用户认证
导入模块
import userIAM_userAuth from '@ohos.userIAM.userAuth';
完整示例
// API version 6
export default {
startAuth() {
console.info("start auth");
let auth = userIAM_userAuth.getAuthenticator();
auth.execute("FACE_ONLY", "S2").then((code)= >{
console.info("auth success");
// 此处添加认证成功逻辑
}).catch((code)= >{
console.error("auth fail, code = " + code);
// 此处添加认证失败逻辑
// API version 8
let auth = new userIAM_userAuth.UserAuth();
export default {
getVersion() {
console.info("start get version");
let version = this.auth.getVersion();
console.info("auth version = " + version);
startAuth() {
this.auth.auth(null, userIAM_userAuth.UserAuthType.FACE, userIAM_userAuth.AuthTrustLevel.ATL1, {
onResult: (result, extraInfo) = > {
try {
console.info("auth onResult result = " + result);
console.info("auth onResult extraInfo = " + JSON.stringify(extraInfo));
if (result == 'SUCCESS') {
// 此处添加认证成功逻辑
} else {
// 此处添加认证失败逻辑
} catch (e) {
console.info("auth onResult error = " + e);
onAcquireInfo: (module, acquire, extraInfo) = > {
try {
console.info("auth onAcquireInfo module = " + module);
console.info("auth onAcquireInfo acquire = " + acquire);
console.info("auth onAcquireInfo extraInfo = " + JSON.stringify(extraInfo));
} catch (e) {
console.info("auth onAcquireInfo error = " + e);
checkAuthSupport() {
console.info("start check auth support");
let checkCode = this.auth.getAvailableStatus(userIAM_userAuth.UserAuthType.FACE, userIAM_userAuth.AuthTrustLevel.ATL1);
if (checkCode == userIAM_userAuth.ResultCode.SUCCESS) {
console.info("check auth support success");
// 此处添加支持指定类型认证的逻辑
} else {
console.error("check auth support fail, code = " + checkCode);
// 此处添加不支持指定类型认证的逻辑
cancelAuth() {
console.info("start cancel auth");
// contextId通过auth接口获取
let contextId = auth.auth(null, userIAM_userAuth.UserAuthType.FACE, userIAM_userAuth.AuthTrustLevel.ATL1, {
let cancelCode = this.auth.cancel(contextId);
if (cancelCode == userIAM_userAuth.Result.SUCCESS) {
console.info("cancel auth success");
} else {
console.error("cancel auth fail");
userIAM_userAuth.getAuthenticator(deprecated)
getAuthenticator(): Authenticator
说明: 从 API Version 8 开始废弃,建议使用[constructor]替代。
获取Authenticator对象,用于执行用户身份认证。
需要权限 :ohos.permission.ACCESS_BIOMETRIC
系统能力 :以下各项对应的系统能力均为SystemCapability.UserIAM.UserAuth.Core
返回值:
类型 | 说明 |
[Authenticator] | 认证器对象。 |
示例:
let authenticator = userIAM_userAuth.getAuthenticator();
说明: 从 API Version 8 开始废弃,建议使用[UserAuth]替代。
认证器对象。
execute(deprecated)
execute(type: string, level: string, callback: AsyncCallback): void
说明: 从 API Version 8 开始废弃,建议使用[auth]替代。
执行用户认证,使用callback方式作为异步方法。
参数:
