在追求高效、节能与高度集成的今天,电子设备的电源管理成为了设计的关键环节。今天,我们隆重介绍一款颠覆性的产品——ET3138高级负载管理开关。这款开关专为需要严格关断状态下电流控制的DC电源轨(<5.5V)供电负载的应用而设计,以其卓越的性能和高度集成性,为各类消费、光学、医疗、存储、便携及工业设备的电源管理提供了全新的解决方案。
In the pursuit of high efficiency, energy saving and highly integrated today, the power management of electronic devices has become a key part of the design. Today, we are introducing a disruptive product - ET3138 Advanced load management switch. Designed for applications that require current-controlled DC power rail (<5.5V) power loads in a tightly turned off state, the switch provides a new solution for power management in a wide range of consumer, optical, medical, storage, portable and industrial devices with its superior performance and high degree of integration.
一、产品概述
ET3138不仅集成了低阻抗MOSFET开关(典型值为40mΩ),还配备了其他先进的模拟功能,如斜率控制等。这种斜率控制的开启特性能够有效防止浪涌电流的产生,从而避免电源轨上出现过度的电压下降。这一创新设计使得ET3138在保障系统稳定运行的同时,还能显著提升能效。
The ET3138 not only integrates a low-impedance MOSFET switch (typical value 40mΩ), but also comes with other advanced analog features such as slope control. This slope controlled on feature effectively prevents the generation of inrush current, thus avoiding excessive voltage drop on the power rail. This innovative design enables the ET3138 to significantly improve energy efficiency while maintaining system stability.
二、核心特性与优势
1. 宽输入电压范围与低阻抗设计
ET3138的输入电压范围广泛,从1.2V到5.5V DC,满足了多种应用场景的需求。其低阻抗MOSFET开关在不同输入电压下的典型RDS(ON)值分别为:在VIN=5.5V时为40mΩ,VIN=3.3V时为50mΩ,VIN=1.8V时为90mΩ,VIN=1.2V时为180mΩ。这种低阻抗设计有助于减少功耗,提高系统的整体效率。
The ET3138 has a wide range of input voltages, from 1.2V to 5.5V DC, to meet the needs of a variety of application scenarios. The typical RDS(ON) values of the low-impedance MOSFET switch at different input voltages are 40mΩ at VIN=5.5V, 50mΩ at VIN=3.3V, 90mΩ at VIN=1.8V, and 180mΩ at VIN=1.2V. This low-impedance design helps to reduce power consumption and improve the overall efficiency of the system.
2. 斜率控制与浪涌电流抑制
ET3138配备了斜率控制功能,通过精确控制开关的开启速度,有效抑制了浪涌电流的产生。斜率控制参数tR的典型值为60微秒,这意味着在开关开启过程中,电流将平稳上升,避免了因瞬间大电流冲击而导致的电压下降和系统不稳定。
The ET3138 is equipped with slope control, which effectively inhibits the generation of inrush current by precisely controlling the opening speed of the switch. The typical value of the slope control parameter tR is 60 microseconds, which means that during the switch on process, the current will rise smoothly, avoiding the voltage drop and system instability caused by the instantaneous large current shock.
3. 低关断状态电流消耗
ET3138在关断状态下的电流消耗极低,最大值仅为1微安。这一特性使得它非常适合于低功耗待机应用,如智能手机、平板电脑等设备的休眠模式。在这些应用中,低功耗待机是延长电池续航能力的关键因素之一。
The ET3138 has a very low current consumption in the off state, with a maximum of only 1 microamp. This feature makes it ideal for low-power standby applications, such as sleep modes for devices such as smartphones and tablets. In these applications, low-power standby is one of the key factors in extending battery life.
4. 逻辑CMOS输入输出与标准兼容性
ET3138的逻辑CMOS输入输出接口符合JESD76标准,能够直接与低压控制信号/GPIO接口连接,无需外部下拉电阻。这一设计简化了电路布局,降低了系统成本,并提高了系统的可靠性和稳定性。
The ET3138's logical CMOS input/output interface is JESD76 compliant and can be directly connected to the low voltage control signal /GPIO interface without the need for an external pull-down resistor. This design simplifies the circuit layout, reduces the system cost, and improves the reliability and stability of the system.
