HMAC(C/C++)
HMAC是密钥相关的哈希运算消息认证码(Hash-based Message Authentication Code),是一种基于Hash函数和密钥进行消息认证的方法。
在CMake脚本中链接相关动态库
target_link_libraries(entry PUBLIC libhuks_ndk.z.so)
开发步骤
生成密钥
- 指定密钥别名。
- 初始化密钥属性集。
- 调用OH_Huks_GenerateKeyItem生成密钥,HMAC支持的规格请参考[密钥生成]。
- 开发前请熟悉鸿蒙开发指导文档 :[
gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md
除此之外,开发者也可以参考[密钥导入]的规格介绍,导入已有的密钥。
执行HMAC
- 获取密钥别名。
- 获取待运算的数据。
- 调用[OH_Huks_InitParamSet]指定算法参数配置。
- 调用[OH_Huks_InitSession]初始化密钥会话,并获取会话的句柄handle。
- 调用[OH_Huks_FinishSession]结束密钥会话,获取哈希后的数据。
#include "huks/native_huks_api.h"
#include "huks/native_huks_param.h"
#include < string.h >
OH_Huks_Result InitParamSet(
struct OH_Huks_ParamSet **paramSet,
const struct OH_Huks_Param *params,
uint32_t paramCount)
OH_Huks_Result ret = OH_Huks_InitParamSet(paramSet);
if (ret.errorCode != OH_HUKS_SUCCESS) {
return ret;
ret = OH_Huks_AddParams(*paramSet, params, paramCount);
OH_Huks_FreeParamSet(paramSet);
return ret;
ret = OH_Huks_BuildParamSet(paramSet);
return ret;
return ret;
static struct OH_Huks_Param g_genHmacParams[] = {
.tag = OH_HUKS_TAG_ALGORITHM,
.uint32Param = OH_HUKS_ALG_HMAC
.tag = OH_HUKS_TAG_PURPOSE,
.uint32Param = OH_HUKS_KEY_PURPOSE_MAC
.tag = OH_HUKS_TAG_KEY_SIZE,
.uint32Param = OH_HUKS_AES_KEY_SIZE_256
.tag = OH_HUKS_TAG_DIGEST,
.uint32Param = OH_HUKS_DIGEST_SHA384
static const uint32_t HMAC_COMMON_SIZE = 1024;
OH_Huks_Result HksHmacTest(
const struct OH_Huks_Blob *keyAlias,
const struct OH_Huks_ParamSet *hmacParamSet, const struct OH_Huks_Blob *inData, struct OH_Huks_Blob *hashText)
uint8_t handleE[sizeof(uint64_t)] = {0};
struct OH_Huks_Blob handle = {sizeof(uint64_t), handleE};
OH_Huks_Result ret = OH_Huks_InitSession(keyAlias, hmacParamSet, &handle, nullptr);
return ret;
ret = OH_Huks_FinishSession(&handle, hmacParamSet, inData, hashText);
return ret;
static napi_value HmacKey(napi_env env, napi_callback_info info)
char tmpKeyAlias[] = "test_hmac";
struct OH_Huks_Blob keyAlias = { (uint32_t)strlen(tmpKeyAlias), (uint8_t *)tmpKeyAlias };
struct OH_Huks_ParamSet *hmacParamSet = nullptr;
OH_Huks_Result ohResult;
do {
/* 1. Generate Key */
* 模拟生成密钥场景
* 1.1. 确定密钥别名
* 1.2. 获取生成密钥算法参数配置
ohResult = InitParamSet(&hmacParamSet, g_genHmacParams, sizeof(g_genHmacParams) / sizeof(OH_Huks_Param));
if (ohResult.errorCode != OH_HUKS_SUCCESS) {
break;
* 1.3. 调用generateKeyItem
ohResult = OH_Huks_GenerateKeyItem(&keyAlias, hmacParamSet, nullptr);
break;
/* 2. Hmac */
* 模拟哈希场景
* 2.1. 获取密钥别名
* 2.2. 获取待哈希的数据
char tmpInData[] = "HMAC_MAC_INDATA_1";
struct OH_Huks_Blob inData = { (uint32_t)strlen(tmpInData), (uint8_t *)tmpInData };
uint8_t cipher[HMAC_COMMON_SIZE] = {0};
struct OH_Huks_Blob hashText = {HMAC_COMMON_SIZE, cipher};
* 2.3. 调用initSession获取handle
* 2.4. 调用finishSession获取哈希后的内容
ohResult = HksHmacTest(&keyAlias, hmacParamSet, &inData, &hashText);
break;
} while (0);
OH_Huks_FreeParamSet(&hmacParamSet);
举报投诉
C++
21文章
2084浏览量
73264 -
鸿蒙
56文章
2264浏览量
42451
鸿蒙开发:Universal Keystore Kit密钥管理服务 密钥导入介绍及算法规格
如果业务在HUKS外部生成密钥(比如应用间协商生成、服务器端生成),业务可以将密钥导入到HUKS中由HUKS进行管理。密钥一旦导入到HUKS
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b><b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> <b class='flag-5'>密钥</b>导入介绍及算法规格](https://file1.elecfans.com/web2/M00/F8/7C/wKgZomaH9CSAL-kiAADi0VyKdNE681.jpg)
鸿蒙开发:Universal Keystore Kit 密钥管理服务 密钥协商 C、C++
以协商密钥类型为ECDH,并密钥仅在HUKS内使用为例,完成密钥协商。具体的场景介绍及支持的算法规格,请参考[密钥生成支持的算法]。
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b> <b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> <b class='flag-5'>密钥</b>协商 <b class='flag-5'>C</b>、<b class='flag-5'>C++</b>](https://file1.elecfans.com/web2/M00/EB/95/wKgZomZevfiAZTUiAAAYyNC3ogI340.png)
鸿蒙开发:Universal Keystore Kit 密钥管理服务 HMAC ArkTS
鸿蒙开发:Universal Keystore Kit 密钥管理服务 获取密钥属性C C++
HUKS提供了接口供业务获取指定密钥的相关属性。在获取指定密钥属性前,需要确保已在HUKS中生成或导入持久化存储的密钥。
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b> <b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> 获取<b class='flag-5'>密钥</b>属性<b class='flag-5'>C</b> <b class='flag-5'>C++</b>](https://file1.elecfans.com/web2/M00/FC/E0/wKgZomaWcSmAQSJrAACe0wV1Qmg721.png)
鸿蒙开发:Universal Keystore Kit 密钥管理服务 密钥导出 C C++
业务需要获取持久化存储的非对称密钥的公钥时使用,当前支持ECC/RSA/ED25519/X25519的公钥导出。
![<b class='flag-5'>鸿蒙</b><b class='flag-5'>开发</b>:<b class='flag-5'>Universal</b> <b class='flag-5'>Keystore</b> <b class='flag-5'>Kit</b> <b class='flag-5'>密钥</b><b class='flag-5'>管理</b><b class='flag-5'>服务</b> <b class='flag-5'>密钥</b>导出 <b class='flag-5'>C</b> <b class='flag-5'>C++</b>](https://file1.elecfans.com/web2/M00/EB/95/wKgZomZevfiAZTUiAAAYyNC3ogI340.png)
