鸿蒙HarmonyOS开发实例:【分布式关系型数据库】
jf_46214456 来源:jf_46214456 作者:jf_46214456 2024-04-11 09:52 次阅读
分布式关系型数据库
介绍
本示例使用[@ohos.data.relationalStore]接口和[@ohos.distributedDeviceManager] 接口展示了在eTS中分布式关系型数据库的使用,在增、删、改、查的基本操作外,还包括分布式数据库的数据同步同能。
效果预览
使用说明:
  1. 启动应用后点击“ + ”按钮可以添加联系人;
  2. 点击联系人可以进入编辑界面编辑联系人信息;
  3. 长按联系人进入多选状态,底部有“ 全选 ”、“ 取消 ”、“ 删除 ”、“ 退出 ”按钮,点击退出可以退出多选状态;
  4. 点击右上角更多按钮,点击“ 连接设备 ”,选择要同步数据的设备,连接成功后可以开始将本端数据同步到对端;
  5. 点击右上角更多按钮,点击“ 设置 ”可以进入设置界面设置数据同步方式,包括自动同步和手动同步。
具体实现
  • 数据库的增、删、改、查操作都在RdbModel中,源码参考[RdbModel.ets]:
 * Copyright (c) 2023 Huawei Device Co., Ltd.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
import data_rdb from '@ohos.data.relationalStore'
import common from '@ohos.app.ability.common'
import Contact from '../model/Contact'
import Logger from '../model/Logger'
import { STORE_CONFIG } from '../model/RdbConst'
import { ValuesBucket } from '@ohos.data.ValuesBucket';
const TAG = 'RdbModel'
export default class RdbModel {
  private rdbStore: data_rdb.RdbStore | undefined = undefined
  private tableName: string = ''
  private sqlCreateTable: string = ''
  private columns: Array< string > = []
  private distributedTable: string = ''
  private dataChangeCallback : Function| null = null
  private isCreateDbDone: boolean = false
  private context: common.UIAbilityContext
  constructor(tableName: string, sqlCreateTable: string, columns: Array< string >, context: common.UIAbilityContext) {
    this.tableName = tableName
    this.sqlCreateTable = sqlCreateTable
    this.columns = columns
    this.context = context
    this.getRdbStore()
  // 初始化数据库
  async getRdbStore() {
    Logger.info(TAG, 'getRdbStore begin')
    if (this.isCreateDbDone) {
      Logger.info(TAG, 'getRdbStore isCreateDbDone')
      return
    try {
      // 获取数据库存储对象
      this.rdbStore = await data_rdb.getRdbStore(this.context, STORE_CONFIG);
    } catch (err) {
      console.info(`getRdbStore err ${JSON.stringify(err)}`);
    Logger.info(TAG, 'getRdbStore end')
    try {
      // 执行sql语句,联系人个各个属性设定
      if(this.rdbStore != undefined) {
        await this.rdbStore.executeSql(this.sqlCreateTable)
        console.info(`create tabe start ` + this.sqlCreateTable);
        // 设置分布式表,表明为contact
        await this.rdbStore.setDistributedTables([this.tableName])
    } catch (e) {
      Logger.error(TAG, 'getRdbStore:' + JSON.stringify(e))
    // 分布式数据库创建为完成
    this.isCreateDbDone = true
    Logger.info(TAG, 'create table done')
  async insertData(contact: Contact) {
    let value1 = contact.name;
    let value2 = contact.gender;
    let value3 = contact.phone;
    let value4 = contact.remark;
    let value5 = contact.age;
    const valueBucket: ValuesBucket = {
      'name': value1,
      'gender': value2,
      'phone': value3,
      'remark': value4,
      'age': value5,
      let ret = await this.rdbStore.insert(this.tableName, valueBucket, data_rdb.ConflictResolution.ON_CONFLICT_REPLACE)
      Logger.info(TAG, `insert done:${ret}`)
  async updateData(contact: Contact) {
      'name': value1,
      'gender': value2,
      'phone': value3,
      'remark': value4,
      'age': value5,
    let predicates = new data_rdb.RdbPredicates(this.tableName)
    Logger.info(TAG, `updateData id=${contact.id}`)
    predicates.equalTo('id', contact.id)
