【鸿蒙】OpenHarmony使用strace
王程 来源: jf_75796907 作者: jf_75796907 2024-03-01 09:41 次阅读
简介
Strace 是一个强大的进程行为跟踪工具,当怀疑某个进程运行异常的时候,比如死锁,CPU 高或者莫名卡顿等,可以使用 strace 查看该进程发起的系统调用和接收到的信号,从而确定问题所在。当然也可以利用 strace 去学习了解进程的运行流程,调用库以及参数和统计。那么如何在 OpenHarmony 里编译使用此工具就是我们这篇文章要分享的话题
编译构建
下载:从https://github.com/strace 下载最新源码
//下载地址
wget https://github.com/strace/strace/releases/download/v6.6/strace-6.6.tar.xz
安装编译环境
//编译工具链(32位)
sudo apt-get install gcc-arm-linux-gnueabi
//ohos的源码下载后,其实也有对应的工具链,位置如下
prebuilts/gcc/linux-x86/arm(32位)/gcc-linaro-7.5.0-arm-linux-gnueabi/bin
编译
//设置环境变量
export CC=arm-linux-gnueabi-gcc
export CFLAGS=-static
export CPPFLAGS=-static
export LDFLAGS='-static -pthread'
//配置
 ./configure CC=arm-linux-gnueabi-gcc CXX=arm-linux-gnueabi-cpp  LD=arm-linux-gnueabi-ld RANLIB=arm-linux-gnueabi-ranlib --host=arm-linux --target=arm-linux --enable-mpers=no
//编译
make
//strip
arm-linux-gnueabi-strip strace
运行测试
//传到板子上
hdc_std.exe shell mount -o rw,remount /
hdc_std.exe file send strace /system/bin
hdc_std.exe shell chmod +x /system/bin/strace
//运行测试
hdc_std.exe shell
# strace --help
Usage: strace [-ACdffhiqqrtttTvVwxxyyzZ] [-I N] [-b execve] [-e EXPR]...
              [-a COLUMN] [-o FILE] [-s STRSIZE] [-X FORMAT] [-P PATH]...
              [-p PID]... [--seccomp-bpf]
              { -p PID | [-DDD] [-E VAR=VAL]... [-u USERNAME] PROG [ARGS] }
   or: strace -c[dfwzZ] [-I N] [-b execve] [-e EXPR]... [-O OVERHEAD]
              [-S SORTBY] [-P PATH]... [-p PID]... [--seccomp-bpf]
General:
  -e EXPR        a qualifying expression: OPTION=[!]all or OPTION=[!]VAL1[,VAL2]...
     options:    trace, abbrev, verbose, raw, signal, read, write, fault,
                 inject, status, kvm
Startup:
  -E VAR=VAL, --env=VAR=VAL
                 put VAR=VAL in the environment for command
  -E VAR, --env=VAR
                 remove VAR from the environment for command
  -p PID, --attach=PID
                 trace process with process id PID, may be repeated
  -u USERNAME, --user=USERNAME
                 run command as USERNAME handling setuid and/or setgid
Tracing:
  -b execve, --detach-on=execve
                 detach on execve syscall
  -D             run tracer process as a grandchild, not as a parent
  -DD            run tracer process in a separate process group
  -DDD           run tracer process in a separate session
  -f             follow forks
  -ff            follow forks with output into separate files
  -I INTERRUPTIBLE
     1:          no signals are blocked
     2:          fatal signals are blocked while decoding syscall (default)
     3:          fatal signals are always blocked (default if '-o FILE PROG')
     4:          fatal signals and SIGTSTP (^Z) are always blocked
                 (useful to make 'strace -o FILE PROG' not stop on ^Z)
Filtering:
  -e trace=[!]{[?]SYSCALL[@64|@32|@x32]|[?]/REGEX|GROUP|all|none},
  --trace=[!]{[?]SYSCALL[@64|@32|@x32]|[?]/REGEX|GROUP|all|none}
                 trace only specified syscalls.