5. 静电放电保护
ET3138具备出色的静电放电(ESD)保护能力,其HBM(人体模型)和CDM(充电器件模型)的ESD保护等级分别超过8kV和2kV。这一特性确保了开关在恶劣的静电环境下仍能正常工作,提高了系统的抗干扰能力和可靠性。
The ET3138 offers excellent electrostatic discharge (ESD) protection with HBM (human body model) and CDM (Charging device model) ESD protection ratings exceeding 8kV and 2kV, respectively. This feature ensures that the switch can still work normally in the harsh electrostatic environment, and improves the anti-interference ability and reliability of the system.
三、应用领域与前景
ET3138凭借其卓越的性能和高度集成性,在多个领域展现出了广阔的应用前景:
1. 智能手机与平板电脑
在智能手机和平板电脑等便携设备中,ET3138的低功耗待机特性和高效的电源管理能力使其成为理想的电源管理解决方案。它能够帮助设备在休眠模式下保持低功耗,延长电池续航时间,同时确保在需要时能够迅速启动并稳定运行。
In portable devices such as smartphones and tablets, the ET3138's low power standby and efficient power management capabilities make it an ideal power management solution. It helps devices maintain low power consumption in sleep mode, extending battery life while ensuring quick startup and stable operation when needed.
2. 硬盘驱动器、存储设备及固态存储器
在硬盘驱动器、存储设备及固态存储器等存储设备中,ET3138的宽输入电压范围和精确的电流控制能力有助于保护存储设备免受电流冲击和电压波动的损害。同时,其低功耗特性也有助于降低设备的整体功耗,提高能效。
In storage devices such as hard drives, storage devices and solid-state memory, the ET3138's wide input voltage range and precise current control help protect storage devices from current shocks and voltage fluctuations. At the same time, its low-power characteristics also help to reduce the overall power consumption of the device and improve energy efficiency.
3. SLR数码相机
在SLR数码相机等光学设备中,ET3138的高效电源管理能力和低阻抗设计有助于确保相机在捕捉瞬间时能够迅速响应并提供稳定的电源输出。这有助于提升相机的拍摄性能和画质表现。
In optical devices such as SLR digital cameras, the ET3138's efficient power management capabilities and low impedance design help ensure that the camera responds quickly and provides a stable power output when capturing a moment. This helps improve camera performance and picture quality.
4. GPS和导航设备
在GPS和导航设备等便携式导航系统中,ET3138的低功耗待机特性和精确的电流控制能力有助于延长设备的续航时间,同时确保在导航过程中能够提供稳定、准确的定位服务。
In portable navigation systems such as GPS and navigation devices, the ET3138's low-power standby and precise current control capabilities help extend the device's battery life while ensuring stable, accurate positioning services during navigation.
5. 工业手持设备和企业设备
在工业手持设备和企业设备等工业应用中,ET3138的宽输入电压范围、高效的电源管理能力和出色的静电放电保护能力使其成为理想的电源管理解决方案。它能够帮助设备在恶劣的工业环境中稳定运行,同时降低功耗和成本。
In industrial applications such as industrial handhelds and enterprise equipment, the ET3138's wide input voltage range, efficient power management capabilities and excellent electrostatic discharge protection make it an ideal power management solution. It helps equipment operate stably in harsh industrial environments while reducing power consumption and costs.
负载开关
2文章
353浏览量
21358
力芯微正式发布ET9545L
一次说清芯茂微 SR 同步整流芯片替代这件事
国产替代IC vs TMC2209|两相步进驱动芯片国产替代选型推荐
赋能车载芯片国产化!华润微CD7377CZ/7388替代方案重磅来袭
干货分享:华润微CD7377CZ/7388车载功放国产化替代实用指南
IntelliMAX FPF2000 - FPF2007 负载开关:设计与应用全解析
技术赋能车载音频国产化——华润微CD7377CZ/7388芯片深度解读(深智微科技专享)
Neway微波产品的国产化替代方案
力芯微红外遥控IC芯片ET4008MTC是家用遥控器的智能芯选
中科微电ZG2131:300V驱动芯片国产化替代的实战样本
力芯微美林美深负载开关ET3138替代FPF1204型号国产替代
