【S32K146 RT-thread】之 SPI驱动适配
RT-Thread官方账号 2024-11-01 08:11 次阅读
概述
RT-Thread 对SPI总线的驱动,抽象出了spi bus 的设备驱动,我们基于S32K146 的硬件学习spi bus 设备驱动。
SPI总线驱动适配
驱动涉及的主要结构体为如下:
rt_spi_device:app 通过该结构体和bus 绑定通过bus 控制spi总线
rt_spi_bus spi bus总线设备抽象
rt_spi_ops bus设备依赖的底层操作函数
结构体关系如下:
对于总线设备的驱动对接我们需要实现对应的ops函数。
使用S32 Design Studio 工具配置spi1
本次实验使用的是lpspi1 ,首先使用S32 Design Studio 工具生成pinmux 和 clk 初始化配置代码。
配置SPI1 master 参数
配置pimmux
配置clk
适配SPI1 ops 函数至RT-Thread
根据上面的梳理,依赖芯片层实现ops函数并开启spi设备驱动
config ops函数
tatic rt_err_t spi_configure(struct rt_spi_device* device,
struct rt_spi_configuration* configuration)
struct rt_spi_bus * spi_bus = (struct rt_spi_bus *)device->bus;
struct s32k_spi *spi_device = (struct s32k_spi *)spi_bus->parent.user_data;
status_t ret;
RT_ASSERT(device != RT_NULL);
RT_ASSERT(configuration != RT_NULL);
/* config spi init spi bus */
//LPSPI_DRV_MasterDeinit(spi_device->instance);
switch(configuration->mode & RT_SPI_MODE_3)
case RT_SPI_MODE_0:
spi_device->masterconfig->clkPhase = LPSPI_CLOCK_PHASE_2ND_EDGE;
spi_device->masterconfig->clkPolarity = LPSPI_SCK_ACTIVE_LOW;
break;
case RT_SPI_MODE_1:
spi_device->masterconfig->clkPhase = LPSPI_CLOCK_PHASE_1ST_EDGE;
break;
case RT_SPI_MODE_2:
spi_device->masterconfig->clkPolarity = LPSPI_SCK_ACTIVE_HIGH;
break;
case RT_SPI_MODE_3:
break;
/* MSB or LSB */
if(configuration->mode & RT_SPI_MSB)
spi_device->masterconfig->lsbFirst = false;
else
spi_device->masterconfig->lsbFirst = true;
if(configuration->max_hz < 10000000)
spi_device->masterconfig->bitsPerSec = configuration->max_hz;
spi_device->masterconfig->bitcount = configuration->data_width;
ret = LPSPI_DRV_MasterInit(spi_device->instance,spi_device->status,spi_device->masterconfig);
RT_ASSERT(ret == STATUS_SUCCESS);
ret = LPSPI_DRV_MasterSetDelay(spi_device->instance, 1, 1, 1);
return ret == STATUS_SUCCESS ? RT_EOK:RT_ERROR;
xfer ops 函数
truct s32k_spi
struct rt_spi_bus spi_bus; /* spi bus device */
lpspi_master_config_t * masterconfig; /* lpspi master config */
lpspi_state_t * status; /* lpspi driver status */
uint32_t instance; /* spi instance id */
char * bus_name;
}s32k_spi_t;
static rt_ssize_t spixfer(struct rt_spi_device* device, struct rt_spi_message* message){
status_t ret;
RT_ASSERT(device != NULL);
RT_ASSERT(message != NULL);
ret = LPSPI_DRV_MasterTransferBlocking(spi_device->instance,message->send_buf,message->recv_buf,message->length,1000);
return ret == STATUS_SUCCESS ? message->length:0;
添加如下初始化代码像系统注册spibus设备
xtern void LPSPI_DRV_IRQHandler(uint32_t instance);
void S32K14X_LPspi1_Master_Slave_IRQHandler(void){
/* enter interrupt */
rt_interrupt_enter();
LPSPI_DRV_IRQHandler(1);
/* leave interrupt */
rt_interrupt_leave();
/* private rt-thread spi ops function */
static struct rt_spi_ops s32k_spi_ops =
.configure = spi_configure,
.xfer = spixfer,
static struct s32k_spi spi1;
int rt_hw_spi_init(void){
int result = 0;
/* config spi strruct */
spi1.instance = INST_LPSPI_1;
spi1.masterconfig = &lpspi_1_MasterConfig0;
spi1.status = &lpspi_1State;
spi1.spi_bus.parent.user_data = (void *)&spi1;
spi1.bus_name = "spi1";
result = rt_spi_bus_register(&spi1.spi_bus, spi1.bus_name, &s32k_spi_ops);
RT_ASSERT(result == RT_EOK);
LOG_D("%s bus init done", spi1.bus_name);
if(result == RT_EOK)
INT_SYS_InstallHandler(LPSPI1_IRQn,S32K14X_LPspi1_Master_Slave_IRQHandler,NULL);
return result;
INIT_APP_EXPORT(rt_hw_spi_init);
验证
添加如下测试代码输入 spi10 open/config/readid 命令打开并挂载到spi1总线,并读取板子上的spi flash 的id信息
include
#include
#include
#include
#include