    if (this.rdbStore != undefined) {
      let ret = await this.rdbStore.update(valueBucket, predicates)
      Logger.info(TAG, `updated row count: ${ret}`)
  async deleteContacts(contacts: Array< Contact >) {
    contacts.forEach((contact) = > {
      predicates.or()
      let rows = await this.rdbStore.delete(predicates)
      Logger.info(TAG, `delete rows: ${rows}`)
  async query(predicates: data_rdb.RdbPredicates): Promise< Array< Contact >> {
    Logger.info(TAG, 'query start')
    Logger.info(TAG, 'predicates is ' + JSON.stringify(predicates))
    Logger.info(TAG, 'columns ' + JSON.stringify(this.columns))
      // 默认查询所有列
      let resultSet: data_rdb.ResultSet = await this.rdbStore.query(predicates, this.columns);
      Logger.info(TAG, 'result is ' + JSON.stringify(resultSet.rowCount))
      // 处理查询到的结果数组
      return this.getListFromResultSet(resultSet)
    return []
  async syncData(predicates: data_rdb.RdbPredicates) {
    Logger.info(TAG, 'syncData')
      let result = await this.rdbStore.sync(data_rdb.SyncMode.SYNC_MODE_PUSH, predicates)
      for (let i = 0; i < result.length; i++) {
        Logger.info(TAG, `device=${result[i][0]}, status = ${result[i][1]}`)
  async onDataChange(device: string, callback: Function) {
    Logger.info(TAG, `onDataChange enter,device=` + device + ` ,tableName = ` + this.tableName)
    try {
        this.distributedTable = await this.rdbStore.obtainDistributedTableName(device, this.tableName)
        Logger.info(TAG, `obtainDistributedTableName,distributedTable=` + this.distributedTable)
    catch (err) {
      Logger.error(TAG, `ObtainDistributedTableName failed, code is ${err.code},message is ${err.message}`)
    this.dataChangeCallback = callback
    await this.pullData()
      this.rdbStore.on('dataChange', data_rdb.SubscribeType.SUBSCRIBE_TYPE_REMOTE, async (devices) = > {
        Logger.info(TAG, `on dataChange, callback`)
  async pullData() {
    Logger.info(TAG, `start pullData`)
      await this.rdbStore.executeSql('delete from ' + this.tableName)
      let predicates = new data_rdb.RdbPredicates(this.distributedTable)
      let resultSet = await this.rdbStore.query(predicates, this.columns)
      let result = this.getListFromResultSet(resultSet)
      Logger.info(TAG, `on dataChange,result.length=${result.length}`)
        Logger.info(TAG, `on dataChange,insert${result[i].name}`)
        let predicate = new data_rdb.RdbPredicates(this.tableName)
        predicate.equalTo('name', result[i].name)
        let exit = await this.rdbStore.query(predicate, this.columns)
        exit.goToFirstRow()
        if (exit.rowCount === 0) {
          await this.insertData(result[i])
        } else {
          result[i].id = exit.getDouble(resultSet.getColumnIndex('id'))
          await this.updateData(result[i])
      if (this.dataChangeCallback != null) {
        this.dataChangeCallback(result)
  offDataChange() {
      this.rdbStore.off('dataChange', data_rdb.SubscribeType.SUBSCRIBE_TYPE_REMOTE, (devices) = > {
        for (let i = 0; i < devices.length; i++) {
          Logger.info(TAG, `device=${devices[i]} off data changed`)
  // 处理数据格式
  getListFromResultSet(resultSet: data_rdb.ResultSet): Array< Contact > {
    // 声明结果变量
    let contacts: Array< Contact > = []
