使用Python搭建简易本地http服务器,升级WIPI模组
jf_94171069 来源:jf_94171069 作者:jf_94171069 2024-09-29 15:38 次阅读
01
下载python
https://www.python.org/downloads/
02
安装python
安装时候选择把path加入电脑环境变量
3 由于python内建了简单http服务包,因此对于python来说,只需输入一行命令,就能轻松打开http服务。当然,要运行网页,就需要网页有显示内容。因此我们可以先建立一个用于存放网页文件的文件夹。例如在F盘创建一个httpserver文件夹,同时复制升级包到该文件夹下
4 WIN+R打开cmd,打开命令行,执行命令(如图,根据自己建立的文件夹来输入路径)
F:
cd httpserver
如果Python版本为2.x,输入命令
python -m SimpleHTTPServer 8081
如果Python版本为3.x,输入命令
python -m http.server 8001
05
打开浏览器,输入http://localhost:8001/(http://192.168.1.8:8001 地址在命令行输入ipconfig /all查看),就可以看到该目录下的升级包了。点击可以测试下是否可以用浏览器下载
06
升级AW100 WIPI模组,需要电脑和wipi模组在同一个wipi网关网络下。AT指令配置模组连接wipi网关,电脑连接wipi网关连接的路由器就可以
07
wipi模组连接wipi网关后,先联网,ping baidu.com成功后发送AT+FWUP=http://192.168.1.8:8001/TH6180_fw_v1.0.16_20230725_ota.img 就开始升级了,串口0会有进度,升级完后串口3会收到+OK=STARTUP
[07-25 17:47:56:656]+OK [07-25 17:47:56:656] [07-25 17:47:58:999]+OK [07-25 17:47:58:999] [07-25 17:48:04:109]AT+QVER [07-25 17:48:04:109]+OK=H1.00.00.0000,v1.00.15@ 17:54:48 Jun 15 2023 [07-25 17:48:04:109] [07-25 17:48:06:185]AT+SSID=ZK_1666 [07-25 17:48:06:185]+OK [07-25 17:48:06:185] [07-25 17:48:07:786]AT+KEY=0,1,0,12345678 [07-25 17:48:07:786]+OK [07-25 17:48:07:786] [07-25 17:48:08:883]AT+NIP=0 [07-25 17:48:08:883]+OK [07-25 17:48:08:883] [07-25 17:48:15:512]AT+WJOIN [07-25 17:48:15:512]+OK=286dce64434c,0,11,1,"WAPI-PSK",67 [07-25 17:48:15:512] [07-25 17:48:17:671]AT+LKSTT [07-25 17:48:17:671]+OK=1,"192.168.1.63","255.255.255.0","192.168.1.1","192.168.1.1","0.0.0.0" [07-25 17:48:17:671] [07-25 17:48:19:445]AT+PING=baidu.com,1000,4,1 [07-25 17:48:19:445]+OK [07-25 17:48:19:445] [07-25 17:48:19:597] [07-25 17:48:19:597]PING baidu.com(39.156.66.10): 32 bytes data in ICMP packets. [07-25 17:48:19:611]32 byte from 39.156.66.10: icmp_seq=0 ttl=50 rtt=16 ms [07-25 17:48:20:620]32 byte from 39.156.66.10: icmp_seq=1 ttl=50 rtt=24 ms [07-25 17:48:21:622]32 byte from 39.156.66.10: icmp_seq=2 ttl=50 rtt=20 ms [07-25 17:48:22:619]32 byte from 39.156.66.10: icmp_seq=3 ttl=50 rtt=16 ms [07-25 17:48:23:622] [07-25 17:48:23:622]--------------------PING statistics------------------- [07-25 17:48:23:622]4 packets transmitted, 4 received , 0(0.00%) lost. AT+FWUP=http://192.168.1.5:8001/TH6180_fw_v1.0.18_20230803_ota.img [07-25 17:48:34:383]+OK=STARTUP [07-25 17:52:37:940] [07-25 17:53:01:503]+OK [07-25 17:53:01:503] [07-25 17:53:02:639]AT+QVER [07-25 17:53:02:639]+OK=H1.00.00.0000,v1.00.16@ 14:26:22 Jul 25 2023 [07-25 17:53:02:639][07-25 17:48:27:768]Location: http://192.168.1.8:8001/TH6180_fw_v1.0.16_20230725_ota.img [07-25 17:48:27:768]content_length: 336076 [07-25 17:48:28:010]download 2047 / 336076 [07-25 17:48:28:010]download 4094 / 336076 [07-25 17:48:28:010]download 6141 / 336076 [07-25 17:48:28:047]download 8188 / 336076 [07-25 