Maxim公司的MAX13335E/MAX13336E是用于汽车的高保真立体声音频输入放大器,具有双路低噪音可编增益放大器,采用全差分(7VRMS)和准差分(3.5VRMS)输入信号以及通过I2C接口控制的诊断功能,工作电压3.3V或5V,28V到-16V容差输入,共模输入-5V到+11.5V,主要用在汽车无线电前置单元,RSA/RSE,连接模块和汽车远程信息处理。本文介绍了MAX13335E/MAX13336E主要优势和特性,框图和应用电路,以及评估板MAX13335E EVK主要特性,电路图,材料清单和PCB设计图。
The MAX13335E/MAX13336E are high-fidelity stereo audio input amplifiers designed for automotive applications requiring audio-level detection and/or jack sensing capability. The devices feature a dual-channel, low-noise, programmable gain amplifier that accepts fully differential and quasi-differential input signals with diagnostics capability controlled through an I2C interface. The devices’audio receiver can also pair with the MAX13325/MAX13326 audio transmitter to form a complete differential audio link in automotive systems.
Each channel of the device features high common-mode rejection ratio (CMRR) (80dB), enabling the recovery of audio signals in the presence of large common-mode noise in automotive environments. An integrated programmable gain amplifier is adjustable from -14dB to +16dB (MAX13335E) and -22dB to +8dB (MAX13336E) with zero-crossing detection to provide an optimum output-signal level and limit zip noise. The external flexible diagnostic inputs can be configured to perform jack sense functions or to detect short-to-battery, short-to-ground, open load, and shorts between channels.
The audio inputs are protected against ISO 10605 ±15kV Air Gap and ±8kV Contact Discharge ESD pulses. Both devices have a -40℃ to +105℃ operating temperature range, and are available in a 16-pin QSOP package.
MAX13335E/MAX13336E主要优势和特性:
+3.3V or +5V Operation
+28V to -16V Tolerant Inputs
Wide Common-Mode Input Range (-5V to +11.5V)
Fully Differential Inputs Up to 7VRMS
Quasi-Differential Inputs Up to 3.5VRMS
Audio Presence Detection
Jack Sense Detection
Diagnostic Capability
Programmable Gain with Zero-Crossing Detection
I2C Control Interface
Automotive Grade ESD Protection
• ISO 10605 ±15kV Air Gap
• ±8kV Contact Discharge
MAX13335E/MAX13336E应用:
Radio Head Units
RSA/RSE
Connectivity Modules
Automotive Telematics
图1.MAX13335E/MAX13336E典型应用框图
图2.MAX13335E/MAX13336E应用电路图(1)
图3.MAX13335E/MAX13336E应用电路图(2)
图4.MAX13335E/MAX13336E应用电路图(3)
评估板MAX13335E EVK
The MAX13335E evaluation kit (EV kit) is a fully assembled and tested PCB that evaluates the MAX13335E automotive audio receiver. The IC features a dual automotive differential audio receiver with I2C control and diagnostics. The EV kit features an on-board microcontroller for communicating with the I2C interface of the device. PCB pads are provided for accessing the analog inputs/outputs and the diagnostic I/O ports.
The EV kit operates from a +3.3V or +5V power supply that provides 100mA of current. The EV kit can also operate from the on-board USB +5V supply. The EV kit delivers the audio outputs with programmable gain between -14dB and +16dB. The EV kit can also evaluate the MAX13336E after IC replacement of U1.
Windows XPM-, Windows VistaM-, and WindowsM 7-compatible software is provided to facilitate configuration. The EV kit software controls the on-board microcontroller over the USB, which generates I2C commands.
评估板MAX13335E EVK主要特性:
S +3.3V or +5V Single-Supply Operation
S Proven Audio PCB Layout
S On-Board USB Interface Circuit Generates I2C-Compatible Signals
S PCB Pads for User-Supplied I2C-Compatible Signals
S Surface-Mount Components
S Evaluates the MAX13336E After IC Replacement
S Windows XP-, Windows Vista-, and Windows 7-Compatible Software
S Fully Assembled and Tested
图5.评估板MAX13335E EVK电路图(1)
图6. 评估板MAX13335E EVK电路图(2)
评估板MAX13335E EVK材料清单:
图7.评估板MAX13335E EVK PVB设计图(1):左:元件布局;右:元件面走线
图8.评估板MAX13335E EVK PVB设计图(2):GND层2
图9.评估板MAX13335E EVK PVB设计图(3):左:PWR层3;右:焊接面
Maxim
8文章
859浏览量
87486 -
音频
29文章
2915浏览量
82084
8路立体声音频光端机
22W立体声音频功率放大器MAX9787相关资料下载
HiFi立体声音频处理芯片TDA8425相关资料下载
MAX9888 具有FLEXSOUND技术的立体声音频编解码
![<b class='flag-5'>MAX</b>9888 具有FLEXSOUND技术的<b class='flag-5'>立体声音频</b>编解码](https://file1.elecfans.com//web2/M00/A5/AE/wKgZomUMOZSAOWTkAACow7yIGxk532.jpg)
Maxim MAX9888立体声音频CODEC解决方案
![<b class='flag-5'>Maxim</b> <b class='flag-5'>MAX</b>9888<b class='flag-5'>立体声音频</b>CODEC解决<b class='flag-5'>方案</b>](https://file1.elecfans.com//web2/M00/A5/C0/wKgZomUMOe6AdqMbAACNsGuX0DY006.gif)
MAX9867 超低功耗立体声音频编解码器
![<b class='flag-5'>MAX</b>9867 超低功耗<b class='flag-5'>立体声音频</b>编解码器](https://file1.elecfans.com//web2/M00/A5/D4/wKgZomUMOk-AXM7eAADx4quOlfc933.jpg)
MAX5556–MAX5559立体声音频数模转换器(DAC)
![<b class='flag-5'>MAX</b>5556–<b class='flag-5'>MAX</b>5559<b class='flag-5'>立体声音频</b>数模转换器(DAC)](https://file1.elecfans.com//web2/M00/A5/DB/wKgZomUMOnOAP4McAAAOTX9lZMU924.jpg)
Maxim推出高集成度立体声音频编解码器MAX98089
![<b class='flag-5'>Maxim</b>推出高集成度<b class='flag-5'>立体声音频</b>编解码器<b class='flag-5'>MAX</b>98089](https://file1.elecfans.com//web2/M00/A5/F0/wKgZomUMOuaABgb-AABkbieyc98228.jpg)
