ADI ADM3065EIEC静电放电(ESD)保护RS-485收发器解决方案
电子工程师 作者:工程师陈翠 2018-06-17 16:54 次阅读
ADI公司ADM3065E是3.0V-5.5V IEC ESD保护的RS-485收发器,其总线引脚上能经受住±12 kV接触放电,IEC 61000-4-2≥±12 kV 空气放电,HBM ≥ ±30 kV,数据速率50Mbps,完全符合Profibus®标准,扩展温度到125℃ ,半双工作,可连接多达128个节点到总线,主要用在工业现场总线,过程控制,建筑物自动化,Profibus网络以及马达控制伺服驱动和编码器。本文介绍了ADM3065E主要特性,框图和应用电路,以及评估板EVAL-ADM3061EEBZ和EVAL-ADM3061EEB1Z主要特性,电路图,材料清单和PCB设计图。
The ADM3065E is a 3.0 V to 5.5 V, IEC electrostatic discharge (ESD) protected RS-485 transceiver, allowing the device to withstand ±12 kV contact discharges on the transceiver bus pins without latch-up or damage. The ADM3066E features a VIO logic supply pin allowing a flexible digital interface capable of operating as low as 1.62 V.
The ADM3065E/ADM3066E are suitable for high speed, 50 Mbps, bidirectional data communication on multipoint bus transmission lines.
The ADM3061E/ADM3065E/ADM3066E feature a ¼ unit load input impedance, which allows up to 128 transceivers on a bus. The ADM3061E models offer all of the same features as the ADM3065E models, but at a low 500 kbps data rate suitable for operation over long cable runs.
The ADM3061E/ADM3065E/ADM3066E are half-duplex RS-485 transceivers, fully compliant to the Profibus® standard with increased 2.1 V bus differential voltage at VCC ≥ 4.5 V.
The RS-485 transceivers are available in a number of space-saving packages, such as a 10-lead, 3 mm × 3 mm LFCSP, an 8-lead, 3 mm × 3 mm MSOP, a 10-lead, 3 mm×3 mm MSOP,and an 8-lead, narrow body SOIC package. Models with operating temperature ranges of −40℃ to +125℃ and −40℃ to +85℃ are available.
Excessive power dissipation caused by bus contention or by output shorting is prevented by a thermal shutdown circuit. If, during fault conditions,a significant temperature increase is detected in the internal driver circuitry, this feature forces the driver output into a high impedance state.
The ADM3061E/ADM3065E/ADM3066E guarantee a logic high receiver output when the receiver inputs are shorted, open, or connected to a terminated transmission line with all drivers disabled.
ADM3065E主要特性:
TIA/EIA RS-485 compliant over full supply range
3.0 V to 5.5 V operating voltage range on VCC
1.62 V to 5.5 V VIO logic supply
ESD protection on the bus pins
IEC 61000-4-2 ≥ ±12 kV contact discharge
IEC 61000-4-2 ≥ ±12 kV air discharge
HBM ≥ ±30 kV
Full hot swap support (glitch free power-up/power-down)
High speed 50 Mbps data rate (ADM3065E/ADM3066E)
Low speed 500 kbps data rate for long cables (ADM3061E)
Full receiver short-circuit, open circuit, and bus idle fail-safe
Extended temperature range up to 125℃
Profibus compliant at VCC ≥ 4.5 V
Half duplex
Allows connection of up to 128 nodes onto the bus
Space-saving package options
8-lead and 10-lead MSOP
ADM3065E应用:
Industrial fieldbuses
Process control
Building automation
Profibus networks
Motor control servo drives and encoders
图1.ADM3066E功能框图
图2.ADM3061E/ADM3065E功能框图
图3.ADM3061E/ADM3065E半双工RS-485通信网络
图4.ADM3061E/ADM3065E信号电源隔离25Mbps RS-485解决方案简图
图5.ADM3061E/ADM3065E信号和电源隔离50Mbps RS-485解决方案简图
The EVAL-ADM3061EEBZ and EVAL-ADM3061EEB1Z allow quick and easy evaluation of the ADM3061E 50 Mbps RS-485 transceiver with standard SOIC and MSOP footprints, respectively. The evaluation boards allow the input and output functions to be exercised without external components. Screw terminal blocks provide convenient connections for power and ground, digital input and output, and RS-485 signals. The evaluation boards can be powered by a standard configurable bench power supply within a 3 V to 5 V range.
The EVAL-ADM3061EEBZ evaluation board has a footprint for the ADM3061EBRZ half-duplex RS-485 transceiver in an 8-lead SOIC package. The EVAL-ADM3061EEB1Z evaluation board has a footprint for a full duplex RS-485 transceiver in an 8-lead MSOP package.
Complete specifications for the ADM3061E device are provided in the ADM3061E data sheet and should be consulted in conjunction with this user guide when using the evaluation board.
