安科瑞MID认证双向计量导轨电表
吴春红 来源:jf_60594575 作者:jf_60594575 2024-10-18 14:11 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
1 概述General
ADL400导轨式多功能电能表,是主要针对电力系统,工矿企业,公用设施的电能统计、管理需求而设计的一款智能仪表,产品具有精度高、体积小、安装方便等优点。集成常见电力参数测量及电能计量及考核管理,提供上48月的各类电能数据统计。具有2~31次分次谐波与总谐波含量检测。带有RS485通信接口,可选用MODBUS-RTU协议。该电力仪表可广泛应用于各种控制系统,SCADA系统和能源管理系统中。产品符合IEC62053-21认证
ADL400is a smart meter designed for power supply system, industrial and mining enterprises and utilities to calculate the electricity consumption and manage the electric demand. It features the high precision, small size and simple installation. It integrates the measurement of all electrical parameters with the comprehensive electricity metering and management provides various data on previous 48months, checks the 31st harmonic content and the total harmonic content, realizes the remote communication and the remote control with switching input and relay output and boasts the alarm output. It is fitted with RS485 communication port and adapted to MODBUS-RTU.ADL400can be used in all kinds of control systems, SCADA systems and energy management systems. Themeter meet the related technical requirements of electronic meter in the IEC62053-21standards.
2 型号说明Type description
3 功能列表Function description
表1 功能说明列表
Table 1 Function description list
功能Function 功能说明Function description 功能配置Function provide
电能计量Measurement of kWh 有功电能计量(正、反向)
Active kWh (positive and negative)
无功电能计量(正、反向)
Reactive kWh (positive and negative)
A、B、C分相正向有功电能
电量测量Measurement of electrical parameters U、I
P、Q、S、PF、F
谐波测量Measurement ofharmonics 2~31次谐波电压电流
2~31STVoltage and current harmonic
LCD显示
LCD Display
12位段式LCD显示、背光显示
12bits section LCD display, background light
按键编程
Key programming
3按键可编程通信、变比等参数
3keys to communication and set parameters
脉冲输出
Pulse output
有功脉冲输出
Active pulse output
复费率及
附带功能
Multi-tariffand functions
支持4个时区、2个时段表、
14个日时段、4个费率
Adapt 4 time zones, 2 time interval lists, 14 time interval by day and 4 tariff rates
最大需量及发生时间
Max demanded kWh and time happened
上48月、上90日历史冻结数据
Frozen data on last 48 months, last 90days
日期、时间
Date, time
通讯
Communication
RS485接口
支持Modbus
Communication interface: RS485, Communication protocol: MODBUS-RTU
4 技术参数Technical parameter
表2 技术参数说明
Table 2 technical parameter descriptions
项目 性能参数
规格
Specification
三相四线
3 phase 4 wires
Measurement
Voltage
参比电压
Referencevoltage
3×230/400V
功耗
Consumption
<10VA(单相)(Single phase)
阻抗
Impedance
>2MΩ
精度等级
Accuracy class
误差±0.2%(Error±0.2%)
Current
输入电流
Input current
0.1-10(80)A(直接接入 Direct access model)
功耗
Consumption
<1VA(单路额定电流)(Single phase rated current)
精度等级
Accuracy class
误差±0.2%(Error±0.2%)
功率Power 有功、无功、视在功率,误差±0.5℅
Active, reactive, apparent power, error±0.5℅
电网频率Frequency 45~65Hz,误差±0.2%(Error±0.2%)
Measurement
电能Energy 准确度等级C级
Accuracy class:C
时钟Clock ≤0.5s/d
Digit signal
电量脉冲输出
Energy pulse output
1路有功光耦输出
Oneactive photocoupleroutput
脉冲
pulse
脉冲宽度
Width of pulse
80±20ms
脉冲常数
Pulse constant
400imp/kWh(与基本电流对应)(Correspond with the basic current)
communication
接口与通信规约
Interface and communication
RS485口:Modbus RTU规约
RS485:Modbus RTU
通信地址范围
Range of communication address
Modbus RTU:1~ 254;
波特率
Baud rate
1200bps~19200bps
environment
工作环境
work environment
室内(如需在户外使用,请为电表配备防水防尘表箱)
Indoor ( If it needs to be installed outdoors, please add a dustproof and waterproof shell )
工作温度
Relative temperature
-40℃to +70℃(直接接入Direct access model)
相对湿度
Relative humidity
≤95℅(无凝露)(No condensation)
防护等级
IP Rating
IP51
Must be installed in a suitable IP rated enclosure
5 外形尺寸Dimension drawings
注:直接接入的接线力矩应该在3-4N·m,经互感器接入的接线力矩应该在1.5-2N·m。
Note:The torque of direct connect should be3-4N·m,and the torque of connect via CT should be 1.5-2N·m.
