STMicro STSPIN32G0 是一系列新的高级三相电机控制器,可变电压范围为 45V 至 600V,通过集成 MCU 和电机驱动器扩展了 STMicro 的器件产品组合。
新系列将三半桥栅极驱动器与基于 Arm Cortex-M0+ 的 [STM32G0] 微控制器相结合,能够处理六步和磁场定向控制 (FOC) 算法。STSPIN32G0 系列的集成设计可节省成本,并“在不影响性能和稳健性的情况下显著减少 BOM 面积”。
STSPIN32G0 系列有两个主要版本,低压和高压。低压 3 相电机控制器包括一个稳压器、一个或三个分流器以及一个额定电压为 45V、电流高达 0.6A 的栅极驱动器。它们主要针对家用电器、电动工具和无人机。高压版本可以处理 250V 或 600V,使其适用于工业逆变器和风扇。它们针对家用电器、空调、家用和工业冰箱、工业泵和工业自动化。
STSPIN32G0A1/A2/B1/B2 ( low-voltage ) specifications:
- MCU – [Arm Cortex-M0+] 32-bit core @ up to 64MHz
- Memory – 64KB flash memory and 8KB SRAM
- Motor Control
- Peripherals
- 5-channel DMA controller with flexible mapping
- Power
- Debugging – On-chip debug support via SWD and embedded bootloader through UART and I2C
- Operating Temperature – -40°C to 125°C
- Package –VFQFPN48 (7mm x 7mm)
STSPIN32G0251/252/601/602 ( high-voltage ) specifications:
- MCU – Arm Cortex-M0+ 32-bit core @ up to 64MHz
- Motor Control
- Operating voltage from 6.7 to 45 V
- Three-phase gate drivers
- High-voltage rail up to 250 V (STSPIN32G0251/252)
- High-voltage rail up to 600 V (STSPIN32G0601/602)
- dV/dt transient immunity ±50 V/ns
- Gate driving voltage range from 9 V to 20 V
- Integrated bootstrap diodes
- Driver current capability: 200/350 mA source/sink current @ 25 °C
- Peripherals
- I2C, USART, and SPI interfaces
- 32x GPIO
- Timers – 5x general-purpose timers (1x 32-bit + 4x 16-bit), 1x advanced-control timer dedicated for motor control, 2 low-power timers
- Analog – 1x comparator, 12-bit ADC (up to 15 external channels) with 2 Msps conversion rate
- Standby mode for low power consumption
- Protection – UVLO, interlocking, deadtime, and smart shutdown
- Package – QFN 72-pin (10 x 10 mm), 0.5 pitch
Part numbers ending in “1” have fewer pins than those ending in “2.” However, they support Vbat as a backup to Vdd, ensuring the system can resume operations after power loss, or provide Vref, maintaining a stable ADC reference.
EVSPIN32G06Q1S1 3-phase complete inverter board based on the STSPIN32G0601 controller
STMicro offers an evaluation board for each product variant and compatibility with software tools such as the X-CUBE-MCSDK and STM32CubeMX configurator.
ST
32文章
1128浏览量
128808 -
电机控制器
20文章
515浏览量
32026