    // 进入结果集的第一行
    resultSet.goToFirstRow()
    // 如果没有结束就继续遍历
    while (!resultSet.isEnded) {
      // 读取各个属性,初始化临时变量contact
      let contact: Contact = new Contact(resultSet.getDouble(resultSet.getColumnIndex('id'))
        , resultSet.getString(resultSet.getColumnIndex('name'))
        , resultSet.getDouble(resultSet.getColumnIndex('gender'))
        , resultSet.getString(resultSet.getColumnIndex('phone'))
        , resultSet.getLong(resultSet.getColumnIndex('age'))
        , resultSet.getString(resultSet.getColumnIndex('remark')))
      if (!contacts.includes(contact)) {
        // 如果数据集合中没有这条数据就添加进去
        contacts.push(contact)
      // 进入下一行
      resultSet.goToNextRow()
    // 数据整合完毕就释放资源
    resultSet.close()
    Logger.info(TAG, 'contacts number is ' + contacts.length)
    // 返回整合的联系人数据
    return contacts
  • 数据库操作:使用[@ohos.data.relationalStore] 接口的getRdbStore获得一个相关的操作型关系数据库RdbStore,通过这个RdbStore调用相关接口进行增删改查,RdbStore.insert数据插入,RdbStore.delete数据删除,RdbStore.update更新数据,RdbStore.query根据条件查询数据;
  • 数据同步:RdbStore.on注册数据库观察者,使用RdbStore.obtainDistributedTableName根据本地表名获取指定远程设备的分布式表名,数据发生变动时通过RdbStore.sync同步数据,不需要用时删除指定观察者使用RdbStore.off。
  • 连接设备管理在RemoteDeviceModel中,源码参考[RemoteDeviceModel.ets]:
import deviceManager from '@ohos.distributedDeviceManager';
import { BUNDLE } from '../model/RdbConst'
import { BusinessError } from '@ohos.base';
let SUBSCRIBE_ID = 100
const TAG: string = 'RemoteDeviceModel'
class Data {
  device: deviceManager.DeviceBasicInfo = {
    deviceId: "",
    deviceName: "",
    deviceType: "",
    networkId: "",
class RemoteDeviceModel {
  public deviceList: Array< deviceManager.DeviceBasicInfo > = [];
  public discoverList: Array< deviceManager.DeviceBasicInfo > = [];
  private callback: () = > void = () = > {};
  private authCallback: (device: deviceManager.DeviceBasicInfo) = > void = (device: deviceManager.DeviceBasicInfo) = > '';
  private deviceManager: deviceManager.DeviceManager | undefined = undefined
  registerDeviceListCallback(callback: () = > void) {
    if (typeof (this.deviceManager) !== 'undefined') {
      this.registerDeviceListCallbackImplement(callback)
      return
    Logger.info(TAG, 'deviceManager.createDeviceManager begin')
    try {
      let dmInstance = deviceManager.createDeviceManager(BUNDLE);
      Logger.info(TAG, `dmInstance= ${JSON.stringify (dmInstance)}`);
      this.deviceManager = dmInstance;
      this.registerDeviceListCallbackImplement(callback);
      Logger.info(TAG, `createDeviceManager callback returned, value= ${JSON.stringify(this.deviceManager)}`);
    } catch (error) {
      Logger.error(TAG, `createDeviceManager throw error, code: ${(error as BusinessError).code} message: ${(error as BusinessError).message}`);
    Logger.info(TAG, 'deviceManager.createDeviceManager end');
  deviceStateChangeActionOnline(device: deviceManager.DeviceBasicInfo) {
    this.deviceList[this.deviceList.length] = device
    Logger.info(TAG, `online, device list=${JSON.stringify(this.deviceList)}`)
    if (this.authCallback !== undefined) {
      this.authCallback(device)
      this.authCallback = () = > {}
  deviceStateChangeActionReady(device: deviceManager.DeviceBasicInfo) {
    if (this.deviceList.length <= 0) {
      this.callback()
