Ability与ServiceExtensionAbility通信
介绍
本示例展示通过[IDL的方式]和 [@ohos.rpc] 等接口实现了Ability与ServiceExtensionAbility之间的通信。
效果预览
使用说明
1.启动应用后,首页展示城市的天气信息,当前温度每隔5S会刷新一次。
工程目录
entry/src/main/ets/
|---Application
|---feature
| |---HomeFeature.ets // 任务信息组件
|---MainAbility
|---Mock
| |---RequestData.ts // 远程请求的数据
| |---WeatherData.ts // 天气页面数据
|---model
| |---FormDate.ts // 日期函数方法
| |---Main.ts // 数据类
|---pages
| |---home
| | |---BasicDataSource.ets // 懒加载封装类
| | |---HomeContent.ets // 内容组件
| | |---HoursWeather.ets // 天气组件(小时)
| | |---IndexHeader.ets // 首页头部组件
| | |---MultiDayWeather.ets // 天气组件(天)
| |---Home.ets // 首页
|---util
| |---Logger.ts // 日志工具
| |---Style.ts // 静态样式变量
具体实现
- Ability与ServiceExtensionAbility通信的方法主要封装在idl_weather_service_proxy、idl_weather_service_stub、HomeFeature、ServiceExtAbility中。
- 源码参考:[idl_weather_service_proxy.ts]
* Copyright (c) 2022 Huawei Device Co., Ltd.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
import rpc from '@ohos.rpc'
import { updateWeatherCallback } from './i_idl_weather_service'
import IIdlWeatherService from './i_idl_weather_service'
import Logger from '../../../util/Logger'
export default class IdlWeatherServiceProxy implements IIdlWeatherService {
constructor(proxy) {
this.proxy = proxy
updateWeather(data: number, callback: updateWeatherCallback): void {
let _option = new rpc.MessageOption(0)
let _data = new rpc.MessageParcel()
let _reply = new rpc.MessageParcel()
_data.writeInt(data)
this.proxy.sendRequest(IdlWeatherServiceProxy.COMMAND_UPDATE_WEATHER, _data, _reply, _option).then(function (result) {
if (result.errCode === 0) {
let _errCode = result.reply.readInt()
if (_errCode != 0) {
let _returnValue = undefined
callback(_errCode, _returnValue)
return
let _returnValue = result.reply.readInt()
} else {
Logger.error("sendRequest failed, errCode: " + result.errCode)
static readonly COMMAND_UPDATE_WEATHER = 1
private proxy
- [idl_weather_service_stub.ts]
export default class IdlWeatherServiceStub extends rpc.RemoteObject implements IIdlWeatherService {
constructor(des: string) {
super(des)
onRemoteRequest(code: number, data, reply, option): boolean {
Logger.info("onRemoteRequest called, code = " + code)
switch (code) {
case IdlWeatherServiceStub.COMMAND_UPDATE_WEATHER: {
let _data = data.readInt()
this.updateWeather(_data, (errCode, returnValue) = > {
reply.writeInt(errCode)
if (errCode == 0) {
reply.writeInt(returnValue)
return true
default: {
Logger.error("invalid request code" + code)
break
return false
- [HomeFeature]
import Logger from '../util/Logger'
import IdlWeatherServiceProxy from '../MainAbility/data/IIdlWeatherServiceTS/idl_weather_service_proxy'
const BUNDLE_NAME = "com.example.abilityconnectserviceextension"
const SERVICE_EXTENSION_ABILITY_NAME = "ServiceExtAbility"
const ERROR_CODE = -1 // 失败
const SUCCESS_CODE = 0 // 成功
export default class HomeFeature {
connection = -1 // 初始值
remoteCallback = null
context = null
options = null
constructor(context) {
this.context = context
this.options = {
outObj: this,
// 连接成功时回调
onConnect: function (elementName, proxy) {
Logger.info(`onConnect success`)
// 接收来自服务返回的实例
let weatherProxy = new IdlWeatherServiceProxy(proxy)
weatherProxy.updateWeather(123, this.outObj.remoteCallback)
onDisconnect: function () {
Logger.info(`onDisconnect`)
onFailed: function () {
Logger.info(`onFailed`)
connectServiceExtAbility(callback) {
Logger.info(`connectServiceExtAbility`)
this.remoteCallback = callback
let want = {
bundleName: BUNDLE_NAME,
abilityName: SERVICE_EXTENSION_ABILITY_NAME