17:48:28:047]download 10235 / 336076 [07-25 17:48:28:078]download 12282 / 336076 [07-25 17:48:28:078]download 14329 / 336076 [07-25 17:48:28:112]download 16376 / 336076 [07-25 17:48:28:112]download 18423 / 336076 [07-25 17:48:28:143]download 20470 / 336076 [07-25 17:48:28:143]download 22517 / 336076 [07-25 17:48:28:174]download 24564 / 336076 [07-25 17:48:28:174]download 26611 / 336076 [07-25 17:48:28:207]download 28658 / 336076 [07-25 17:48:28:207]download 30705 / 336076 [07-25 17:48:28:238]download 32752 / 336076 [07-25 17:48:28:238]download 34799 / 336076 [07-25 17:48:28:271]download 36846 / 336076 [07-25 17:48:28:271]download 38893 / 336076 [07-25 17:48:28:306]download 40940 / 336076 [07-25 17:48:28:306]download 42987 / 336076 [07-25 17:48:28:336]download 45034 / 336076 [07-25 17:48:28:336]download 47081 / 336076 [07-25 17:48:28:368]download 49128 / 336076 [07-25 17:48:28:368]download 51175 / 336076 [07-25 17:48:28:401]download 53222 / 336076 [07-25 17:48:28:401]download 55269 / 336076 [07-25 17:48:28:432]download 57316 / 336076 [07-25 17:48:28:432]download 59363 / 336076 [07-25 17:48:28:466]download 61410 / 336076 [07-25 17:48:28:466]download 63457 / 336076 [07-25 17:48:28:498]download 65504 / 336076 [07-25 17:48:28:498]download 67551 / 336076 [07-25 17:48:28:530]download 69598 / 336076 [07-25 17:48:28:530]download 71540 / 336076 [07-25 17:48:28:573]download 73587 / 336076 [07-25 17:48:28:573]download 75634 / 336076 [07-25 17:48:28:600]download 77681 / 336076 [07-25 17:48:28:600]download 79728 / 336076 [07-25 17:48:28:629]download 81775 / 336076 [07-25 17:48:28:629]download 83822 / 336076 [07-25 17:48:28:659]download 85869 / 336076 [07-25 17:48:28:659]download 87916 / 336076 [07-25 17:48:28:691]download 89963 / 336076 [07-25 17:48:28:691]download 92010 / 336076 [07-25 17:48:28:724]download 94057 / 336076 [07-25 17:48:28:724]download 96104 / 336076 [07-25 17:48:28:756]download 98151 / 336076 [07-25 17:48:28:756]download 100198 / 336076 [07-25 17:48:28:788]download 102245 / 336076 [07-25 17:48:28:788]download 104292 / 336076 [07-25 17:48:28:821]download 106339 / 336076 [07-25 17:48:28:821]download 108386 / 336076 [07-25 17:48:28:854]download 110433 / 336076 [07-25 17:48:28:854]download 112480 / 336076 [07-25 17:48:28:886]download 114527 / 336076 [07-25 17:48:28:886]download 116574 / 336076 [07-25 17:48:28:918]download 118621 / 336076 [07-25 17:48:28:918]download 120668 / 336076 [07-25 17:48:28:952]download 122715 / 336076 [07-25 17:48:28:952]download 124762 / 336076 [07-25 17:48:28:985]download 126809 / 336076 [07-25 17:48:28:985]download 128856 / 336076 [07-25 17:48:29:017]download 130903 / 336076 [07-25 17:48:29:017]download 132950 / 336076 [07-25 17:48:29:049]download 134997 / 336076 [07-25 17:48:29:049]download 137044 / 