      return
    let list: Array< deviceManager.DeviceBasicInfo > = new Array()
    for (let i = 0; i < this.deviceList.length; i++) {
      if (this.deviceList[i].deviceId !== device.deviceId) {
        list[i] = device
    this.deviceList = list
    Logger.info(TAG, `ready, device list=${JSON.stringify(this.deviceList)}`)
    this.callback()
  deviceStateChangeActionOffline(device: deviceManager.DeviceBasicInfo) {
      this.callback()
      return
    for (let j = 0; j < this.deviceList.length; j++) {
      if (this.deviceList[j].deviceId === device.deviceId) {
        this.deviceList[j] = device
        break
    Logger.info(TAG, `offline, device list=${JSON.stringify(this.deviceList)}`)
  getLocalDevice(): string {
    Logger.info(TAG, `getLocalDevice`);
    if(this.deviceManager != undefined) {
      let deviceId: string = this.deviceManager.getLocalDeviceId();
      Logger.info(TAG, `local deviceInfo=${JSON.stringify(deviceId)}`);
      return deviceId;
    return ''
  registerDeviceListCallbackImplement(callback: () = > void) {
    Logger.info(TAG, 'registerDeviceListCallback' + JSON.stringify(this.deviceManager))
    this.callback = callback
    if (this.deviceManager === undefined) {
      Logger.error(TAG, 'deviceManager has not initialized')
      this.callback()
      return
    Logger.info(TAG, 'getTrustedDeviceListSync begin' + JSON.stringify(this.deviceManager));
    let list = this.deviceManager.getAvailableDeviceListSync();
    Logger.info(TAG, `getTrustedDeviceListSync end, deviceList=${JSON.stringify(list)}`)
    if (typeof (list) !== 'undefined' && typeof (list.length) !== 'undefined') {
    this.callback()
    Logger.info(TAG, 'callback finished')
    this.deviceManager.on('deviceStateChange', (data) = > {
      Logger.info(TAG, 'deviceStateChange on:' + JSON.stringify(data));
      if (data === null) {
        return
      switch (data.action) {
        case deviceManager.DeviceStateChange.UNKNOWN:
          this.deviceStateChangeActionOnline(data.device)
          break
        case deviceManager.DeviceStateChange.AVAILABLE:
          this.deviceStateChangeActionReady(data.device)
          break
        case deviceManager.DeviceStateChange.UNAVAILABLE:
          this.deviceStateChangeActionOffline(data.device)
          break
        default:
          break
    this.deviceManager.on('discoverSuccess', (data: Data) = > {
        return
      Logger.info(TAG, `discoverSuccess data=${JSON.stringify(data)}`);
      this.deviceFound(data);
    this.deviceManager.on('discoverFailure', (data) = > {
      Logger.info(TAG, `discoverFailure data=${JSON.stringify(data)}`);
    this.deviceManager.on('serviceDie', () = > {
      Logger.info(TAG, 'serviceDie')
    this.startDeviceDiscovery()
  deviceFound(data: Data) {
    if(data != undefined) {
      if (data.device != undefined) {
        for (let i = 0; i < this.discoverList.length; i++) {
          if (this.discoverList[i].deviceId === data.device.deviceId) {
            Logger.info(TAG, 'device founded ignored')
            return
        this.discoverList[this.discoverList.length] = data.device
        Logger.info(TAG, `deviceFound self.discoverList=${JSON.stringify(this.discoverList)}`);
        this.callback()
  startDeviceDiscovery() {