6 接线与安装Wiring and installing
6.1电压电流接线示意图Wiring sample of voltage and current
Fig2Three phase four lines connect via CT
安科瑞电气股份有限公司
吴春红18702111910
上海市嘉定区育绿路253号
  • 电表
  • MID
    MID
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    双UL认证加持|安科电表,为北美光储出海提供计量安全底座
    顺利清关、通过电网验收、进入主流项目供应链。187 安科两款明星计量产品——ADL3000-E-B/KC导轨双向
    的头像 发表于 04-21 17:39 1077次阅读
    双UL<b class='flag-5'>认证</b>加持|<b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>电表</b>,为北美光储出海提供<b class='flag-5'>计量</b>安全底座
    出口欧洲充电桩,计量合规是关键:安科 MID 直流电能表为您护航
    计量器具指令(MID)更是关键门槛。采用具备MID认证的电能表,作为充电桩的核心电能计量部件,不仅能直接满足欧盟法规要求,还能显著缩短项目周
    的头像 发表于 04-15 17:22 1628次阅读
    出口欧洲充电桩,<b class='flag-5'>计量</b>合规是关键:<b class='flag-5'>安科</b><b class='flag-5'>瑞</b> <b class='flag-5'>MID</b> 直流电能表为您护航
    精准计量,智能节能!PMC-340-A6与220-A6通过欧盟MID认证
    认证通过!CET中电技术自主研发的两款导轨电表PMC-340-A6(三相)与PMC-220-A6(单相),已顺利通过欧盟MID计量
    的头像 发表于 03-31 18:04 357次阅读
    精准<b class='flag-5'>计量</b>,智能节能!PMC-340-A6与220-A6通过欧盟<b class='flag-5'>MID</b><b class='flag-5'>认证</b>
    用了MID认证的电能表,充电桩还需要做MID认证吗?
    MID认证:不仅是针对“表”,更是针对“计量系统”
    的头像 发表于 03-19 14:58 769次阅读
    用了<b class='flag-5'>MID</b><b class='flag-5'>认证</b>的电能表,充电桩还需要做<b class='flag-5'>MID</b><b class='flag-5'>认证</b>吗?
    精准计量,连通北美:安科阳台光伏美规单相电表
    在全球能源管理与智能电网的建设浪潮中,电能计量仪表的“本地化合规”与“高精度性能”至关重要。安科电气(Acrel)作为国内领先的智能用电解决方案提供商,其针对北美市场设计的单相电表
    的头像 发表于 01-16 15:31 656次阅读
    精准<b class='flag-5'>计量</b>,连通北美:<b class='flag-5'>安科</b><b class='flag-5'>瑞</b>阳台光伏美规单相<b class='flag-5'>电表</b>
    揭秘MID电表:它和普通电表有啥不同?
    计费的精准度、使用的合规性和管理的便捷性!今天,我们就来一次性说清楚,帮大家轻松搞懂电表知识,省钱又省心! MID认证MID电表 首先,
    的头像 发表于 11-07 15:03 763次阅读
    安科APM521:UL认证硬核加持,一表双装解锁计量灵活性!
    1 . 背景 还在为电表安装方式纠结不已?选面板式担心后期维护麻烦,挑导轨式又顾虑防护性不足?现在,这些烦恼都将成为过去!安科APM521双模式安装多功能
    的头像 发表于 09-18 08:47 656次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b>APM521:UL<b class='flag-5'>认证</b>硬核加持,一表双装解锁<b class='flag-5'>计量</b>灵活性!
