基于MAX30102可穿戴血氧和心率生物传感器解决方案
电子工程师 作者:工程师陈翠 2018-06-17 18:25 次阅读
Maxim公司的MAX30102是高灵敏度血氧和心率生物传感器,包括内部的LED光电检测器,光学元件,以及环境光抑制的低噪音电子学。单个1.8V电源,内部LED电源5.0V,通信通过标准的I2C接口进行,工作温度-40℃ 到 +85℃,微细5.6mm x 3.3mm x 1.55mm 14引脚封装,主要用在可穿戴设备以及健美辅助设备。本文介绍了MAX30102主要优势和特性,系统框图和功能框图,典型应用电路以及评估板MAX30102 EVK主要特性,子板和主板电路图,材料清单和PCB设计图。
The MAX30102 is an integrated pulse oximetry and heart-rate monitor module. It includes internal LEDs, photodetectors, optical elements, and low-noise electronics with ambient light rejection. The MAX30102 provides a complete system solution to ease the design-in process for mobile and wearable devices.
The MAX30102 operates on a single 1.8V power supply and a separate 5.0V power supply for the internal LEDs. Communication is through a standard I2C-compatible interface. The module can be shut down through software with zero standby current, allowing the power rails to remain powered at all times.
MAX30102主要优势和特性:
Heart-Rate Monitor and Pulse Oximeter Sensor in LED Reflective Solution
Tiny 5.6mm x 3.3mm x 1.55mm 14-Pin Optical Module Integrated Cover Glass for Optimal, Robust Performance
Ultra-Low Power Operation for Mobile Devices Programmable Sample Rate and LED Current for Power Savings
Low-Power Heart-Rate Monitor (《1mW)
Ultra-Low Shutdown Current (0.7μA, typ)
Fast Data Output Capability High Sample Rates
Robust Motion Artifact Resilience High SNR
-40℃ to +85℃ Operating Temperature Range
MAX30102应用:
Wearable Devices
Fitness Assistant Devices
图1.MAX30102系统框图
图2.MAX30102功能框图
图3.MAX30102典型应用电路
评估板MAX30102 EVK
The MAX30102 evaluation kit (EV kit) provides a provendesign to evaluate the MAX30102 integrated pulse-oximetryand heart-rate monitor integrated circuit (IC)。 The EV kitconsist of two boards. USBOSMB is the mother boardand MAX30102DBEVKIT is the daughter board thatincludes the MAX30102 and an accelerometer. The EVkit is powered using the USB supply to generate +1.8Vfor the sensor and +4.5V for the internal LEDs of theMAX30102, and +3.3V for the accelerometer.The EV kit comes with a MAX30102EFD+ installed in a14-pin OESIP package.
评估板MAX30102 EVK特性和优势:
●● Real-Time Monitoring
●● Flexible PCB Design
●● USB-Powered
●● On-Board Accelerometer
●● Proven PCB Layout
●● Fully Assembled and Tested
●● Windows® 7-, and Windows 8/8.1-CompatibleSoftware
图4.评估板MAX30102 EVK子板电路图
图5.评估板MAX30102 EVK子板PCB设计图:左:元件布局;右:层2
图6.评估板MAX30102 EVK子板PCB设计图:左:层3;右:元件面布线图
