随着数字经济快速发展,各种应用场景对数据传输速率的要求也越来越高,这也对高速连接器提出了更高的功能需求。为此,中航光电推出了平行板间高速信号传输的CQTL/CQSL系列连接器,产品符合PICMG COM Express标准,可为用户提供更多选择。
With the rapid development of digital economy, various application scenarios require higher data transmission rate, which also puts forward higher functional requirements for high-speed connectors. JONHONhas launched the CQTL/CQSL series connectors for high-speed signal transmissionbetween mezzanine boards.The products complywith PICMG COM Express standard, which can provide users with more choices.
「CQTL/CQSL系列连接器」
产品亮点
高密度小型化设计:节点间距0.5mm,在紧凑的空间内实现高密度引脚布局,有效减少占用面积,同时确保信号传输的稳定性与高效性。
0.5mm pitch for tighter arrangement in limited space,at the same time, it ensures the stability and efficiency of signaltransmission.
精准防错插设计:独特的防错插机制,确保连接器在快速对接过程中准确无误,大大降低误操作的风险,提升设备的安全性与可靠性。
It ensures the accurateconnection in the process of rapid docking, greatly reducing the risk ofmisoperation, and improving the safety and reliability of the equipment.
高质量SMT焊接:结合专用钢网辅助刷锡膏,通过回流焊设备实现上板焊接,确保焊接质量的一致性与稳定性。
Combined with the specialauxiliary solder paste, the upper plate welding is realized through reflowsoldering equipment to ensure the consistency and stability of solderingquality.
耐高温低翘曲材料:选用高耐热、低翘曲的高性能材料,配合成熟的加工装配工艺,使连接器能够轻松应对极端工作环境,满足高温使用要求。
Combined with mature processing and assembly technology,the connector is easy to cope with extreme working environments and meet therequirements of high-temperature use.
产品特性
CQTL/CQSL系列连接器支持16Gbps高速传输速率,产品有5mm和8mm两种板间高度选项,适应不同板间高度的安装需求,提供220芯和440芯两种规格,满足不同场景下的数据传输容量要求,可确保在-55℃至125℃的极端温度条件下仍能稳定工作,电气性能优异,可保障电气安全与系统稳定运行。
The CQTL/CQSL series connector supportshigh-speed transmission rate of 16Gbps, with two board height options of 5mm and 8mm and two specifications of 220-core and 440-core to meet different requirements. It can ensure stable operation under extreme temperature conditions from -55℃ to 125℃, which can ensure electrical safety and stable system operation. 产品应用
服务器与数据中心:在服务器内部,用于连接主板与模组板(GPU、RAID卡、网络卡等),实现高速信号传输。
Server and data center:inside the server, it is used to connect the motherboard and module board (GPU, RAID card, network card, etc.) to achieve high-speed signal transmission.
通信基础设施:BBU、RRU、交换机、路由器等通信设备中广泛应用。
Communication infrastructure:used in BBUs, RRUs, switches, routers and other communication equipment.
工业控制与自动化:用于连接控制器、传感器和执行器等设备,实现实时数据采集、处理和反馈控制。
Industrial control and automation:used to connect devices such as controllers, sensors and actuators for real-time data acquisition, processing and feedback control.
医疗电子设备:在高端医疗设备中,如医学影像设备、手术机器人等,用于连接处理器、图像采集卡和显示单元等关键组件。
Medical equipment:used to connect key components (processors, frame grabbers and display units, etc.) in high-end medical equipment such as medical imaging equipment, surgical robots, etc.
未来,中航光电将继续立足技术创新前沿,提升核心竞争力,为客户提供优质的产品和服务,助力行业高质量发展。
In the future, JONHON will consist in technologicalinnovation, improving the core competitivenessandprovide customers with high-quality products.
连接器
98文章
14553浏览量
136683 -
信号传输
4文章
429浏览量
20200 -
平行板
4浏览量
5789
原文标题:产品推荐丨CQTL/CQSL系列平行板连接器
文章出处:【微信号:jonhon-connectivity,微信公众号:中航光电】欢迎添加关注!文章转载请注明出处。
