Thundercomm 最近推出了围绕 Qualcomm QCS6490 SoC 构建的 Rubik Pi AI SBC,该 SoC 具有 12.5 TOPS AI 加速器。SBC 采用“PI-CO ITX”外形尺寸,结合了 Pico-ITX 标准和 Raspberry Pi SBC 上的 40 针 GPIO 接头。
SBC 带有一组标准接口,包括 USB、HDMI 输出、MIPI-CSI 摄像头支持、以太网、Wi-Fi 5、蓝牙 5.2 等等。此外,SBC 还具有用于 GPIO 的 40 引脚接头、用于调试的 UART、音频输出和 RTC 电池支持。该公司提到,这是第一个使用高通 AI 平台的基于 Pi 的系统,因此它支持 Raspberry Pi HAT/HAT+ 扩展板,使其适用于各种 AI、物联网和边缘计算项目。
Rubik Pi AI SBC specification
SoC –Qualcomm QCS6490
CPU – Octa-core Kryo 670 with 1x Gold Plus core (Cortex-A78) @ 2.7 GHz, 3x Gold cores (Cortex-A78) @ 2.4 GHz, 4x Silver cores (Cortex-A55) @ up to 1.9 GHz
GPU – Adreno 643L GPU @ 812 MHz with support for Open GL ES 3.2, Open CL 2.0, Vulkan 1.x, DX FL 12
DSP – Hexagon DSP with dual HVX and 4K HMX
VPU – Adreno 633 VPU up to 4K60 decode for H.264/H.265/VP9, Up to 4K30 encode for H.264/H.265; Support for HDR10 and HDR10+ playback
Spectra ISP – 64 MP / 36 + 22 MP / 3×22 MP at 30fps ZSL; 192 MP non-ZSL
AI – 6th gen Qualcomm AI Engine that combines Compute Hexagon DSP with dual Hexagon Vector, eXtensions (HVX), Hexagon Co-processor (Hexagon CP) 2.0 and Hexagon Tensor accelerator forup to 12 TOPS of AI performance
System Memory – 8GB LPDDR5
Storage
128GB UFS flash (µMCP: i.e. the RAM and UFS are in the same chip)
M.2 M-Key socket for SSD
Video Output
HDMI 1.4 (4K @ 30FPS)
DisplayPort over USB Type-C (4K @ 60FPS)
Camera Inputs – 2 x MIPI-CSI D-PHY (4-lane)
Audio
3.5mm headphone jack
HDMI audio out
Connectivity
Wi-Fi 5 supports 802.11 ac/a/b/g/n
Bluetooth 5.2
USB
1 x USB Type-C port (USB 3.1 Gen 1)
2 x USB Type-A ports (USB 3.0)
1 x USB Type-A port (USB 2.0 Host/Device)
Expansion
M.2 M Key Connector for SSD
40-pin Raspberry Pi compatible header with 28x GPIO, 1x I2S, 1x PWM, 2x I2C, 3x I2C or SPI or UART
Misc
Power on button
RGB LED
RTC battery connector
PWM fan connector
Power supply – 12V/3A input over USB Type-C PD
Dimensions – 100mm x 75mm (~Pico-ITX and PI-CO ITX form factors)
AI
87文章
32422浏览量
271587 -
SBC
80浏览量
19324 -
Qualcomm
8文章
676浏览量
52481
中科创达旗下创通联达宣布RUBIK Pi 3全球发售
linux是实时系统还是分时操作系统
Banana Pi BPI-M1S RK3528 SBC 具有 HDMI 2.0、2.5GbE、WiFi 6 等功能
linux操作系统安装步骤 linux操作系统的特点及组成
工控机支持什么操作系统
请问MODUS支持LINUX、FREERTOS、UCOS、Mbed、Android所有操作系统吗?
工业实时操作系统对比:鸿道Intewell跟rt-linux有啥区别
广和通发布基于高通 QCM6490和QCS8550处理器的端侧AI解决方案
广和通发布基于高通QCM6490和QCS8550的端侧AI解决方案,使AI“更接地气”
玄铁正式支持 Linux Kernel 6.6,携手全球生态伙伴共同推动操作系统 RISC-V 主线演进
vivo首批适配Android 15 Beta版本操作系统
广和通发布多款基于高通智能模组的系列Linux边缘AI解决方案
embedded world 2024 | 广和通发布多款基于高通平台的Linux边缘AI解决方案
embedded world 2024广和通发布多款基于高通平台的Linux边缘AI解决方案
