Gitea 私有仓库是一款轻量级的自托管 Git 服务,它提供了与 Github、Gitlab 等类似的功能,但允许用户在自己的服务器上部署和运行,从而完全掌控代码的存储和访问权限
华为云端口
•服务器放行对应端口 3000,3317
Docker 安装并配置镜像加速
1、购买华为云 Flexus X 实例
Flexus云服务器X实例-华为云 (huaweicloud.com)
2、docker 安装
yuminstall -ydocker-ce
3、验证 Docker 是否安装成功,启动 docker 服务并设置开机自启动,且查看 docker 状态
docker --versionsystemctl enable dockersystemctl start dockersystemctl status docker
4、docker-ce 下载
wget-O/etc/yum.repos.d/docker-ce.repo https://mirrors.huaweicloud.com/docker-ce/linux/centos/docker-ce.repo
5、路径/etc/yum.repos.d 修改配置文件
[docker-ce-stable]name=Docker CEStable -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/stableenabled=1gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-debuginfo]name=Docker CEStable -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-source]name=Docker CEStable -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test]name=Docker CETest -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-debuginfo]name=Docker CETest -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-source]name=Docker CETest -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly]name=Docker CENightly -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-debuginfo]name=Docker CENightly -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-source]name=Docker CENightly -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg
6、清除和构建缓存
yumclean allyummakecache
7、docker 配置镜像加速(在华为云镜像中心可获取自己的镜像加速配置)
8、创建镜像加速配置文件
vim/etc/docker/daemon.json
{"registry-mirrors":[ "https://fd0cfec0ac0d446db7fd9d27e92d4a8e.mirror.swr.myhuaweicloud.com"]}
9、重新加载配置文件,重新启动 docker,查看是否配置成功
systemctldaemon-reloadsystemctlrestart docker.service
10、docker info 查看配置信息,是否配置成功镜像加速
dockerinfo
搭建 Gitea 私有仓库
1、docker 拉取 Gitea 镜像
dockerpull gitea/gitea
2、实例化一个 Gitea 容器端口 3000
3、拉取 mysql 镜像,Gitea 需要数据源,因此使用 mysql
dockerpull mysql
4、实例化一个 mysql 容器端口 3317
dockerrun -d--namemysql -p3317:3306 -eMYSQL_ROOT_PASSWORD=1234 mysql
5、mysql 中创建数据库为 gitea
•进入 mysql 容器中
dockerexec -itmysql bash
•登录 mysql 数据库
mysql-uroot -p
•创建新数据库 gitea
createdatabase if not exists `gitea`;
6、浏览器访问公网 IP:3000,如下配置完成
总结
828 华为云服务器 Flexus X 实例,Docker 集成搭建 Gitea 私有仓库,搭建自己的代码仓库服务,在自己的服务器上部署和运行,从而完全掌控代码的存储和访问权限,非常便利,如果有小伙伴需要搭建,可以和我一样购买华为云服务器,目前服务器正在大促,优惠非常多!
华为云828 Flexus X实例
云计算
39文章
7890浏览量
138349 -
Git
201浏览量
15890 -
云服务器
765浏览量
13499
云服务器 Flexus X 实例,Docker 集成搭建搭建 Flink
云服务器 Flexus X 实例,Docker 集成搭建 Grafana 开源数据可视化平台
云服务器 Flexus X 实例:部署 Gitea,拥有自己的 Git 仓库,管理本地代码
Flexus 云服务器 X 实例:在 Docker 环境下搭建 java 开发环境
基于华为云 Flexus 云服务器 X 实例部搭建 Halo 博客平台
基于华为云 Flexus 云服务器 X 实例搭建 Linux 学习环境
