顺络电子sunlord美林美深MnO₂钽电容器TC212A476K006Y
Carl 来源:jf_01356556 作者:jf_01356556 2024-12-01 21:45 次阅读
钽电容,作为一种以钽金属为阳极材料制成的电容器,具有体积小、容量大、工作电压高、稳定性好等优点。与铝电解电容相比,钽电容在高频和脉冲电路中表现出更低的等效串联电阻(ESR)和更高的能量密度。因此,钽电容被广泛应用于通信消费电子仪器仪表医疗电子等领域。
Tantalum capacitor, as a kind of capacitor made of tantalum metal as anode material, has the advantages of small size, large capacity, high operating voltage and good stability. Tantalum capacitors exhibit lower equivalent series resistance (ESR) and higher energy density in high frequency and pulse circuits compared to aluminum electrolytic capacitors. Therefore, tantalum capacitors are widely used in communication, consumer electronics, instrumentation, medical electronics and other fields.
TC212A476K006Y是深圳顺络电子有限公司推出的一款高性能钽电容器。从规格书可以看出,这款电容器具有多项显著特点:
TC212A476K006Y is a high performance tantalum capacitor launched by Shenzhen Shunluo Electronics Co., LTD. As can be seen from the specification, this capacitor has a number of notable features:
高可靠性:TC212A476K006Y钽电容符合或超过EIA-535BAAC标准,具有自我修复能力,能够在恶劣的工作环境中保持高稳定性。
High reliability: The TC212A476K006Y tantalum capacitor meets or exceeds the EIA-535BAAC standard, has self-healing capability, and can maintain high stability in harsh working environments.
宽广的工作温度范围:其工作温度范围达到-55°C至+125°C,适用于各种极端条件下的应用。
Wide operating temperature range: Its operating temperature range of -55°C to +125°C is suitable for applications under various extreme conditions.
高容量稳定性:在工作温度范围内,电容器的容量保持稳定,为电路提供稳定的电荷存储能力。
High capacity stability: In the operating temperature range, the capacity of the capacitor remains stable, providing a stable charge storage capacity for the circuit.
高体积效率:得益于钽金属的高能量密度,TC212A476K006Y在较小的体积内提供了较高的电容值,有利于电路的小型化和集成化。
High volume efficiency: Thanks to the high energy density of tantalum metal, TC212A476K006Y provides a high capacitance value in a small volume, which is conducive to the miniaturization and integration of the circuit.
三、详细规格
1. 产品标识与尺寸
TC212A476K006Y的产品标识中,各个字符代表了不同的含义:
TC:代表产品系列。
212:表示外部尺寸(LxW)为6.0×3.2mm的封装。
A:表示低ESR(等效串联电阻)类型。
476:表示电容器的标称容量为47μF。
K:表示电容器的容量公差为±10%。
006:表示电容器的额定电压为6.3Vdc
此外,规格书中还详细列出了各种尺寸的电容器封装及其对应的EIA标准代码,如3216-18、3528-21等,方便工程师在设计时选择合适的封装。
1. Product identification and size
In the product identification of TC212A476K006Y, each character represents different meanings:
TC: indicates the product series.
212: represents a package with an external dimension (LxW) of 6.0×3.2mm.
A: Indicates low ESR (equivalent series resistance) type.
476: indicates that the nominal capacity of the capacitor is 47μF.
K: indicates that the capacitance tolerance of the capacitor is ±10%.
006: indicates that the rated voltage of the capacitor is 6.3Vdc.
In addition, the specification also details various sizes of capacitor packages and their corresponding EIA standard codes, such as 3216-18, 3528-21, etc., so that engineers can choose the right package when designing.
电性能参数
TC212A476K006Y的电性能参数同样出色:
容量范围:从0.15μF到680μF不等,可根据具体需求选择合适的容量。
容量公差:±10%或±20%,确保电容器在制造过程中的精度。
额定电压:提供多种额定电压选项,如4V、10V、16V、20V等,满足不同电路的需求。
工作温度范围:-55°C至+125°C,确保电容器在各种极端温度下的可靠性。
等效串联电阻(ESR):低ESR设计,有助于降低电路中的功耗和热量产生。
漏电流(DCL):在特定条件下,电容器的漏电流被控制在较小范围内,保证电路的稳定性。
Electrical property parameter
The electrical performance parameters of the TC212A476K006Y are also excellent:
Capacity range: from 0.15μF to 680μF, suitable capacity can be selected according to specific requirements.
