处。
FPGA User Guide之report_cdc
如何使用report_cdc命令分析、调试和修复CDC问题
ic设计——CDC的基本概念
要实现CDC验证标准,ASIC开发团队将会面临哪些挑战
ASIC/FPGA设计中的CDC问题分析
芯片设计之模拟IC设计全流程分析
XDC约束技巧之CDC篇
芯片设计进阶之路—SpyGlass CDC流程深入理解
