创建DataAbility
实现DataAbility中Insert、Query、Update、Delete接口的业务内容。保证能够满足数据库存储业务的基本需求。BatchInsert与ExecuteBatch接口已经在系统中实现遍历逻辑,依赖Insert、Query、Update、Delete接口逻辑,来实现数据的批量处理。 开发前请熟悉鸿蒙开发指导文档 :[gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md
创建DataAbility的代码示例如下:
import featureAbility from '@ohos.ability.featureAbility';
import type common from '@ohos.app.ability.common';
import type Want from '@ohos.app.ability.Want';
import type { AsyncCallback, BusinessError } from '@ohos.base';
import dataAbility from '@ohos.data.dataAbility';
import rdb from '@ohos.data.rdb';
import hilog from '@ohos.hilog';
let TABLE_NAME = 'book';
let STORE_CONFIG: rdb.StoreConfig = { name: 'book.db' };
let SQL_CREATE_TABLE = 'CREATE TABLE IF NOT EXISTS book(id INTEGER PRIMARY KEY AUTOINCREMENT, name TEXT NOT NULL, introduction TEXT NOT NULL)';
let rdbStore: rdb.RdbStore | undefined = undefined;
const TAG: string = '[Sample_FAModelAbilityDevelop]';
const domain: number = 0xFF00;
class DataAbility {
onInitialized(want: Want): void {
hilog.info(domain, TAG, 'DataAbility onInitialized, abilityInfo:' + want.bundleName);
let context: common.BaseContext = { stageMode: featureAbility.getContext().stageMode };
rdb.getRdbStore(context, STORE_CONFIG, 1, (err, store) = > {
hilog.info(domain, TAG, 'DataAbility getRdbStore callback');
store.executeSql(SQL_CREATE_TABLE, []);
rdbStore = store;
insert(uri: string, valueBucket: rdb.ValuesBucket, callback: AsyncCallback< number >): void {
hilog.info(domain, TAG, 'DataAbility insert start');
if (rdbStore) {
rdbStore.insert(TABLE_NAME, valueBucket, callback);
batchInsert(uri: string, valueBuckets: Array< rdb.ValuesBucket >, callback: AsyncCallback< number >): void {
hilog.info(domain, TAG, 'DataAbility batch insert start');
if (rdbStore) {
for (let i = 0; i < valueBuckets.length; i++) {
hilog.info(domain, TAG, 'DataAbility batch insert i=' + i);
if (i < valueBuckets.length - 1) {
rdbStore.insert(TABLE_NAME, valueBuckets[i], (err: BusinessError, num: number) = > {
hilog.info(domain, TAG, 'DataAbility batch insert ret=' + num);
} else {
rdbStore.insert(TABLE_NAME, valueBuckets[i], callback);
query(uri: string, columns: Array< string >, predicates: dataAbility.DataAbilityPredicates, callback: AsyncCallback< rdb.ResultSet >): void {
hilog.info(domain, TAG, 'DataAbility query start');
let rdbPredicates = dataAbility.createRdbPredicates(TABLE_NAME, predicates);
if (rdbStore) {
rdbStore.query(rdbPredicates, columns, callback);
update(uri: string, valueBucket: rdb.ValuesBucket, predicates: dataAbility.DataAbilityPredicates, callback: AsyncCallback< number >): void {
hilog.info(domain, TAG, 'DataAbility update start');
if (rdbStore) {
rdbStore.update(valueBucket, rdbPredicates, callback);
delete(uri: string, predicates: dataAbility.DataAbilityPredicates, callback: AsyncCallback< number >): void {
hilog.info(domain, TAG, 'DataAbility delete start');
if (rdbStore) {
rdbStore.delete(rdbPredicates, callback);
export default new DataAbility();
举报投诉
组件
1文章
496浏览量
17744 -
鸿蒙
57文章
2272浏览量
42528
鸿蒙Ability开发-Stage模型下Ability的创建和使用
hilog.info(ENTRY_ABILITY_DOMAIN, TAG, \'%{public}s\', \'Ability onBackground\');
本文内容是鸿蒙开发中
发表于 01-08 15:34
鸿蒙开发基础-Web组件之cookie操作
本文章主要是对鸿蒙开发当中ArkTS语言的基础应用实战,Web组件里的cookie操作。更多的鸿蒙应用开发技
发表于 01-14 21:31
鸿蒙开发OpenHarmony组件复用案例
概述
在开发应用时,有些场景下的自定义组件具有相同的组件布局结构,仅有状态变量等承载数据的差异。这样的组件缓存起来,需要使用到该组件时直接复
发表于 01-15 17:37
HarmonyOS应用开发-访问DataAbility问题记录
在鸿蒙官方文档中,介绍了访问DataAbility的方法,如下: // 读取文件描述符FileDescriptor fd = helper.openFile(uri, "r"
发表于 12-28 10:27
鸿蒙开源第三方组件资料合集
1、鸿蒙开源第三方组件——日志工具组件Timber_ohosTimber_ohos是一个带有小型可扩展API的日志工具组件,它可以给开发者提
发表于 03-23 09:53
供鸿蒙应用开发者使用的精美图表库控件
该三方开源库从github fork过来,主要将底层接口调用的实现修改成鸿蒙接口的实现,将三方库鸿蒙化,供开发鸿蒙应用的开发者使用 Eaze
发表于 04-01 10:31
•1次下载
鸿蒙开发:创建PageAbility
通过DevEco Studio开发平台创建PageAbility时,DevEco Studio会在app.js/app.ets中默认生成onCreate()和onDestroy()方法,其他方法需要开发者自行实现。
鸿蒙开发组件:DataAbility的生命周期
应用开发者可以根据业务场景实现data.js/data.ets中的生命周期相关接口。DataAbility生命周期接口说明见下表。
鸿蒙开发组件:DataAbility权限控制
DataAbility提供数据服务,并不是所有的Ability都有权限读写它,DataAbility有一套权限控制机制来保证数据安全。分为静态权限控制和动态权限控制两部分。
鸿蒙开发Ability Kit程序框架服务:FA模型与Stage模型应用组件互通综述
FA模型与Stage模型是两套不同的应用模型,他们拥有各自的组件。FA模型提供三种应用组件,分别是PageAbility、ServiceAbility和DataAbility。Stage模型提供了两种应用
