Cypress CYW4343W高度集成的单片WLAN解决方案
电子工程师 作者:工程师a 2018-06-16 11:45 次阅读
Cypress公司的CYW4343W是高度集成的单片解决方案,包括了ARM Cortex-M3 MCU,802.11 b/g/n MAC/基带/无线电,支持蓝牙4.1,以及功率放大器(PA),低噪音放大器(LNA),内部发送/接收(iTR)RF开关,WLAN主接口支持SDIO v2.0模式,数据传输速率高达200Mbps,单独的UART提供蓝牙主接口,支持单边带2.4 GHz IEEE 802.11b/g/n,主要用在可穿戴,物联网IoT)网关,家庭自动化,以及各种其它手持设备。本文介绍了CYW4343W主要特性,系统框图,以及评估板BCM94343WWCD1_EVB主要特性,电路图和材料清单。
The Cypress CYW4343W is a highly integrated single-chip solution and offers the lowest RBOM in the industry for wearables, Internetof Things (IoT) gateways, home automation, and a wide range of other portable devices. The chip includes a 2.4 GHz WLAN IEEE 802.11 b/g/n MAC/baseband/radio and Bluetooth 4.1 support. In addition, it integrates a power amplifier (PA) that meets the outputpower requirements of most handheld systems, a low-noise amplifier (LNA) for best-in-class receiver sensitivity, and an internal transmit/receive (iTR) RF switch, further reducing the overall solution cost and printed circuit board area.
The WLAN host interface supports SDIO v2.0 mode, providing a raw data transfer rate up to 200 Mbps when operating in 4-bit modeat a 50 MHz bus frequency. An independent, high-speed UART is provided for the Bluetooth host interface.Using advanced design techniques and process technology to reduce active and idle power, the CYW4343W is designed to address the needs of highly mobiledevices that require minimal power consumption and compact size. It includes a power management unit that simplifies the systempower topology and allows for operation directly from a rechargeable mobile platform battery while maximizing battery life.
The CYW4343W implements the world’s most advanced Enhanced Collaborative Coexistence algorithms and hardware mechanisms,allowing for an extremely collaborative WLAN and Bluetooth coexistence.
The Cypress CYW4343W provides the highest level of integration for a mobile or handheld wireless system, with integrated IEEE 802.11 b/g/n. It provides a small form-factorsolution with minimal external components to drive down cost for mass volumes and allows for handheld device flexibility in size, form, and function. The CYW4343W isdesigned to address the needs of highly mobile devices that require minimal power consumption and reliable operation.
CYW4343W主要特性:
IEEE 802.11x Key Features
■ Single-band 2.4 GHz IEEE 802.11b/g/n.
■ Support for 2.4 GHz Cypress TurboQAM® data rates (256-QAM) and 20 MHz channel bandwidth.
■ Integrated iTR switch supports a single 2.4 GHz antennashared between WLAN and Bluetooth.
■ Supports explicit IEEE 802.11n transmit beamforming
■ Tx and Rx Low-density Parity Check (LDPC) support forimproved range and power efficiency.
■ Supports standard SDIO v2.0 host interface.
■ Supports Space-Time Block Coding (STBC) in the receiver.
■ Integrated ARM Cortex-M3 processor and on-chip memory forcomplete WLAN subsystem functionality, minimizing the needto wake up the applications processor for standard WLANfunctions. This allows for further minimization of powerconsumption, while maintaining the ability to field-upgrade withfuture features. On-chip memory includes 512 KB SRAM and640 KB ROM.
■ OneDriver™ software architecture for easy migration fromexisting embedded WLAN and Bluetooth devices as well as tofuture devices.
Bluetooth Features
■ Complies with Bluetooth Core Specification Version 4.1 withprovisions for supporting future specifications.
■ Bluetooth Class 1 or Class 2 transmitter operation.
■ Supports extended Synchronous Connections (eSCO), forenhanced voice quality by allowing for retransmission ofdropped packets.
■ Adaptive Frequency Hopping (AFH) for reducing radiofrequency interference.
■ Interface support — Host Controller Interface (HCI) using ahigh-speed UART interface and PCM for audio data.
■ Low-power consumption improves battery life of handhelddevices.
■ Supports multiple simultaneous Advanced Audio DistributionProfiles (A2DP) for stereo sound.
■ Automatic frequency detection for standard crystal and TCXOValues
General Features
■ Supports a battery voltage range from 3.0V to 4.8V with aninternal switching regulator.
■ Programmable dynamic power management.
■ 4 Kbit One-Time Programmable (OTP) memory for storingboard parameters.
Can be routed on low-cost 1 x 1 PCB stack-ups.