参数名 | 类型 | 必填 | 说明 |
type | string | 是 | 认证类型,当前只支持FACE_ONLY。 ALL为预留参数,当前版本暂不支持ALL类型的认证。 |
level | string | 是 | 安全级别,对应认证的安全级别,有效值为S1(最低)、S2、S3、S4(最高)。 具备3D人脸识别能力的设备支持S3及以下安全级别的认证。 具备2D人脸识别能力的设备支持S2及以下安全级别的认证。 |
callback | AsyncCallback | 否 | 回调函数。 |
callback返回值:
类型 | 说明 |
number | 表示认证结果,参见[AuthenticationResult]。 |
示例:
authenticator.execute("FACE_ONLY", "S2", (code)= >{
if (code == userIAM_userAuth.AuthenticationResult.SUCCESS) {
return;
execute(deprecated)
execute(type:string, level:string): Promise
执行用户认证,使用promise方式作为异步方法。
参数:
返回值:
类型 | 说明 |
Promise | 返回携带一个number的Promise。number 为认证结果,参见[AuthenticationResult]。 |
示例:
authenticator.execute("FACE_ONLY", "S2").then((code)= >{
}).catch((code)= >{
AuthenticationResult(deprecated)
说明: 从 API Version 8 开始废弃,建议使用[ResultCode](替代。
表示认证结果的枚举。
名称 | 默认值 | 描述 |
NO_SUPPORT | -1 | 设备不支持当前的认证方式。 |
SUCCESS | 0 | 认证成功。 |
COMPARE_FAILURE | 1 | 比对失败。 |
CANCELED | 2 | 用户取消认证。 |
TIMEOUT | 3 | 认证超时。 |
CAMERA_FAIL | 4 | 开启相机失败。 |
BUSY | 5 | 认证服务忙,请稍后重试。 |
INVALID_PARAMETERS | 6 | 认证参数无效。 |
LOCKED | 7 | 认证失败次数过多,已锁定。 |
NOT_ENROLLED | 8 | 未录入认证凭据。 |
GENERAL_ERROR | 100 | 其他错误。 |
UserAuth8+
认证器的对象。
constructor8+
constructor()
表示获取的认证器对象。
返回值:
类型 | 说明 |
[UserAuth] | UserAuth认证器对象。 |
示例:
getVersion8+
getVersion() : number
表示获取的认证器版本信息。
返回值:
类型 | 说明 |
number | 获取的认证器版本信息。 |
示例:
let version = auth.getVersion();
getAvailableStatus8+
getAvailableStatus(authType : UserAuthType, authTrustLevel : AuthTrustLevel) : number
表示检查指定的认证等级的认证能力是否可用。
参数:
authType | [UserAuthType] | 是 | 认证类型,当前只支持FACE。 |
authTrustLevel | [AuthTrustLevel] | 是 | 认证结果的信任等级。 |
返回值:
类型 | 说明 |
number | 获取指定的认证等级的认证能力是否可用的检查结果,返回值参见[ResultCode]。 |
示例:
let checkCode = auth.getAvailableStatus(userIAM_userAuth.UserAuthType.FACE, userIAM_userAuth.AuthTrustLevel.ATL1);
// 此处添加支持指定类型认证的逻辑
} else {
// 此处添加不支持指定类型认证的逻辑
auth8+
auth(challenge: Uint8Array, authType: UserAuthType, authTrustLevel: AuthTrustLevel, callback: IUserAuthCallback): Uint8Array
表示执行用户认证,使用callback方式作为异步方法。
参数:
challenge | Uint8Array | 是 | 挑战值,可以填null。 |
authType | [UserAuthType] | 是 | 认证类型,当前支持FACE。 |
authTrustLevel | [AuthTrustLevel] | 是 | 信任等级。 |
callback | [IUserAuthCallback] | 是 | 回调函数。 |
返回值:
类型 | 说明 |
Uint8Array | ContextId,作为取消认证[cancelAuth]接口的入参。 |
示例:
try {
if (result == userIAM_userAuth.ResultCode.SUCCESS) {
// 此处添加认证成功逻辑
} else {
// 此处添加认证失败逻辑
} catch (e) {
cancelAuth8+
cancelAuth(contextID : Uint8Array) : number
表示通过contextID取消本次认证操作。
参数:
contextID | Uint8Array | 是 | 上下文ID信息,通过[auth]接口获得。 |
返回值:
类型 | 说明 |
number | 取消本次认证操作的结果。 |
示例:
// contextId可通过auth接口获取,此处直接定义
let contextId = new Uint8Array([0, 1, 2, 3, 4, 5, 6, 7]);
