转载请注明以下内容:
作者:圈圈
最简单的WLAN三层组网实验
1、拓扑图
2、组网配置
SW1配置:
[SW1]vlanbatch10101102 //放行VLAN [SW1]interfaceGigabitEthernet0/0/1 [SW1-GigabitEthernet0/0/1]portlink-typetrunk [SW1-GigabitEthernet0/0/1]porttrunkpvidvlan100 [SW1-GigabitEthernet0/0/1]porttrunkallow-passvlan100to101 //放行VLAN [SW1]interfaceGigabitEthernet0/0/2 [SW1-GigabitEthernet0/0/2]portlink-typetrunk [SW1-GigabitEthernet0/0/2]porttrunkallow-passvlan10101 //配置网关 [SW1]interfaceVlanif10 [SW1-Vlanif10]ipaddress192.168.13.1255.255.255.0 [SW1]interfaceVlanif100 [SW1-Vlanif100]ipaddress192.168.100.254255.255.255.0 [SW1-Vlanif100]dhcpselectinterface [SW1-Vlanif100]dhcpserveroption43sub-option2ip-address192.168.13.2 [SW1]interfaceVlanif101 [SW1-Vlanif101]ipaddress192.168.101.254255.255.255.0 [SW1-Vlanif101]dhcpselectinterface
查看SW1中mac地址
00e0-fc4e-5810是AP的mac地址后面有用
[SW1]dismac-address MACaddresstableofslot0: ------------------------------------------------------------------------------- MACAddressVLAN/PEVLANCEVLANPortTypeLSP/LSR-ID VSI/SIMAC-Tunnel ------------------------------------------------------------------------------- 00e0-fc63-169810--GE0/0/2dynamic0/- 00e0-fc4e-5810100--GE0/0/1dynamic0/- ------------------------------------------------------------------------------- Totalmatchingitemsonslot0displayed=2
AC1配置
[AC]vlanbatch10101 //放行VLAN [AC]interfaceGigabitEthernet0/0/1 [AC-GigabitEthernet0/0/1]portlink-typetrunk [AC-GigabitEthernet0/0/1]porttrunkallow-passvlan10101 //配置IP地址 [AC]interfaceVlanif10 [AC-Vlanif10]ipaddress192.168.13.2255.255.255.0 [AC]capwapsourceip-address192.168.13.2 //配置默认路由使AP与AC互通 [AC]iproute-static192.168.100.024192.168.13.1 //配置AP上线 [AC]wlan [AC-wlan-view]ap-id0ap-mac00e0-fc63-1698
查看ap是否以及上线
0 00e0-fc4e-5810 00e0-fc4e-5810 default 192.168.100.253 AP2050DN nor
0 14S
这里为nor即为已上线
[AC]disapall Info:Thisoperationmaytakeafewseconds.Pleasewaitforamoment.done. TotalAPinformation: nor:normal[1] -------------------------------------------------------------------------------- ---------------------- IDMACNameGroupIPTypeState STAUptime -------------------------------------------------------------------------------- ---------------------- 000e0-fc4e-581000e0-fc4e-5810default192.168.100.253AP2050DNnor 014S -------------------------------------------------------------------------------- ---------------------- Total:1
AC模板配置
[AC]wlan [AC-wlan-view]ssid-profilenameljr//ljr为自定义名字 [AC-wlan-ssid-prof-ljr]ssidlinjianrong//linjianrong可以理解为WiFi的名字 [AC-wlan-ssid-prof-ljr]q [AC-wlan-view]security-profilenameljr//ljr为自定义名字 [AC-wlan-sec-prof-ljr]securitywpa2pskpass-phrase2018060301324tkip Warning:Thecurrentpasswordistoosimple.Forthesakeofsecurity,youarea dvisedtosetapasswordcontainingatleasttwoofthefollowing:lowercaselet tersatoz,uppercaselettersAtoZ,digits,andspecialcharacters.Continue? [Y/N]:y Warning:Ifthewmmdisablecommand,TKIP,WEP,orradiotypeof802.11a/b/gis configured,thefunctionofdenyingaccessoflegacySTAscannottakeeffect. 这里的2018060301324为密码 [AC-wlan-sec-prof-ljr]q [AC-wlan-view]vap-profilenameljr [AC-wlan-vap-prof-ljr]forward-modedirect-forward//direct-forward为直接转发模式 [AC-wlan-vap-prof-ljr]service-vlanvlan-id101//管理的vlan,即ap下面管理的PC [AC-wlan-vap-prof-ljr]ssid-profileljr//ssid模块 [AC-wlan-vap-prof-ljr]security-profileljr//安全模块 [AC-wlan-view]ap-groupnamedefault [AC-wlan-ap-group-default]vap-profileljrwlan1radioall Info:Thisoperationmaytakeafewseconds,pleasewait...done.
上面的敲完后会出现下面的情况
双击1、2,输入密码2018060301324,点击确定完成连接
可以看到已经连上了
双击STA1,在命令行输入ipconfig查看是否已经获取IP地址
到此为止,整个实验完成。
3、总结:
(1)在ENSP中观察不到AP上线可能需要重启AP;
(2)AP与192.168.13.2IP地址需要互通,AP才可能上线;
WLAN
2文章
648浏览量
72833 -
Mac
1082浏览量
51123 -
组网
1文章
333浏览量
22244
原文标题:最简单的WLAN三层组网实验
文章出处:【微信号:网络技术干货圈,微信公众号:网络技术干货圈】欢迎添加关注!文章转载请注明出处。