this.connection = this.context.connectAbility(want, this.options)
Logger.info(`connectServiceExtAbility result:${this.connection}`)
disconnectServiceExtAbility(callback) {
Logger.info(`disconnectServiceExtAbility`)
this.context.disconnectAbility(this.connection).then((data) = > {
Logger.info(`disconnectAbility success:${JSON.stringify(data)}`)
callback(SUCCESS_CODE)
}).catch((error) = > {
Logger.error(`disconnectAbility failed:${JSON.stringify(error)}`)
callback(ERROR_CODE)
- [ServiceExtAbility]
/*`HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿`
import ServiceExtension from '@ohos.app.ability.ServiceExtensionAbility'
import IdlWeatherServiceStub from '../MainAbility/data/IIdlWeatherServiceTS/idl_weather_service_stub'
import { updateWeatherCallback } from "../MainAbility/data/IIdlWeatherServiceTS/i_idl_weather_service"
import { getUpdateTemperature } from '../mock/RequestData'
class WeatherServiceStub extends IdlWeatherServiceStub {
constructor(des) {
super(des)
let temperature = getUpdateTemperature()
callback(0, temperature)
Logger.info(`testIntTransaction: temperature: ${temperature}`)
export default class ServiceExtAbility extends ServiceExtension {
onCreate(want) {
Logger.info(`onCreate, want: ${want.abilityName}`)
onRequest(want, startId) {
Logger.info(`onRequest, want: ${want.abilityName}`)
onConnect(want) {
Logger.info(`onConnect , want: ${want.abilityName}`)
return new WeatherServiceStub("weather service stub")
onDisconnect(want) {
Logger.info(`onDisconnect, want: ${want.abilityName}`)
onDestroy() {
Logger.info(`onDestroy`)
- 建立服务器连接:通过HomeFeature中的this.context.connectAbility(want, this.options)方法来建立服务器连接;
- 接收服务端实例并发送请求:连接成功时new IdlWeatherServiceProxy(proxy)来接收服务端实例,通过[@ohos.rpc] 接口来执行new rpc.MessageOption(0)、 new rpc.MessageParcel()、 new rpc.MessageParcel()获取 MessageParcel对象和请求的模式,调用idl_weather_service_proxy中的this.proxy.sendRequest()来发送请求;
- 接收远程请求处理数据:在idl_weather_service_stub中接收远程请求并通过ServiceExtAbility中的updateWeather()函数来处理数据进行返回;
- 获取数据:最后将获得的数据渲染到页面中去;
- 断开连接:可以通过HomeFeature中的this.context.disconnectAbility(this.connection)方法来断开服务器连接,这里的this.connection是建立连接之后的返回值。
举报投诉
框架
403浏览量
17514 -
鸿蒙
57文章
2372浏览量
42916
鸿蒙开发接口Ability框架:【@ohos.application.Ability (Ability)】
Ability模块提供对Ability生命周期、上下文环境等调用管理的能力,包括Ability创建、销毁、转储客户端信息等。
鸿蒙开发接口Ability框架:【@ohos.ability.featureAbility (FeatureAbility模块)】
FeatureAbility模块提供带有UI设计与用户交互的能力,包括启动新的ability、获取dataAbilityHelper、设置此Page Ability、获取当前Ability对应的窗口,连接
鸿蒙开发接口Ability框架:【@ohos.ability.particleAbility (particleAbility模块)】
particleAbility模块提供了Service类型Ability的能力,包括启动、停止指定的particleAbility,获取dataAbilityHelper,连接、断开当前Ability与指定ServiceAbility等。
鸿蒙开发接口Ability框架:【 (ServiceExtensionAbility)】
ServiceExtensionAbility模块提供ServiceExtension服务扩展相关接口的能力。
鸿蒙开发接口Ability框架:【(AbilityDelegator)】
AbilityDelegator提供添加用于监视指定能力的生命周期状态更改的AbilityMonitor对象的能力,包括对AbilityMonitor实例的添加、删除、等待ability到达
鸿蒙开发接口Ability框架:【AbilityDelegator】
鸿蒙Ability Kit(程序框架服务)【ServiceExtensionAbility】
[ServiceExtensionAbility]是SERVICE类型的ExtensionAbility组件,提供后台服务能力,其内部持有了一个[ServiceExtensionContext],通过[ServiceExtensionContext]提供了丰富的接口供外部
鸿蒙Ability开发-Stage模型下Ability的创建和使用
UIAbilityContext模块启动Ability的能力
UIAbilityContext模块提供允许访问特定Ability的资源的能力,包括对Ability的启动、停止
发表于 01-08 15:34
跟阿斌一起学鸿蒙(2): Ability vs App?
,程序员们依然可以为你实现,只是实现起来会相对麻烦,比如各种远程通信,各种数据和状态的同步,还有各种联调和测试。而鸿蒙OS,将很多麻烦的处理过程整合到操作系统中,借此希望让程序员们可以
发表于 11-30 20:56
鸿蒙开发Ability Kit程序框架服务:FA模型绑定Stage模型ServiceExtensionAbility
本文介绍FA模型的三种应用组件如何绑定Stage模型的ServiceExtensionAbility组件。