    MID证书篇 | 做海外电表生意怕踩合规 “坑”?安科资质认证明细帮你提前避开!
    电表想进欧盟及 EEA 市场,MID 证书是强制准入凭证—— 没它,产品禁售、海关扣留,连合作资格都没有。这张证不只是 “通行证”,更经权威机构严苛检测,确保电表计量精准、抗干扰,能打
    的头像 发表于 08-25 16:38 869次阅读
    <b class='flag-5'>MID</b>证书篇 | 做海外<b class='flag-5'>电表</b>生意怕踩合规 “坑”?<b class='flag-5'>安科</b><b class='flag-5'>瑞</b>资质<b class='flag-5'>认证</b>明细帮你提前避开!
    安科DJSF1352-D系列一体化MID认证直流电能表助力开启新能源充电新时代
    安科徐赟杰18706165067 随着全球能源转型的加速,中国充电桩企业纷纷将目光投向海外市场,尤其是欧洲市场。然而,出口欧洲并非易事,企需要通过一系列严格的合规认证体系。其中,CE认证
    的头像 发表于 07-17 16:29 663次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b>DJSF1352-D系列一体化<b class='flag-5'>MID</b><b class='flag-5'>认证</b>直流电能表助力开启新能源充电新时代
    UL、CE、MID三重认证,精准掌控能源脉搏:安科ADL400N-CT系列储能计量表助力绿色能源管理升级
    在“双碳”目标驱动下,工商业分布式光伏与储能市场迎来爆发式增长。然而,如何高效管理光储系统的能量流动、实现峰谷套利与电网安全平衡,成为行业核心挑战。安科电气推出的ADL400N-CT系列储能计量表,凭借UL、CE、
    的头像 发表于 06-11 15:32 759次阅读
    UL、CE、<b class='flag-5'>MID</b>三重<b class='flag-5'>认证</b>,精准掌控能源脉搏:<b class='flag-5'>安科</b><b class='flag-5'>瑞</b>ADL400N-CT系列储能<b class='flag-5'>计量</b>表助力绿色能源管理升级
    安科ADL400导轨电表安装使用说明书
    ADL400 是安科电气专为电力系统、工矿企业及公用设施设计的智能导轨式电能表,具备高精度、小体积、易安装等优势。支持多电力参数测量、电能计量、谐波分析及远程通信,适用于能源管理、S
    发表于 05-20 16:29 10次下载
    安科直流电表直流计量方案借力政策东风,重塑充电桩行业标准
    充电桩计量解决方案中,安科 DJSF1352-D 直流电表脱颖而出,成为行业内备受瞩目的优质选择。 安科
    的头像 发表于 05-14 16:21 742次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b>直流<b class='flag-5'>电表</b>直流<b class='flag-5'>计量</b>方案借力政策东风,重塑充电桩行业标准
    安科直流计量方案,解决直流充电桩计量问题!
    运营商的运营成本核算与服务质量提升。在众多直流充电桩计量解决方案中,安科 DJSF1352-D 直流电表脱颖而出,成为行业内备受瞩目的优质选择。 一、直击传统痛点,创新设计破局 过去
    的头像 发表于 05-13 13:59 731次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b>直流<b class='flag-5'>计量</b>方案,解决直流充电桩<b class='flag-5'>计量</b>问题!
    什么是光伏双向电表?双向电表有哪些应用?
    电能的双向流动轨迹。在用户侧并网运行模式下,不仅计量用户从公共电网获取的用电量(正向有功电能),同时精准统计光伏系统向电网回馈的发电量(逆向有功电能),实现能源流量的全维度监控。 技术支持 安科
    的头像 发表于 05-12 09:42 2482次阅读
    什么是光伏<b class='flag-5'>双向</b><b class='flag-5'>电表</b>?<b class='flag-5'>双向</b><b class='flag-5'>电表</b>有哪些应用?
    安科双向计量电表:分布式光伏时代的“智能能源管家”
    的精细化管控。 安科双向计量电表应势而生,以精度计量、智能化管理、多场景适配为优势,成为分布
    的头像 发表于 05-08 16:36 944次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>双向</b><b class='flag-5'>计量</b><b class='flag-5'>电表</b>:分布式光伏时代的“智能能源管家”
