TI公司的TIDA-03027是USB Type-C和供电多端口适配器电源参考设计,包括USB Type-C全特性的插座,可即时连接USB Type-C充电器(高达20V/3A)或设备。也可连接到HDMI 2.0和USB3.0 Type-A接口,主要用在笔记本电脑,平板电脑和带USB Type-C接口的电话系统。本文介绍了参考设计TIDA-03027主要特性,生态系统图和框图,电路图,材料清单和PCB设计图。
The TIDA-03027 reference design offers a multiportadapter solution that enables products with a USBType-C™ interface to connect to HDMI 2.0 and USB3.0 Type-A interfaces. The design also includes anadditional USB Type-C full-feature receptacle, whichallows the user to simultaneously connect USB Type-C chargers (up to 20 V, 3 A) or devices. This featureset is particularly useful as a peripheral to notebook,tablet, and phone systems with a single USB Type-Cinterface.
The TIDA-03027 reference design showcases a Type-C plug that allows a notebook, tablet, or phone tosimultaneously interface with HDMI 2.0, USB 3.0 Type-A, and USB Type-C systems (chargers anddevices)。 Thus, the board serves as a multiport adapter for USB Type-C hosts. This board features USB3.0 data, video, and charging (up to 20 V, 3 A) over a single, USB Type-C plug connection.
The USB Type-C plug and receptacle both interface with a TPS65983B device, which handles powerdelivery negotiations and controls the primary power field-effect transistors (FETs)。 Two SuperSpeedlanes (SSTX/RX2) are routed directly to a DisplayPort (DP) to HDMI converter. The other SuperSpeedlanes (SSTX/RX1) are routed to the HD3SS3212, which demuxes the signals between the DP-to-HDMIconverter and the TUSB8041 USB 3.0 HUB. This routing allows the TPS65983B device to controlbetween four-lanes of DP-to-HDMI and two-lanes of DP-to-HDMI + USB3.0 (for Type-A and Type-C dataconnections)。
The TUSB8041 is a USB 3.0 HUB, which receives high-speed and SuperSpeed signals from the upstreamUSB Type-C plug. This device expands the USB Type-C host signals to four ports, which allowssimultaneous USB 3.0 or USB 2.0 enumeration at the Type-C and Type-A receptacle ports. This devicealso enables the USB Type-C plug to utilize the USB 2.0 low-speed endpoint feature of the TPS65983B.
The power path between the USB Type-C plug and receptacle ports is controlled by the LM3489 variableDC-DC converter. The TPS65983B device controls the output voltage of the LM3489 device, dependingon the power contract that is negotiated with the USB Type-C host. This feature is particularly useful whenthere is a mismatch in power contracts between a USB Type-C host and charger.
Both USB Type-C interfaces utilize the TPS83S00 and TPD1E01B04 electrostatic discharge (ESD)devices for signal input-output (I/O) protection. The USB Type-A interface uses single-bit ESD(TPD1E01B04) for I/O protection. The HDMI interface is protected using the TPD13S523, which is anintegrated 13-channel ESD and current-limiting device.
参考设计TIDA-03027主要特性:
• USB Type-C and PD Full-Feature Plug
• Bi-Directional Power (up to 20 V, 3 A)
• Fast Role-Swap Capable
• Video (up to 4K) Through HDMI 2.0
• USB 3.0 Through USB Type-A or USB Type-C™Receptacle
• Aardvark Connector for Debug and Flash Update
• Flash Update Over USB Type-C™ Through USB2.0 Endpoint
参考设计TIDA-03027应用:
• Evaluation of USB Type-C Multiport Adapter andDongle Solutions With Video, Charging, and DataCapabilities
图1.参考设计TIDA-03027外形图
图2.参考设计TIDA-03027生态系统图
图3.参考设计TIDA-03027框图
图4.参考设计TIDA-03027电路图(1)
图5.参考设计TIDA-03027电路图(2)
图6.参考设计TIDA-03027电路图(3)
图7.参考设计TIDA-03027电路图(4)
图8.参考设计TIDA-03027电路图(5)
图9.参考设计TIDA-03027电路图(6)
图10.参考设计TIDA-03027电路图(7)
图11.参考设计TIDA-03027电路图(8)
图12.参考设计TIDA-03027电路图(9)
图13.参考设计TIDA-03027电路图(10)
图14.参考设计TIDA-03027电路图(11)
图15.参考设计TIDA-03027电路图(12)
参考设计TIDA-03027材料清单(BOM):
图16.参考设计TIDA-03027 PCB设计图(1)
图17.参考设计TIDA-03027 PCB设计图(2)
图18.参考设计TIDA-03027 PCB设计图(3)
图19.参考设计TIDA-03027 PCB设计图(4)
图20.参考设计TIDA-03027 PCB设计图(5)
图21.参考设计TIDA-03027 PCB设计图(6)
图22.参考设计TIDA-03027 PCB设计图(7)
图23.参考设计TIDA-03027 PCB设计图(8)
usb
60文章
8474浏览量
285766 -
type-c
557文章
2053浏览量
278276
一种多端口适配器解决方案TIDA-03027技术参考资料及物料清单下载
45W USB Type-C™PD DFP适配器
USB Type-C DFP输出适配器参考设计包括BOM及层图
Type-C适配器达到能源效率标准
USB-C PD适配器的相关资料推荐
为什么考虑使用USB Type-C PD充电?
赛普拉斯全新EZ-PD CCG3控制器简化USB Type-C主机、配件以及电源适配器设计
小米USB Type-C 65W电源适配器使用体验
微软推Surface Connect转USB Type-C适配器,售价19.99美元起
Type-C适配器的使用场景
Type-C多口适配器解决方案
基于EVLONEPCC USB Type-C适配器的技术应用解析
基于TIDA-03027的USB Type-C多端口适配器电源参考设计