图7.评估板MAX30102 EVK子板PCB设计图:左:焊接面布局;右:焊接面元件布局
图8.评估板MAX30102 EVK主板电路图
图9.评估板MAX30102 EVK主板PCB设计图:元件面布局;右:元件面PCB布局
图810.评估板MAX30102 EVK主板焊接面PCB布局图
评估板MAX30102 EVK主板材料清单:
  • 传感器
    基于STM32物联网开发板(7)--心率采集MAX30102
    MAX30102是一种集成的脉搏心率监测模块。它包括内部LED,光电探测、光学元件和低噪声电子器件具有环境光抑制。
    的头像 发表于 05-24 11:10 8989次阅读
    基于STM32物联网开发板(7)--<b class='flag-5'>心率</b><b class='flag-5'>血</b><b class='flag-5'>氧</b>采集<b class='flag-5'>MAX30102</b>
    max30102心率传感器
    请问有人用过max30102传感器么? 手册里面有个Proximity Function 功能。大概意思就是 设置完
    发表于 07-24 15:42
    MAX30102脉搏模块AT指令串口输出
    `MAX30102脉搏模块AT指令串口输出芯片说明MAX30102是一个集成的脉搏仪和
    发表于 03-10 17:14
    MAX30102模块的原理及编程 精选资料分享
    一.简介MAX30102是一个集成的脉搏仪和心率监测仪生物传感器的模块(芯片)。它集成了一个660nm红光LED、880nm红外光LED
    发表于 07-19 09:15
    STM32是如何去MAX30102心率传感器
    STM32F103单片机通过IIC控制MAX30102心率传感器MAX30102的VCC引脚
    发表于 08-19 08:33
    基于MAX30100/MAX30102传感器设计的心率检测相关资料分享
    基于美信MAX30100/MAX30102传感器设计的心率检测,以单片机STM32F103
    发表于 11-10 07:27
    心率MAX30102模块资料分享
    心率MAX30102模块资料话不多说,
    发表于 01-07 08:02
    基于MAX30102心率传感器设计
    最近的一个项目需要用到一款心率传感器,选型选择了MAX30102,可以在ArduinoIDE中搜到M
    发表于 01-13 06:24
    脉搏心率监测集成传感器模组,为可穿戴应用提供超低功耗方案
    Maxim Integrated Products, Inc. (NASDAQ: MXIM)推出脉搏心率监测集成传感器模组MAX30102
    发表于 01-13 18:09 3099次阅读
    MAX30102脉搏仪和心率监测模块的数据手册免费下载
    MAX30102是一个集成的脉搏仪和心率监测模块。它包括内部发光二极管,光电探测,光学元件,以及低噪音的电子设备。
    发表于 04-13 08:00 0次下载
    <b class='flag-5'>MAX30102</b>脉搏<b class='flag-5'>血</b><b class='flag-5'>氧</b>仪和<b class='flag-5'>心率</b>监测模块的数据手册免费下载
    MAX30102脉搏仪和心率监测模块的中文数据手册免费下载
    发表于 06-11 08:00 142次下载
    <b class='flag-5'>MAX30102</b>脉搏<b class='flag-5'>血</b><b class='flag-5'>氧</b>仪和<b class='flag-5'>心率</b>监测模块的中文数据手册免费下载
    高灵敏度脉搏仪和心率传感器max30102说明书
    发表于 11-16 17:05 74次下载
    DFRobot心率传感器有哪些,心率传感器的原理
    DFRobot Gravity: MAX30102 心率传感器模块搭载了美信(maxim)的MAX3
    的头像 发表于 02-22 16:27 5809次阅读
    DFRobot<b class='flag-5'>心率</b><b class='flag-5'>血</b><b class='flag-5'>氧</b><b class='flag-5'>传感器</b>有哪些,<b class='flag-5'>心率</b><b class='flag-5'>血</b><b class='flag-5'>氧</b><b class='flag-5'>传感器</b>的原理
    如何使用MAX30102心律脉搏传感器量测心跳和
    MAX30102 是一个集成的脉搏仪和心率监测仪生物传感器的模块。它集成了一个红光 LED和一个红外光 LED、光电检测
    的头像 发表于 11-16 16:18 7098次阅读
    便携式心率检测仪
    便携式心率检测仪使用了一款医疗级别的传感器MAX30102MAX30102是一个集成的脉搏
    的头像 发表于 03-27 09:16 832次阅读
    便携式<b class='flag-5'>心率</b><b class='flag-5'>血</b><b class='flag-5'>氧</b>检测仪