评估板EVAL-ADM3061EEBZ和EVAL-ADM3061EEB1Z主要特性:
Easy evaluation of the ADM3061E 50 Mbps RS-485 transceiver Board layouts for standard half-duplex RS-485 footprints
8-lead, SOIC, ADM3061EBRZ (EVAL-ADM3061EEBZ)
8-lead, MSOP, ADM3061EBRMZ (EVAL-ADM3061EEB1Z)
Power/ground connections through screw terminal block
IEC ESD protection on the RS-485 A bus pin and B bus pin
±12 kV contact discharge and ±12 kV air discharge
Screw terminal blocks for logic input/output and RS-485 signals
Jumper-selectable enable/disable for RE and DE
Test points for measuring all signals
Resistors and footprints for termination and biasing networks
图6.评估板EVAL-ADM3061EEBZ外形图
图7.评估板EVAL-ADM3061EEB1Z外形图
图8.半双工RS-485两板点对点测试图
图9.评估板EVAL-ADM3061EEBZ电路图
图10.评估板EVAL-ADM3061EEB1Z电路图
评估板EVAL-ADM3061EEBZ材料清单:
评估板EVAL-ADM3061EEB1Z材料清单:
图11.评估板EVAL-ADM3061EEBZ PCB设计图:丝印
图12.评估板EVAL-ADM3061EEBZ PCB设计图:元件面/层1
图13.评估板EVAL-ADM3061EEBZ PCB设计图:层2
  • ADI
    ADI
  • RS-485
    RS-485接口保护电路
    如图所示RS-485接口保护电路,是经过验证并测试的电磁兼容性(EMC)解决方案,可为使用广泛的RS-485通信端口提供三重保护。每个
    发表于 05-08 10:04
    EMC COMPLIANT RS-485收发器参考保护电路
    电路功能与优势图1所示电路使用ADM3485E 收发器,是经过验证并测试的 电磁兼容性(EMC)解决方案,可为使用广泛的RS-485通信端口提供三重
    发表于 10-16 08:56
    信号和电源隔离RS-485现场总线的高速或低功耗解决方案
    ,通常需要更高的数据速率、更小的RS-485收发器封装和IEC 61000-4-2 ESD保护ADM3065E/
    发表于 10-23 17:11
    ADM306xE是一款3至5.5 V的RS-485收发器
    典型应用使用ADM3065EARZ-R7 3至5.5 V,±12 kV IEC ESD保护,50 Mbps RS-485收发器
    发表于 06-26 08:57
    ADM306xE是一款3至5.5 V,IEC静电放电ESD保护RS-485收发器
    典型应用使用ADM3066EACPZ-R7 3至5.5 V,±12 kV IEC ESD保护,500 kbps RS-485收发器
    发表于 06-26 13:08
    ADM3065E适用于多点总线传输线上的高速
    典型应用使用ADM3065EBRMZ 3至5.5 V,±12 kV IEC ESD保护,50 Mbps RS-485收发器
    发表于 06-27 11:03
    使用ADM3062EBRMZ的50 Mbps RS-485收发器典型应用
    典型应用使用ADM3062EBRMZ 3至5.5 V,±12 kV IEC ESD保护,50 Mbps RS-485收发器
    发表于 06-27 12:09
    EVAL-CN0313-SDPZ适用于使用ADM3485E收发器的流行RS-485通信端口的三种保护级别
    EVAL-CN0313-SDPZ,评估板展示经过验证和测试的电磁兼容性(EMC)兼容解决方案,适用于使用ADM3485E收发器的流行RS-485通信端口的三种
    发表于 07-15 11:16
    信号和电源隔离RS-485现场总线应用笔记
    应用而言,通常需要更高的数据速率、更小的RS-485收发器封装和IEC 61000-4-2 ESD保护ADM3065E/
    发表于 07-18 07:39
    ADM2682E/ADM2687E: 5 kV rms信号和电源隔离RS-485收发器,提供±15 kV ESD保护
    发表于 03-21 12:36 8次下载
    <b class='flag-5'>ADM</b>2682E/<b class='flag-5'>ADM</b>2687E: 5 kV rms信号和电源隔离<b class='flag-5'>RS-485</b><b class='flag-5'>收发器</b>,提供±15 kV <b class='flag-5'>ESD</b><b class='flag-5'>保护</b>
    UG-1266:使用ADM2587E 2.5 kV rms信号和带±15 kV ESD保护的电源隔离RS-485/RS-422收发器评估隔离RS-485中继
    发表于 04-30 08:50 9次下载
    UG-1266:使用<b class='flag-5'>ADM</b>2587E 2.5 kV rms信号和带±15 kV <b class='flag-5'>ESD</b><b class='flag-5'>保护</b>的电源隔离<b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422<b class='flag-5'>收发器</b>评估隔离<b class='flag-5'>RS-485</b>中继<b class='flag-5'>器</b>
    ADM3485E:15 kV ESD保护,3.3 V,12 Mbps,EIA RS-485/RS-422收发器数据表
    发表于 05-08 15:55 9次下载
    <b class='flag-5'>ADM</b>3485E:15 kV <b class='flag-5'>ESD</b><b class='flag-5'>保护</b>,3.3 V,12 Mbps,EIA <b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422<b class='flag-5'>收发器</b>数据表
    ADM485E/ADM487E/ADM1487E:5 V,15 kV ESD保护的半双工RS-485/RS-422收发器数据表
    发表于 05-09 17:15 6次下载
    <b class='flag-5'>ADM485</b>E/<b class='flag-5'>ADM</b>487E/<b class='flag-5'>ADM</b>1487E:5 V,15 kV <b class='flag-5'>ESD</b><b class='flag-5'>保护</b>的半双工<b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422<b class='flag-5'>收发器</b>数据表
    ADM1490E/ADM1491E:16 Mbps,ESD保护,全双工RS-485收发器数据表
    发表于 05-12 19:44 3次下载
    <b class='flag-5'>ADM</b>1490E/<b class='flag-5'>ADM</b>1491E:16 Mbps,<b class='flag-5'>ESD</b><b class='flag-5'>保护</b>,全双工<b class='flag-5'>RS-485</b><b class='flag-5'>收发器</b>数据表
    UG-1000:评估ADM3065E 3.0 V至5.5 V,±12 kV IEC ESD保护,50 Mbps RS-485收发器
    发表于 05-13 12:23 9次下载
    UG-1000:评估<b class='flag-5'>ADM3065</b>E 3.0 V至5.5 V,±12 kV IEC <b class='flag-5'>ESD</b><b class='flag-5'>保护</b>,50 Mbps <b class='flag-5'>RS-485</b><b class='flag-5'>收发器</b>
