明文导入密钥(C/C++)
在CMake脚本中链接相关动态库
target_link_libraries(entry PUBLIC libhuks_ndk.z.so)
开发步骤
- 指定密钥别名keyAlias。 密钥别名的最大长度为64字节。
- 封装密钥属性集和密钥材料。通过[OH_Huks_InitParamSet]、[OH_Huks_AddParams]、[OH_Huks_BuildParamSet]构造密钥属性集paramSet。
- 调用[OH_Huks_ImportKeyItem],传入密钥别名和密钥属性集,导入密钥。
/* 以下以明文导入ECC密钥为例 */
#include "huks/native_huks_api.h"
#include "huks/native_huks_param.h"
#include < string.h >
OH_Huks_Result InitParamSet(struct OH_Huks_ParamSet **paramSet, const struct OH_Huks_Param *params,
uint32_t paramCount) {
OH_Huks_Result ret = OH_Huks_InitParamSet(paramSet);
if (ret.errorCode != OH_HUKS_SUCCESS) {
return ret;
ret = OH_Huks_AddParams(*paramSet, params, paramCount);
OH_Huks_FreeParamSet(paramSet);
return ret;
ret = OH_Huks_BuildParamSet(paramSet);
return ret;
return ret;
struct OH_Huks_Param g_testGenerateKeyParam[] = {{.tag = OH_HUKS_TAG_ALGORITHM, .uint32Param = OH_HUKS_ALG_ECC},
{.tag = OH_HUKS_TAG_PURPOSE, .uint32Param = OH_HUKS_KEY_PURPOSE_AGREE},
{.tag = OH_HUKS_TAG_KEY_SIZE, .uint32Param = OH_HUKS_ECC_KEY_SIZE_256},
{.tag = OH_HUKS_TAG_DIGEST, .uint32Param = OH_HUKS_DIGEST_NONE}};
static napi_value GenerateKey(napi_env env, napi_callback_info info) {
const char *alias = "test_generate";
struct OH_Huks_Blob aliasBlob = {.size = (uint32_t)strlen(alias), .data = (uint8_t *)alias};
struct OH_Huks_ParamSet *testGenerateKeyParamSet = nullptr;
struct OH_Huks_Result ohResult;
do {
ohResult = InitParamSet(&testGenerateKeyParamSet, g_testGenerateKeyParam,
sizeof(g_testGenerateKeyParam) / sizeof(OH_Huks_Param));
if (ohResult.errorCode != OH_HUKS_SUCCESS) {
break;
ohResult = OH_Huks_GenerateKeyItem(&aliasBlob, testGenerateKeyParamSet, nullptr);
} while (0);
OH_Huks_FreeParamSet(&testGenerateKeyParamSet);
napi_value ret;
napi_create_int32(env, ohResult.errorCode, &ret);
return ret;
static napi_value ImportKey(napi_env env, napi_callback_info info) {
(void)GenerateKey(env, info);
uint8_t pubKey[OH_HUKS_ECC_KEY_SIZE_256] = {0};
struct OH_Huks_Blob publicKey = {OH_HUKS_ECC_KEY_SIZE_256, pubKey};
struct OH_Huks_ParamSet *testImportKeyParamSet = nullptr;
do {
ohResult = InitParamSet(&testImportKeyParamSet, g_testGenerateKeyParam,
break;
ohResult = OH_Huks_ExportPublicKeyItem(&aliasBlob, testImportKeyParamSet, &publicKey);
break;
/* 4. Import Key */
char newKey[] = "test_import";
struct OH_Huks_Blob newKeyAlias = {.size = (uint32_t)strlen(newKey), .data = (uint8_t *)newKey};
ohResult = OH_Huks_ImportKeyItem(&newKeyAlias, testImportKeyParamSet, &publicKey);
} while (0);
OH_Huks_FreeParamSet(&testImportKeyParamSet);
napi_value ret;
return ret;
举报投诉
C++
21文章
2084浏览量
73264 -
ECC
91浏览量
20454 -
鸿蒙
56文章
2264浏览量
42451
鸿蒙开发:Universal Keystore Kit密钥管理服务 密钥导入介绍及算法规格
如果业务在HUKS外部生成密钥(比如应用间协商生成、服务器端生成),业务可以将密钥导入到HUKS中由HUKS进行管理。
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b><b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> <b class='flag-5'>密钥</b><b class='flag-5'>导入</b>介绍及算法规格](https://file1.elecfans.com/web2/M00/F8/7C/wKgZomaH9CSAL-kiAADi0VyKdNE681.jpg)
鸿蒙开发:Universal Keystore Kit 密钥管理服务 密钥协商 C、C++
以协商密钥类型为ECDH,并密钥仅在HUKS内使用为例,完成密钥协商。具体的场景介绍及支持的算法规格,请参考[密钥生成支持的算法]。
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b> <b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> <b class='flag-5'>密钥</b>协商 <b class='flag-5'>C</b>、<b class='flag-5'>C++</b>](https://file1.elecfans.com/web2/M00/EB/95/wKgZomZevfiAZTUiAAAYyNC3ogI340.png)
鸿蒙开发:Universal Keystore Kit 密钥管理服务 HMAC C、C++
HMAC是密钥相关的哈希运算消息认证码(Hash-based Message Authentication Code),是一种基于Hash函数和密钥进行消息认证的方法。
鸿蒙开发:Universal Keystore Kit 密钥管理服务 获取密钥属性ArkTS
HUKS提供了接口供业务获取指定密钥的相关属性。在获取指定密钥属性前,需要确保已在HUKS中生成或导入持久化存储的密钥。
鸿蒙开发:Universal Keystore Kit 密钥管理服务 获取密钥属性C C++
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b> <b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> 获取<b class='flag-5'>密钥</b>属性<b class='flag-5'>C</b> <b class='flag-5'>C++</b>](https://file1.elecfans.com/web2/M00/FC/E0/wKgZomaWcSmAQSJrAACe0wV1Qmg721.png)
鸿蒙开发:Universal Keystore Kit 密钥管理服务 密钥导出 C C++
业务需要获取持久化存储的非对称密钥的公钥时使用,当前支持ECC/RSA/ED25519/X25519的公钥导出。
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b> <b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> <b class='flag-5'>密钥</b>导出 <b class='flag-5'>C</b> <b class='flag-5'>C++</b>](https://file1.elecfans.com/web2/M00/EB/95/wKgZomZevfiAZTUiAAAYyNC3ogI340.png)