Capacity tolerance: ±10% or ±20%, ensuring the accuracy of the capacitor in the manufacturing process.
Rated voltage: Provide a variety of rated voltage options, such as 4V, 10V, 16V, 20V, etc., to meet the needs of different circuits.
Operating temperature range: -55°C to +125°C, ensuring the reliability of the capacitor in a variety of extreme temperatures.
Equivalent Series resistance (ESR) : Low ESR design helps reduce power consumption and heat generation in the circuit.
Leakage current (DCL) : Under certain conditions, the leakage current of the capacitor is controlled within a small range to ensure the stability of the circuit.
构造与极性标识
TC212A476K006Y采用模制外壳封装,负极端为银色粘附垫片,并带有极性条纹以标识电容器的极性。内部构造包括钽阳极、二氧化锰阴极涂层、碳银漆层以及钽引线等。此外,规格书中还详细列出了电容器的标记方法,包括额定电压代码、容量代码等,方便用户在使用时进行识别和选择。
The TC212A476K006Y is packaged in a moulded housing with a silver adhesive spacer at the negative end and a polar stripe to identify the polarity of the capacitor. The internal structure includes tantalum anode, manganese dioxide cathode coating, carbon-silver coating and tantalum lead. In addition, the specification also lists in detail the marking method of the capacitor, including the rated voltage code, the capacity code, etc., to facilitate the user to identify and select when in use.
应用场景与优势
凭借其出色的性能和稳定性,TC212A476K006Y钽电容在多个领域具有广泛的应用前景:
通信领域:在移动通信、固定电话等通信设备中,TC212A476K006Y可用于滤波、去耦和储能等电路,确保信号的稳定传输和电路的高效运行。
消费电子:在智能手机、平板电脑数码相机等消费电子产品中,TC212A476K006Y可用于电源管理音频电路和信号处理等方面,提高产品的性能和稳定性。
仪器仪表:在精密仪器仪表中,TC212A476K006Y可用于时间延迟电路、测量电路和控制系统等,确保测量结果的准确性和可靠性。
医疗电子:在医疗设备中,TC212A476K006Y可用于起搏器、监护仪等生命支持设备中,确保设备的长期稳定运行和患者的安全。
与其他类型的电容器相比,TC212A476K006Y钽电容具有以下显著优势:
高能量密度:在相同体积下,钽电容能够提供更高的电容值,有利于电路的小型化和集成化。
低ESR:低ESR设计有助于降低电路中的功耗和热量产生,提高电路的效率和稳定性。
长寿命:钽电容具有自我修复能力,能够在一定程度上恢复其电容值,延长电容器的使用寿命。
宽广的工作温度范围:适用于各种极端温度条件下的应用,确保电路在各种环境下的可靠性。
  • 电容器
  • 顺络电子
    如何测试钽电容器的性能 钽电容器在电源管理中的应用
    测试钽电容器的性能 钽电容器因其体积小、容量大、可靠性高等特点,在电子设备中被广泛应用。为了确保钽电容器的性能符合要求,需要进行一系列的测试。以下是测试
    的头像 发表于 11-28 09:23 318次阅读
    钽电容器的常见故障排除方法
