本文将介绍通过Python绘制地形图的方法,所需第三方Python相关模块包括 rasterio、geopandas、cartopy 等,可通过 pip 等方式安装。
1 示例代码
1.1 导入相关模块
import rasterio | |
import geopandas as gpd | |
import numpy as np | |
import cartopy.crs as ccrs | |
import matplotlib.pyplot as plt | |
from matplotlib.colors import LinearSegmentedColormap |
1.2 设置地图字体及字号
plt.rcParams["font.family"] = "Times New Roman" | |
plt.rcParams["font.size"] = 14 |
1.3 绘制地图
# 设置投影:墨卡托投影 | |
# cartopy 投影说明:https://www.cnblogs.com/youxiaogang/p/14247184.html | |
projection = ccrs.Mercator() | |
# 绘制地图 | |
fig, ax = plt.subplots(figsize=(20, 10), subplot_kw={'projection': projection}) | |
# 设置地图范围(数值参数为对应投影下的范围坐标) | |
ax.set_extent([13530000, 14630000, 4960000, 5850000], crs=projection) | |
# 读取矢量文件 | |
shp = gpd.read_file("Data/Jilin_Mercator.shp") | |
shp.plot(ax=ax, transform=projection, edgecolor="black", linewidth=1, facecolor="none") | |
# 创建自定义颜色映射 | |
colors = ["#369121", "#95C769", "#FFFFBF", "#E6865A", "#D14E30", "#BA1414"] | |
n_bins = 100 # 定义色带的颜色数量 | |
cmap_name = "green_brown" | |
cm = LinearSegmentedColormap.from_list(cmap_name, colors, N=n_bins) | |
# 读取地形栅格数据 | |
dataset = rasterio.open("Data/DEM_Jilin_Mercator.tif") | |
data = dataset.read(1) # 读取第一个波段的数据 | |
nodata_value = dataset.nodata # 获取NoData值 | |
# 创建掩膜,去除NoData区域 | |
data = np.ma.masked_where(data == nodata_value, data) | |
# 将地形栅格添加到地图中 | |
extent = [dataset.bounds.left, dataset.bounds.right, | |
dataset.bounds.bottom, dataset.bounds.top] | |
im = ax.imshow(data, origin="upper", extent=extent, | |
transform=projection, cmap=cm) | |
# 绘制网格线并添加标签 | |
gl = ax.gridlines(draw_labels=True, linestyle="--", color="#4F4F4F") | |
gl.xlocator = plt.FixedLocator(range(120, 135, 3)) | |
gl.ylocator = plt.FixedLocator(range(40, 50, 2)) | |
# 添加色带,设置色带的缩放比例为 0.4,主图和色带之间的间距为 0.1 | |
cbar = plt.colorbar(im, ax=ax, orientation="horizontal", shrink=0.4, pad=0.1) | |
cbar.set_label("Elevation (m)", labelpad=10) # 设置色带标签与色带的距离为 10 点 | |
cbar.ax.xaxis.set_label_position("top") # 设置色带标签位置 | |
plt.savefig("Pic.jpg", dpi=600) | |
plt.show() |
2 结果图展示
审核编辑:黄飞
举报投诉
python
55文章
4778浏览量
84439 -
地图绘制
4浏览量
2353
原文标题:基于Python的地图绘制教程
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
丰田汽车地图绘制服务比谷歌地图服务还要好
普及,谷歌地图也正一步一步走下神坛,而这或许正是 丰田 公司想要得到的结果。 丰田将推出一款全新基于众包模式的地图绘制服务,通过众包模式丰田车行地图能够保持不间断的更新。在丰田看来,谷
路径规划算法之栅格地图绘制
a. 本栏路径规划利用矩阵(二维数组)来表示栅格地图(因为对于矩阵,无论MATLAB、C++还是Python,矩阵更适合数组的表达,更便于编程。)
用Python来绘制世界地图
Python之所以这么流行,是因为它不仅能够应用于科技领域,还能用来做许多其他学科的研究工具,绘制地图便是其功能之一。 今天我们用matplot工具包之一的 mpl_toolkits 来绘制世界
Diagrams :基于Python绘制云系统架构的模块
Diagrams 是一个基于Python绘制云系统架构的模块,它能够通过非常简单的描述就能可视化架构,并支持以下6个云产品的图标: AWS、Azure、GCP、K8s、阿里云 和 Oracle 云
Diagrams:基于Python绘制云系统架构的模块
绘制同切圆python代码怎么运行
绘制同切圆是一个很有趣的数学问题,可以使用Python语言进行实现。在这篇文章中,我们将探讨同切圆的概念、绘制同切圆的算法和Python代码的实现。 同切圆的概念 同切圆是指具有相同圆