336076 [07-25 17:48:29:083]download 139091 / 336076 [07-25 17:48:29:083]download 141138 / 336076 [07-25 17:48:29:115]download 143185 / 336076 [07-25 17:48:29:115]download 145232 / 336076 [07-25 17:48:29:148]download 147279 / 336076 [07-25 17:48:29:148]download 149326 / 336076 [07-25 17:48:29:181]download 151373 / 336076 [07-25 17:48:29:181]download 153420 / 336076 [07-25 17:48:29:215]download 155467 / 336076 [07-25 17:48:29:215]download 157514 / 336076 [07-25 17:48:29:248]download 159561 / 336076 [07-25 17:48:29:248]download 161608 / 336076 [07-25 17:48:29:282]download 163655 / 336076 [07-25 17:48:29:282]download 165702 / 336076 [07-25 17:48:29:314]download 167749 / 336076 [07-25 17:48:29:314]download 169796 / 336076 [07-25 17:48:29:347]download 171843 / 336076 [07-25 17:48:29:347]download 173890 / 336076 [07-25 17:48:29:380]download 175937 / 336076 [07-25 17:48:29:380]download 177984 / 336076 [07-25 17:48:29:414]download 180031 / 336076 [07-25 17:48:29:414]download 182078 / 336076 [07-25 17:48:29:444]download 184125 / 336076 [07-25 17:48:29:444]download 186172 / 336076 [07-25 17:48:29:477]download 188219 / 336076 [07-25 17:48:29:477]download 190266 / 336076 [07-25 17:48:29:510]download 192313 / 336076 [07-25 17:48:29:510]download 194360 / 336076 [07-25 17:48:29:544]download 196407 / 336076 [07-25 17:48:29:544]download 198454 / 336076 [07-25 17:48:29:574]download 200501 / 336076 [07-25 17:48:29:574]download 202548 / 336076 [07-25 17:48:29:607]download 204595 / 336076 [07-25 17:48:29:607]download 206642 / 336076 [07-25 17:48:29:641]download 208689 / 336076 [07-25 17:48:29:641]download 210736 / 336076 [07-25 17:48:29:673]download 212783 / 336076 [07-25 17:48:29:673]download 214830 / 336076 [07-25 17:48:29:705]download 216877 / 336076 [07-25 17:48:29:705]download 218924 / 336076 [07-25 17:48:29:736]download 220971 / 336076 [07-25 17:48:29:736]download 223018 / 336076 [07-25 17:48:29:769]download 225065 / 336076 [07-25 17:48:29:769]download 227112 / 336076 [07-25 17:48:29:801]download 229159 / 336076 [07-25 17:48:29:801]download 231206 / 336076 [07-25 17:48:29:835]download 233253 / 336076 [07-25 17:48:29:835]download 235300 / 336076 [07-25 17:48:29:867]download 237347 / 336076 [07-25 17:48:29:867]download 239394 / 336076 [07-25 17:48:29:900]download 241441 / 336076 [07-25 17:48:29:900]download 243488 / 336076 [07-25 17:48:29:932]download 245535 / 336076 [07-25 17:48:29:932]download 247582 / 336076 [07-25 17:48:29:963]download 249629 / 336076 [07-25 17:48:29:963]download 251676 / 336076 [07-25 17:48:29:997]download 253723 / 336076 [07-25 17:48:29:997]download 255770 / 336076 [07-25 17:48:30:030]download 257817 / 336076 [07-25 17:48:30:030]download 259864 / 336076 [07-25 17:48:30:061]download 261911 / 336076 [07-25 17:48:30:061]download 