     groups:     %creds, %desc, %file, %fstat, %fstatfs %ipc, %lstat,
                 %memory, %net, %process, %pure, %signal, %stat, %%stat,
                 %statfs, %%statfs
  -e signal=SET, --signal=SET
                 trace only the specified set of signals
                 print only the signals from SET
  -e status=SET, --status=SET
                 print only system calls with the return statuses in SET
     statuses:   successful, failed, unfinished, unavailable, detached
  -P PATH, --trace-path=PATH
                 trace accesses to PATH
  -z             print only syscalls that returned without an error code
  -Z             print only syscalls that returned with an error code
Output format:
  -a COLUMN, --columns=COLUMN
                 alignment COLUMN for printing syscall results (default 40)
  -e abbrev=SET, --abbrev=SET
                 abbreviate output for the syscalls in SET
  -e verbose=SET, --verbose=SET
                 dereference structures for the syscall in SET
  -e raw=SET, --raw=SET
                 print undecoded arguments for the syscalls in SET
  -e read=SET, --read=SET
                 dump the data read from the file descriptors in SET
  -e write=SET, --write=SET
                 dump the data written to the file descriptors in SET
  -e kvm=vcpu, --kvm=vcpu
                 print exit reason of kvm vcpu
  -i, --instruction-pointer
                 print instruction pointer at time of syscall
  -o FILE, --output=FILE
                 send trace output to FILE instead of stderr
  -A, --output-append-mode
                 open the file provided in the -o option in append mode
  -q             suppress messages about attaching, detaching, etc.
  -qq            suppress messages about process exit status as well.
  -r             print relative timestamp
  -s STRSIZE, --string-limit=STRSIZE
                 limit length of print strings to STRSIZE chars (default 32)
  -t             print absolute timestamp
  -tt            print absolute timestamp with usecs
  -ttt           print absolute UNIX time with usecs
  -T             print time spent in each syscall
  -v, --no-abbrev
                 verbose mode: print entities unabbreviated
  -x             print non-ascii strings in hex
  -xx            print all strings in hex
  -X FORMAT      set the FORMAT for printing of named constants and flags
     formats:    raw, abbrev, verbose
  -y             print paths associated with file descriptor arguments
  -yy            print protocol specific information associated with socket
                 file descriptors
Statistics:
  -c, --summary-only
                 count time, calls, and errors for each syscall and report
                 summary
  -C, --summary  like -c, but also print the regular output
  -O OVERHEAD    set overhead for tracing syscalls to OVERHEAD usecs
  -S SORTBY, --summary-sort-by=SORTBY
                 sort syscall counts by: time, calls, errors, name, nothing
                 (default time)
  -w             summarise syscall latency (default is system time)
Tampering:
  -e inject=SET[:error=ERRNO|:retval=VALUE][:signal=SIG][:syscall=SYSCALL]
            [:delay_enter=DELAY][:delay_exit=DELAY][:when=WHEN],
  --inject=SET[:error=ERRNO|:retval=VALUE][:signal=SIG][:syscall=SYSCALL]
                 perform syscall tampering for the syscalls in SET