    let discoverParam: Record< string, number > = {
      'discoverTargetType': 1
    let filterOptions: Record< string, number > = {
      'availableStatus': 0
    Logger.info(TAG, `startDeviceDiscovery${SUBSCRIBE_ID}`);
    try {
        this.deviceManager.startDiscovering(discoverParam, filterOptions);
    } catch (error) {
      Logger.error(TAG, `startDeviceDiscovery throw error, code: ${(error as BusinessError).code} message: ${(error as BusinessError).message}`);
  unregisterDeviceListCallback() {
      Logger.info(TAG, `stopDeviceDiscovery${SUBSCRIBE_ID}`);
      this.deviceManager.stopDiscovering();
      this.deviceManager.off('deviceStateChange');
      this.deviceManager.off('discoverSuccess');
      this.deviceManager.off('discoverFailure');
      this.deviceManager.off('serviceDie');
    this.deviceList = [];
    this.discoverList = [];
  authenticateDevice(device: deviceManager.DeviceBasicInfo, callBack: (device: deviceManager.DeviceBasicInfo) = > void) {
    Logger.info(TAG, `bindTarget${JSON.stringify(device)}`);
      if (this.discoverList[i].deviceId !== device.deviceId) {
        continue
        return
      try {
        if (this.deviceManager !== null) {
          this.deviceManager.bindTarget(device.deviceId, {
            bindType: 1,
            targetPkgName: BUNDLE,
            appName: 'Distributed distributedrdb',
          }, (err, data) = > {
            if (err) {
              Logger.error(TAG, `authenticateDevice throw error, code: ${(err as BusinessError).code} message: ${(err as BusinessError).message}`);
              return
            Logger.debug(TAG, `authenticateDevice succeed: ${JSON.stringify(data)}`);
            this.authCallback = callBack;
      } catch (error) {
        Logger.error(TAG, `authenticateDevice throw error, code: ${(error as BusinessError).code} message: ${(error as BusinessError).message}`);
export default new RemoteDeviceModel()
  • 设备同步:设备同步数据需要[ohos.permission.DISTRIBUTED_DATASYNC] 权限,在页面渲染前申请权限,源码参考[Index.ets],
 * Copyright (c) 2022-2023 Huawei Device Co., Ltd.
import Want from '@ohos.app.ability.Want'
import router from '@ohos.router'
import ContactDataSource from '../common/BasicDataSource'
import LiteStore from '../model/LiteStore'
import RdbModel from '../model/RdbModel'
import { BottomBtn } from '../common/BottomBtn'
import { ContactItem } from '../common/ContactItem'
import { PopupMenu } from '../common/PopupMenu'
import { SyncState } from '../model/LiteStore'
import { SearchBar } from '../common/SearchBar'
import { TitleBar } from '../common/TitleBar'
import { TABLE_NAME, BUNDLE, ABILITY, SQL_CREATE_TABLE, COLUMNS } from '../model/RdbConst'
const TAG: string = 'Index'
export interface stateType {
  popupMenu: boolean,
  isDistributed: boolean,
  isStage: boolean,
  selectedIndex: number,
  syncState: string,
  distributedDevice: string,
  opacityValue: number
@Entry
@Component
struct Index {
  private liteStore = new LiteStore("sync_state", getContext(this) as common.UIAbilityContext)
  private rdbModel = new RdbModel(TABLE_NAME, SQL_CREATE_TABLE, COLUMNS, getContext(this) as common.UIAbilityContext)
  private intervalId: number = 0
  @State contacts: ContactDataSource = new ContactDataSource([])
  @State isMultiCheck: boolean = false