■ 74-ball[4343W+43CS4343W1]74-ball 63-ball WLBGApackage (4.87 mm × 2.87 mm, 0.4 mm pitch)。
■ 153-bump WLCSP package (115 μm bump diameter, 180 μmbump pitch)。
■ Security:
❐WPA and WPA2 (Personal) support for powerful encryptionand authentication.
❐AES in WLAN hardware for faster data encryption and IEEE802.11i compatibility.
❐Reference WLAN subsystem provides Cisco Compatible Extensions(CCX, CCX 2.0, CCX 3.0, CCX 4.0, CCX 5.0)。
❐Reference WLAN subsystem provides Wi–Fi Protected Setup(WPS)。
■ Worldwide regulatory support: Global products supported withworldwide homologated design
图1.CYW4343W框图
图2. CYW4343W系统框图
The CYW4343W supports the following WLAN and Bluetooth features:
■ IEEE 802.11b/g/n single-band radio with an internal power amplifier, LNA, and T/R switch
■ Bluetooth v4.1 with integrated Class 1 PA
■ Concurrent Bluetooth, and WLAN operation
■ On-chip WLAN driver execution capable of supporting IEEE 802.11 functionality
■ Simultaneous BT/WLAN reception with a single antenna
■ WLAN host interface options:
❐SDIO v2.0, including default and high-speed timing.
■ BT UART (up to 4 Mbps) host digital interface that can be used concurrently with the above WLAN host interfaces.
■ ECI—enhanced coexistence support, which coordinates BT SCO transmissions around WLAN receptions.
■ I2S/PCM for BT audio
■ HCI high-speed UART (H4 and H5) transport support
■ Wideband speech support (16 bits, 16 kHz sampling PCM, through I2S and PCM interfaces)
■ Bluetooth SmartAudio® technology improves voice and music quality to headsets.
■ Bluetooth low power inquiry and page scan
■ Bluetooth Low Energy (BLE) support
■ Bluetooth Packet Loss Concealment (PLC
Standards Compliance
The CYW4343W supports the following standards:
■ Bluetooth 2.1 + EDR
■ Bluetooth 3.0
■ Bluetooth 4.1 (Bluetooth Low Energy)
■ IEEE 802.11n—Handheld Device Class (Section 11)
■ IEEE 802.11b
■ IEEE 802.11g
■ IEEE 802.11d
■ IEEE 802.11h
■ IEEE 802.11i
The CYW4343W will support the following future drafts/standards:
■ IEEE 802.11r — Fast Roaming (between APs)
■ IEEE 802.11k — Resource Management
■ IEEE 802.11w — Secure Management Frames
■ IEEE 802.11 Extensions:
■ IEEE 802.11e QoS Enhancements (as per the WMM® specification is already supported)
■ IEEE 802.11i MAC Enhancements
■ IEEE 802.11r Fast Roaming Support
■ IEEE 802.11k Radio Resource Measurement
The CYW4343W supports the following security features and proprietary protocols:
■ Security:
❐WEP
❐WPA™ Personal
❐WPA2™ Personal
❐WMM
❐WMM-PS (U-APSD)
❐WMM-SA
❐WAPI
❐AES (Hardware Accelerator)
❐TKIP (host-computed)
❐CKIP (SW Support)
■ Proprietary Protocols:
❐CCXv2
❐CCXv3
❐CCXv4
❐CCXv5
■ IEEE 802.15.2 Coexistence Compliance — on silicon solution compliant with IEEE 3-wire requirements
The Cypress BCM94343WWCD1_EVB kit includes a BCM94343WWCD1 SIP module mounted on a full-featured USB-based evaluation and development board that is fully compatible with the WICED™ Wi-Fi SDK. The onboard SIP module leverages the BCM4343W, featuring an 802.11b/g/n MAC/baseband/radio, Bluetooth 4.1 support, and an FM receiver. In addition, the module integrates a power amplifier (PA) that meets the output power requirements of most handheld systems, a low-noise amplifier (LNA) for best-in-class receiver sensitivity, and an internal transmit/receive (iTR) RF switch, reducing the overall solution cost and printed circuit board area. The BCM943364WCD1_EVB also includes an on-board STM32F411 32-bit ARM microcontroller, and is provisioned to support the authentication chip utilized by Apple’s HomeKit offering.