263958 / 336076 [07-25 17:48:30:095]download 266005 / 336076 [07-25 17:48:30:095]download 268052 / 336076 [07-25 17:48:30:125]download 270099 / 336076 [07-25 17:48:30:125]download 272146 / 336076 [07-25 17:48:30:159]download 274193 / 336076 [07-25 17:48:30:159]download 276240 / 336076 [07-25 17:48:30:191]download 278287 / 336076 [07-25 17:48:30:191]download 280334 / 336076 [07-25 17:48:30:226]download 282381 / 336076 [07-25 17:48:30:226]download 284428 / 336076 [07-25 17:48:30:257]download 286475 / 336076 [07-25 17:48:30:257]download 288522 / 336076 [07-25 17:48:30:287]download 290569 / 336076 [07-25 17:48:30:287]download 292616 / 336076 [07-25 17:48:30:316]download 294663 / 336076 [07-25 17:48:30:316]download 296710 / 336076 [07-25 17:48:30:357]download 298757 / 336076 [07-25 17:48:30:357]download 300804 / 336076 [07-25 17:48:30:388]download 302851 / 336076 [07-25 17:48:30:388]download 304898 / 336076 [07-25 17:48:30:420]download 306945 / 336076 [07-25 17:48:30:420]download 308992 / 336076 [07-25 17:48:30:453]download 311039 / 336076 [07-25 17:48:30:453]download 313086 / 336076 [07-25 17:48:30:486]download 315133 / 336076 [07-25 17:48:30:486]download 317180 / 336076 [07-25 17:48:30:518]download 319227 / 336076 [07-25 17:48:30:518]download 321274 / 336076 [07-25 17:48:30:546]download 323321 / 336076 [07-25 17:48:30:557]download 325368 / 336076 [07-25 17:48:30:583]download 327415 / 336076 [07-25 17:48:30:583]download 329462 / 336076 [07-25 17:48:30:613]download 331509 / 336076 [07-25 17:48:30:613]download 333556 / 336076 [07-25 17:48:30:643]download 335603 / 336076 [07-25 17:48:30:643]libwapi_asue wapi version V10.20,4.0.12735-F04 debug level = 4 [07-25 17:48:34:379]ssid: WAPI-PSK [07-25 17:48:34:379]key: 0,1,0,12345678 [07-25 17:48:34:379]atm mode: disable [07-25 17:48:34:379]atsn mode: 0,0,0
本文章源自奇迹物联开源的物联网应用知识库Cellular IoT Wiki,更多技术干货欢迎关注收藏Wiki:Cellular IoT Wiki 知识库(https://rckrv97mzx.feishu.cn/wiki/wikcnBvAC9WOkEYG5CLqGwm6PHf)
欢迎同学们走进AmazIOT知识库的世界!
这里是为物联网人构建的技术应用百科,以便帮助你更快更简单的开发物联网产品
Cellular IoT Wiki初心:
在我们长期投身于蜂窝物联网 ODM/OEM 解决方案的实践过程中,一直被物联网技术碎片化与产业资源碎片化的问题所困扰。从产品定义、芯片选型,到软硬件研发和测试,物联网技术的碎片化以及产业资源的碎片化,始终对团队的产品开发交付质量和效率形成制约。为了减少因物联网碎片化而带来的重复开发工作,我们着手对物联网开发中高频应用的技术知识进行沉淀管理,并基于 Bloom OS 搭建了不同平台的 RTOS 应用生态。后来我们发现,很多物联网产品开发团队都面临着相似的困扰,于是,我们决定向全体物联网行业开发者开放奇迹物联内部沉淀的应用技术知识库 Wiki,期望能为更多物联网产品开发者减轻一些重复造轮子的负担。
Cellular IoT Wiki沉淀的技术内容方向如下:
奇迹物联的业务服务范围:基于自研的NB-IoT、Cat1、Cat4等物联网模组,为客户物联网ODM/OEM解决方案服务。我们的研发技术中心在石家庄,PCBA生产基地分布在深圳、石家庄、北京三个工厂,满足不同区域&不同量产规模&不同产品开发阶段的生产制造任务。跟传统PCBA工厂最大的区别是我们只服务物联网行业客户。
连接我们,和10000+物联网开发者一起降低技术和成本门槛
让蜂窝物联网应用更简单~~
哈哈你终于滑到最重要的模块了,
千万不!要!划!走!忍住冲动!~
欢迎加入飞书“开源技术交流群”,随时找到我们哦~
点击链接如何加入奇迹物联技术话题群(https://rckrv97mzx.feishu.cn/docx/Xskpd1cFQo7hu9x5EuicbsjTnTf)可以获取加入技术话题群攻略
Hey 物联网从业者,
你是否有了解过奇迹物联的官方公众号“eSIM物联工场”呢?