  @State isSelectedAll: boolean = false
  @State state: stateType = {
    popupMenu: false,
    isDistributed: false,
    isStage: false,
    selectedIndex: 0,
    syncState: SyncState.ManualSync,
    distributedDevice: '',
    opacityValue: 1
  async aboutToAppear() {
    Logger.info(TAG, 'aboutToAppear')
    await this.rdbModel.getRdbStore();
    await this.getData();
  // 拉起应用后读取数据,暂定为分布式功能
  getWant() {
    let want = AppStorage.Get< Want >('want') as Want
    if(want.parameters != undefined) {
      if (this.state.isDistributed && want.parameters.isStage === 'EXIT') {
        Logger.info(TAG, 'isStage = EXIT')
        this.state.isStage = false
        this.state.isDistributed = false
        this.state.selectedIndex = 0
        this.state.distributedDevice = ''
        this.rdbModel.offDataChange()
      if (!this.state.isDistributed && want.parameters.isStage === 'Stage') {
        Logger.info(TAG, 'isStage = Stage')
        this.state.isStage = true
        this.state.isDistributed = true
        this.state.distributedDevice = want.parameters.dmsSrcNetworkId as string;
        let context = getContext(this) as common.UIAbilityContext
        context.startAbility({
          bundleName: BUNDLE,
          abilityName: ABILITY,
          deviceId: this.state.distributedDevice,
          parameters: {
            isStage: 'CONNECT'
        Logger.info(TAG, 'onDataChange')
        this.rdbModel.onDataChange(this.state.distributedDevice, (result: Array< Contact >)= > {
        this.contacts.dataArray = result
          this.contacts.notifyDataReload()
  async onPageShow() {
    try {
      // 初始化分部署数据库
      this.intervalId = setInterval(() = > {
        // 手动侦听应用被拉起的动作
        this.getWant()
      }, 1000)
      // 读取数据库数据
    } catch (err) {
      Logger.error('onPageShow:' + JSON.stringify(err))
  async getData() {
    Logger.info(TAG, 'getData')
    // 初始化数据库的表,表名为contact
    let predicates = new data_rdb.RdbPredicates(TABLE_NAME)
    // 读取表中的数据
    this.contacts.replaceDataArray(await this.rdbModel.query(predicates));
    // 通知懒加载数据变更
    Logger.info(TAG, 'getData contacts count' + this.contacts.dataArray.length)
    // 读取Preferences中的数据
    let syncState = await this.liteStore.getValue()
    this.state.syncState = `${syncState}`
    if (!this.state.isStage && this.state.isDistributed && syncState === SyncState.AutomaticSync) {
      await this.syncData()
  showDeleteDialog() {
    let deleteContacts: Contact[] = []
    this.contacts.dataArray.forEach((contact) = > {
      if (contact.isSelected) {
        deleteContacts.push(contact)
    if (deleteContacts.length == 0) {
      return
    AlertDialog.show({
      message: $r('app.string.delete_contact'),
      primaryButton: {
        value: $r('app.string.sure'),
        fontColor: Color.Red,
        action: async () = > {
          await this.rdbModel.deleteContacts(deleteContacts)
          this.quitMultiCheck()
      secondaryButton: {
        value: $r('app.string.cancel'),
        fontColor: Color.Blue,
        action: () = > {
  handleClickContact(item: Contact, index: number) {
    Logger.info(TAG, `handleClickContact, item = ${JSON.stringify(item)}`)
    if (this.isMultiCheck) {
      let tempContacts = this.contacts.dataArray
