KiCad发布了第四个7系列的错误修复版本。7.0.6稳定版包含了自上一版本以来的关键错误修复和其他小的改进。 自7.0.5版本以来所有修复的问题列表可以在KiCad 7.0.6里程碑页面找到。这个版本包含几个关键的错误修复,所以请考虑尽快升级。 7.0.6版本是在7.0分支的基础上,从开发分支中挑出一些修改。 修复问题列表:
https://gitlab.com/groups/kicad/-/milestones/28#tab-issues
下载页面:
https://www.kicad.org/download/
变更列表
通用
Fix issue with colours in the new lazy-loaded preference panels.#14784
Fix preferences dialog "Reset to Default" button.#14786
Fix view shifting when infobar is shown.
Improve appearance of stroked knockout text.
Outline font performance improvements.#14303
Correctly handle hidden columns when pasting into grids.#14844
Handle numeric keypad enter in missing places.#14244
Force word wrapping of PCM package descriptions on Mac.#13328
Fix broken cursor key handling in library tree pane.#12702
Fix null pointer access attempting to read common settings.#14928
Maintain file permissions to prevent locking out other developers.#13574
Fix broken file locking.#14734
原理图
Fix block mirroring of fields attached to labels.14758
Fix pin preferences dialog size.#14785
Fix crash if ${VALUE} variable expansion recurses.#14815
Fix worksheet text layout when using custom font.#14822
Don’t dim fields when selecting them.
Fix arc color printing bug.#14915
Fix inter-sheet reference position when printing.#14978
Fix handling of SPICE parameters that include capital letters.#14793
Fix unhandled exception when loading model files.#15012
Fix unknown model type in IBIS file.#15068
Fix SENTRY issue KICAD-2EF.
符号编辑器
Ensure a new derived symbol has the correct alternate body style option displayed.#13739
Fix null pointer assertion in symbol library cache.#14927
Fix segfault when selecting a pad from the footprint browser.#14971
封装分配工具
Fix crash when "View selected footprint in footprint viewer" is clicked.#14850
Fix crash when destroy footprint frame gets called more than once.#14928
PCB编辑器
Export STEP circular board outlines as cylinder.
Fix unexpected rats nest behavior.#14715
Delete ratsnest line after drawing track.#14781
Fix discrepancy between interactive routing and design rules checker.#14771
Fix clipped combobox entry in text box dialog.
Hook up text variable automatic completion.#14777
Fix crash when saving a board with overbar text using a non KiCad font.#14804
Shorten overly verbose error message on board load failure.#14780
Fix DRC assertion for unsupported collisions.#14890
Fix differential pair routing crash.#14852
Fix use after free crash in router drag walkaround mode.
Don’t allow setting a pad width or height of 0.#14278
Fix broken rotated dimensions when importing Altium PCB.#13751
Fix net inspector crash.#14697
Fix search pane not remembering docking sizes and positions.#14120
Do not allow selecting reference text when reference display is disabled.#14911
Show dimensions in footprint preview panel.#14913
Re-create missing exclusion markers if DRC was canceled.#14919
Do not plot edge cut layer arcs in Gerber files when plotting solder mask layers.#14960
Do not require restart to make graphic default settings changes take effect.#14932
Ensure differential pair gap is respected when switching track postures.#14984
Fix tab order in edit text and graphics properties dialog.#9406
Fix broken arcs on DXF import.#14210
Fix zone fill issue with net ties.#15069
Add DRC testing for copper graphic to zone fill collisions.
封装编辑器
Fix unexpected change of default preferences in text and graphic properties dialog.#14925
3D 查看器
Trim solder paste and other layers to holes.#8484
Fix display of castellated vias.#14757
PCB 计算器
Fix grid layout issues on Ubuntu.#14743
命令行接口
Fix blank symbol on SVG export file names.#14857
Fix incorrect unit when user origin is specifed when exporting STEP files.
Support mirror option in PDF export.
Add the missing plot formats to schematic export.
Add option to plot PCB GERBER files with KiCad file extension.
KiCAD
5文章
171浏览量
8855