图3.评估板BCM94343WWCD1_EVB外形图
评估板BCM94343WWCD1_EVB主要特性:
The BCM94343WWCD1_EVB is a self-contained evaluation and debug kit that can be powered from a wired USB (+5V) connection or a 5V DC jack (not provided with the kit)
The USB interface enumerates as both a USB-JTAG (Program and Debug) and USB-UART (Serial Command Interface)
Support for ThreadX and FreeRTOS Real-Time Operating Systems (RTOS), and NetX/NetXDuo IPv4/IPv6 and LwIP IPv4 TCP/IP network stack implementations via WICED WIFI SDK
Open On Chip Debugger (Open OCD)
Optional external flash for memory expansion
图4.评估板BCM94343WWCD1_EVB电路图(1)
图5.评估板BCM94343WWCD1_EVB电路图(2)
评估板BCM94343WWCD1_EVB材料清单见:
BCM94343WWCD1_EVB_BOM.xls
  • 功率放大器
  • Cypress
    CYW4343W能输出125k/500k/1M/2M bps传输速率的的BLE指令或文件吗?
    请问有人知道CYW4343W这颗IC能输出125k/500k/1M/2M bps传输速率的的BLE指令或文件吗?谢谢
    发表于 03-01 06:21
    使用基于muRata CYW4343W的LBEE5KL1DX-883模块,会持续向蓝牙UART发送 0x01 0x03 0x0c 0x00没有收到任何响应的原因?
    大家好,我正在使用基于 muRata CYW4343W的LBEE5KL1DX-883模块。示意图如下,有什么问题吗? 我引用了 I.MX RT1060 SDK 中的示例,我已经成功移植了
    发表于 03-01 09:18
    请问CYW4343W支持HFP吗?
    请说明 CYW4343W 是否支持免提配置文件,以便我们在智能手表中使用它通过蓝牙将电话从手机传输到智能手表?
    发表于 05-27 08:04
    博通高集成WLAN路由器解决方案
    WLAN路由器提供理想的性价比。这颗单频(2.4GHz)解决方案高度集成,缩短了802.11n与802.11g间的成本差距。 BCM4717在一个小封装中为
    发表于 10-20 09:10
    WICED 6.2是否支持CYW20706和CYW20719上的A2DP AAC编解码器?
    20719B1, CYW4343W, CYW43340 According to "https://community.cypress.com/message/154799#154799", WICED
    发表于 09-11 14:39
    WICED是否支持CYW4343W的蓝牙?
    。 以上来自于百度翻译 以下为原文Is there any one knows how to build 43xxx_Wi-Fi\apps\demo\dual_hf_a2dp for CYW4343W
    发表于 09-18 14:38
    使用WICED SDK在AP和STA中可以同时使用CYW4343W/类型1DX模块吗?
    Is there any update on this topic ? Is it possible to have the CYW4343W run as STA and AP simultaneously
    发表于 09-21 09:37
    Mouser贸泽Cypress PSoC 6 WiFi-BT Pioneer套件用于物联网及可穿戴应用
    CYW4343W Wi-Fi和蓝牙? 复合芯片的Murata LBEE5KL1DX模块,可提供2.4-GHz WLAN和蓝牙功能。  PSoC 6微控制器采用Cypres的超低功耗40-nm SONOS
    发表于 09-21 11:51
    如何用CYW4343W/CYW43438开发FM RDS应用?
    我试图找出任何可用的模块或开发板支持使用CYW4338的FM RDS功能的应用程序,除了Wi-Fi和BT之外,旧的工具包似乎提到了FM接收器,但是示意图显示FM RX(输入引脚)没有连接
    发表于 10-30 10:28
    CYW433W外部32 K LPO时钟是否需要用于上电顺序?
    ,马特瓦纳 以上来自于百度翻译 以下为原文Hi, We are using the CYW4343W for our Wi-Fi + BT/BLE interface, where we have
    发表于 12-25 15:47
    1DX有开放的linux内核驱动程序吗
    if 1DX wifi/BT murata module (CYW4343W based) has an open linux driver, so we can compile and integrate in our kernel.Thank you
    发表于 12-27 15:47
    MSC8328Q高度集成的运动DV解决方案
      MSC8328Q是高度集成的运动DV探险摄像机等解决方案,主芯片为Dual600MHz32-bitRISC运动级图像处理器,内置DDR,On-chiphighqualityISP。可自动循环录影
    发表于 07-01 17:33
    ROCm移动WLAN解决方案详解
    ROCm移动WLAN解决方案详解
    发表于 06-01 06:34
    求一种Cypress CYW20719的集成解决方案
    为什么使用蓝牙?Cypress Semiconductor CYW20719有什么优点?Cypress Semiconductor CYW20719有什么作用?
    发表于 07-02 07:54
    基于CYW20719的无线基带处理器解决方案
    Cypress公司的CYW20719是兼容BT 5.0单独可用的基带处理器,集成了带BLE,EDR和BR的2.4GHz收发器;采用先进的40nm CMOS低功耗制造工艺,实现了高度
    的头像 发表于 04-05 22:33 5137次阅读
    基于<b class='flag-5'>CYW</b>20719的无线基带处理器<b class='flag-5'>解决方案</b>