      this.contacts.dataArray = []
      tempContacts[index].isSelected = !item.isSelected
      this.contacts.dataArray = tempContacts
    } else {
      router.pushUrl({
        url: 'pages/ContactEdit',
        params: { contact: item, isInsert: false }
  refreshSelectState(isSelect: boolean) {
      contact.isSelected = isSelect
  quitMultiCheck() {
    this.isSelectedAll = false
    this.refreshSelectState(this.isSelectedAll)
    this.isMultiCheck = false
  handleBottomBtnClick = (index: number) = > {
    switch (index) {
      case 0:
        this.isSelectedAll = !this.isSelectedAll
        break
      case 1:
        this.showDeleteDialog()
        break
      case 2:
        break
      default:
        break
  handleRightBtn = () = > {
    this.state.popupMenu = true;
    this.state.opacityValue = 1;
  syncData = () = > {
    Logger.info(TAG, 'sync data')
    predicates.inAllDevices()
    this.rdbModel.syncData(predicates)
  build() {
    Stack({ alignContent: Alignment.BottomEnd }) {
      Column() {
        Stack() {
          if (this.state.isStage) {
            TitleBar()
          } else {
            TitleBar({ rightBtn: $r('app.media.more'), handleRightBtn: this.handleRightBtn })
          if (this.state.isDistributed && !this.state.isStage && this.state.syncState === SyncState.ManualSync) {
            Row() {
              Blank()
              Image($r('app.media.ic_syncto'))
                .size({ width: 50, height: 60 })
                .onClick(this.syncData)
            }.width('80%')
        }.width('100%')
        SearchBar()
        List() {
          LazyForEach(this.contacts, (item: Contact, index) = > {
            ListItem() {
              ContactItem({ contact: item, isMultiCheck: $isMultiCheck })
            .onClick(() = > {
              this.handleClickContact(item, index)
          }, (item: Contact) = > JSON.stringify(item))
        .width('100%')
        .layoutWeight(1)
        .padding({ left: 10, right: 10 })
        .divider({ strokeWidth: 1, color: Color.Gray, startMargin: 16, endMargin: 16 })
      .width('100%')
      .height('100%')
      if (this.state.popupMenu) {
        PopupMenu({ state: $state, handleStartAbility: this.syncData })
      BottomBtn({
        isMultiCheck: this.isMultiCheck,
        isSelectedAll: this.isSelectedAll,
        handleBottomBtnClick: this.handleBottomBtnClick
      if (!this.isMultiCheck && !this.state.isStage) {
        Button() {
          Image($r('app.media.add'))
            .height('100%')
            .width('100%')
            .objectFit(ImageFit.Contain)
            .align(Alignment.End)
        .id('btnAdd')
        .width(80)
        .height(80)
        .margin({ right: 20, bottom: 50 })
        .type(ButtonType.Circle)
        .backgroundColor('#0D9FFB')
        .onClick(() = > {
          Logger.info(TAG, 'onClick')
          router.pushUrl({
            params: { contact: new Contact(0, '', 0, '', -1, ''), isInsert: true }
    .width('100%')
    .height('100%')
  onBackPress() {
    Logger.info(TAG, 'onBackPress')
      bundleName: BUNDLE,
      parameters: {
        isStage: 'EXIT'
  onPageHide() {
    clearInterval(this.intervalId)
使用[@ohos.distributedDeviceManager]接口,首先通过createDeviceManager创建设备管理器实例,然后通过getTrustedDeviceListSync同步获取所有可信设备列表;
