来源 | 嵌入式应用研究院
整理&排版| 嵌入式应用研究院
今天介绍一款我工作上经常用到的一款VSCode的插件-VsCode Action Buttons,这个插件可以释放手敲命令行清除、编译、运行、部署到目标机等操作,具体功能可由开发者自由定义,详细功能的使用可以参考官网。
安装插件并使用
选择扩展设置:
在settings.json中编辑:
根据个人的需求定制功能:
以下是我经常用来编译应用设置的脚本:
"actionButtons":{
"align":"left",
"defaultColor":"White",
"loadNpmCommands":false,
"reloadButton":"刷新",
"commands":[
"cwd":"${workspaceFolder}",
"name":"编译",
"color":"white",
"singleInstance":true,
"command":"rm-rftest_imx6ull&&arm-buildroot-linux-gnueabihf-gcc-gimx6ull.c-otest_imx6ull"
"name":"清除",
"color":"white",
"command":"rm-rftest_imx6ull"
"name":"运行",
"color":"white",
"command":"cdbuild&&./test&"
"name":"部署",
"color":"white",
"command":"scp/home/bruce/workspace/test_imx6ullroot@192.168.31.173:/root"
"local-history.path":"/opt/workspace/.history",
"security.allowedUNCHosts":[
"192.168.31.173"
"security.workspace.trust.untrustedFiles":"open",
"remote.SSH.remotePlatform":{
"192.168.31.173":"linux"
"workbench.iconTheme":"material-icon-theme",
然后底部状态栏处右键将插件使能后将可以愉快的使用类似IDE一样的功能了:
点击清除:
点击编译:
点击部署:
在目标机上运行:
以上还可以将gdb远程调试部署上去,基于目标机的远程调试就更容易定位问题找Bug了,非常方便!大家在工作中有哪些好用的生产力工具呢?欢迎分享!
举报投诉
嵌入式
5210文章
20680浏览量
337374 -
代码
30文章
4977浏览量
74420 -
vscode
1文章
173浏览量
9281
原文标题:工欲善其事,必先利其器-让Vscode调试代码就像IDE一样好用
文章出处:【微信号:嵌入式应用研究院,微信公众号:嵌入式应用研究院】欢迎添加关注!文章转载请注明出处。
热点推荐
WSL2下VSCode插件安装失败的原因?
Collecting gevent<2.0,>=1.2.2 (from gdbgui==0.13.2.0->-r /home/qinge/esp/esp-idf/requirements.txt (line 26))
Using cached gevent-1.5.0.tar.gz (5.3 MB)
Installing build dependencies: started
Installing build dependencies: still running...
Installing build dependencies: finished with status \'done\'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status \'error\'
Installing Python packages from /home/qinge/esp/esp-idf/requirements.txt
error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [315 lines of output]
Compiling src/gevent/resolver/cares.pyx because it changed.
[1/1] Cythonizing src/gevent/resolver/cares.pyx
performance hint: src/gevent/libev/corecext.pyx:1291:5: Exception check on \'_syserr_cb\' will always require the GIL to be acquired.
Possible solutions:
1. Declare \'_syserr_cb\' as \'noexcept\' if you control the definition and you\'re sure you don\'t want the function to raise exceptions.
2. Use an \'int\' return type on \'_syserr_cb\' to allow an error code to be returned.
warning: src/gevent/libev/corecext.pyx:1288:0: Global name __SYSERR_CALLBACK matched from within class scope in contradiction to to Python \'class private name\' rules. This may change in a future release.
Error compiling Cython file:
if events & ~(libev.EV__IOFDSET | libev.EV_READ | libev.EV_WRITE):
raise ValueError(\'illegal event mask: %r\' % events)
# All the vfd_functions are no-ops on POSIX
cdef int vfd = libev.vfd_open(fd)
libev.ev_io_init(&self._watcher, gevent_callback_io, vfd, events)
self.__watcher = &self._watcher
src/gevent/libev/corecext.pyx:1027:25: Cannot convert \'ev_watcher *\' to Python object
self.__ss = &io_ss
src/gevent/libev/corecext.pyx:1028:20: Cannot convert \'start_and_stop *\' to Python object
发表于 06-06 08:07
用离线安装器安装的idf,其创建的Python虚拟环境无激活脚本是怎么回事?
如题,用离线安装器安装的idf,其创建的Python虚拟环境无激活脚本,具体如下图所示:
反而用vscode插件安装的idf有,如下图:
发表于 06-11 06:49
VSCode关闭重启后插件就会失效,提示重新安装怎么解决?
安装完esp-idf离线版后,使用Use existing setup安装插件,可以成功编译运行hello world。
关闭VScode并重新打开,就会提示以下
发表于 06-19 08:28
ubuntu下的vscode插件安装idf时,总是找不到git,为什么?
总是提示:Git is not found in current environment
但是我已经在setting.json下设置了\"git.path\": \"/bin/git\"
同行,命令行里查看git版本和路径都是可以的。为什么还是不行呢?
发表于 06-21 07:16
【合宙Air551G双频定位开发板试用体验】之b站视频
?https://www.bilibili.com/video/BV1si4y1y7eC/这个是视频的链接。按照文档中的提示,我进行相关vscode插件的安装,并继续随后的调试工作。但是这个是
发表于 03-30 07:35
如何在RT-THREAD上生成doxygen呢
vscode 插件安装我们先讲讲doxygen怎么写。传统方法直接用文本编辑器来写,这个我这边就不多介绍了。这边我们用一个工具来帮助我们来写常用的doxygen。打开vscode,
发表于 08-09 10:50
ubuntu下的vscode插件安装idf时,总是找不到git的原因?
总是提示:Git is not found in current environment但是我已经在setting.json下设置了"git.path": "/bin/git"同行,命令行里查看git版本和路径都是可以的。为什么还是不行呢?
发表于 02-20 06:24
vscode常用插件有哪些
vscode是一个不错的开源IDE,可以完全替代sublime,又是跨平台,使用起来还比较方便。使用一段时间后,我觉得有些插件,值得推荐一下。我这里的开发环境是win10下vscode+node.在
发表于 12-23 10:42
•2.2w次阅读
ubuntu18安装vscode搭建嵌入式linux开发环境
ubuntu18安装vscode搭建嵌入式linux开发环境安装vscode配置vscode(安装
发表于 11-01 16:57
•10次下载
VSCODE如何安装ChatGPT插件
zh1:首先在插件商店搜索ChatGPT中文版。然后点击安装就可以
chatGPT插件目前需要登陆账号才能使用,官方介绍下一个版本会有升级(不需要登陆)
a:前往
发表于 02-13 10:02
•0次下载
VSCode批量迁移插件
代码的路
打开之前电脑,找到原电脑VS Code的插件安装目录:
如:
C:\\\\Users\\\\用户名\\\\.vscode\\\\extensions
将extensions文件夹拷贝到
VSCode插件的安装和使用
