市面上的新型 管道光电液位传感器 LL10AH
kingfrom308803 来源:kingfrom308803 作者:kingfrom308803 2024-11-25 14:39 次阅读
光学式管道液体传感器
应用邻域 / Application
1. 洗地机/ Washing machine :
检测洗地机清水箱是否有水,给予用户提示加水。检测污水箱是否装满,给予用户提
示需要倒出污水
Check if there is water in the cleaning tank of the floor scrubber and provide
users with a prompt to add water. Check if the sewage tank is full and provide
users with a prompt to pour out the sewage
2. 饮品设备/ Beverage equipment :
在出液设备前添加传感器,若管道内检测不到液体,代表此时设备饮料已经使用完
了,给用户提示添加材料
Add a sensor before the liquid dispensing device. If no liquid is detected in
the pipeline, it means that the device's beverage has been used up and prompts
the user to add materials
3. 咖啡机/ Coffee machine :
在咖啡机的出水管进行安装,当水箱的水使用完后进行提示
Install the water outlet pipe of the coffee machine and provide a prompt when
the water in the tank is used up
4. 自动添料设备(液体)/ Automatic feeding equipment (liquid) :
当材料使用完后需要进行提示或者保护
Prompt or protection is required after the material is used up
需要进行水泵空抽保护,缺液保护的设备都可以使用
Equipment that requires pump vacuum protection and liquid shortage
protection can be used
⚫ 原理及优势/ Principle and Advantages
1. 光学式管道液体传感器的原理/ Principle of Optical Pipeline Liquid Sensor
传感器利用光电效应和光的棱镜的折射效应进行检测管道内是否有液体的存在
当管道内没有液体,传感器的红外发光源发出的光照射到棱镜上,会进行反射
光电二极管接受到红外光,当管内有液体时,不会发生反射现象。受光器件便
不会发生阻值的变化,由电阻的改变从而引发电压的改变,所以在MCU上检测
电压的状态便可以得出管内有没有水
Sensors use the photoelectric effect and the refractive effect of prisms to detect the
presence of liquid in pipelines When there is no liquid in the pipeline, the infrared
light source of the sensor emits light that reflects off the prism The photodiode
receives infrared light and does not reflect when there is liquid inside the tube. The
light receiving device will not undergo a change in resistance, and the change in
resistance will cause a change in voltage. Therefore, detecting the voltage status on
the MCU can determine whether there is water inside the tube
  • 传感器
  • 光电
  • 液位传感器
    变送器与传感器的区别
    在工业自动化和过程控制领域,精确监测液体的对于确保流程的稳定性和安全性至关重要。变送器和
    的头像 发表于 01-06 15:28 380次阅读
    电容传感器的报警原理及优缺点
    电容传感器是一种利用电容量变化来检测变化的传感器。它广泛应用于石油、化工、食品加工、水处
    的头像 发表于 09-19 09:47 977次阅读
    传感器怎么安装和使用呢
    浮球在液体中的浮力变化来检测。 超声波传感器 :利用超声波在液体中的传播时间来测量
    的头像 发表于 09-07 11:07 857次阅读
    ICMAN管道式水位检测演示#传感器 #pcb设计 #电子技术
    传感器
    ICman
    发布于 :2024年09月03日 17:19:14
    无线传感器的应用
    在现代化工业与自动化快速发展的今天,监测已成为保障生产安全、提升运营效率的重要环节。传统监测方式大多依赖于有线传感器,其安装维护复杂
    的头像 发表于 08-28 13:57 345次阅读
    使用霍尔传感器进行检测
    电子发烧友网站提供《使用霍尔传感器进行检测.pdf》资料免费下载
    发表于 08-27 11:12 0次下载
    使用霍尔<b class='flag-5'>传感器</b>进行<b class='flag-5'>液</b><b class='flag-5'>位</b>检测
    传感器,你选对了吗?
    一流传感器系列产品与应用分解
    的头像 发表于 08-07 14:52 3305次阅读
    <b class='flag-5'>液</b><b class='flag-5'>位</b><b class='flag-5'>传感器</b>,你选对了吗?
    斯丹麦德传感器 | 应用介绍
    电子发烧友网站提供《斯丹麦德传感器 | 应用介绍.pdf》资料免费下载
    发表于 08-07 11:35 1次下载
    传感器电路图 带Arduino的SST传感器设计
    传感器是一种广泛应用于工业、农业、环境监测等领域的装置,用于测量液体或固体物质的高低。随着科技的进步,
    的头像 发表于 07-03 16:57 2378次阅读
    <b class='flag-5'>液</b><b class='flag-5'>位</b><b class='flag-5'>传感器</b>电路图 带Arduino的SST<b class='flag-5'>液</b><b class='flag-5'>位</b><b class='flag-5'>传感器</b>设计
    传感器的功能特点及主要类型
      传感器是一种用于监测、维护和测量液体,水平的装置。一旦检测到传感器就会将感知到的数
    的头像 发表于 06-28 17:47 854次阅读
    <b class='flag-5'>液</b><b class='flag-5'>位</b><b class='flag-5'>传感器</b>的功能特点及主要类型
    低价线性霍尔开关AH601在传感器中应用
    的头像 发表于 05-27 09:49 528次阅读
    低价线性霍尔开关<b class='flag-5'>AH</b>601在<b class='flag-5'>液</b><b class='flag-5'>位</b><b class='flag-5'>传感器</b>中应用
    非接触式传感器的工作原理
    传感器,作为工业自动化和过程控制中的重要组成部分,广泛应用于各种液体测量和控制系统中。根据其工作原理和应用场景的不同,
    的头像 发表于 05-24 17:08 3427次阅读
    什么叫做光电传感器光电面的精确控制?
    光电传感器主要由可以反射光的光锥、发射接收管一对、线材组成。一体式的光电
    的头像 发表于 05-11 16:29 661次阅读
    市面上FPGA入门用哪块板子好啊?
    市面上FPGA入门用哪块板子好啊?用的什么开发软件和编程语言的??
    发表于 03-30 11:24