    钽电容器的工作原理 在深入讨论故障排除之前,简要了解钽电容器的工作原理是必要的。钽电容器使用钽金属作为阳极,氧化钽膜作为介质,而阴极则是电解质。这种结构使得钽电容器具有高稳定性和低等效
    的头像 发表于 11-28 09:21 299次阅读
    钽电容器在自动化设备中的应用
    随着科技的不断进步,自动化设备在工业生产中扮演着越来越重要的角色。钽电容器作为一种高性能的电子元件,因其独特的物理和化学特性,在自动化设备中得到了广泛的应用。 钽电容器简介 钽电容器
    的头像 发表于 11-28 09:19 292次阅读
    高温钽电容器的特性 钽电容器的储存注意事项
    高温钽电容器的特性 高温钽电容器是一种在高温环境下能够稳定工作的电容器,它们通常用于需要在极端温度条件下运行的电子设备中。以下是高温钽电容器
    的头像 发表于 11-28 09:18 297次阅读
    钽电容器的生产工艺 钽电容器的优势和缺点
    钽电容器的生产工艺 钽粉制备 : 钽粉是钽电容器的核心材料,通常通过粉末冶金工艺制备。首先,将钽金属熔化,然后通过喷雾干燥技术制成粉末。 压制成型 : 将钽粉压制成所需的形状,通常是圆柱形或矩形块状
    的头像 发表于 11-28 09:16 337次阅读
    钽电容器的工作原理 如何选择钽电容器
    钽电容器的工作原理 结构 : 钽电容器通常由一个钽金属阳极、一个二氧化锰(MnO2)阴极和电解液组成。 阳极是钽金属,阴极是二氧化锰,它们之间由电解质隔开。 电荷存储 : 钽电容器通过
    的头像 发表于 11-28 09:11 314次阅读
    钽电容器的应用领域 钽电容器与铝电容器的比较
    钽电容器的应用领域 钽电容器因其独特的性能特点,在多个领域有着广泛的应用: 消费电子 : 手机 :用于电源管理、信号处理及显示屏驱动电路中,确保手机正常工作并提升信号质量。 电脑 :在电脑主板、内存
    的头像 发表于 11-28 09:09 374次阅读
    代理-钽电容的标识方法
    钽电容的标识方法可能因具体产品系列和规格而有所不同,但一般来说,钽电容的标识方法主要包括以下几种,这些方法同样适用于
    的头像 发表于 11-06 16:18 180次阅读
    <b class='flag-5'>顺</b><b class='flag-5'>络</b>代理-<b class='flag-5'>顺</b><b class='flag-5'>络</b><b class='flag-5'>钽电容</b>的标识方法
    Vishay推出新型固体模压型片式钽电容器
    Vishay 推出专为电子引爆系统设计的新型系列 Tantamount 表面贴装固体模压型片式钽电容器。Vishay Sprague TX3 系列器件机械结构牢固,漏电流( DCL )低,具有严格的测试规范,性能和可靠性优于商用钽电容器
    的头像 发表于 07-19 09:26 553次阅读
    串联电容器和并联电容器的区别
    电容器电子电路中常见的一种元件,它具有储存电荷的作用。在电路设计中,我们常常会遇到串联电容器和并联电容器这两种情况。串联电容器和并联
    的头像 发表于 05-16 14:14 4334次阅读
    电容器公式中的k是什么单位
    电容器公式中,k表示电容器的介电常数。介电常数是描述某种物质在电场中相对于真空的相对介电常数或相对电容率。介电常数是无单位的。 电容器是一
    的头像 发表于 02-18 14:55 4545次阅读
    电容器的作用及原理 电容器的功率是属于什么功率
    电容器是一种被广泛应用于电子电路中的被动元件。它具有存储电荷和能量的特性,可以在电子电路中起到多种作用。本文将详细介绍电容器的作用及其工作原理,并探讨
    的头像 发表于 02-14 17:35 5195次阅读
    超级电容器与传统电容器的区别 影响超级电容器性能的因素
    超级电容器与传统电容器的区别 影响超级电容器性能的因素 在现代电子技术和能量储存领域,超级电容器(也称为超级
    的头像 发表于 02-02 10:28 3282次阅读
    钽电容与陶瓷电容性能上优缺点
    钽电容和陶瓷电容是常见的电子元件,都有着各自的优点和缺点。本文将详细介绍这两种电容的性能。 钽电容是一种极具性能优势的
    的头像 发表于 12-20 10:03 3337次阅读
    陶瓷电容器钽电容器介绍
    陶瓷电容器钽电容器介绍
    的头像 发表于 12-13 15:45 607次阅读
    陶瓷<b class='flag-5'>电容器</b>和<b class='flag-5'>钽电容器</b>介绍