#define SPF_R_JEDEC_CMD (0x9Fu)
#define SPF_R_JEDEC_LEN (4u)
struct rt_spi_device spi1_device;
static void spi10(int argc,char *argv[]){
rt_err_t ret;
struct rt_spi_configuration cfg;
uint8_t sendbuff[4] = {SPF_R_JEDEC_CMD,0x00,0x00,0x00};
uint8_t recvbuff[4] = {0x00,0x00,0x00,0x00};
if(!strcmp(argv[1], "readid"))
rt_spi_transfer(&spi1_device,sendbuff,recvbuff,4);
rt_kprintf("read did [%x][%x][%x]\n",recvbuff[1],recvbuff[2],recvbuff[3]);
else if(!strcmp(argv[1], "open"))
ret = rt_spi_bus_attach_device(&spi1_device,"spi10","spi1",NULL);
if(ret != RT_EOK)
rt_kprintf("attach spi1 faied %d\n",ret);
else if(!strcmp(argv[1], "config"))
cfg.data_width = 8;
cfg.max_hz = 8000000;
cfg.mode = RT_SPI_MODE_3 | RT_SPI_MSB;
rt_spi_configure(&spi1_device,&cfg);
else if(!strcmp(argv[1], "read"))
MSH_CMD_EXPORT(spi10,spi10flashtest)
输入命令验证已经读取到flash 的Id 信息说明SPI 总线和spi flash 通信ok ,而且系统内也已经多了spi1 bus设备和spi10 的spi 设备节点。
试验读取的did和芯片手册的也是一致的。
  • SPI总线
  • 设备驱动
  • RT-Thread
    RT-Thread NUC97x 移植 LVGL
    不涉及 rt-thread 驱动,但是它是 LVGL 和 rt-thread 的接口。LVGL 在 rt-thread 上运行的基石。
    发表于 07-08 09:37 1466次阅读
    基于RT-ThreadSPI通讯
         sdk 目前还不支持 spi,没有 spi 就失去了很多乐趣,如 easyflash、spi 的屏幕,蓝讯的这次活动我接到了模拟 spi 的任务,下面介绍如何写
    的头像 发表于 08-22 09:28 1652次阅读
    RT-Thread ssd1306驱动
    RT-Thread 驱动ssd1306
    的头像 发表于 04-21 10:08 26.4w次阅读
    <b class='flag-5'>RT-Thread</b> ssd1306<b class='flag-5'>驱动</b>
    S32K146的hard fault问题解决方案
    最近有个客户使用S32K146的产品在量产之后出现了三个售后件,ABBA测试之后的结果表明失效现象跟着S32K146走;同时客户反馈说试着将其中一个售后件重新烧录程序,S32K146又正常工作了。结合这两种情况,
    的头像 发表于 11-22 11:35 2215次阅读
    <b class='flag-5'>S32K146</b>的hard fault问题解决方案
    基于MM32F5270开发板RT-Thread SPI驱动适配指南
    1、第一次给RT-Thread添加芯片SPI驱动  为MM32F5370开发板添加SPI驱动支持的过程。
    发表于 09-02 14:59
    如何使用RT-Thread SPI设备驱动
    RT-Thread中引入了SPI设备驱动框架。本文说明了如何使用RT-Thread SPI设备驱动
    发表于 10-25 14:20
    RT-Thread编程指南
    RT-Thread编程指南——RT-Thread开发组(2015-03-31)。RT-Thread做为国内有较大影响力的开源实时操作系统,本文是RT-Thread实时操作系统的编程指南
    发表于 11-26 16:06 0次下载
    RT-ThreadSPI的细节内容
    作为通信协议的两大基础,IIC和SPI两者的应用都非常广泛,上一篇文章讲过了RTT上IIC的移植与实践。 《一步到位!教你RT-Thread上设备IIC驱动移植》 讲完IIC,自然少不了SPI
    的头像 发表于 09-30 15:35 3838次阅读
    <b class='flag-5'>RT-Thread</b>上<b class='flag-5'>SPI</b>的细节内容
    RT-Thread (2) RTT SPI设备驱动流程 || LWIP + ENC28J60
    系列文章目录RT-Thread (1) 添加外部内存到内存管理RT-Thread (2) RTT SPI设备驱动流程 || LWIP + ENC28J60目录0 概述0.0 参考资料0
    发表于 11-19 14:21 15次下载
    <b class='flag-5'>RT-Thread</b> (2) RTT <b class='flag-5'>SPI</b>设备<b class='flag-5'>驱动</b>流程 || LWIP + ENC28J60
    RT-Thread Studio驱动SD卡
    RT-Thread Studio驱动SD卡前言一、创建基本工程1、创建Bootloader2、创建项目工程二、配置RT-Thread Settings三、代码分析1.引入库2.读入数据四、效果验证
    发表于 12-27 19:13 20次下载
    <b class='flag-5'>RT-Thread</b> Studio<b class='flag-5'>驱动</b>SD卡
    RT-Thread低功耗的适配和应用
    近期 RT-Thread 工程师完成了基于瑞萨 CPK-RA2L1 开发板的BSP适配,支持了GPIO、UART、I2C、SPI、ADC、DAC、PWM、CAN、on-chip Flash
    的头像 发表于 08-03 10:29 2430次阅读
    RT-Thread文档_RT-Thread 简介
    发表于 02-22 18:22 5次下载
    <b class='flag-5'>RT-Thread</b>文档_<b class='flag-5'>RT-Thread</b> 简介
    RT-Thread文档_RT-Thread SMP 介绍与移植
    发表于 02-22 18:31 9次下载
    <b class='flag-5'>RT-Thread</b>文档_<b class='flag-5'>RT-Thread</b> SMP 介绍与移植
    RT-Thread文档_SPI 设备
    RT-Thread文档_SPI 设备
    发表于 02-22 18:36 2次下载
    <b class='flag-5'>RT-Thread</b>文档_<b class='flag-5'>SPI</b> 设备
    S32K146 RT-Thread 使用SFUD组件驱动spi flash
    的头像 发表于 11-21 01:05 42次阅读
    【<b class='flag-5'>S32K146</b> <b class='flag-5'>RT-Thread</b>】<b class='flag-5'>之</b> 使用SFUD组件<b class='flag-5'>驱动</b><b class='flag-5'>spi</b> flash