     delay:      milliseconds or NUMBER{s|ms|us|ns}
     when:       FIRST, FIRST+, or FIRST+STEP
  -e fault=SET[:error=ERRNO][:when=WHEN], --fault=SET[:error=ERRNO][:when=WHEN]
                 synonym for -e inject with default ERRNO set to ENOSYS.
Miscellaneous:
  -d, --debug    enable debug output to stderr
  -h, --help     print help message
  --seccomp-bpf  enable seccomp-bpf filtering
  -V, --version  print version
小结
简单说说 strace 的典型场景:
进程统计:针对某个运行高 cpu 消耗的进程,进行监控统计,什么操作耗时多?后台在做什么事?统计出来高消耗的系统操作
# top
Tasks: 243 total,   2 running, 237 sleeping,   0 stopped,   4 zombie
  Mem:  1992724K total,  1501188K used,   491536K free,   1830912 buffers
 Swap:  1048572K total,         0 used,  1048572K free,   683260K cached
400%cpu 125%user   1%nice  70%sys 202%idle   0%iow   0%irq   2%sirq   0%host
  PID USER         PR  NI VIRT  RES  SHR S[%CPU] %MEM     TIME+ ARGS
  555 graphics     -2  -8 150M  62M  45M S 72.4   3.1 895:19.80 render_service
  539 composer_ho+ -2  -8  17M 4.9M 3.8M S 23.2   0.2 282:37.59 composer_host           9 composer_host -8 1
  247 logd         20   0  16M 4.9M 2.3M S 12.2   0.2 167:45.62 hilogd
14516 root          0 -20    0    0    0 I  3.3   0.0   0:07.05 [kworker/u9:1-kbase_pm_poweroff_wait]
14587 root         25   5  14M 3.0M 2.6M R  2.9   0.1   0:00.12 top
  178 root         RT   0    0    0    0 S  2.3   0.0  36:26.03 [sugov:0]
# strace -cp 555
strace: Process 555 attached
strace: Process 555 detached
% time     seconds  usecs/call     calls    errors syscall
 22.34    0.456649          22     20705           clock_gettime64
 20.30    0.415126          66      6201           ioctl
 16.03    0.327786          45      7236           writev
 10.87    0.222298          31      7006           close
  7.24    0.148065          18      7855           gettid
  5.90    0.120715          58      2058       168 futex
  3.65    0.074596          22      3296           dup
  2.76    0.056384          68       825           munmap
  2.27    0.046345          55       828           write
  1.93    0.039523          27      1442           poll
  1.64    0.033546          40       824           mmap2
  1.49    0.030400          36       828           fcntl64
  1.40    0.028689          34       824           prctl
  0.80    0.016341          36       447       206 read
  0.50    0.010236          24       412           _llseek
  0.46    0.009408          45       207           madvise
  0.36    0.007341          35       206           epoll_pwait
  0.05    0.001017        1017         1           restart_syscall
100.00    2.044465                 61201       374 total
跟进分析:通过「T」选项可以获取操作实际消耗的时间,通过「e」选项可以跟踪某个操作
strace -T -e clock_gettime64 -p 555
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=627412894}) = 0 < 0.000037 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=627777769}) = 0 < 0.000149 >
clock_gettime64(CLOCK_REALTIME, {tv_sec=1702433139, tv_nsec=94341493}) = 0 < 0.000047 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=628287311}) = 0 < 0.000042 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=628442478}) = 0 < 0.000038 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=628586853}) = 0 < 0.000039 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=628774978}) = 0 < 0.000037 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=629033978}) = 0 < 0.000039 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=629318936}) = 0 < 0.000041 >