  • 设备连接:首先通过on方法注册设备状态,例如发现设备,设备连接失败,然后通过startDeviceDiscovery方法发现周边设备,然后选择连接设备,再用[startAbility]启动连接设备的应用。
  • 数据库
  • 分布式
  • 鸿蒙
  • HarmonyOS
  • OpenHarmony
    一文讲清什么是分布式云化数据库
    分布式云化数据库是一种先进的数据管理系统,它将传统的数据库技术与分布式计算、云计算和大数据处理技
    的头像 发表于 10-14 10:06 218次阅读
    基于分布式存储WDS的金融信创云承载数据库类关键应用
    的头像 发表于 08-16 09:42 268次阅读
    基于<b class='flag-5'>分布式</b>存储WDS的金融信创云承载<b class='flag-5'>数据库</b>类关键应用
    鸿蒙开发接口数据管理:【@ohos.data.rdb (关系数据库)】
    关系数据库(Relational Database,RDB)是一种基于关系模型来管理数据数据库
    的头像 发表于 06-10 18:35 1300次阅读
    鸿蒙开发接口数据管理:【@ohos.data.distributedData (分布式数据管理)】
    分布式数据管理为应用程序提供不同设备间数据库分布式协同能力。通过调用分布式数据各个接口,应用程
    的头像 发表于 06-07 09:30 962次阅读
    <b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>接口<b class='flag-5'>数据</b>管理:【@ohos.data.distributedData (<b class='flag-5'>分布式</b><b class='flag-5'>数据</b>管理)】
    HarmonyOS开发案例:【搭建关系数据库】(4)
    本节将介绍如何调用关系数据库接口在本地搭建数据库,并读写相应的用户数据
    的头像 发表于 05-11 10:27 869次阅读
    <b class='flag-5'>HarmonyOS</b><b class='flag-5'>开发</b>案例:【搭建<b class='flag-5'>关系</b><b class='flag-5'>型</b><b class='flag-5'>数据库</b>】(4)
    HarmonyOS开发案例:【关系数据库
    使用关系数据库的相关接口实现了对账单的增、删、改、查操作。
    的头像 发表于 04-22 14:58 647次阅读
    <b class='flag-5'>HarmonyOS</b><b class='flag-5'>开发</b>案例:【<b class='flag-5'>关系</b><b class='flag-5'>型</b><b class='flag-5'>数据库</b>】
    HarmonyOS开发实例:【分布式数据服务】
    分布式数据服务(Distributed Data Service,DDS)为应用程序提供不同设备间数据分布式的能力。
    的头像 发表于 04-18 10:18 707次阅读
    <b class='flag-5'>HarmonyOS</b><b class='flag-5'>开发</b><b class='flag-5'>实例</b>:【<b class='flag-5'>分布式</b><b class='flag-5'>数据</b>服务】
    HarmonyOS开发实例:【分布式手写板】
    使用设备管理及分布式键值数据库能力,实现多设备之间手写板应用拉起及同步书写内容的功能。
    的头像 发表于 04-17 21:45 486次阅读
    <b class='flag-5'>HarmonyOS</b><b class='flag-5'>开发</b><b class='flag-5'>实例</b>:【<b class='flag-5'>分布式</b>手写板】
    HarmonyOS开发实例:【分布式新闻客户端】
    基于栅格布局、设备管理和多端协同,实现一次开发,多端部署的分布式新闻客户端页面。
    的头像 发表于 04-17 15:57 868次阅读
    <b class='flag-5'>HarmonyOS</b><b class='flag-5'>开发</b><b class='flag-5'>实例</b>:【<b class='flag-5'>分布式</b>新闻客户端】
    HarmonyOS开发实例:【分布式邮件】
    基于TS扩展的声明开发范式编程语言编写的一个分布式邮件系统,可以由一台设备拉起另一台设备,每次改动邮件内容,都会同步更新两台设备的信息
    的头像 发表于 04-17 10:29 759次阅读
    <b class='flag-5'>HarmonyOS</b><b class='flag-5'>开发</b><b class='flag-5'>实例</b>:【<b class='flag-5'>分布式</b>邮件】
    HarmonyOS开发实例:【分布式数据管理】
    eTS中分布式数据管理的使用,包括KVManager对象实例的创建和KVStore数据流转的使用。
    的头像 发表于 04-11 09:57 927次阅读
    <b class='flag-5'>HarmonyOS</b><b class='flag-5'>开发</b><b class='flag-5'>实例</b>:【<b class='flag-5'>分布式</b><b class='flag-5'>数据</b>管理】
    HarmonyOS开发技术全面分析
    的快速连接、能力互助、资源共享,匹配合适的设备、提供流畅的全场景体验。 ⚫ 对应用开发者而言, HarmonyOS 采用了多种分布式技术,使得应用程序的开发实现与不同终端设备的形态差异
    发表于 02-21 16:31
    数据库数据恢复】Oracle数据库ASM实例无法挂载的数据恢复案例
    oracle数据库ASM磁盘组掉线,ASM实例不能挂载。数据库管理员尝试修复数据库,但是没有成功。
    的头像 发表于 02-01 17:39 518次阅读
    【<b class='flag-5'>数据库</b><b class='flag-5'>数据</b>恢复】Oracle<b class='flag-5'>数据库</b>ASM<b class='flag-5'>实例</b>无法挂载的<b class='flag-5'>数据</b>恢复案例
    鸿蒙OS 分布式任务调度
    鸿蒙OS 分布式任务调度概述 在 HarmonyO S中,分布式任务调度平台对搭载 HarmonyOS 的多设备构筑的“超级虚拟终端”提供统一的组件管理能力,为应用定义统一的能力基线、
    的头像 发表于 01-29 16:50 488次阅读
    鸿蒙千帆起】《开心消消乐》完成鸿蒙原生应用开发,创新多端联动用户体验
    加强游戏与玩家之间交互的提醒,用户不需要频繁打开游戏就能接收到游戏中的关键信息,比如精力恢复、新关卡开放、活动信息提醒等,给玩家提供了更加便捷的游戏体验。 同时,HarmonyOS 特有的分布式软总线
    发表于 01-03 10:22