这里是奇迹物联的物联网应用技术开源wiki主阵地,欢迎关注公众号,不迷路~
及时获得最新物联网应用技术沉淀发布
  • 服务器
  • HTTP
  • python
    ftp服务器怎么搭建
    搭建FTP(文件传输协议)服务器是一个涉及多个步骤的过程,这些步骤包括选择合适的FTP服务器软件、安装软件、配置服务器以及测试连接等。 一、选择合适的FTP
    的头像 发表于 02-01 15:43 171次阅读
    服务器如何处理 HTTP 请求
    服务器处理HTTP请求的过程是一个有序且复杂的流程,通常涉及多个步骤。以下是服务器处理HTTP请求的具体步骤: 监听端口 :HTTP
    的头像 发表于 12-30 09:37 182次阅读
    如何使用HTTP服务器搭建本地Web网站
    最近在学习 ETH 模块,ETH 模块具有 HTTP 服务的功能,我将在本帖中探讨如何使用 HTTP 服务搭建一个
    的头像 发表于 12-24 09:54 1165次阅读
    如何使用<b class='flag-5'>HTTP</b><b class='flag-5'>服务器</b><b class='flag-5'>搭建</b><b class='flag-5'>本地</b>Web网站
    企业云服务器平台设计与搭建
    企业云服务器平台的设计与搭建是一个复杂但系统的过程,涉及多个环节和因素。主机推荐小编为您整理发布企业云服务器平台设计与搭建这一过程的详细阐述。
    的头像 发表于 12-04 09:51 153次阅读
    Python环境下的代理服务器搭建与自动化管理
    Python环境下搭建与自动化管理代理服务器是一项涉及网络编程和自动化技术的综合任务。
    的头像 发表于 11-14 07:31 265次阅读
    Python中代理服务器的配置与应用
    在网络通信中,代理服务器作为一种重要的网络中间件,充当着客户端和目标服务器之间的中间人角色。它能够接收来自客户端的请求,并将这些请求转发给目标服务器,然后将服务器的响应返回给客户端。
    的头像 发表于 11-12 07:13 241次阅读
    使用Python构建高效的HTTP代理服务器
    构建一个高效的HTTP代理服务器Python中涉及多个方面,包括性能优化、并发处理、协议支持(HTTP/HTTPS)、错误处理以及日志记录等。
    的头像 发表于 10-23 07:41 244次阅读
    服务器搭建步骤
    服务器不仅提供了灵活的资源配置和强大的计算能力,还降低了IT基础设施的维护成本。下面,rak小编带您详细了解云服务器搭建的步骤。
    的头像 发表于 10-09 10:58 280次阅读
    本地服务器和云服务器区别在哪里
    本地服务器依赖物理硬件,资源调配受限,成本高且扩展不便,但数据控制力强;而云服务器则基于虚拟化技术,资源弹性调配,成本低,易于扩展,且由云服务提供商负责维护安全和高可用性,适合快速变化
    的头像 发表于 09-27 10:02 315次阅读
    服务器搭建详细过程
    随着云计算技术的发展,越来越多的企业和个人开始选择使用云服务器来部署自己的应用和服务。相比于传统的物理服务器,云服务器提供了更高的灵活性、可扩展性和安全性。下面将详细介绍如何
    的头像 发表于 09-12 10:00 445次阅读
    使用NS1串口服务器HTTP模式上传服务器数据
    HTTP协议工作于客户端-服务端架构之上。浏览作为HTTP客户端通过URL向HTTP服务端即W
    的头像 发表于 08-30 12:36 521次阅读
    使用NS1串口<b class='flag-5'>服务器</b><b class='flag-5'>HTTP</b>模式上传<b class='flag-5'>服务器</b>数据
    如何在服务器上调试本地FPGA板卡
    联合开发或者跑多策略工程的时候,一般都使用多核的服务器进行FPGA设计。这个时候如果板卡在本地电脑上应该怎么进行调试呢? 今天就简单讲讲《如何在服务器上调试本地FPGA板卡
    发表于 07-31 17:36
    tcp方式连接不了服务器了,服务器代码还能开源吗?
    是在维护服务器吗?已经两天了。http方式还可以连接上,就tcp的方式不行了.服务器代码能开源吗?让我们自己搭建服务器用。
    发表于 07-15 06:53
    分享 | PTP、NTP时间同步服务器的部署与搭建过程
    的头像 发表于 05-15 10:01 1169次阅读
    分享 | PTP、NTP时间同步<b class='flag-5'>服务器</b>的部署与<b class='flag-5'>搭建</b>过程
     海外云服务器搭建pi节点详细步骤
     海外云服务器搭建pi节点简单吗?海外云服务器搭建pi节点步骤有哪些?小编为您整理发布海外云服务器搭建
    的头像 发表于 02-21 10:16 1327次阅读