clock_gettime64(CLOCK_MONOTONIC, {tv_sec=89616, tv_nsec=629491020}) = 0 < 0.000039 >
这就是一个最简单的查看性能问题的流程,先统计,再看具体操作,然后查看代码,锁定问题。剩下的就是祝好运咯。当然如果发现输出比较少,还有个工具是 ltrace
为了能让大家更好的学习鸿蒙 (OpenHarmony) 开发技术,这边特意整理了《鸿蒙 (OpenHarmony)开发学习手册》,希望对大家有所帮助:
《鸿蒙(Harmony OS)开发学习手册》
入门必看:https://docs.qq.com/doc/DUk51cHZJaUpmSlhH
1.应用开发导读(ArKTS)
2.……
HarmonyOS概念:https://docs.qq.com/doc/DUk51cHZJaUpmSlhH
1.系统定义
2.技术框架
3.技术特性
4.系统安全
快速入门:https://docs.qq.com/doc/DUk51cHZJaUpmSlhH
1.基本概念
2.构建第一个ArkTS应用
3.……
开发基础知识:https://docs.qq.com/doc/DUk51cHZJaUpmSlhH
1.应用基础知识
2.配置文件
3.应用数据管理
4.应用安全管理
5.应用隐私保护
6.三方应用调用管控机制
7.资源分类与访问
8.学习ArkTS
9…
基于ArkTS 开发:https://docs.qq.com/doc/DUk51cHZJaUpmSlhH
1.Ability开发
2.UI开发
3.公共事件与通知
4.窗口管理
5.媒体
6.安全
7.网络与链接
8.电话服务
9.数据管理
10.后台任务(Background Task)管理
11.设备管理
12.设备使用信息统计
13.DFX
14.国际化开发
15.折叠屏系列
16………
  • 鸿蒙
  • HarmonyOS
    基于OPenHarmony的智慧牧场#鸿蒙
    鸿蒙HarmonyOSOpenHarmony
    发布于 :2022年09月23日 16:21:11
    基于 OpenHarmony,国内首个轻鸿蒙手表 OS 发行版出炉
    基于OpenHarmony,国内首个轻鸿蒙手表OS发行版出炉好叭科技近日发布了基于 OpenHarmony 的轻鸿蒙手表 OS 发行版。本次发行版主要有三个特性:UI 交互、数据与语音
    发表于 11-16 14:14
    Linux strace命令的用法
    简介strace常用来跟踪进程执行时的系统调用和所接收的信号。 在Linux世界,进程不能直接访问硬件设备,当进程需要访问硬件设备(比如读取磁盘文件,接收网络数据等等)时,必须由用户
    发表于 04-02 14:48 379次阅读
    openharmony鸿蒙区别
    OpenHarmony是HarmonyOS的开源版。 华为的鸿蒙操作系统是纯自己研发的,但是openharmony却不是华为的,openharmony是由开放原子开源基金会(OpenA
    的头像 发表于 06-24 16:21 4243次阅读
    openharmony鸿蒙有什么关系
    平板、手机、智能家居都可以通过建房子搭积木的方式来使用鸿蒙系统。 openharmony鸿蒙之间属于相辅相成的,可以说openharmony就是建设
    的头像 发表于 06-22 16:02 1.2w次阅读
    openharmony 鸿蒙
    openharmony 鸿蒙 openharmony 鸿蒙,HarmonyOS是一款“面向未来”、面向全场景(移动办公、运动健康、社交通信、媒体娱乐等)的分布式操作系统。在传统的单设备
    的头像 发表于 06-21 19:37 1913次阅读
    openharmony官网和鸿蒙
    openharmony官网和鸿蒙 OpenHarmony(开源鸿蒙系统)是HarmonyOS的开源版,由华为捐赠给开放原子开源基金会(OpenAtom Foundation)开源,第一
    的头像 发表于 06-21 19:50 2707次阅读
    openharmony鸿蒙的关系
    openharmony鸿蒙的关系 openharmony鸿蒙的关系,6月15日,华为发布了一份名为“2021 年 HarmonyOS 2 全国统一考试”的考卷,题型有听力题、单选题
    的头像 发表于 06-21 19:56 2407次阅读
    <b class='flag-5'>openharmony</b>和<b class='flag-5'>鸿蒙</b>的关系
    华为openharmony鸿蒙 2.0
    华为openharmony鸿蒙 2.0 IT之家 5 月 17 日消息 微博博主 @钊哥科普 此前爆料,华为鸿蒙 OpenHarmony 2.0 从 5 月 16 日开始开源,关键代码
    的头像 发表于 06-21 20:13 2121次阅读
    openharmony2.0大会 openharmony鸿蒙的关系
    近日,开放原子开源基金会(以下简称“基金会”)在深圳·国际开源谷举办了OpenHarmony 2.0共建邀请会。那么,OpenHarmony等于热词HarmonyOS吗?openharmony
    的头像 发表于 06-22 09:58 2358次阅读
    openharmony鸿蒙区别
    我们知道华为是开源了鸿蒙系统的,开源的项目叫做OpenHarmony 2.0。华为捐赠给了“开放原子开源基金会”,这样可以根据不同的诉求来做不同的产品。那么这个开源的OpenHarmony和华为
    的头像 发表于 06-22 15:14 5693次阅读
    openharmony鸿蒙2.0的关系
    openharmony鸿蒙2.0的关系到底是什么?下面就由小编带领大家简单介绍一下!
    的头像 发表于 06-23 11:10 2146次阅读
    openharmony鸿蒙的区别是什么
    我们都知道,华为鸿蒙系统华为是开源了的,开源项目叫做OpenHarmony 2.0,那么这个开源的OpenHarmony 2.0与华为自家使用的鸿蒙HarmonyOS 2,又有什么区别
    的头像 发表于 06-23 11:53 1w次阅读
    如何在开源鸿蒙OpenHarmony开启SELinux模式?RK3566鸿蒙开发板演示
    本文介绍开源鸿蒙OpenHarmony系统下,开启/关闭SELinux权限的方法,触觉智能Purple Pi OH鸿蒙开发板演示,已适配全新OpenHarmony5.0 Release
    的头像 发表于 11-18 19:03 462次阅读
    如何在开源<b class='flag-5'>鸿蒙</b><b class='flag-5'>OpenHarmony</b>开启SELinux模式?RK3566<b class='flag-5'>鸿蒙</b>开发板演示
    OpenHarmony怎么修改DPI密度值?触觉智能RK3566鸿蒙开发板演示
    开源鸿蒙OpenHarmony系统下,修改DPI密度值的方法,触觉智能Purple Pi OH鸿蒙开发板演示,搭载了瑞芯微RK3566四核处理器,Laval鸿蒙社区推荐开发板,已适配全
    的头像 发表于 12-24 11:46 296次阅读
    <b class='flag-5'>OpenHarmony</b>怎么修改DPI密度值?触觉智能RK3566<b class='flag-5'>鸿蒙</b>开发板演示