let cancelCode = auth.cancel(contextId);
if (cancelCode == userIAM_userAuth.ResultCode.SUCCESS) {
} else {
IUserAuthCallback8+
认证过程中回调结果的对象。
onResult8+
onResult: (result : number, extraInfo : AuthResult) => void
表示在认证操作中,获取认证结果。
参数:
result | number | 是 | 认证结果,参见[ResultCode]。 |
extraInfo | [AuthResult] | 是 | 扩展信息,不同情况下的具体信息, 如果身份验证通过,则在extrainfo中返回用户认证令牌, 如果身份验证失败,则在extrainfo中返回剩余的用户认证次数, 如果身份验证执行器被锁定,则在extrainfo中返回冻结时间。 |
示例:
try {
if (result == SUCCESS) {
// 此处添加认证成功逻辑
} else {
// 此处添加认证失败逻辑
} catch (e) {
try {
} catch (e) {
onAcquireInfo8+
onAcquireInfo ?: (module : number, acquire : number, extraInfo : any) => void
表示在认证过程中,获取提示码信息,非必须实现。
参数:
module | number | 是 | 认证执行器的类型。 |
acquire | number | 是 | 认证执行器认证过程的交互信息。 |
extraInfo | any | 是 | 预留字段。 |
示例:
try {
// 此处添加认证成功逻辑
} else {
// 此处添加认证失败逻辑
} catch (e) {
try {
} catch (e) {
AuthResult8+
表示认证结果的对象。
名称 | 参数类型 | 必填 | 说明 |
token | Uint8Array | 否 | 身份认证令牌。 |
remainTimes | number | 否 | 剩余的认证操作次数。 |
freezingTime | number | 否 | 认证操作的冻结时间。 |
ResultCode8+
表示执行结果的枚举。
名称 | 默认值 | 描述 |
SUCCESS | 0 | 执行成功。 |
FAIL | 1 | 执行失败。 |
GENERAL_ERROR | 2 | 操作通用错误。 |
CANCELED | 3 | 操作取消。 |
TIMEOUT | 4 | 操作超时。 |
TYPE_NOT_SUPPORT | 5 | 不支持的认证类型。 |
TRUST_LEVEL_NOT_SUPPORT | 6 | 不支持的认证等级。 |
BUSY | 7 | 忙碌状态。 |
INVALID_PARAMETERS | 8 | 无效参数。 |
LOCKED | 9 | 认证器已锁定。 |
NOT_ENROLLED | 10 | 用户未录入认证信息。 |
FaceTips8+
表示人脸认证过程中提示码的枚举。
名称 | 默认值 | 描述 |
FACE_AUTH_TIP_TOO_BRIGHT | 1 | 光线太强,获取的图像太亮。 |
FACE_AUTH_TIP_TOO_DARK | 2 | 光线太暗,获取的图像太暗。 |
FACE_AUTH_TIP_TOO_CLOSE | 3 | 人脸距离设备过近。 |
FACE_AUTH_TIP_TOO_FAR | 4 | 人脸距离设备过远。 |
FACE_AUTH_TIP_TOO_HIGH | 5 | 设备太高,仅获取到人脸上部。 |
FACE_AUTH_TIP_TOO_LOW | 6 | 设备太低,仅获取到人脸下部。 |
FACE_AUTH_TIP_TOO_RIGHT | 7 | 设备太靠右,仅获取到人脸右部。 |
FACE_AUTH_TIP_TOO_LEFT | 8 | 设备太靠左,仅获取到人脸左部。 |
FACE_AUTH_TIP_TOO_MUCH_MOTION | 9 | 在图像采集过程中,用户人脸移动太快。 |
FACE_AUTH_TIP_POOR_GAZE | 10 | 没有正视摄像头。 |
FACE_AUTH_TIP_NOT_DETECTED | 11 | 没有检测到人脸信息。 |
FingerprintTips8+
表示指纹认证过程中提示码的枚举。
名称 | 默认值 | 描述 |
FINGERPRINT_AUTH_TIP_GOOD | 0 | 获取的指纹图像良好。 |
FINGERPRINT_AUTH_TIP_DIRTY | 1 | 由于传感器上可疑或检测到的污垢,指纹图像噪音过大。 |
FINGERPRINT_AUTH_TIP_INSUFFICIENT | 2 | 由于检测到的情况,指纹图像噪声太大,无法处理。 |
FINGERPRINT_AUTH_TIP_PARTIAL | 3 | 仅检测到部分指纹图像。 |
FINGERPRINT_AUTH_TIP_TOO_FAST | 4 | 快速移动,指纹图像不完整。 |
FINGERPRINT_AUTH_TIP_TOO_SLOW | 5 | 缺少运动,指纹图像无法读取。 |
UserAuthType8+
表示身份认证的凭据类型枚举。
名称 | 默认值 | 描述 |
FACE | 2 | 人脸认证。 |
FINGERPRINT | 4 | 指纹认证。 |
AuthTrustLevel8+
表示认证结果的信任等级枚举。
名称 | 默认值 | 描述 |
ATL1 | 10000 | 认证结果的信任等级级别1。 |
ATL2 | 20000 | 认证结果的信任等级级别2。 |
ATL3 | 30000 | 认证结果的信任等级级别3。 |
ATL4 | 40000 | 认证结果的信任等级级别4。 |
接口
33文章
7963浏览量
149211 -
鸿蒙
55文章
2090浏览量
42261
