启动指定页面
当PageAbility的启动模式设置为单例时(具体设置方法和典型场景示例见[PageAbility的启动模式],缺省情况下是单实例模式),若PageAbility已被拉起,再次启动PageAbility会触发onNewWant回调(即非首次拉起)。应用开发者可以通过want传递启动参数,例如开发者希望指定页面启动PageAbility,可以通过want中的parameters参数传递pages信息,具体示例代码如下: 开发前请熟悉鸿蒙开发指导文档 :[gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md
调用方PageAbility的app.ets中或者page中,使用startAbility再次拉起PageAbility,通过want中的uri参数传递页面信息:
import featureAbility from '@ohos.ability.featureAbility';
import Want from '@ohos.app.ability.Want';
import hilog from '@ohos.hilog';
const TAG: string = 'PagePageAbilityFirst';
const domain: number = 0xFF00;
(async (): Promise< void > = > {
let wantInfo: Want = {
bundleName: 'com.samples.famodelabilitydevelop',
abilityName: 'com.samples.famodelabilitydevelop.PageAbilitySingleton',
parameters: { page: 'pages/second' }
featureAbility.startAbility({ want: wantInfo }).then((data) = > {
hilog.debug(domain, TAG, `restartAbility success : ${data}`);
在目标端PageAbility的onNewWant回调中获取包含页面信息的want参数:
// GlobalContext.ts 构造单例对象
export class GlobalContext {
private constructor() {
private static instance: GlobalContext;
private _objects = new Map< string, Object >();
public static getContext(): GlobalContext {
if (!GlobalContext.instance) {
GlobalContext.instance = new GlobalContext();
return GlobalContext.instance;
getObject(value: string): Object | undefined {
return this._objects.get(value);
setObject(key: string, objectClass: Object): void {
this._objects.set(key, objectClass);
import { GlobalContext } from '../utils/GlobalContext';
class PageAbilitySingleton {
onNewWant(want: Want) {
featureAbility.getWant().then((want) = > {
GlobalContext.getContext().setObject('newWant', want);
export default new PageAbilitySingleton();
在目标端页面的自定义组件中获取包含页面信息的want参数并根据uri做路由处理:
import router from '@ohos.router';
import { GlobalContext } from '../../utils/GlobalContext';
@Entry
@Component
struct First {
onPageShow() {
let newWant = GlobalContext.getContext().getObject('newWant') as Want;
if (newWant) {
if (newWant.parameters) {
if (newWant.parameters.page) {
router.pushUrl({ url: newWant.parameters.page as string});
GlobalContext.getContext().setObject("newWant", undefined)
build() {
Column() {
Row() {
Text($r('app.string.singleton_first_title'))
.fontSize(24)
.fontWeight(FontWeight.Bold)
.textAlign(TextAlign.Start)
.margin({ top: 12, bottom: 11, right: 24, left: 24 })
.width('100%')
.height(56)
.justifyContent(FlexAlign.Start)
Image($r('app.media.pic_empty'))
.width(120)
.height(120)
.margin({ top: 224 })
Text($r('app.string.no_content'))
.fontSize(14)
.margin({ top: 8, bottom: 317, right: 152, left: 152 })
.fontColor($r('app.color.text_color'))
.opacity(0.4)
.width('100%')
.height('100%')
.backgroundColor($r('app.color.backGrounding'))
当PageAbility的启动模式设置为多实例模式或为首次启动单例模式的PageAbility时(具体设置方法和典型场景示例见[PageAbility的启动模式]),在调用方PageAbility中,通过want中的parameters参数传递要启动的指定页面的pages信息,调用startAbility()方法启动PageAbility。被调用方可以在onCreate中使用featureAbility的getWant方法获取want,再通过调用router.pushUrl实现启动指定页面。
调用方的页面中实现按钮点击触发startAbility方法启动目标端PageAbility,startAbility方法的入参want中携带指定页面信息,示例代码如下:
import { BusinessError } from '@ohos.base';
import fs from '@ohos.file.fs';
import promptAction from '@ohos.promptAction';
import worker from '@ohos.worker';
@Entry
@Component
struct PagePageAbilityFirst {
build() {
Column() {
List({ initialIndex: 0 }) {
ListItem() {
Flex({ justifyContent: FlexAlign.SpaceBetween, alignContent: FlexAlign.Center }) {
.onClick(() = > {
let want: Want = {
abilityName: 'com.samples.famodelabilitydevelop.PageAbilityStandard',
parameters: { page: 'pages/first' }
featureAbility.startAbility({ want: want }).then((data) = > {
hilog.info(domain, TAG, `startAbility finish:${data}`);
}).catch((err: BusinessError) = > {
hilog.info(domain, TAG, `startAbility failed errcode:${err.code}`);
ListItem() {
.onClick(() = > {
let want: Want = {
`HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿`
目标端PageAbility的onCreate生命周期回调中通过featureAbility的getWant方法获取want,并对参数进行解析,实现指定页面拉起:
class PageAbilityStandard {
onCreate() {
if (want.parameters) {
if (want.parameters.page) {
router.pushUrl({ url: want.parameters.page as string });
export default new PageAbilityStandard();
鸿蒙
57文章
2401浏览量
43177
鸿蒙Ability开发-Stage模型下Ability的创建和使用
纯血鸿蒙开发教程-运行时动态加载页面提升性能
鸿蒙原生页面高性能解决方案上线OpenHarmony社区 助力打造高性能原生应用
鸿蒙OS应用开发实践(三)
鸿蒙OS应用开发实践(三)
鸿蒙应用开发入门资料合集
鸿蒙原生应用开发-关于页面接口router返回问题与解决思路
京东正式启动鸿蒙原生应用开发
淘宝正式启动华为鸿蒙原生应用开发
淘宝与华为合作将基于HarmonyOS NEXT启动鸿蒙原生应用开发
哪吒汽车APP启动鸿蒙原生应用开发
鸿蒙开发:【页面栈及任务链】
